Results 1 to 7 of 7
Thread: Control Exhaust Valves B9 Audi S4/S5
    Jun 2017
    The B9 S4/S5's are still very new to the US but has anyone had any luck controlling the two exhaust valves with VCDS? I'd like to try to code (or adapt) them to be open all the time. Here's a link to the auto scan and I'll post a controller (block) map here in a minute. One thing that may be of some help PID IDE03816-ENG129421 - Exhaust flap bank 1 -Test_Program Channel it toggles between 136 (valves closed) and 135 (valves open) depending on the mode (comfort/dynamic).
    Controller Map (engine off)
    ;SW:8W0-907-559-H   HW:06M-907-309-D ---  Engine
    ;Component:V6 3.0l TFSI  H21 0005, Coding:1A2A00322366010E34280000000000000000000000000000
    ;EV_ECM30TFS0118W0907559H,001006,EV_ECM30TFS0118W0907559H.rod
    ;Sunday,18,June,2017,11:55:13:15996
    ;VCDS Version: Beta 17.6.0 (x64)  Data version: 20170602 DS274
    ;VCID: CAD802E86D81F517DF-809E
    Group,Description,Actual
    IDE00011,Vehicle Identification Number (VIN),WAUC4DF59JA0XXXX,
    IDE00019,Voltage terminal 30,12.260, V
    IDE00020-ENG104207,Terminal 15 status-Bit 0,1,
    IDE00021,Engine speed,0, /min
    IDE00025,Coolant temperature,76, C
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0, km/h
    IDE00076,Status of initial fuel filling,was not yet started,
    IDE00078,Time since engine start,0, s
    IDE00083,Throttle valve position (absolute),20.0, %
    IDE00084,Absolute load value,0, %
    IDE00085,Normed load value,0.0, %
    IDE00086,Accelerator position,15, %
    IDE00090-ENG104207,selected gear-Bit 0,0,
    IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
    IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
    IDE00100,Engine torque,0.0, Nm
    IDE00148,Median injection timing,0.0000, ms
    IDE00150,Pressure in brake booster,141.99, hPa
    IDE00151,Oil fill level,87.904, mm
    IDE00155,Timing angle retardation cylinder 1,0.0,
    IDE00156,Timing angle retardation cylinder 2,0.0,
    IDE00157,Timing angle retardation cylinder 3,0.0,
    IDE00158,Timing angle retardation cylinder 4,0.0,
    IDE00159,Timing angle retardation cylinder 5,0.0,
    IDE00160,Timing angle retardation cylinder 6,0.0,
    IDE00167,Exhaust temperature 1 bank 1,139.1, C
    IDE00172,A/C compressor torque,0.0, Nm
    IDE00173,Cruise Control System: specified speed,0.00, km/h
    IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.37,
    IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.00,
    IDE00176,Camshaft adjustment: exhaust: bank 2: specified value,-25.23,
    IDE00177,Camshaft adjustment: exhaust: bank 2: actual value,-25.00,
    IDE00178,Camshaft adjustment intake bank 1: specified value,9.47,
    IDE00179,Camshaft adjustment intake bank 1: actual value,8.06,
    IDE00180,Camshaft adjustment intake bank 2: specified value,5.39,
    IDE00181,Camshaft adjustment intake bank 2: actual value,8.06,
    IDE00182,Camshaft adaptation intake bank 1: phase position,-0.00,
    IDE00183,Camshaft adaptation intake bank 2: phase position,-0.00,
    IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.00,
    IDE00185,Camshaft adaptation exhaust bank 2: phase position,-0.00,
    IDE00186,Fuel low pressure: actual value,722.3, kPa
    IDE00187,Coolant temperature at engine start,76.0, C
    IDE00188,Fuel high pressure: actual value,17.9700, MPa
    IDE00190,Charge air pressure specified value,259.14, hPa
    IDE00191,Charge air pressure: actual value,995.70, hPa
    IDE00192,Coolant temperature at radiator outlet: actual value,40.8, C
    IDE00194,Coolant temperature at radiator output: specified value,104.9, C
    IDE00196,Engine oil temperature,67.4, C
    IDE00201,High fuel pressure: specified value,10.0000, MPa
    IDE00202,Low fuel pressure: specified value,580.0, kPa
    IDE00304,Fuel level,50.00, l
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00349,Throttle valve position: normed,10, %
    IDE00350,Air mass: specified value,5.7, kg/h
    IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
    IDE00355-ENG104207,Cruise Control System (CCS): status-Bit 0,0,
    IDE00356-ENG104207,Cruise Control System (CCS): switch position-Bit 0,0,
    IDE00357,Fuel temperature,73.5, C
    IDE00358,Limitation: torque,1000.0, Nm
    IDE00360,Limitation: accelerator pedal,0.0, Nm
    IDE00361,Ambient air pressure,998.05, hPa
    IDE00371,Fuel consumption,0.00, l/h
    IDE00375,Generator: load signal,0.00, %
    IDE00380,Coolant fan 1: activation,10.15, %
    IDE00381,Coolant fan 2: activation,0.00, %
    IDE00392,Accelerator pedal: sensor voltage 1,749.0, mV
    IDE00393,Accelerator pedal: sensor voltage 2,374.0, mV
    IDE00394,Camshaft position: start of phase window,121.82,
    IDE00405,Crankshaft speed (RPM),0.0, /min
    IDE00406,Camshaft speed (RPM),0.0, /min
    IDE00407-ENG104207,Rail pressure regulation: status-Bit 0,0,
    IDE00407-ENG28465,Rail pressure regulation: status-Byte,00000000 ,
    IDE00408-ENG104207,Engine mount 1-Bit 0,0,
    IDE00409-ENG104207,Engine mount 2-Bit 0,0,
    IDE00410-ENG104207,Transmission mount 1-Bit 0,0,
    IDE00411-ENG104207,Transmission mount 2-Bit 0,0,
    IDE00412-ENG104207,Starter control: terminal 50-Bit 0,0,
    IDE00413-ENG104207,Starter control: Interlock- or P/N-signal-Bit 0,17,
    IDE00414-ENG104207,Starter control: relay 1-Bit 0,0,
    IDE00416-ENG104207,Starter control: terminal 50 acknowledgment-Bit 0,4,
    IDE00417-ENG104207,Starter control: shut-off conditions 1-Bit 0,0,
    IDE00417-ENG101796,Starter control: shut-off conditions 1-Bit 8,0,
    IDE00443-ENG104207,Accelerator pedal: switch positions-Bit 0,8,
    IDE00445,Unlearning counter according OBD,255,
    IDE00450-ENG124478,Operating Instructions-Test_Program_Requested Action,0,
    IDE00451,Currently running routine,Unknown,
    IDE00474,Ambient air pressure,99, kPa abs
    IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
    IDE00496-ENG104207,Activation of oil pressure switch valve-Bit 0,0,
    IDE00541,Acceleration,0.000, m/s
    IDE00556,Outside air temperature,33, C
    IDE00559-MAS04135,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value,1.012, lambda
    IDE00559-MAS04136,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current,127.996, mA
    IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.455, V
    IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
    IDE00582,Equivalence ratio target value,1.999, Lambda
    IDE00583,Throttle valve specified value,2, %
    IDE00584,Distance driven since erasing DTC memory,1863, km
    IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
    IDE00588,Fuel tank fill level,84.7, %
    IDE00592-MAS04113,Oxygen sensor control status-Oxygen sensor control 1 status,Not available,
    IDE00592-MAS04114,Oxygen sensor control status-Oxygen sensor control 2 status,Not available,
    IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
    IDE00595-MAS01839,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 1,installed,
    IDE00595-MAS01840,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 2,installed,
    IDE00595-MAS04115,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 3,not installed,
    IDE00595-MAS04116,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 4,not installed,
    IDE00595-MAS04117,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 1,not installed,
    IDE00595-MAS04118,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 2,not installed,
    IDE00595-MAS04119,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 3,not installed,
    IDE00595-MAS04120,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 4,not installed,
    IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
    IDE00601-MAS00317,Monitoring status since erasing DTC memory-Malfunction Indicator Lamp,OFF,
    IDE00601-MAS00328,Monitoring status since erasing DTC memory-Monitoring of ignition misfires,activated,
    IDE00601-MAS00329,Monitoring status since erasing DTC memory-Monitoring of fuel system,activated,
    IDE00601-MAS00330,Monitoring status since erasing DTC memory-Monitoring of entire system,activated,
    IDE00601-MAS00331,Monitoring status since erasing DTC memory-Ignition misfire test,Unknown,
    IDE00601-MAS00332,Monitoring status since erasing DTC memory-Fuel system test,Unknown,
    IDE00601-MAS00333,Monitoring status since erasing DTC memory-Entire system test,completed successfully,
    IDE00601-MAS00503,Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries,0,
    IDE00601-MAS04092,Monitoring status since erasing DTC memory-Monitoring of compression ignition,Not supported,
    IDE00601-ENG20482,Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared,00,
    IDE00602-MAS04092,Monitoring status in current driving cycle-Monitoring of compression ignition,Not supported,
    IDE00602-ENG20399,Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle,No,
    IDE00602-ENG20507,Monitoring status in current driving cycle-Comprehensive component monitoring completed,completed successfully,
    IDE00602-ENG20447,Monitoring status in current driving cycle-Comprehensive component monitoring enabled,activated,
    IDE00602-ENG20496,Monitoring status in current driving cycle-Fuel system monitoring completed,not completed successfully,
    IDE00602-ENG20425,Monitoring status in current driving cycle-Fuel system monitoring enabled,activated,
    IDE00602-ENG20449,Monitoring status in current driving cycle-Misfire monitoring completed,completed successfully,
    IDE00602-ENG20506,Monitoring status in current driving cycle-Misfire monitoring enabled,activated,
    IDE00603,Number of driving cycles since erasing DTC memory,47,
    IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
    IDE00608,Type of fuel,Gasoline,
    IDE00612,Target position of EVAP canister valve,0.0, %
    IDE00727,Test steps still to be performed,0,
    IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,-0.00021,
    IDE00739,Test of oxygen sensors bank 2: Delta-Lambda,0.00000,
    IDE00773,Terminal 15 status via CAN,1,
    IDE00787,Cause for cancellation,0,
    IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
    IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
    IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
    IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
    IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
    IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
    IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
    IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
    IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
    IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
    IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
    IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
    IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
    IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
    IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
    IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
    IDE00973,Outside air temperature,33.5, C
    IDE01076,Time since ignition off,6372, s
    IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
    IDE01260,Generator power,0.0123888, W
    IDE01266-ENG104207,Coolant shut-off valve-Bit 0,2,
    IDE01267,Height correction,0.98511,
    IDE01378,High fuel pressure: control deviation,-7.9620, MPa
    IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
    IDE01385-ENG104207,Wear index-Bit 0,0,
    IDE01385-ENG101796,Wear index-Bit 8,0,
    IDE01386-ENG104207,Soot index-Bit 0,0,
    IDE01386-ENG101796,Soot index-Bit 8,0,
    IDE01405-ENG104207,Status of starter activation-Bit 0,2,
    IDE01590-ENG127367,Status of brakes-Test_Program_Channel 600,167,
    IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.454, V
    IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.000, V
    IDE01650,Throttle valve position 2,20, %
    IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
    IDE01666-ENG129412,Result of test of camshaft adjustment intake bank 2-Test_Program_Channel 105,235,
    IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
    IDE01668-ENG129419,Result of test of camshaft adjustment outlet bank 2-Test_Program_Channel 620,235,
    IDE01773,Misfire sum counter,0,
    IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
    IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
    IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
    IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
    IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
    IDE01834,Battery voltage,12260, mV
    IDE01869,Long-term fuel trim bank 1 at idle,0.14, %
    IDE01873,Test of catalytic converter: measured value,6.4285,
    IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
    IDE01875,Required torque adjustment by idling regulator,0.000, %
    IDE01876,Adaptation of loss torque,0.0, Nm
    IDE01877-MAS05513,Operating condition of idle speed control-Bit 0,0,
    IDE01877-ENG103108,Operating condition of idle speed control-Bitregister,00000000 ,
    IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
    IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
    IDE01880,Accelerator position 2,15, %
    IDE01881,Adaptation of kick-down shifting point,4125.2, mV
    IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
    IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
    IDE01887,Adaptation of Fuel Pump (FP),54.0, kPa
    IDE01888,Cold start enrichment: adaptation area 1,1.000,
    IDE01889,Cold start enrichment: adaptation area 2,1.000,
    IDE01890,Cold start enrichment: adaptation area 3,1.000,
    IDE01891,Cold start enrichment: adaptation area 4,1.000,
    IDE01892,Cold start enrichment: adaptation area 5,1.000,
    IDE01893,Fuel pump: specified value,10.001, %
    IDE01899,Load value: corrected specified value,124.03, %
    IDE01901,Lost torque adaptation: idle,-3.2, Nm
    IDE01902,Lost torque adaptation A/C compressor,-0.9, Nm
    IDE01903,Lost torque adaptation driving mode,2.9, Nm
    IDE01904,Lost torque adaptation A/C compressor and driving mode,-0.8, Nm
    IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
    IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.00000,
    IDE01911,Leakage air,6.7, kg/h
    IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
    IDE01922,Vehicle distance driven,1904, km
    IDE01923,Control module distance driven,1896915, m
    IDE01928,Close cam shaft angle at quantity control valve,0.0,
    IDE01929,Open cam shaft angle at quantity control valve,1.0,
    IDE01930,High pressure regulation: adaptation value,0.000, MPa
    IDE01932,High pressure pump injection volume,-327.68, mm
    IDE01975,Numb.of misfir.: cylinder 1,77,
    IDE01976,Numb.of misfir.: cylinder 2,108,
    IDE01977,Numb.of misfir.: cylinder 3,473,
    IDE01978,Numb.of misfir.: cylinder 4,119,
    IDE02117,Relative load value,65.46, %
    IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
    IDE02211,Brake pressure,0.00, MPa
    IDE02540-ENG104207,Longitudinal acceleration sensor: status-Bit 0,0,
    IDE02742,Oil pressure actual value,101.9, kPa
    IDE02756,Number of manual engine starts,149,
    IDE02757,Number of automatic engine starts,81,
    IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
    IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
    IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
    IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
    IDE03008-MAS06602,Stop process prevented-Engine temperature,active,
    IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,not active,
    IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
    IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
    IDE03010-IDE00924,Number of prevented stop processes-Steering angle,4,
    IDE03010-MAS01627,Number of prevented stop processes-Steering,24,
    IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
    IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
    IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,0,
    IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
    IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
    IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,10,
    IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
    IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
    IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
    IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
    IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
    IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
    IDE03010-MAS05758,Number of prevented stop processes-Driving situation,109,
    IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,5,
    IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
    IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
    IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
    IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
    IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
    IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
    IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,3,
    IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,7,
    IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
    IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
    IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
    IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
    IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
    IDE03011-MAS01627,Number of requested start processes-Steering,0,
    IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
    IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
    IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
    IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
    IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
    IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
    IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
    IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
    IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
    IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
    IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,1,
    IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
    IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
    IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
    IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
    IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
    IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,768, counts
    IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,0, counts
    IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
    IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
    IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
    IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
    IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,12,
    IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,0,
    IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
    IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
    IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
    IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,11,
    IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,0,
    IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
    IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
    IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
    IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,1501, km
    IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,0, km
    IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
    IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
    IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
    IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
    IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,46,
    IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,0,
    IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
    IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
    IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
    IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,6,
    IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,0,
    IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
    IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
    IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
    IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,57607,
    IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,0,
    IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
    IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
    IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
    IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
    IDE03190-ENG103639,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature,0, counts
    IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
    IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
    IDE03190-ENG99665,Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature,0,
    IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
    IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
    IDE03190-ENG100535,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature,0,
    IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
    IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
    IDE03190-ENG99682,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature,0, km
    IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
    IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
    IDE03190-ENG101771,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature,0,
    IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
    IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
    IDE03190-ENG104020,Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature,0,
    IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
    IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
    IDE03190-ENG103316,Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature,0,
    IDE03246,Neutral position sensor: upper adaptation value,0, mV
    IDE03247,Neutral position sensor: lower adaptation value,32770, mV
    IDE03262,Adapt of angle sensor 1 f throttle valve,0.518, V
    IDE03263,Adapt of angle sensor 2 f throttle valve,4.482, V
    IDE03362,Requested transmission torque,1000.0, Nm
    IDE03363,Numb.of misfir.: cylinder 5,158,
    IDE03364,Numb.of misfir.: cylinder 6,315,
    IDE03377,Coolant temp at radiator output: unconditioned voltage,2687.2, mV
    IDE03393-ENG104207,Selector lever position-Bit 0,8,
    IDE03493-ENG121091,Driver door status-Dsplb Drv Door Act Opn,0,
    IDE03584-ENG104207,Engine starting requirements-Bit 0,0,
    IDE03585,System status for the start/stop function master,All releases are present,
    IDE03586-ENG104207,Starting requirements for active participants-Bit 0,0,
    IDE03586-ENG101796,Starting requirements for active participants-Bit 8,0,
    IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
    IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
    IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
    IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
    IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
    IDE03587-MAS01090,Stop overrides for active participants-Transmission,active,
    IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
    IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
    IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
    IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
    IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
    IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
    IDE03587-MAS05129,Stop overrides for active participants-Engine,active,
    IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
    IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
    IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
    IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
    IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
    IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
    IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
    IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
    IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
    IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
    IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
    IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
    IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
    IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
    IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
    IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
    IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
    IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
    IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
    IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
    IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
    IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
    IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
    IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
    IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
    IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
    IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
    IDE03660,Longitudinal acceleration,-0.258, m/s
    IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,207,
    IDE03692-ENG103108,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bitregister,11001111 ,
    IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
    IDE03709,Angle difference actual-specified camshaft adjuster,1.41,
    IDE03711,Mass flow through throttle valve,0.0, kg/h
    IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
    IDE03771,Turbocharger speed sensor 2,0, /min
    IDE03794,Long-term fuel trim bank 2 at idle,0.00, %
    IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
    IDE03796,Camshaft adjustment: exhaust: bank 2: activation,0.000, %
    IDE03797,Camshaft adjustment intake bank 2: activation,0.000, %
    IDE03806-ENG104207,Oxygen sensor bank 1 sensor 1: status-Bit 0,0,
    IDE03806-ENG28465,Oxygen sensor bank 1 sensor 1: status-Byte,00000000 ,
    IDE03807-ENG104207,Oxygen sensor bank 1 sensor 2: status-Bit 0,0,
    IDE03807-ENG28465,Oxygen sensor bank 1 sensor 2: status-Byte,00000000 ,
    IDE03809-ENG104207,Oxygen sensor bank 2 sensor 2: status-Bit 0,0,
    IDE03809-ENG28465,Oxygen sensor bank 2 sensor 2: status-Byte,00000000 ,
    IDE03810,Oxygen sensor bank 2 sensor 1: specified value,0.0000,
    IDE03816-ENG129421,Exhaust flap bank 1-Test_Program_Channel 825,135,
    IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
    IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
    IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
    IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.0, Ohm
    IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
    IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,0.000, Ohm
    IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,0,
    IDE03823-ENG129414,Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125,0,
    IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,0.0, Ohm
    IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,0.000, %
    IDE03826,Conversion test Bank 2: measured value,8.0000,
    IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,0,
    IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
    IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
    IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
    IDE03952-ENG114938,Intake manifold pressure plausibility check recovery conditions-Bhepl psr,0,
    IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.98554,
    IDE03954-ENG112663,Throttle valve adaptation steady state condition-Badko se,1,
    IDE03955-ENG114936,Intake manifold pressure model steady state condition-Bapsl mdse,1,
    IDE03966,Transmission neutral position sensor PWM signal,0.00, %
    IDE04000-MAS03307,Intake air temperature sensor-Intake air temperature sensor bank 1: sensor 1,installed,
    IDE04000-MAS03307,Intake air temperature sensor-Intake air temperature sensor bank 1: sensor 1,67, C
    IDE04000-MAS03308,Intake air temperature sensor-Intake air temperature sensor bank 1: sensor 2,not installed,
    IDE04000-MAS03308,Intake air temperature sensor-Intake air temperature sensor bank 1: sensor 2,-40, C
    IDE04000-MAS03309,Intake air temperature sensor-Intake air temperature sensor bank 1: sensor 3,not installed,
    IDE04000-MAS03309,Intake air temperature sensor-Intake air temperature sensor bank 1: sensor 3,-40, C
    IDE04000-MAS03310,Intake air temperature sensor-Intake air temperature sensor bank 2: sensor 1,not installed,
    IDE04000-MAS03310,Intake air temperature sensor-Intake air temperature sensor bank 2: sensor 1,-40, C
    IDE04000-MAS03311,Intake air temperature sensor-Intake air temperature sensor bank 2: sensor 2,not installed,
    IDE04000-MAS03311,Intake air temperature sensor-Intake air temperature sensor bank 2: sensor 2,-40, C
    IDE04000-MAS03312,Intake air temperature sensor-Intake air temperature sensor bank 2: sensor 3,not installed,
    IDE04000-MAS03312,Intake air temperature sensor-Intake air temperature sensor bank 2: sensor 3,-40, C
    IDE04002-MAS03315,Charge press. ctrl.-Charge air pressure 1: specified value,0.00, kPa
    IDE04002-MAS03315,Charge press. ctrl.-Charge air pressure 1: specified value,Not available,
    IDE04002-MAS03316,Charge press. ctrl.-Charge air pressure 1: actual value,99.56, kPa
    IDE04002-MAS03316,Charge press. ctrl.-Charge air pressure 1: actual value,installed,
    IDE04002-MAS03317,Charge press. ctrl.-Charge air pressure 1: status,--no display--,
    IDE04002-MAS03317,Charge press. ctrl.-Charge air pressure 1: status,Not available,
    IDE04002-MAS03318,Charge press. ctrl.-Charge air pressure 2: specified value,Not available,
    IDE04002-MAS03318,Charge press. ctrl.-Charge air pressure 2: specified value,0.00, kPa
    IDE04002-MAS03319,Charge press. ctrl.-Charge air pressure 2: actual value,0.00, kPa
    IDE04002-MAS03319,Charge press. ctrl.-Charge air pressure 2: actual value,not installed,
    IDE04002-MAS03320,Charge press. ctrl.-Charge air pressure 2: status,Not available,
    IDE04002-MAS03320,Charge press. ctrl.-Charge air pressure 2: status,--no display--,
    IDE04003-MAS03324,Charge air temperature sensor-Charge air temperature sensor bank 1: sensor 1,59, C
    IDE04003-MAS03324,Charge air temperature sensor-Charge air temperature sensor bank 1: sensor 1,installed,
    IDE04003-MAS03325,Charge air temperature sensor-Charge air temperature sensor bank 1: sensor 2,215, C
    IDE04003-MAS03325,Charge air temperature sensor-Charge air temperature sensor bank 1: sensor 2,not installed,
    IDE04003-MAS03326,Charge air temperature sensor-Charge air temperature sensor bank 2: sensor 1,215, C
    IDE04003-MAS03326,Charge air temperature sensor-Charge air temperature sensor bank 2: sensor 1,not installed,
    IDE04003-MAS03327,Charge air temperature sensor-Charge air temperature sensor bank 2: sensor 2,not installed,
    IDE04003-MAS03327,Charge air temperature sensor-Charge air temperature sensor bank 2: sensor 2,215, C
    IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,Not available,
    IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,0, kPa
    IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,Available,
    IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,17810, kPa
    IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,Not available,
    IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,0, C
    IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,Not available,
    IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,0, kPa
    IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,0, kPa
    IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,Not available,
    IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,0, C
    IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,Not available,
    IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,75, C
    IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,installed,
    IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,75, C
    IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,installed,
    IDE04101-MAS03486,Intake pressure-Intake pressure sensor 1,99.56, kPa
    IDE04101-MAS03486,Intake pressure-Intake pressure sensor 1,installed,
    IDE04101-MAS03487,Intake pressure-Intake pressure sensor 2,not installed,
    IDE04101-MAS03487,Intake pressure-Intake pressure sensor 2,0.00, kPa
    IDE04256,Temp sensor for engine coolant: unconditioned voltage,1361.2, mV
    IDE04409,Intake manifold pressure: corrected,998.13, hPa
    IDE04410,Intake manifold pressure: target value,246.25, hPa
    IDE04414,Cat conv temp: modeled,85, C
    IDE04604,Accelerator pedal travel,0.00, %
    IDE04630-ENG06942,AVS valve stroke position: current-Test_Program_Xaied Fa Ehan Adc jnotd jb n 0 A1T UBYTE,1,
    IDE04637,Engine temperature management actuator,99.74, %
    IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
    IDE04651,Torque request: A/C compressor,0.0, Nm
    IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,1,
    IDE04685,Setpoint generation interior torque,0.0, Nm
    IDE04693,Increasing desired torque intervention of ESP,-3276.8, Nm
    IDE04695-ENG06680,Immobilizer snapshot A-Sia Error Snap,00 00 00,
    IDE04696-ENG06680,Immobilizer snapshot B-Sia Error Snap,00 00 00,
    IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
    IDE04820,Fuel content due to degassing of engine oil,0.00, %
    IDE04858,Brake booster low pressure actual value,856.02, hPa
    IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
    IDE04887,Powertrain target torque,0.1, Nm
    IDE04889,Target torque for combustion engine crankshaft level,-27.1, Nm
    IDE04909-ENG104207,Operating mode of hybrid system-Bit 0,0,
    IDE04933,Number of fill level decreases,196,
    IDE04934,Last odometer reading since fill level decrease,393210, km
    IDE04935,Next to last odometer reading since fill level decrease,393210, km
    IDE04936,3. Last odometer reading since fill level decrease,393210, km
    IDE04937,Sensor for engine block temperature: raw value,75.9, C
    IDE05128,Intake air temperature in intake manifold bank 1,59.3, C
    IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
    IDE05138,Shut-off timer: last engine shut-off time,6396, s
    IDE05140,Intake manifold pressure raw value,995.70, hPa
    IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
    IDE05214,Tank vent valve diagnosis pressure difference ratio,0.00,
    IDE05221,E-machine torque actual value,0.0, Nm
    IDE05240-ENG104207,Request for A/C compressor power reduction-Bit 0,0,
    IDE05241-ENG104207,A/C compressor release status-Bit 0,0,
    IDE05260-ENG104207,Gear position sensor: current value-Bit 0,0,
    IDE05329,Activation for electrical reserve coolant pump in NT circuit,0.00, %
    IDE05331,DCDC converter temperature: actual value,-273.1, C
    IDE05332-ENG104207,Heat request from heater to thermal management-Bit 0,3,
    IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
    IDE05437,Outside air temperature via CAN,3.8, C
    IDE05438,Rear cat conv temp main cat conv model value,85.1, C
    IDE05439,Rear cat conv temp main cat conv bank 2 model value,-273.1, C
    IDE05440,ESI: Soot equiv 2 calculated from soot index,0.0000,
    IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.0000,
    IDE05442,Roadway slope angle acceleration interface: calculated,-0.0271, rad
    IDE05444,Air filling: specified value,12.40, %
    IDE05445,Pressure before throttle valve of pressure sensor,998.05, hPa
    IDE05448,Long term adaptation of mixture form bank 2 at partial load,0.00000,
    IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,131070, Ohm
    IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,0, Ohm
    IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00101,
    IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00000,
    IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, C
    IDE05469,Oxygen sensor 1 bank 2 ceramic temp,-273.15, C
    IDE05470,Cat converter oxygen storage capacity,0.0, mg
    IDE05471,Cat converter oxygen storage capacity bank 2,0.0, mg
    IDE05474,Main cat converter OSC age correction factor,0.89063,
    IDE05475,Main cat converter OSC age correction factor bank 2,0.00000,
    IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
    IDE05477,Cat converter oxygen storage capacity bank 2 measured,0.0, mg
    IDE05479,Misfire recognition reference moment,0.000, %
    IDE05482,Tank venting adaptation factor,0.000,
    IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
    IDE05485-ENG104207,Irregular shutdown of the counter control mod-Bit 0,0,
    IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
    IDE05488,Coolant temperature modeled value,70.0, C
    IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,255,
    IDE05797,Throttle valve adapter: specified value,1.695, %
    IDE05928,Fuel consumption since DTC memory last erased,10.275, l/100km
    IDE05941-ENG112665,Enable condition: camshaft control-Bnws,0,
    IDE05943-ENG129326,Release for supply to fuel pump-Test_Program_Channel 890,136,
    IDE06015,Time since term 15 OFF StartStop,6400, s
    IDE06017,Camshaft position deviation from reference position,-0.00,
    IDE06020,Intake air temperature in intake manifold bank raw value,67.2, C
    IDE06021,Intake air temperature before throttle valve: raw value,60.0, C
    IDE06023-ENG104207,BDE operating mode flag register-Bit 0,1,
    IDE06023-ENG28465,BDE operating mode flag register-Byte,00000001 ,
    IDE06039,Required RPM at idle speed,1100.0, /min
    IDE06040,High fuel pressure: regulator output value,-3.9480, MPa
    IDE06041-ENG104207,PDTC drive cycle conditions status-Bit 0,0,
    IDE06043,Cylinder head temperature: actual value,76.5, C
    IDE06045-ENG104207,Output DTM status-Bit 0,0,
    IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
    IDE06049,Pressure in brake booster: raw value,142, hPa
    IDE06098,Sensor control factor: output value,1.00000,
    IDE06112-ENG104207,Cylinder shut-off test-Bit 0,5,
    IDE06192,Knock sensor: cylinder 2: voltage,0.0400001, V"ms
    IDE06193,Knock sensor: cylinder 3: voltage,0.0400001, V"ms
    IDE06194,Knock sensor: cylinder 4: voltage,0.0400001, V"ms
    IDE06195,Knock sensor: cylinder 1: voltage,0.0400001, V"ms
    IDE06198-ENG104207,Tank vent valve: diagnostic status-Bit 0,32,
    IDE06255,Vehicle lateral acceleration,-0.06, g
    IDE06256,Vehicle lateral acceleration: raw value,-0.06, g
    IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s
    IDE06307-MAS00106,Stop prevention history data-Year,2000,
    IDE06307-MAS00107,Stop prevention history data-Month,1,
    IDE06307-MAS00108,Stop prevention history data-Day,18,
    IDE06307-MAS00109,Stop prevention history data-Hours,10,
    IDE06307-MAS00110,Stop prevention history data-Minutes,2,
    IDE06307-MAS00111,Stop prevention history data-Seconds,51,
    IDE06308-MAS00106,Start request history data-Year,2000,
    IDE06308-MAS00107,Start request history data-Month,1,
    IDE06308-MAS00108,Start request history data-Day,15,
    IDE06308-MAS00109,Start request history data-Hours,9,
    IDE06308-MAS00110,Start request history data-Minutes,2,
    IDE06308-MAS00111,Start request history data-Seconds,50,
    IDE06389,Oil level: maximum value,18.836, mm
    IDE06390,Oil level: minimum value,52.068, mm
    IDE06391,Oil temperature sensor 2,75.5, C
    IDE06392,Oil temperature sensor 2: raw value,1371.0, mV
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
    IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
    IDE06435,A/C compressor: refrigerant pressure,0, hPa
    IDE06436,A/C compressor: refrigerant pressure: raw value,0.00, %
    IDE06445,Longitudinal acceleration: raw value,0.000, m/s
    IDE06446-ENG104207,Status: incline angle-Bit 0,0,
    IDE06567,Start-stop function deactivation frequency counter,278,
    IDE06568,Stop prevention by driver frequency counter,101,
    IDE06569,Vehicle stopped frequency counter,532,
    IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,67.4, C
    IDE06610,Vehicle standstill with stop frequency counter,78,
    IDE06647-ENG104207,Start-stop switch status-Bit 0,1,
    IDE06702-ENG104207,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0,0,
    IDE06702-ENG102612,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16,128,
    IDE06702-ENG101717,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24,130,
    IDE06702-ENG101796,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8,0,
    IDE06703-ENG104207,Drivetrain coordinator: ACC fault status-Bit 0,0,
    IDE06703-ENG101796,Drivetrain coordinator: ACC fault status-Bit 8,0,
    IDE06704-ENG104207,Drivetrain coordinator: brake fault status-Bit 0,0,
    IDE06705-ENG104207,Drivetrain coordinator: brake function status-Bit 0,4,
    IDE06705-ENG101796,Drivetrain coordinator: brake function status-Bit 8,32,
    IDE06706-ENG104207,ACC variants-Bit 0,2,
    IDE06707-ENG104207,CCS Switch-Bit 0,2,
    IDE06708-ENG104207,Cruise control switch actuation-Bit 0,0,
    IDE06708-ENG101796,Cruise control switch actuation-Bit 8,32,
    IDE06709-ENG104207,ACC variants (coding)-Bit 0,3,
    IDE06710-ENG104207,Cruise control system: permanent deactivation-Bit 0,255,
    IDE06711-ENG104207,Cruise control system: temporary deactivation-Bit 0,255,
    IDE06726,Timing deviation after chain replacement: intake bank 1,0.00,
    IDE06727,Timing deviation after chain replacement: intake bank 2,0.00,
    IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.00,
    IDE06729,Timing deviation after chain replacement: exhaust bank 2,0.00,
    IDE06730,Timing deviation after other repairs: intake bank 1,0.00,
    IDE06731,Timing deviation after other repairs: intake bank 2,0.00,
    IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00,
    IDE06733,Timing deviation after other repairs: exhaust bank 2,0.00,
    IDE06734,Timing deviation: current value intake bank 1,0.00,
    IDE06735,Timing deviation: current value intake bank 2,0.00,
    IDE06736,Timing deviation: current value exhaust bank 1,0.00,
    IDE06737,Timing deviation: current value exhaust bank 2,0.00,
    IDE06738-ENG104207,Chain elongation: no. of valid initial values: intake bank 1-Bit 0,0,
    IDE06739-ENG104207,Chain elongation: no. of valid initial values: intake bank 2-Bit 0,0,
    IDE06740-ENG104207,Chain elongation: no. of valid initial values: exhaust bank 1-Bit 0,0,
    IDE06741-ENG104207,Chain elongation: no. of valid initial values: exhaust bank 2-Bit 0,0,
    IDE06742,Chain elongation: initial values valid: intake bank 1,0,
    IDE06743,Chain elongation: initial values valid: intake bank 2,0,
    IDE06744,Chain elongation: initial values valid: exhaust bank 1,0,
    IDE06745,Chain elongation: initial values valid: exhaust bank 2,0,
    IDE06758,Air mass since engine start,0.0000, kg
    IDE06794,NG to gasoline split factor,0.000,
    IDE06799-ENG104207,A/C compressor status: HW input-Bit 0,0,
    IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
    IDE06828,Coolant recirc. pump 2: spec. value,10.00, %
    IDE06830,Coolant pump for charge-air cooling: spec. value,0.00, %
    IDE06944,A/C compressor: load current: act. value,0.00, A
    IDE06946-ENG104207,Brake actuated status-Bit 0,0,
    IDE06947-ENG104207,E-machine operating mode: spec. state-Bit 0,0,
    IDE06956-ENG104207,Driver-side belt buckle status-Bit 0,2,
    IDE06957,Unfiltered clutch input rpm,0.0, /min
    IDE06970,Desired braking torque: driving assistant,0.1, Nm
    IDE06975-ENG104207,Regeneration stages-Bit 0,0,
    IDE07001,Piston-cooling jets: activation,0,
    IDE07031,Oil pressure switch for piston-cooling jets: status,0,
    IDE07051-ENG104207,Engaged gear: raw signal-Bit 0,0,
    IDE07076,AVS valve stroke position intake,63,
    IDE07077,AVS valve stroke position: exhaust,0,
    IDE07078,AVS result of last switch-over: intake,63,
    IDE07164,Number injections,0,
    IDE07170,Clutch K0: torque,0.0, Nm
    IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
    IDE07225-ENG104207,Transfer electric drive to combustion drive-Bit 0,0,
    IDE07238,Status of power transfer,0.00,
    IDE07240-ENG104207,Status transition of engine control module sequencing-Bit 0,1,
    IDE07242,Heater support pump: spec. value,10.00, %
    IDE07254,Gasoline pressure tank refueling request button,0,
    IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
    IDE07573,Throttle valve adapter: actual value,12.680, %
    IDE07615-ENG129324,Operating of tank: empty or reserve-Test_Program_Channel 372,194,
    IDE07620-ENG104207,Status momentary default during stability intervention-Bit 0,0,
    IDE07664,Pre-coordinated torque of increased stability intervention,-50000.0, Nm
    IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
    IDE07666,Target torque of elec. motor: coordinated output signal,0.0, Nm
    IDE07667,Desired torque of regeneration,-27.0, Nm
    IDE07724,Coolant temperature at engine outlet: calculated,75.8, C
    IDE07799,Heater support pump 1 bank 1 primary circuit: activation,0.00, %
    IDE07840-ENG104207,Status plausibility accelerator pedal to brake pedal-Bit 0,0,
    IDE07904-ENG104207,Brake test switch status-Bit 0,0,
    IDE07905-ENG104207,Brake light switch status-Bit 0,0,
    IDE07906-ENG104207,Upper clutch switch: status-Bit 0,0,
    IDE07908,Coolant fan activation requested by A/C,0.00, %
    IDE07963-ENG104207,Cam piece counter position malfunction-Bit 0,0,
    IDE07963-ENG102612,Cam piece counter position malfunction-Bit 16,0,
    IDE07963-ENG101717,Cam piece counter position malfunction-Bit 24,0,
    IDE07963-ENG101796,Cam piece counter position malfunction-Bit 8,0,
    IDE09307-ENG104207,Pre-ignition counter cylinder 1-Bit 0,0,
    IDE09307-ENG101796,Pre-ignition counter cylinder 1-Bit 8,0,
    IDE09308-ENG104207,Pre-ignition counter cylinder 2-Bit 0,0,
    IDE09308-ENG101796,Pre-ignition counter cylinder 2-Bit 8,0,
    IDE09309-ENG104207,Pre-ignition counter cylinder 3-Bit 0,0,
    IDE09309-ENG101796,Pre-ignition counter cylinder 3-Bit 8,0,
    IDE09310-ENG104207,Pre-ignition counter cylinder 4-Bit 0,0,
    IDE09310-ENG101796,Pre-ignition counter cylinder 4-Bit 8,0,
    IDE09311-ENG104207,Pre-ignition counter cylinder 5-Bit 0,0,
    IDE09311-ENG101796,Pre-ignition counter cylinder 5-Bit 8,0,
    IDE09312-ENG104207,Pre-ignition counter cylinder 6-Bit 0,0,
    IDE09312-ENG101796,Pre-ignition counter cylinder 6-Bit 8,0,
    IDE09313-ENG104207,Pre-ignition counter over serv.life cylinder 1-Bit 0,0,
    IDE09313-ENG101796,Pre-ignition counter over serv.life cylinder 1-Bit 8,0,
    IDE09314-ENG104207,Pre-ignition counter over serv.life cylinder 2-Bit 0,0,
    IDE09314-ENG101796,Pre-ignition counter over serv.life cylinder 2-Bit 8,0,
    IDE09315-ENG104207,Pre-ignition counter over serv.life cylinder 3-Bit 0,0,
    IDE09315-ENG101796,Pre-ignition counter over serv.life cylinder 3-Bit 8,0,
    IDE09316-ENG104207,Pre-ignition counter over serv.life cylinder 4-Bit 0,0,
    IDE09316-ENG101796,Pre-ignition counter over serv.life cylinder 4-Bit 8,0,
    IDE09317-ENG104207,Pre-ignition counter over serv.life cylinder 5-Bit 0,0,
    IDE09317-ENG101796,Pre-ignition counter over serv.life cylinder 5-Bit 8,0,
    IDE09318-ENG104207,Pre-ignition counter over serv.life cylinder 6-Bit 0,0,
    IDE09318-ENG101796,Pre-ignition counter over serv.life cylinder 6-Bit 8,0,
    IDE09319-ENG104207,Pre-ignition action counter injection cut-off-Bit 0,0,
    IDE09320-ENG104207,Pre-ignition action counter fill level limit-Bit 0,0,
    IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
    IDE09531,Total mass of gasoline and alcohol in oil,0.00, g
    IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
    IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
    IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
    IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
    IDE09694-ENG104207,Charisma driving program: act. value-Bit 0,2,
    IDE09695-ENG104207,Charisma driving program: target value from coordinator-Bit 0,2,
    IDE09696-ENG104207,Charisma driving program: CAN output value-Bit 0,2,
    IDE09925-ENG104207,Intake camshaft bank 1: adaption error cause-Bit 0,0,
    IDE09926-ENG104207,Outlet camshaft bank 1: adaption error cause-Bit 0,0,
    IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
    IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
    IDE09929,Intake camshaft bank 1: adaption value hardware offset active,1.41,
    IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,1.63,
    IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-1.14,
    IDE09932,Intake camshaft bank1: adaption value sensor tolerance,-0.26,
    IDE09943,Long-term adaptation of mixture formation FSI: multiplicative,0.00000,
    IDE09945,Long-term adaptation of mixture formation MPI: multiplicative,0.00000,
    IDE10040-ENG104207,Outlet camshaft bank 1 active operating mode-Bit 0,0,
    IDE10041,Intake camshaft bank1 active operating mode,0,
    IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
    IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
    IDE10063-MAS00666,Engine oil level: current value-Warning,0,
    IDE10063-MAS00900,Engine oil level: current value-Oil level,115.8, %
    IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,1307, km
    IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,1304, km
    IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
    IDE10063-ENG06679,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,3,
    IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
    IDE10064-MAS00900,Engine oil level: history 1-Oil level,120.1, %
    IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,599, km
    IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,597, km
    IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
    IDE10064-ENG06679,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,3,
    IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
    IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.0, %
    IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
    IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
    IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
    IDE10065-ENG06679,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,0,
    IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
    IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.0, %
    IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
    IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
    IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
    IDE10066-ENG06679,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,0,
    IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
    IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.0, %
    IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
    IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
    IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
    IDE10067-ENG06679,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,0,
    IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
    IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.0, %
    IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
    IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
    IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
    IDE10068-ENG06679,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,0,
    IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
    IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.0, %
    IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
    IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
    IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
    IDE10069-ENG06679,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,0,
    IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
    IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.0, %
    IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
    IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
    IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
    IDE10070-ENG06679,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,0,
    IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
    IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.0, %
    IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
    IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
    IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
    IDE10071-ENG06679,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,0,
    IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
    IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.0, %
    IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
    IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
    IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
    IDE10072-ENG06679,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,0,
    IDE10302,Time since engine start,0.0, s
    IDE10303,Integrated air masse at first engine start,0.0000, kg
    IDE10580,Engine oil level: test method 1,95.5, %
    IDE10581,Engine oil level: test method 2,110.3, %
    IDE10582,Engine oil level: test method 3,108.4, %
    IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.03, s
    IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
    IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
    IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.05, s
    IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.00, s
    IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
    IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
    IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
    IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
    IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
    IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
    IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
    IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
    IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
    IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
    IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
    IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
    IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
    IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
    IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
    IDE10968,Activation radiator shutter result,0.00, %
    IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
    IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
    IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
    IDE10989-MAS00106,Immobilizer: historic data-Year,2063,
    IDE10989-MAS00107,Immobilizer: historic data-Month,3,
    IDE10989-MAS00108,Immobilizer: historic data-Day,31,
    IDE10989-MAS00109,Immobilizer: historic data-Hours,15,
    IDE10989-MAS00110,Immobilizer: historic data-Minutes,3,
    IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
    IDE10994,Poor start counter at start-stop,0,
    IDE11065-ENG104207,Accel. pedal pos. sensor 1-Bit 0,102,
    IDE11065-ENG101796,Accel. pedal pos. sensor 1-Bit 8,2,
    IDE11066-ENG104207,Accel. pedal pos. sensor 2-Bit 0,51,
    IDE11066-ENG101796,Accel. pedal pos. sensor 2-Bit 8,1,
    IDE11081,AVS operating state: inlet,0,
    IDE11083-ENG29792,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
    IDE11115,Start/stop driver request: counter restart by starter,2,
    IDE11116,Start/stop driver request: counter internal-motor restart,3,
    IDE11203,Oil pressure setpoint,214.5, kPa
    IDE11267,Oil level: max. value: relative,121.9, %
    IDE11268,Oil level: min. value: relative,97.2, %
    IDE11293,Fuel consumption difference: injectors/sensors,3.063, l
    IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,11.063, l
    IDE11302-ENG104207,Engine oil level: test method 1:qualification-Bit 0,8,
    IDE11303-ENG104207,Engine oil level: test method 3:qualification-Bit 0,2,
    IDE11329-ENG104207,Oil press. sensor: raw value-Bit 0,198,
    IDE11329-ENG101796,Oil press. sensor: raw value-Bit 8,0,
    IDE11330,Oil press. control valve: activation pulse duty factor,66.50, %
    IDE11372,Camshaft angle adaptation: inlet deviation,-1.937,
    IDE11499,Camshaft angle adaptation: inlet deviation: bank 2,-1.937,
    IDE11541-ENG104207,Autom.pre-selection sys operat.state of the actuator test-Bit 0,0,
    IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
    IDE11577-MAS04416,Stop process prevented 2-Sporadic function restriction,not active,
    IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
    IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
    IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
    IDE11577-MAS04591,Stop process prevented 2-Diagnosis of air system,not active,
    IDE11577-MAS04870,Stop process prevented 2-Test of thermostat not complete,not active,
    IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
    IDE11577-MAS06604,Stop process prevented 2-Start-stop sensor system,not active,
    IDE11577-MAS06605,Stop process prevented 2-Regeneration operation,not active,
    IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
    IDE11577-MAS08032,Stop process prevented 2-Event memory entry in engine control module,not active,
    IDE11577-MAS09416,Stop process prevented 2-Adaptation active,not active,
    IDE11577-MAS13644,Stop process prevented 2-Motor protection active,not active,
    IDE11577-MAS13645,Stop process prevented 2-Fuel salinization protection active,not active,
    IDE11577-MAS13661,Stop process prevented 2-Exhaust emission control diagnosis,not active,
    IDE11577-MAS16918,Stop process prevented 2-Restriction in the start system,not active,
    IDE11635-ENG104207,Radiator shutter 1: status referencing-Bit 0,0,
    IDE11636-ENG104207,Radiator shutter 2: status referencing-Bit 0,0,
    IDE11929,I share of PID control of fully variable oil pump,0.00, %
    IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,-0.00021,
    IDE12104,Cylinder block coolant valve: pulse duty factor,0.00, %
    IDE12105,Temperature sensor for cylinder block: uncond. voltage value,1369.8, mV
    IDE12106,Temperature sensor for cylinder block,75.6, C
    IDE12483,Service life data 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    IDE12551,Camshaft adjustment intake bank 1: adaptation value,-1.41,
    IDE12663,Camshaft adjustment intake bank 2: adaptation value,2.66,
    IDE12664,Camshaft adjustment outlet bank 1: adaptation value,-1.63,
    IDE12665,Camshaft adjustment outlet bank 2: adaptation value,0.22,
    IDE12688,Catalytic converter temperature bank 2: modeled,-50, C
    IDE12748,Oil level: amount added MIN to MAX,1250, ml
    IDE12765,Pressure: tank ventilation leads: bank 2,-2.89, hPa
    IDE12997,Long-term mixture adaptation during valve overlap bank 1,-0.02539,
    IDE12998,Long-term mixture adaptation during valve overlap bank 2,0.00000,
    IDE13012,Tank breather valve: activation duty factor,0.000, %
    IDE13301,Drivetrain coordinator: brake fault status,0,
    IDE80106,Analysis 106,00 03 00 00 00 00 00 01 00 00 00 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00 08 4E 00 00 00 00 00 2B 06 26 00 64 00 01 00 00 00 00 00 00 00 00,
    MAS15845,Fuel: tank fill level,50.0, l
    MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,102.8, C
    MAS16067,Exhaust gas temperature at the probe before PreCat bank 2: model value,-273.1, C
    MAS16074,Temperature in pre-cat bank 1: model value,137.1, C
    MAS16075,Temperature in pre-cat bank 2: model value,-273.1, C
    MAS16088,Lambda driver request: specified value,15.9998,
    MAS16089,Lambda component protection: bank 1: specified value,1.0000,
    MAS16091,Lambda Delta from exhaust gas temperature regulation bank 1: actual value,0.0000,
    MAS16097,Tank ventilation factorial fuel amount: actual value,0.000,
    MAS16098,Tank ventilation relative mixture proportion: actual value,0.00, %
    MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,0,
    ENG105012,Abo,0,
    ENG105037,Acc Ped trq Des,0.1, Nm
    ENG105054,Act Mod trq Clth,-27.1, Nm
    ENG119898,Actual_section_of_standard_test,0,
    ENG105091,Afmim n,99.6, %
    ENG105092,Afmim x,0.0, %
    ENG105093,Afnmn,10200, /min
    ENG105094,Afnmx,0, /min
    ENG105095,AFS dm,0.0, kg/h
    ENG112666,Air conditioner pressure linearised raw value,0, hPa
    ENG112928-ENG104207,Air_conditioning_compressor_actual_status-Bit 0,0,
    ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.00, kg
    ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,9.87, kg
    ENG106228,Ambient air pressure,998, hPa
    ENG106231,Ambient temperature,28.0, C
    ENG105192,APP r,0.00, %
    ENG26434-ENG104207,AVS_Cam_element_position_error_counter_lift_0-Bit 0,0,
    ENG26434-ENG102612,AVS_Cam_element_position_error_counter_lift_0-Bit 16,0,
    ENG26434-ENG101717,AVS_Cam_element_position_error_counter_lift_0-Bit 24,0,
    ENG26434-ENG101796,AVS_Cam_element_position_error_counter_lift_0-Bit 8,0,
    ENG26435-ENG104207,AVS_Cam_element_position_error_counter_lift_1-Bit 0,0,
    ENG26435-ENG102612,AVS_Cam_element_position_error_counter_lift_1-Bit 16,0,
    ENG26435-ENG101717,AVS_Cam_element_position_error_counter_lift_1-Bit 24,0,
    ENG26435-ENG101796,AVS_Cam_element_position_error_counter_lift_1-Bit 8,0,
    ENG26436-ENG104207,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bit 0,0,
    ENG26436-ENG102612,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bit 16,0,
    ENG26436-ENG101717,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bit 24,0,
    ENG26436-ENG101796,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bit 8,0,
    ENG26437-ENG104207,AVS_Cam_element_position_error_counter_misfire_detection-Bit 0,0,
    ENG26437-ENG102612,AVS_Cam_element_position_error_counter_misfire_detection-Bit 16,0,
    ENG26437-ENG101717,AVS_Cam_element_position_error_counter_misfire_detection-Bit 24,0,
    ENG26437-ENG101796,AVS_Cam_element_position_error_counter_misfire_detection-Bit 8,0,
    ENG121428-ENG104207,AVS_counter_error_debonce-Bit 0,1,
    ENG121428-ENG101796,AVS_counter_error_debonce-Bit 8,0,
    ENG121429-ENG104207,AVS_counter_error_limphome-Bit 0,0,
    ENG121429-ENG101796,AVS_counter_error_limphome-Bit 8,0,
    ENG121426-ENG104207,AVS_counter_sporadic_diagnosis_errors-Bit 0,6,
    ENG121426-ENG101796,AVS_counter_sporadic_diagnosis_errors-Bit 8,0,
    ENG121427-ENG104207,AVS_counter_sporadic_switch_errors-Bit 0,0,
    ENG121427-ENG101796,AVS_counter_sporadic_switch_errors-Bit 8,0,
    ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
    ENG105385,C Eng Us T t,40.7, C
    ENG101413,Calibration Identification,8W0559H 0005BVA,
    ENG99697,Calibration Verification Number,01 26 59 72,
    ENG08794-ENG104207,Com st X Set1 Val1-Bit 0,0,
    ENG08794-ENG101796,Com st X Set1 Val1-Bit 8,0,
    ENG08795-ENG104207,Com st X Set1 Val2-Bit 0,0,
    ENG08795-ENG101796,Com st X Set1 Val2-Bit 8,0,
    ENG08796-ENG104207,Com st X Set1 Val3-Bit 0,0,
    ENG08796-ENG101796,Com st X Set1 Val3-Bit 8,0,
    ENG08797-ENG104207,Com st X Set1 Val4-Bit 0,0,
    ENG08797-ENG101796,Com st X Set1 Val4-Bit 8,0,
    ENG08798-ENG104207,Com st X Set1 Val5-Bit 0,0,
    ENG08798-ENG101796,Com st X Set1 Val5-Bit 8,0,
    ENG08799-ENG104207,Com st X Set1 Val6-Bit 0,0,
    ENG08799-ENG101796,Com st X Set1 Val6-Bit 8,0,
    ENG08800-ENG104207,Com st X Set1 Val7-Bit 0,0,
    ENG08800-ENG101796,Com st X Set1 Val7-Bit 8,0,
    ENG08801-ENG104207,Com st X Set2 Val1-Bit 0,0,
    ENG08801-ENG101796,Com st X Set2 Val1-Bit 8,0,
    ENG08802-ENG104207,Com st X Set2 Val2-Bit 0,0,
    ENG08802-ENG101796,Com st X Set2 Val2-Bit 8,0,
    ENG08803-ENG104207,Com st X Set2 Val3-Bit 0,0,
    ENG08803-ENG101796,Com st X Set2 Val3-Bit 8,0,
    ENG08804-ENG104207,Com st X Set2 Val4-Bit 0,0,
    ENG08804-ENG101796,Com st X Set2 Val4-Bit 8,0,
    ENG08805-ENG104207,Com st X Set2 Val5-Bit 0,0,
    ENG08805-ENG101796,Com st X Set2 Val5-Bit 8,0,
    ENG08806-ENG104207,Com st X Set2 Val6-Bit 0,0,
    ENG08806-ENG101796,Com st X Set2 Val6-Bit 8,0,
    ENG08807-ENG104207,Com st X Set2 Val7-Bit 0,0,
    ENG08807-ENG101796,Com st X Set2 Val7-Bit 8,0,
    ENG08808-ENG104207,Com st X Set3 Val1-Bit 0,0,
    ENG08808-ENG101796,Com st X Set3 Val1-Bit 8,0,
    ENG08809-ENG104207,Com st X Set3 Val2-Bit 0,0,
    ENG08809-ENG101796,Com st X Set3 Val2-Bit 8,0,
    ENG08810-ENG104207,Com st X Set3 Val3-Bit 0,0,
    ENG08810-ENG101796,Com st X Set3 Val3-Bit 8,0,
    ENG08811-ENG104207,Com st X Set3 Val4-Bit 0,0,
    ENG08811-ENG101796,Com st X Set3 Val4-Bit 8,0,
    ENG08812-ENG104207,Com st X Set3 Val5-Bit 0,0,
    ENG08812-ENG101796,Com st X Set3 Val5-Bit 8,0,
    ENG08813-ENG104207,Com st X Set3 Val6-Bit 0,0,
    ENG08813-ENG101796,Com st X Set3 Val6-Bit 8,0,
    ENG08814-ENG104207,Com st X Set3 Val7-Bit 0,0,
    ENG08814-ENG101796,Com st X Set3 Val7-Bit 8,0,
    ENG01773-ENG104207,Configuration_of_cruise_control-Bit 0,154,
    ENG106503,Coolant temperature at radiator outlet,40.5, C
    ENG126402-ENG104207,Cruise_control_shutoff_conditions_irreversible-Bit 0,0,
    ENG126402-ENG101796,Cruise_control_shutoff_conditions_irreversible-Bit 8,0,
    ENG126403-ENG104207,Cruise_control_shutoff_conditions_reversible-Bit 0,64,
    ENG126403-ENG102612,Cruise_control_shutoff_conditions_reversible-Bit 16,25,
    ENG126403-ENG101717,Cruise_control_shutoff_conditions_reversible-Bit 24,1,
    ENG126403-ENG101796,Cruise_control_shutoff_conditions_reversible-Bit 8,68,
    ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
    ENG105761-ENG104207,DC_DC_transformer_mode_actual_state-Bit 0,7,
    ENG111031-ENG104207,DFC_status_error_debounced_counter-Bit 0,0,
    ENG111031-ENG101796,DFC_status_error_debounced_counter-Bit 8,0,
    ENG111033-ENG104207,DFC_status_tested_counter-Bit 0,193,
    ENG111033-ENG101796,DFC_status_tested_counter-Bit 8,3,
    ENG111032-ENG104207,DFC_status_untested_counter-Bit 0,143,
    ENG111032-ENG101796,DFC_status_untested_counter-Bit 8,1,
    ENG126404-ENG104207,Drive_train_coordinator_checked_coding-Bit 0,5,
    ENG112930,Driving_torque_coordinator_requested_driving_torque_from_GRA,-32768.0, Nm
    ENG111582-ENG127289,DrivingProgramSwitch_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
    ENG100152-ENG104003,ECUNAME-ECU,ECM,
    ENG100152,ECUNAME,-EngineControl,
    ENG112932,Engine_oil_temperature_measured_value,75.4, C
    ENG111034,Engine_temperature_modelbased_substitute_value,75.8, C
    ENG106223,Engine_torque_limitation_mechanical,3276.7, Nm
    ENG111568,EngineCoordinator_intervention_request_actual_value,6,
    ENG111610,Epm Ca S phi Adap Ref Pos O1 mp 0,71.30,
    ENG121110,Epm Ca S phi Adap Ref Pos O1 mp 1,103.71,
    ENG26778,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
    ENG26779,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
    ENG26780,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,0.0, hPa
    ENG26781,Evap_purge_system_bank_1_insertion_pre_turbocharger_corrected_cross_correlation_coefficient,0.00,
    ENG26788,ExhMgT_fetak_hllfa_msg,1.000,
    ENG26789,ExhMgT_fetak_htlfa_msg,1.000,
    ENG26808,Fl Lvl vol Tnk Plaus Old,58.000, l
    ENG106677,Frm w,1.00000,
    ENG106678,Frm2 w,0.00000,
    ENG111608,Fuel_consumption_actual_driving_cycle,0.00, l
    ENG106769-ENG104207,Gearbox_heat_request-Bit 0,0,
    ENG112667,Generator load normalised value,0.00, %
    ENG112931,Generator_load_from_CAN,0.0123888, W
    ENG112929,Generator_torque_request,0.0, Nm
    ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,0.0, kg/h
    ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,14 00 30 00 95 00 37 00 30 00 00 00 00 00 34 00 30 00 00 00 00 00 57 00 30 00 00 00 00 00 04 00 08 00 33 00 30 00 00 00 00,
    ENG107236,Knock_sensor_cylinder_5_voltage,0.0400001, V"ms
    ENG107237,Knock_sensor_cylinder_6_voltage,0.0400001, V"ms
    ENG121113,Kvakb i w,0, l
    ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
    ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2000,
    ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,1,
    ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,15,
    ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,9,
    ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,2,
    ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,27,
    ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2000,
    ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,1,
    ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,13,
    ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,9,
    ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,2,
    ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,4,
    ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2000,
    ENG127733-MAS00107,Life_cycle_data_system_failure-Month,0,
    ENG127733-MAS00108,Life_cycle_data_system_failure-Day,0,
    ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,0,
    ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,0,
    ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,0,
    ENG111606,Load value: unrestricted commanded value,0.00, %
    ENG125271,Maximum_ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
    ENG107621,Milso l w,0.000, %
    ENG111040,Misfire_detection_sensor_wheel_adaptation_speed_load_range_index,0,
    ENG107660,Mode_control_commanded_dragmoment_for_em,-27.0, Nm
    ENG107661-ENG104207,Mode_control_operating_status_hybrid_system_bitcoded-Bit 0,0,
    ENG107661-ENG101796,Mode_control_operating_status_hybrid_system_bitcoded-Bit 8,0,
    ENG111575-ENG104207,Mode_control_override_factor_gear_shift_program-Bit 0,0,
    ENG111575-ENG101796,Mode_control_override_factor_gear_shift_program-Bit 8,0,
    ENG111572-ENG127289,Mode_control_sport_mode_activated-Test_Program_B TRUE UBYTE,0,
    ENG111581-ENG104207,Mode_control_start_order_combustion_engine-Bit 0,0,
    ENG107663,Mode_control_torque_electrical_auxilary_systems_requested_value,0.0, Nm
    ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
    ENG26996-ENG104207,OEM2RB VW Byp flg E Hmnplt u8-Bit 0,0,
    ENG27002,P Intk V Us p Raw Ini,995.70, hPa
    ENG108178,Pbksi a w,0.0, kPa
    ENG108262,Powertrain_overall_gear_ratio,1.00,
    ENG111605,Pressure_before_throttle_valve_actual_value,998.05, hPa
    ENG108339,Psr w,998.13, hPa
    ENG125270,Ratio_between_evaporated_fuel_mass_from_engine_oil_and_base_fuel_mass_needed_for_the_combustion,0.000,
    ENG27083,Rba Io Sig Rtc st Diag Stop Count er,96,
    ENG109006,Spark_efficiency_deviation_at_idle_maximum,0.0, %
    ENG109007,Spark_efficiency_deviation_at_part_load_maximum,0.0, %
    ENG121093-ENG104207,State_of_cruise_control_or_speedlimiter-Bit 0,0,
    ENG01786-ENG104207,State_of_requestor_for_drivetrain_coordinator-Bit 0,0,
    ENG27172,Sy C st Vld Ti Ecu Off,1,
    ENG109344,Tasrg w,67.14, C
    ENG109625,Temperature at air conditioner heat exchanger output,95.0, C
    ENG08688,Thr Vlv u Sens1 B1,1.010, V
    ENG08689,Thr Vlv u Sens2 B1,3.994, V
    ENG01775,Top_speed_limitation,238.000, km/h
    ENG109528,Torque_coordination_idle_speed_control_torque_actual_value_air_path,0.0, Nm
    ENG109533,Torque_distribution_Emaschine_combustion_engine_driver_request,0.0, Nm
    ENG01785-ENG104207,Transmission_state_of_drivetrain_coordinator-Bit 0,4,
    ENG01785-ENG101796,Transmission_state_of_drivetrain_coordinator-Bit 8,0,
    ENG109626,TS t Clnt Eng Out,75.7, C
    ENG111604,Turbocharger_inlet_pressure_corrected_value,998.13, hPa
    ENG119911,UEGO r Lam S1 B1,0.9932,
    ENG27251,UEGO r Lam S1 B2,0.0000,
    ENG109861,Vehicle speed,0.00, km/h
    ENG01774,Velocity_limiter_setpoint,511.992, km/h
    ENG27262,Virtual_SigXSet_SyC_tiPostDrv,0, s
    ENG27263,Virtual_SigXSet_TiEngOff_tiDiagRef,1054, s
    ENG27264,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,6196, s
    ENG27265,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8693804, s
    ENG27266,Virtual_SigXSet_TiOff_tiStrtEnd_Off,1611, s
    Elapsed Time: 01:26
    Jun 2017
    A quick way of changing the engine/suspension/steering settings without changing the coding is to personalize the Drive select,
    this can be done by selecting individual in the 'drive select' options.
    You should be able to select engine and choose between 3 options Comfort, Auto and Dynamic,
    with Dynamic selected the exhaust valves should stay open for as long as 'individual' is selected.
    Hope this information helps.
  3. Likes Uwe liked this post
    Jun 2017
    Thanks for the advice, I've been using the individual settings from the get-go. The only problem is the valves don't always stay open and you have to leave the trans in sport mode.
    Nov 2017
    I would like to bring this back up to the top and hopefully get some suggestions. I have been spending some time trying to figure out where the coding is for the exhaust valves. I have a 2018 S5 Sportback and currently have the valves unplugged because it drives me nuts not knowing what they are doing.
    -Eli
    Nov 2017
    I am going to try to do some more mapping tonight. I wonder if bit 9 byte 2 still has something to do with it? I am on a mission and I really want to figure this out.
    -Eli
    Nov 2016
    Mexico
    Did you ever found out?
    Nov 2017
    I have not. I can make them open and close by running a test though....
