Results 1 to 4 of 4
Thread: 2011 vw jetta 2.0 severe lack of power at medium to high rpm
    Mar 2017
    Runs fine at idle.
    When accelerating unable to shift past 2nd if floored unless its done manually
    can continue to shift up manually but AT seemingly wont hit shift points at higher rpm.
    cant even redline in 2nd
    long term fuel trim goes more than 10 percent negative when floored for a while
    noticable surging when floored
    what i've done:
    sparkplugs ( pulled and replaced even though they looked good)
    fuel filter replaced
    air filter replaced
    tersted fuel rail pressure and seems fine with no dips, but tool i have is suspect, also maintains pressure so at least when off.
    exact same performance issues
    completely stock car.
    Saturday,17,June,2017,18:31:39:54294
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
    VIN: 3VW2K7AJ2BM329783   License Plate:
    Chassis Type: AJ (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 56
    VIN: 3VW2K7AJ2BM329783   Mileage: 85080km-52866miles
    Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
       Part No SW: 06G 906 055 C    HW: 06G 906 055 B
       Component: 2.0l /85 KW      01 1110
       Revision: T5H04---    Serial number:
       Coding: 0001015
       Shop #: WSC 03234 444 125919
       VCID: 290CF49415F4632F5A7-807C
                   P0300 - 000 -  - Intermittent
                        Mileage: 85070 km
                        Date: 2011.11.08
                        Time: 03:53:13
                        RPM: 4344 /min
                        Load: 99.6 %
                        Speed: 33.0 km/h
                        Temperature: 81.0C
                        Temperature: 50.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.462 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent
                        Mileage: 85070 km
                        Date: 2011.11.08
                        Time: 03:53:13
                        RPM: 4344 /min
                        Load: 99.6 %
                        Speed: 33.0 km/h
                        Temperature: 81.0C
                        Temperature: 50.0C
                        Voltage: 13.462 V
    001056 - Catalyst System; Bank 1
                   P0420 - 000 - Efficiency Below Threshold
                        Mileage: 85076 km
                        Date: 2011.11.08
                        Time: 05:24:47
                        RPM: 1908 /min
                        Load: 36.8 %
                        Temperature: 89.0C
                        Temperature: 51.0C
                        Voltage: 13.589 V
    Readiness: 0000 0101
       Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
       Component: AQ 250 6F           1791
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 7F580ACCBBF03D9F543-802A
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: B14B240C512408038D1224EC8A1C1061A70000
       VCID: 74B2D5E08EB66EC7391-8020
       Part No SW: 5C0 820 047 M    HW: 5C0 820 047 M
       Component: J301  Klimaanlage   0103
       Revision: 2000908S    Serial number: 00000000122757
       VCID: 2A0E0B9810F2683753D-807E
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0226
       Revision: B2066001    Serial number: 03311293100042
       Coding: 7B994B1808A30B0000302000240884D40042502E60000000300000000000
       VCID: 2D0400842D1C7F0FB6F-8078
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3463
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3463
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3463
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3463
       Coding: 800000
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   012 0805
       Serial number: 003END08JYUF
       Coding: 00003232
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FB8DA8CE7104D1FC43-803A
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1000001DF502
       Coding: 303148
       Serial number: 3572MSME16664556ZZZW
       Serial number: 3582MSME3E461157ZZZZ
       Component: S.Sens.Fahr.H  H01 ----
       Serial number: 3516KSME581D070DZZZ-
       Component: S.Sens.Beif.H  H01 ----
       Serial number: 3526KSME3415060DZZZM
       Component: F.Sens.Fahr  H01 ----
       Serial number: 3556LSME2208010DZZZK
       Component: F.Sens.Beif  H01 ----
       Serial number: 3566LSME3508010DZZZP
       Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
       Component: KOMBI         H07 0406
       Coding: 270201
       Shop #: WSC 00066 000 00150
       VCID: 2B000E9C1388713FA8B-807E
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 0226
       Coding: 102200
       VCID: 70BAD9F0FAAE52E7DD9-8024
       Component: IMMO          H07 0406
       VCID: 6A8ECB98DCF2A83793D-803E
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 164 A    HW: 1K0 035 164 A
       Component: LOW NAR       H13 0042
       Revision: -----05S    Serial number: VWZ4Z6K3049233
       Coding: 0500040001
       VCID: 201AE9B06ACEA2670D9-8074
    End----------(Elapsed Time: 00:58, VBatt start/end: 13.6V/13.7V)-----------
    Component: 2.0l /85 KW 01 1110 <<<<<<<<<<<<<<<<<<<<<<<< Needs firmware update 1313 or higher!
    You better fix those misfires..........and change that CAT that's already wiped out and restricted!
    Since it's under 8/80 shove it right up the OEM's ass........under warranty.
    Unless of course it's been modified FOD?
    Are you down with JPPSG ?
  3. Likes davenport.jacob, Ashraf6119 liked this post
    Mar 2017
    Thank you for the information on the 8/80k, I had no idea that was even a thing. With that in mind, it sounds like warranty work on the cat might fix my power issue to a large degree. Everything is stock, so that should be easy and I don't see any obvious physical damage.
    On the misfire front, I noticed a small crack in the spark plug wire where the metal boot meets the rubber, it seems like that could potentially be a culprit. Because the fuel rail stayed pressurized, I don't suspect a stuck open injector and I didn't see gas on the plug when I pulled it, so I'm hoping for weak spark.
    Does that make sense at least conceptually, or am I going down the wrong path?
    I wish I had an O-scope to see what is going on with the injector and the spark, but I am without either right now. And with the ltft going so negative, the o2 sensor at least thinks something isn't burning right. I would expect a maf problem to be more widespread.
    Doubt it........
    I'd start with an affordable compression check and swap parts to isolate.
    Scope isn't needed to determine a misfire.
