Hi
I know audis can show google earth in the digital dashboard. Is there any way to do it on a VW also??
Monday,05,June,2017,10:09:20:26173
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
VIN: WVWZZZAUZHW389511 License Plate: KJ30802
Mileage: 649km-403mi Repair Order:
Chassis Type AU (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
5F A5 A9
VIN: WVWZZZAUZHW389511 Mileage: 649km-403miles
Address 01: Engine (J623-DJHA) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 092500122466050B3004
ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
ROD: EV_ECM20TFS0208V0906259J.rod
VCID: 479D110BFECBC97F8D-8012
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0GC 300 011 M HW: 0GC 927 711 G
Component: GSG DQ381 H06 0707
Revision: 00H06V07
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061_VW37.rod
VCID: 2C574EA7476D0A2780-8078
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 61247000000890
Coding: 01FA6BA154282175477C070140C46980D62A84E2E0029677384250F8C2A8430000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 77FDA1CBCEAB79FF3D-8022
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0441543000
Coding: 032C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3B757DFBB2039D9F19-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420041001110500020010102A
VCID: 6DD183A3BCF7C32FD7-8038
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001713201143
ROD: EV_BCMBOSCH_017_VW27.rod
VCID: 7EF3B4EFE19148B77E-802A
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170411 043 0551
Serial number: 170427225740
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y17M05D10H23M03S16
Coding: 00A8EE
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY171142RHY
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000069260223
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617132
Coding: 0471155011
ASAM Dataset: EV_EPHVA18AU3700000 009031
VCID: 4A9B283FEDD9341792-801E
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0620
Coding: 330067C15DFFC728949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
VCID: 3C777EE7B70D9AA710-8068
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 13041741350627
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 387F62F78335B687F4-806C
Part No SW: 5Q0 959 655 AS HW: 5Q0 959 655 AS
Component: AirbagVW21 003 0318
Serial number: 003TMR2XXWGP
Coding: 98FCC0C0000000005C5400CF000800000065
VCID: 1129FF53C00F47CF93-8044
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169667E10051750583
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169668E09051751077
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 005 17
Serial number: 3570000000065799342H
Subsystem 4 - Part No SW: ----------- HW: 480 000 905 17
Serial number: 3580000000052795D32J
Subsystem 5 - Part No SW: ----------- HW: 480 400 905 17
Serial number: 3510001C325C67B5E3BF
Subsystem 6 - Part No SW: ----------- HW: 480 400 905 17
Serial number: 3520001A32537344A1DX
Subsystem 7 - Part No SW: ----------- HW: 480 400 805 17
Component: FrontSensor_D 000 6149
Serial number: 3550001A7253734174AY
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 07051708490686
Coding: 0C10
VCID: 0919D733A85F7F0F5B-805C
Part No SW: 5G1 920 791 HW: 5G1 920 791
Component: KOMBI 409 2180
Coding: 07AD30187F8C000801886B0B5400000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 69D9F7B3881FDF0FBB-803C
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 47
Mileage: 82 km
Date: 2017.06.02
Time: 19:59:50
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 29041710803250
Coding: 030100047F085900FB00827E9C0F00010001050000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F6D59AB767B713FA5-807A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 39170001104990107173
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 3792483804
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00028.03.17
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000115986009
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 346756C79F5D52E7D8-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0437404495
Coding: 02011103
ROD: EV_HREntryHella_VW32.rod
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 270417EDQ34564
Coding: 003F1220D000048000001000
VCID: 4385051BCAF3E55F51-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000014394836
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9107
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A7B78FFBD39A49702-806E
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1HBA03JT0G
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI_VW37.rod
Component: TSG BFS 020 0041
Serial number: 020517EE210861
Coding: 003F1020DE00048000801000
VCID: 428B001FD5E9EC575A-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000014493310
Coding: 090000
Part No SW: 5NA 035 020 HW: 5NA 035 020
Component: MU-H-ND-EU H51 1077
Serial number: A845E0HB006283
Coding: 027310010000000041110102008808231F0107F4012004009E
VCID: 6ED384AFB1F13837EE-803A
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9120
Serial number: VWZ6ZHT1330874
Subsystem 2 - Part No SW: V03 959 800 QQ HW: -----------
Component: ECE 2017 --- 0157
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1015
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 11051711P20330
Coding: 0003070000000401002623548050A90098000E300040
ROD: EV_MFKBoschMQBB_VW36.rod
1275 - Camera Interference
C1104 00 [024] - -
Intermittent - Confirmed - Not Tested Since Memory Clear
Reset counter: 9
Mileage: 620 km
Date: 2017.06.04
Time: 23:15:37
Control Module temperature: 35 �C
Outside air temperature: 13.5 �C
Vehicle speed: 31.76 km/h
System run time: 3535.8 s (second)
Voltage terminal 15: 14.4 V
mid: 01 62
Camera_state: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 170407201063
ROD: EV_SoundActuaGen2AU64X_VW26.rod
End-------------------------(Elapsed Time: 05:30)--------------------------
