Good Afternoon, Ive got an issue with a 2011 Crafter. It came in with a turbo issue but while the turbo was being repaired and cycling the ignition with the maf uplugged has stored a fault. The code cleared no problems but has also left the dpf light on permantly. I have no lack of power and have been on a 20 mile plus roadtest but the dpf light will not clear. I have read through the forums and found that accessing chanel 15 in long coding and changing the value from 0 to 1 apparently resets the system but i cant do this without the security login code. I have spoken to rosstech and they are looking into it for me but he also advised posting on here. Ive attached a screen grab as he suggested. Many thanks.
Monday,19,June,2017,16:26:46:08152
VCDS Version: 17.1.3.0 (x64)
VIN: WV1ZZZ2EZB6020561 License Plate: KN11CPY
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB) Labels: Redir Fail!
Part No SW: 076 997 022 A HW: 076 906 022 G
Component: R5 2,5L EDC A020SG 9024
Revision: 24H40--- Serial number: VWXDZ0J1036137
Coding: 0003032
Shop #: WSC 00001 067 08055
VCID: 1B350D7FD9BA18991C-5106
Readiness: 0 2 0 0 1
Address 91: LT3 Engine Labels: Redir Fail!
Coding: 0003032
VCID: 1B350D7FDABA18991C-804E
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 909 052 HG HW: 906 900 200 0
Component: IMMO 0805 1006
Revision: 00805000 Serial number: VWXDZ0J1036137
Shop #: WSC 00540 210 83494
VCID: 6FED09AF7E82D43900-803A
Address 94: LT3 Airbag
Part No HW: 9064461442
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3332.rod (*)
VCID: 55A15B47341E8EE9EA-8000
Address 95: LT3 ESP
Part No SW: 9069022800 HW: 0004460153
ASAM Dataset: 3 4101
ROD: CRFT_ESP_3_4101.rod (*)
VCID: 040756038F04C761CD-8050
4736 - CAN message ID236h Steering Angle Sensor (G85)(LRW-NCV3): failed
MIL ON - Test Complete - Stored
Address 96: LT3 Instruments
Part No SW: 9069026400 HW: 9069012000
ASAM Dataset: 32 787
ROD: CRFT_KOMBI_32_787.rod
Address 99: LT3 Ign. Switch
Part No HW: 9069002000
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 1006
Revision: 00805000 Serial number: 12345678901234
00171 - Key 1 not learned
002 - Lower Limit Exceeded
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BF52DFFF2FAB899BC-802E
9095 - Interior Monitoring Sensor 2 (G592): Self-test malfunction
9092 - Interior Monitoring Sensor (G273)/ Interior Monitoring Sensor (G592): Comm. error
909B - Alarm Horn (H12): No communication
9093 - Interior Monitoring Sensor (G273)/ Interior Monitoring Sensor (G593): Comm. error
9096 - Interior Monitoring Sensor 3 (G593): Self-test malfunction
Address B4: LT3 Central Elec.
Part No SW: 9069027500 HW: 9069011500
ASAM Dataset: 33 804
ROD: CRFT_EZE_33_804.rod (*)
VCID: 06034C0BB938F571D3-8052
909B - Front Right Window Switch in passenger door (E41): mechanical malfunction
Address B6: LT3 Steering Wheel
Part No SW: 9065402345 HW: 9065402345
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
End-------------------------(Elapsed Time: 02:37)--------------------------
