Results 1 to 8 of 8
Thread: VCDS 16.8.3 GOLF 6
    Pirate
    Jun 2017
    Romania
    VCDS 16.8.3 GOLF 6
    Hello !
    Good to be here, this is my first thread, I've read alot of threads about this problem, but it seems I have both of them:
    I own a 2011 1.6 TDI Golf MK6.
    Hooked the VAGCOM Cable with the VCDS 16.8.3 from a friend, detected, fine no problem, but I wanted to see the injectors values so my friend has a passat (no problem with the vcds) he told me to go to : Engine -> Measuring Blocks, but it seems Measuring Blocks is grayed (unavailable), then he told me, "no problem, your car is newer so you have to go to Advance Measuring", but it seems that Advance Measuring is grayed out too (unavailable).
    How can I measure the injector values, what could the problem be ?
    Thank you
    Oct 2014
    Arandjelovac, Serbia
    Hello !
    Post an Auto Scan, please.
  3. Likes Ashraf6119, Uwe liked this post
    And please use the current version!
  5. Likes PetrolDave, Ashraf6119, Boki Ar liked this post
  6. #4
    Pirate
    Jun 2017
    Romania
    Removed.   Data from pirate copies of VCDS is not welcome here.
    Pirate
    Jun 2017
    Romania
    Its interesting that I can acces measure blocks to other options, but i cant acces it in Engine Management and a popup file comes out : missing rod file
    Quote Originally Posted by Buki222 View Post
    As already said please use the latest version, not an out-of-date version of VCDS.
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    The latest version of VCDS is available to download at the bottom of the following web page. Simply download and install that newer version, then post a new Auto-Scan...
    http://www.ross-tech.com/vcds/download/current.php
  10. #8
    Legitimate VCDS systems are available directly from us,
    ... or from any of our authorized distributors.
  11. Likes Jack@European_Parts liked this post
