HI , I HAVE GOLF R 2016 WITH DAMPING SHOCKS AND I NEED TO DO BASIC SETTING BUT I DO NOT KNOW THE SECURITY ACCESS NUMBER , WOULD YOU PLEASE HELP ME WITH IT. THANKS.
Monday,19,June,2017,04:56:39:47987
VIN: WVWGR2AU1GW001019 License Plate: GOLF R DAMPING SUSPENSION
Mileage: 28701km-17833mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWGR2AU1GW001019 Mileage: 28701km-17833miles
Address 01: Engine (J623-CJXB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 E HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091D00322426050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259E 001006
ROD: EV_ECM20TFS0205G0906259E.rod
VCID: 306F4F116B9820C159-8064
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4522
Revision: 03253104 Serial number: TFK01501272818
ROD: EV_TCMDQ250021.rod
VCID: 1F4DBCAD0606AFB9F0-804A
7 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21159 - Gear R
10906 - Cooling Oil Valve
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 61015000005072
Coding: 01FA6BA15420296D0777070141CC6980D62A94E0E08296F7004200B8C208
VCID: 489F07F1F308880161-801C
Revision: 00021000 Serial number: 0365108064
Coding: 030C0C
VCID: 3A7B6D39BDE4EA91E7-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020014200100001005000012101400
VCID: 6ADB9D798DC49A1157-803E
Air quality sensor:
459015 - Databus
Reset counter: 65
Mileage: 28694 km
Date: 2017.06.15
Time: 13:27:38
459526 - Databus
Reset counter: 105
Mileage: 28694 km
Date: 2017.06.15
Time: 13:27:44
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011511001758
Coding: 00111A46C24122F30BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 000FDFD19BB87041E9-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150409 043 0551
Serial number: 150414194522
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150750Y9Y
Serial number: 00000000000062170692
Sun Roof:
Component: J245 PS73.403 H03 0004
Serial number: 0000FST0008T7IQ00000
Coding: 181801
939524 - No Communications with Humidity Sensor
U10F5 00 [009] - -
Reset counter: 65
Mileage: 28694 km
Date: 2017.06.15
Time: 13:27:39
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391510504126
Coding: 0031151011
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 3D716625ACCADDA9C2-8068
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 14031741350125
ROD: EV_DRCONTITEMIC.rod
VCID: 387F773183E8F88111-806C
278272 - Basic Setting of Deflected Position not Performed
C10C5 00 [137] - -
Reset counter: 65
Mileage: 28694 km
Date: 2017.06.15
Time: 13:27:38
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0J7J7H
VCID: 41891AD5D032B949A6-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 204 15
Serial number: 357670000003A659041N
Subsystem 2 - Part No SW: ----------- HW: 480 001 004 15
Serial number: 35867000000BD891D312
Subsystem 3 - Part No SW: ----------- HW: 480 401 304 15
Serial number: 3516502C91A8785072BG
Subsystem 4 - Part No SW: ----------- HW: 480 401 304 15
Serial number: 3526502C11A87852A3BF
Subsystem 5 - Part No SW: ----------- HW: 480 401 004 15
Serial number: 3556502C91941316625%
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 14041504401868
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 79F9B235F8622189AE-802C
Part No SW: 5G1 920 758 HW: 5G1 920 758
Component: KOMBI 304 4310
Coding: 47AD08183B80000801086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
VCID: 6CD79B618730842125-8038
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0003342461
Coding: 030100042F085900EF00026A9C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72EB8519A51452D1EF-8026
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29150000740010025155
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7660836403
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00010.03.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 468309C9F91C9E7193-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000092790001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346743019F801CE13D-8060
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 300315BCU00545
Coding: 003E1220D000040000001000
VCID: 428B15D9D534A251BF-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005964517
Coding: 110000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 377D740D8EF6F7F918-8062
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 010415BCV16064
Coding: 003E1020DC00040000801000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005928692
Coding: 090000
Component: AFS-ECU H07 0090
Coding: 02A202000B010200
VCID: 408F1FD1DB38B041A9-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 5G0 035 045 D HW: 5G0 035 045 C
Component: MU-H-N-RW H44 0377
Serial number: A311D0F7513377
Coding: 0273000CFF00000011110001001800001F0207D40100010057
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 2149BA5530729949C6-8074
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU301FNB
Subsystem 2 - Part No SW: V03 959 801 QH HW: -----------
Component: ROW 2015 --- 0039
Component: Gracenote --- 4006
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 150228200310
VCID: 2D5156657CAA4D2972-8078
End-------------------------(Elapsed Time: 04:51)--------------------------
