Results 1 to 3 of 3
Thread: 04 Phaeton ABS coding concern
    Nov 2016
    I work at a garage, our customer has an 04 Phaeton with intermittent brake system warnings. I cannot duplicate the concern by driving car or wiggling harnesses and the fault codes lead me to suspect the ABS module is faulty. I have not installed a new ABS module yet. When I look at Coding-07 the pop up window has a note saying coding is accepted after a specific login has been carried out. I do not see a menu under advanced functions for login. There is a menu for security access, perhaps this is what I would use, but I don't know what the security code would be.
    So my questions are: Does a new module need coding? Can I code the new module with Ross-Tech? If I need a login, is it in the security code menu and what is the security code?
    Thank you in advance, Rob
    Monday,19,June,2017,09:10:28:06280
    VCDS Version: 17.1.3.0 (x64)
    Dealer/Shop Name: Mellow Motors, Inc.
    VIN: WVWAF63D248011416   License Plate: 7NAJ364
    Mileage: 299480km-186088mi   Repair Order: 115791
    Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
              34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
    VIN: WVWAF63D248011416   Mileage: 299480km-186088miles
    Address 01: Engine        Labels: 4D0-907-560-BGH.lbl
       Part No SW: 4D0 907 560 CS    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0040
       Coding: 0007873
       Shop #: WSC 01065 000 00000
       VCID: 79F9EBAC33C1DA89AE-5140
    18057 - Powertrain Data Bus
                P1649 - 008 - Missing Message from ABS Controller - Intermittent
    16885 - Vehicle Speed Sensor
                P0501 - 004 - Implausible Signal - Intermittent
       Part No SW: 09L 927 760 C    HW: GS1 9.0 4.1 *
       Component: AG6 09L 4,2L V8     1003
       Coding: 0001102
       VCID: 377D2D9445550CF918-5140
    18259 - Powertrain Data Bus
                P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        RPM: 704 /min
                        RPM: 672 /min
                        (no units): 30.0
                        (no units): 27.0
                        Temperature: 37.0°C
                        T.B. Angle: 0.0°
                        Voltage: 12.88 V
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008376
       VCID: 6BD5C1E4499D78192C-5122
    00003 - Control Module
                014 - Defective
       Part No SW: 3D0 909 135 K    HW: 5WK 470 25
       Component:    Kessy            6400
       Coding: 0006376
       VCID: 2D510FFCB709B62972-5140
    01176 - Key
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 B
       Component: Sitzmemory D1 BF    1520
       Coding: 0000003
       VCID: 3561279C5F59FEE90A-5140
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3D0 035 008 M
       Component:    ZAB COCKPIT      0188
       Coding: 0400305
       VCID: 2447EAD8E4C37761AD-5140
    00384 - Optical Databus
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 G
       Component: Climatronic D1      1145
       VCID: 224BECC0FED77951DF-5140
                014 - Defective
    00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
                014 - Defective
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 G
       Component: STG.Bordnetz        5001
       VCID: 2E5308F0BA0FCD314B-5140
       Part No: 3D0 909 601 E
       Component: 0G Airbag 8.4E+ H10 0934
       Coding: 0012359
       VCID: 2541F7DCEFF98E69BA-5140
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 D
       Component: Lenksäulenmodul     3401
       Coding: 0000032
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No: 3D0 920 981 H
       Component: KOMBIINSTRUMENT RB4 0411
       Coding: 0007221
       VCID: 2C5702F88C13BF2165-5140
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70EFD68860BB9BC119-5140
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  X012
       VCID: 66C3B0D0527F457173-5140
    Address 34: Level Control        Labels: 3D0-907-553-V1.clb
       Part No: 3D0 907 553 B
       Component: LUFTFDR.-CDC- 3C1V0 1101
       Coding: 0017700
       VCID: 2643F0D092FF8571B3-5122
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 B
       Component: Sitzmemory D1 F     1520
       Coding: 0000004
    Address 37: Navigation        Labels: 3D0-919-887.lbl
       Part No: 3D0 919 887 A
       Component:    NAVIGATION       0147
       Coding: 0400000
       VCID: 326B1C80AE37E9D12F-5140
    00625 - Vehicle Speed Signal
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 B
       Component: Dachmodul           0605
       Coding: 0000047
    00220 - Connection to Sunroof
       Part No: 3D0 909 158
       Component: EVG GDL+AutoLWR(r)  X012
       VCID: 67DDBDD455755C7948-5140
    01344 - HID (Xenon) Headlight
                012 - Electrical Fault in Circuit - MIL ON
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: 12 HSG              0101
       Coding: 0000034
       VCID: 33651984512DE0D924-4B1A
       Subsystem 1 - Part No: 3D1 959 701 D
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 3D1 959 702 D
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 3D0 959 703 D
       Subsystem 4 - Part No: 3D0 959 704 D
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0020
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    00316 - Bulbs for Rear Illumination
                009 - Open or Short to Ground
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3D0 035 465
       Component: 08K-AUDIOVERST      0111
       VCID: 5EB398308A2F1DB1BB-5140
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
       Part No: 3D1 955 119
       Component: Front Wiper         2005
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
       VCID: 2345E9C4E1CD7059D4-5140
    Address 75: Telematics        Labels: 3D0-035-617.lbl
       Part No SW: 3D0 035 617     HW: 3D0 035 617
       Component: Telematik NAR1      0101
       Coding: 0061850
       Shop #: WSC 01035 444 60028
       VCID: 5DB19F3C872906A9A2-5140
    End-------------------------(Elapsed Time: 08:04)--------------------------
    Control Module Part Number: 3D0 614 517 AK
      Component and/or Version: ESP 5.7 allrad  H33 0047
               Software Coding: 0008376
                Work Shop Code: WSC 01065 000 00000
                014 - Defective
    Address 03,3D0 614 517 AK,recoded (Short coding),from,0008376,to,0008376,(01065/000/00000),
    Nov 2016
    The customer decided not to fix the car, so I never found out about coding the ABS module.
    Oh wow, no bites on the original post... well, I guess this is better way later than never...and for the next guy working with a Pheaton.....
    014 - Defective
    99% of the time, that is in fact a failed control module, ABS in this case. If the car comes back, I would verify the powers/grounds can carry load, voltage drop type issues can cause this to happen in some cases... if the electrical paths are to factory design, replace the module.
    If the module is replaced, has to be coded and such, VCDS can do this, here is the wiki page with the information:
    http://wiki.ross-tech.com/wiki/index...ke_Electronics
    BTW, where there any dead bodies in the trunk?
    Jef
  4. Likes Uwe liked this post
