Greetings all. I have a 2014 JSW (built 2/14). I replaced the OEM RCD 510 with a RNS 510 version N radio/GPS (built 9/14) that came out of a 2015 Passat .
After installation, I had some minor issues but cleared those up with VCDS, these forums, and removing the compass module.
I was finally able to clear the can gateway fault code.
I still have the fault codes for the #37 navigation mode for control module and microphone for radio.
I think the microphone issue needs a hard wire connection but what code should the #37 control module be using? I haven't found it yet.
I ran the full scan but only post the pertinent info here (no other fault codes reported).
Any input or feedback greatly appreciated.
Friday,16,June,2017,21:32:05:25028
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: 3VWML7AJ6EM620622 License Plate:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: 3VWML7AJ6EM620622 Mileage: 86550km-53779miles
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 24041403000976
Coding: 352002
Shop #: WSC 00066 123 12345
VCID: 79ACE413B9DF4E8F6A7-802C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 N HW: 3C0 035 684 N
Component: RNS-MID H26 5378
Revision: AB001001 Serial number: VWZ6Z7P3269019
Coding: 0400004201000010000B
Shop #: WSC 09003 957 00200
VCID: 2E06074F301159378F5-807A
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V8 8112
Reset counter: 162
Mileage: 86544 km
01523 - Microphone for Telephone (R38)
Reset counter: 162
Mileage: 86550 km
Date: 2017.06.16
Time: 20:45:26
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Fault Frequency: 9
Reset counter: 162
Mileage: 86544 km
Reset counter: 162
Mileage: 86550 km
Date: 2017.06.16
Time: 20:45:26
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665901500
Coding: 0A10030080010110
Shop #: WSC 01383 790 50316
ROD: EV_UHVUMI.rod
VCID: 2E06074F309159378F5-807A
End----------(Elapsed Time: 01:10, VBatt start/end: 12.3V/12.3V)-----------
