Results 1 to 4 of 4
Thread: Various Databus Messages
    Northern Ireland
    Have had these various databus messages for sometime, would like to eradicate most if possible, any guidance welcomed!
    Friday,16,June,2017,18:37:11:49196
    VCDS Version: 17.1.3.0 (x64)
    Workshop Code: 874 00874 000874
    VIN: WVWZZZ3CZGxxxxxxx   License Plate: DATABUS
    Mileage: 19036km-11828mi   Repair Order:
    Chassis Type: 3C (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 42 44 52 55 5F
              6C BB BC
    VIN: WVWZZZ3CZGxxxxxxx   Mileage: 19036km-11828miles
    Address 01: Engine (J623-CUAA)       Labels: 03N-906-026-CUA.clb
       Part No SW: 03N 906 026 E    HW: 03N 907 309
       Component: R4 2,0L EDC   H23 1754
       Revision: A1H23---
       Coding: 01250012036705083000
       Shop #: WSC 05311 115 00300
       ASAM Dataset: EV_ECM20BTD01103N906026E 001002
       ROD: EV_ECM20BTD01103N906026E.rod
       VCID: 2D55717A7CD1122972-8078
    17156 - Databus
                        Mileage: 17619 km
                        Date: 2017.05.31
                        Time: 17:19:34
                        Coolant temperature: 51 C
                        Intake air temperature: 46 C
                        Voltage terminal 30: 12.040 V
                        Unlearning counter according OBD: 6
                        Drivetrain coordinator: ACC fault status-Bit 0: 0
                        Drivetrain coordinator: ACC fault status-Bit 8: 0
                        Drivetrain coordinator: brake fault status-Bit 0: 1
                        Drivetrain coordinator: brake function status-Bit 0: 0
                        Drivetrain coordinator: brake function status-Bit 8: 24
                        Acceleration: 0.000 m/s
    Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
       Part No SW: 0DL 300 011 H    HW: 0BH 927 711 F
       Component: GSG DQ500     H10 5201
       Revision: 00H10V01
       ROD: EV_TCMDQ500021_VW41.rod
       Revision: 00000000    Serial number: 62615000001225
       Coding: 0EEC938F54280B6E077E070841C46970C92AD0E0E08296F5186250F8C209
       Shop #: WSC 12345 111 12345
       ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
       VCID: 7AFF8A26FD1F7591A7-802E
    8277 - Databus
              U1122 00 [009] - Implausible Message
                        Reset counter: 201
                        Date: 2017.05.19
                        Time: 17:39:25
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0380968757
       Coding: 000F0F0703
       ASAM Dataset: EV_KessyHellaMQBAB 004032
       VCID: 397D552AB899BE89EE-806C
       Part No SW: 5G2 907 044     HW: 5G2 907 044
       Revision: 00001K10
       Coding: 11120104202100011015504C0010180A
       Shop #: WSC 00015 115 00001
       ROD: EV_ACClimaBHBVW37X_004_VW48.rod
       VCID: 66C7CE5699A7E17173-8032
              P1719 00 [008] - -
                        Reset counter: 28
                        Mileage: 18373 km
                        Date: 2017.06.10
                        Time: 20:17:38
                        Voltage terminal 30: 14.2 V
                        Auxiliary heater: in stages-Act.value: 1
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580309150065
       Coding: 03011C46C2C102FF07804094B11807281880000000000000000000000000
       Shop #: WSC 00874 874 00874
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 0301F7C28AD53459F4-8056
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    150727  043 0607
       Serial number:         150820165011
       Coding: 0E4DFD
       Component: RLHS  037 0059
       Serial number: S2Y15M09D23H21M17S56
       Coding: 90A8DD
       Light switch:
       Serial number: 11 06 2015  10001099
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY152170WU6
       Serial number: 00000000000063683899
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391526001331
       Coding: 0071151811
       VCID: 448334DECF5BF3618D-8010
    Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200678251FFC428949C804D
       Shop #: WSC 05311 115 00090
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3463641E9FFB43E13D-8060
    2102 - Databus
                        Reset counter: 8
                        Mileage: 17619 km
                        Date: 2017.05.31
                        Time: 17:19:33
                        Control Module temperature: 25 C
                        Voltage terminal 15: 12.0 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s
    0836 - Databus
                        Reset counter: 43
                        Mileage: 16542 km
                        Date: 2017.05.19
                        Time: 17:39:24
                        Control Module temperature: 47 C
                        Voltage terminal 15: 14.1 V
    0928 - Databus
                        Reset counter: 8
                        Mileage: 17619 km
                        Date: 2017.05.31
                        Time: 17:19:33
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 19091541350191
       ROD: EV_DRCONTITEMIC.rod
       VCID: 377953128E8DA8F918-8062
       Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003SSPJF5JS+
       Coding: 98FCC0C0008000005C5400CC008800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7EF78636E13759B19B-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G2857705E0261P00127
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G2857706E0260P01251
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 000 609 15
       Serial number: 3576U0000001C969661F
       Subsystem 4 - Part No SW: -----------    HW: 454 000 609 15
       Serial number: 3586U0000006D969661M
       Subsystem 5 - Part No SW: -----------    HW: 454 800 609 15
       Serial number: 3516R78332908000000$
       Subsystem 6 - Part No SW: -----------    HW: 454 800 909 15
       Serial number: 3526R5E0B61080000002
       Subsystem 7 - Part No SW: -----------    HW: 454 803 108 15
       Serial number: 3556V386625080000002
       Part No SW: 3Q0 953 521 AL    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0185
       Revision: FF033033    Serial number: 20140801500212
       Coding: 8010
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH.rod
       Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
       Component: KOMBI         411 1340
       Coding: 27A50018BF80AE0001867F011000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009048
       VCID: 275983525E2D387988-8072
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2227
       Revision: --------    Serial number: 16091510800242
       Coding: 030300045F017300FB00025E9C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 75E5991AD4011AE9CA-8020
       Serial number: 29160000688370046133
       Coding: 2FFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 6808707503
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 0308201500010237
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00028.07.15
       Coding: 0301
       Shop #: WSC 00015 115 08193
       VCID: 4A9F1AE6ED7F251177-801E
       Serial number: 15000073687012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71EDAD0AA06936C916-8024
       Serial number: 140915BIC20916
       Coding: 001F0A20D001028000001000
       VCID: 438137C2CA55F459B4-8016
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 0002
       Shop #: WSC 00015 115 00300
       ROD: EV_SteerAssisMQB_VW31.rod
       Serial number: 100915BIA01933
       Coding: 001F0020D001028000001000
       VCID: 428F32C6D54FFD51BF-8016
       Coding: 03A602000F200200
       Shop #: WSC 05311 000 08193
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3F893B32A6BD90B9D0-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0627
       Coding: 02840101FF00000051111101008808001F0100D601200100CF
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 306B680E6BE37FC159-8064
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9R2580238
       Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
       Component: ECE1 2017  --- 0730
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-980-556.clb
       Part No SW: 5Q0 980 568     HW: 5Q0 980 568
       Component: RVC Compact+  H03 0100
       Coding: 01000101E2002017000048
       ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
       ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW48.rod
    13705497 - Databus
                        Reset counter: 201
                        Mileage: 16542 km
                        Date: 2017.05.19
                        Time: 17:39:24
                        ARA_error_bits: 0
                        ARA_function_operating_time: 0.0000 s
                        Poor_image_quality_reason: Environmental conditions
                        Poor_image_quality_reason: 0.0000
                        Camera_System_Operating_Condition: passive
    13705498 - Databus
                        Reset counter: 201
                        Mileage: 16542 km
                        Date: 2017.05.19
                        Time: 17:39:24
                        ARA_error_bits: 0
    Address BB: Door Rear Drv (J388)       Labels: None
       Serial number: 270815BHR05229
       Coding: 000E00200101028000001000
       VCID: 458529DAC461CA699A-8010
    Address BC: Door Rear Pass (J389)       Labels: None
       Serial number: 270815BHR0522B
    End-------------------------(Elapsed Time: 05:35)--------------------------
    Have you made any changes to this car's factory configuration?
  3. Likes Ashraf6119 liked this post
    Northern Ireland
    Only the rear view camera and added the Virtual Cockpit dashboard however everything apart from the DTCs in 6C were present before both were installed.
    Spurious databus message faults seem to be a fact of life in the current generation of cars. Although they can certainly be brought on by tweaks retrofits, if they were there when the car was in factory stock configuration, I'm afraid I have no advice.
  6. Likes drennie599 liked this post
