Results 1 to 5 of 5
Thread: Audi Q7 Fault Code 02126 (2013 Q7)
    Jun 2017
    Does anyone have any suggestions on a fault code 02126?
    Saturday,17,June,2017,06:35:09:13648
    VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
    VIN: WA1VMAFE2DD008287   License Plate:
    Mileage: 87440km-54332mi   Repair Order:
    Chassis Type: FE (4F0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
              52 55 56 5F 62 69 6C 6D 6F 72
    VIN: WA1VMAFE2DD008287   Mileage: 87440km-54332miles
    Address 01: Engine (J623-CNRB)       Labels: 059-907-401-V2.clb
       Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
       Component: 3.0TDI EDC17  H21 0004
       Revision: 54H21---    Serial number:
       Coding: 2A2A4012257600050000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L2910401A 001005
       ROD: EV_ECM30TDI0114L2910401A.rod
       VCID: 22082F4D35FAA151DF-8076
    Readiness: 0 0 0 1 1
    Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
       Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
       Component: AL1000 AISIN  001 2222
       Coding: 001378
       Shop #: WSC 29122 001 1048576
       ASAM Dataset: EV_TCMAL991031 002114
       ROD: EV_TCMAL991031_002.rod
       VCID: 7BB63229F2D03099BC-802E
    Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
       Revision: 00H02001
       Coding: 0623713
       VCID: 3424D915570E3FE13D-8060
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702023215
       Coding: 0000135
       VCID: 25023451ECD45669BA-8070
       Component: FBSAUDIC6 EZS   H04 0020
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
       Revision: 00---031    Serial number: 00000030261392
       Coding: 0304A036
       VCID: 250234512CD45669BA-8070
       Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0040050511
       Coding: 070000
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0139123
       VCID: 6E900B7D79A255310B-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels: 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961230400253
       Coding: 29011E
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3424D9159F0E3FE13D-8060
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4L0 910 561 A    HW: 4L0 907 561
       Component: ABSTANDSREGELUNGH07 0160
       Coding: 0031111
       VCID: 271E3E5996D8447988-8072
       Component: 73 AIRBAG AUDI8RH43 0230
       Revision: 07H43000    Serial number: 0038QD0A9F75
       Coding: 0014131
       VCID: 2B16C2698A3060196C-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME2F22196EQ
       Subsystem 3 - Serial number: 6342QSME3022434C6
       Subsystem 4 - Serial number: 6352QSME251A30468
       Subsystem 5 - Serial number: 6362QSME302230761
       Subsystem 6 - Serial number: 63734SME6D19316C9
       Subsystem 7 - Serial number: 63834SME6C221F76A
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
       Component: J0527               0830
       Revision: 00H08000    Serial number: 90026121560193
       Coding: 0012252
       VCID: 281C3D659BC64B0181-807C
       Component: E0221           H03 0040
    Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 985 G    HW: 4L0 920 985 G
       Component: KOMBIINSTR.   H35 0316
       Revision: 00000000    Serial number: NGF50YNAD
       Coding: 8BD664040D00CF05020205
       VCID: 383CED258B66DB8111-806C
    Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB700037    Serial number: 3700M12A060050
       Coding: 00C303
       VCID: 3FCE8639AE48ECB9D0-806A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790490620
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
       Revision: 00---011    Serial number: 00000000351732
       Coding: 0000006
       VCID: 689C7D655B468B0141-803C
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000041891140
       Coding: 00581B00000011110000
       VCID: 3228DF0D6D1A31D12F-8066
       Component: J0769_SWA_MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 009 014-10
       Coding: 0010001
       VCID: 2E10CB7DB92215314B-807A
       Component: J0770_SWA_Slave_H02 0050
       Subsystem 3 - Serial number: 5F12.10.1200H02000AMS15367
       Subsystem 4 - Serial number: S15367
    Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000043618742
       Coding: 011F57205E40440004
       VCID: 48DC9DE5FB86AB0161-801C
    Address 46: Central Conv.        Labels: 4L0-910-289.lbl
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01863593750000
       Coding: 3569949
       VCID: 383CED254B66DB8111-806C
       Part No SW: 4L0 035 466 A    HW: 4L0 035 466 A
       Component: BO Q7         H30 0110
       Revision: 07S00000    Serial number: 01907120007145
       Coding: 0D000001
       VCID: 291A386140CC72099E-807C
       Subsystem 1 - Part No SW: 4L0 910 465 A    HW: 4L0 035 465
       Component: BO Q7 SLAVE  H41 0780
       Serial number: 01109120020323
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005190058721
       Coding: 0758477
       VCID: 23062A49E2E0A859D4-8076
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000126225
       Coding: 0012001
       VCID: 5EF05BBD8902C5B1BB-800A
    Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000043373390
       VCID: 47DE9ED9F698A47968-8012
                        Reset counter: 187
                        Mileage: 87440 km
                        Date: 2017.06.17
                        Time: 06:28:22
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000031
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Part No SW: 4G0 035 082 E    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 156JB0C7659908
       Coding: 020007010000000000
       VCID: 22082F4D3DFAA151DF-8076
       Part No SW: 4L2 035 746 C    HW: 4L2 035 746 A
       Component: H-BNT-NA      H44 0624
       Revision: --------    Serial number: 224J.0C7509316
       Coding: 180200060004EBEF710003456F632003140000000100000000
       VCID: 2E10CB7D792215314B-807A
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H41 0104
       Serial number: A130JV0C2573228
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002045006
       Component: CD-Database  4949
    Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000043516216
       Coding: 010E57204040230004
       VCID: 46C093DDF192BD7193-8012
    Address 69: Trailer (J345)       Labels: 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Component: Anhaenger     H12 0100
       Revision: 2A001001    Serial number: 00000375155939
       Coding: 0200000000000000
       VCID: 312AD001681C0AC956-8064
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 4L0 907 428     HW: 7P6 907 441 D
       Component: TopView       H05 0293
       Revision: 11001001    Serial number: 82330JF0059308
       Coding: 020C010001000100010102000000
       ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
       ROD: EV_CamSysteCorneViewAUDI.rod
       VCID: 6E900B7DB1A255310B-803A
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C9401754FBEA72125-8038
       Subsystem 2 - Serial number: )
       Subsystem 3 - Serial number: RD26.10.12--H57001002E0258
       Subsystem 4 - Serial number: 2E0258
    Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 130086127-----
       Coding: 0003595
       VCID: 2600335D91D25D71B3-8072
       Component: J_245_EE16_SKB10H12 0220
       Component: J_394_EE16_SKB10H12 0220
       Component: J_392_EE16_SKB10H12 0220
    Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000043516131
    End----------(Elapsed Time: 02:05, VBatt start/end: 12.2V/12.2V)-----------
    Any functional problems with the controls or actuators in the passenger door?
    Jun 2017
    I have not noticed anything. Doors/Locks/Window work fine. Anything else I should check?
    Thanks!
    Matt
    Clear the dtc or ignore it
    European Parts Emporium/Performance / Immobilizer Solutions LLC
    Jun 2017
    I've tried clearing the DTC... always comes back. I'll ignore it.
    Thanks,
    Matt
