Results 1 to 7 of 7
Thread: passat b6 2010 60 plate no ignition
    Nov 2016
    Hi I have a Passat (well someone I know) I did a diagnosis on it today...........car has no ignition coming on at all, so what I did is put a wire in the fuse box and connected it to another fuse resulting in ignition coming on and car starting and drivng with no lights coming on on the dash...........but soon as the wires disconnected the car go's off............so now I know that its not getting ignition what can be the problem.?
    I have 2 scans one is before faults cleared and one after
    this one below is one taken before the faults were cleared.
    Monday,19,June,2017,12:51:24:07086
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
    VCDS Version: 17.1.3.0
    VIN:    License Plate: 60-PASSAT
    Mileage: 206760km-128474mi   Repair Order:
    Gateway Installation List:  3C0 907 530 Q
    Monday,19,June,2017,12:50:19:07086
    VIN: WVWZZZ3CZAP064007   License Plate: 60 PLATE PASSAT
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77
    VIN: WVWZZZ3CZAP064007   Mileage: 206760km-128474miles
    04-Steering Angle -- Status: Sporadic communication error 1000
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 997 025 P    HW: 03L 907 309
       Component: R4 2,0 EDC  G000SG  0485
       Revision: 13H08---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 50890 001 1048576
       VCID: 3F8750B26E6612B9D0-806A
    000144 - Valve for Fuel Metering (N290)
                   P0090 - 000 - Open Circuit - Intermittent
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:48:31
                        RPM: 552 /min
                        Voltage: 13.30 V
                        Pressure: 0.0 bar
                        Inj. Quantity: 23.9 mg/str
                        Lambda: 44.2 %
                        Lambda: 34.7 %
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 000 - Open Circuit - Intermittent
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:48:31
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --026---    Serial number: 00000706009469
       Coding: 0003347
       Shop #: WSC 00028 790 00007
       VCID: 62C1B9C6BD541F519F-8036
    00576 - Terminal 15
                        Reset counter: 148
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:32:47
                        Hex Value: 0x0000
                        Voltage: 13.25 V
                        Bin. Bits: 00111110
                        Count: 123
                        Hex Value: 0x0000
       Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       Shop #: WSC 00028 028 00020
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6ED9DDF6B18CAB310B-803A
              U1111 00 [008] - -
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:32:56
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:32:56
    9481748 - High Pressure Sensor
              B10AE 14 [009] - Open or Short to Ground
                        Reset counter: 148
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:33:01
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Revision: 00H54000    Serial number: 00000006103215
       Coding: 00808F0700041A00470A00000F000000000859435C000120000000000000
       Shop #: WSC 00028 028 00001
       VCID: 32610986AD34CFD12F-8066
       Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 140710 022  0612
       Coding: 00046997
       Shop #: WSC 00028
    6 Faults Found:
    02092 - Enabling Heated Seat
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 148
                        Mileage: 206763 km
                        Voltage: 13.65 V
    02403 - Terminal 15 for Interior
                        Reset counter: 148
                        Mileage: 206763 km
                        Fault Status: 00100110
                        Reset counter: 188
                        Mileage: 206763 km
                        Voltage: 12.75 V
                        Reset counter: 188
                        Mileage: 206763 km
                        Reset counter: 188
                        Mileage: 206763 km
                        Voltage: 12.95 V
                        Reset counter: 188
                        Mileage: 206763 km
       Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
       Component: J234__006 VW10 HI   1916
       Revision: 21014000    Serial number: 003GHPENQK2H
       Coding: 0012342
       VCID: 48954B6E3BA8550161-801C
       Subsystem 1 - Serial number: 6332MTS650301740
       Subsystem 2 - Serial number: 6342MTS671211740
       Subsystem 3 - Serial number: 6351HTS66ME1D6KR
       Subsystem 4 - Serial number: 6361HTS6EA84D6KR
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Component: LENKS.MODUL   009 0135
       Revision: FF010037    Serial number: 20100726300650
       Coding: 0182270002
       VCID: 72E1C986A5B48FD1EF-8026
       Coding: E20000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
       Component: KOMBI         H03 0305
       Coding: 460F00
       VCID: 2D5B1AFA7C0A902972-8078
    Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3620P10727000E
       Coding: F9807F06400602001003
       VCID: 2F6700F2BE06E23940-807A
                        Reset counter: 188
                        Mileage: 206763 km
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       VCID: 7AF1E1A635C4F791A7-802E
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    02828 - Enabling Steering Column Lock from Diagnostic Interface
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:32:47
    Address 37: Navigation
       Part No SW: 3C0 959 701     HW: 3C0 959 793
       Component: TUER-SG FT    002 0306
       Revision: 13101005    Serial number: 0001202801
       Coding: 0002B5
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 65CBA2DA647A68697A-8030
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0402
       Serial number: 00000001593334
       Coding: 000290
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 147
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:25:01
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [009] - Electrical Failure
                        Reset counter: 148
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:57:06
    68107 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:32:44
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 195    3001
       Revision: 00H17000
       VCID: 3163068AA832F4C956-8064
       Component:    KSG PQ46 ELV 043 0612
       Coding: 01910A0001860E763004941570085FCE107C01
       Subsystem 1 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HORN H11 9004
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:32:45
    00625 - Vehicle Speed Signal
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:32:45
       Part No SW: 3C0 959 702     HW: 3C0 959 792
       Component: TUER-SG BT    002 0306
       Revision: 15101005    Serial number: 0001201168
       Coding: 0002B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 66C9A5D6997C637173-8032
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0402
       Serial number: 00000001594241
       Coding: 000290
              U1111 00 [008] - -
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2017.06.19
                        Time: 14:32:44
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   011       Serial number: 00000000349812
       Coding: 0000057
       VCID: 2C5D17FE8F10992165-8078
    00576 - Terminal 15
                        Fault Frequency: 9
                        Reset counter: 188
                        Mileage: 206763 km
                        Date: 2011.11.10
                        Time: 14:32:44
                        Voltage: 13.60 V
                        Count: 54
                        Hex Value: 0x1161
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Address 56: Radio
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A07951336
       Coding: 012120
       VCID: 2A5111E645E4871197-807E
    End-------------------------(Elapsed Time: 02:24)--------------------------
    Aug 2014
    Now permanent in Maryland, USA.
    Possible open circuit. You will need a wiring diagram for this
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Under the drivers foot well there is a relay box very similar to the picture here I have posted swap those two relays around and see if your ignition is back to live.........Sorry I could not upload the picture but if you look in the are two relays on each corners #460 swap them
    Edited: Anyway look in to this link and you will see those relays.......
    https://sites.google.com/site/1810ma...y-assignment-1
  4. Likes Jack@European_Parts, Uwe liked this post
    Nov 2016
    Quote Originally Posted by Ashraf6119 View Post
    Thanks.......if i swop them around and it works....that means one of the relays is no good? simple replacement should do the trick?
    Dec 2015
    Yes the one on the lift side is for the Ignition 15 make sure you mark them before removing it so, you know which one is faulty
    Nov 2016
    thanks....cars coming to me thursday .....let you know the outcome.
    Nov 2016
    ok....car came today.....running as normal....never got to try changing the relay around as the cars now running and ignition working as normal..........all by itself
    but the guy said it did come up on the instrument cluster as.......column lock fault or column fault..........ive run vcds on it and no faults are stored.....is the steering column lock faulty? is it safe to drive around?
    steering column lock ive priced up at 100 quid........how easy it it to fit and code?.........if it is that.
