- May 27, 2017
- 3,334
- 2,083
- Finland
- C?ID=280813
I finalized Seat Sound System retrofit last week by re-parametrizing the MIB unit.
Only one thing that is missing, the start screen still only shows Seat EasyConnect but no SoundSystem. Is there any way to change the start screen to show the soundsystem?
I know it should be possible as I've seen some Russian guys retrofit screen which read SoundSystem in the startup.
Thanks for any tips.
Here's my autoscan:
Here's my autoscan:
Monday,12,June,2017,12:32:21:18632
VCDS Version: 17.1.3.0
Dealer/Shop Name: Chop shop
VIN: VSSZZZ5FZDR039344 License Plate: OTV-910
Mileage: 107093km-66544mi Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: VSSZZZ5FZDR039344 Mileage: 107093km-66544miles
Address 01: Engine (J623-CJZA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 A HW: 04E 907 309 A
Component: 1.2l R4 TSI H08 5541
Revision: WAH08---
Coding: 01250032232401080000
Shop #: WSC 00049 770 00125
ASAM Dataset: EV_ECM12TFS01104E906016A 001006
ROD: EV_ECM12TFS01104E906016A_AU37.rod
VCID: 20766ECA3B8B2B41C9-8074
Part No SW: 0CW 300 044 T HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4512
Revision: 00043014 Serial number: CU501303286885
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021.rod
VCID: 49A0D36EE8F1CA097E-801C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 A HW: 5Q0 907 379 A
Component: ESC H75 0333
Revision: 00000000 Serial number:
Coding: 20EE6A9220231275007A060401C7240456044800608024F200295020C0
Shop #: WSC 00049 770 00104
ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
ROD: EV_Brake1UDSContiMK100ESP_008.rod
VCID: 3A42BCA2BD175191E7-806E
0070 - Rear Left Wheel Speed Sensor
C101C 29 [008] - Signal Implausible
Reset counter: 69
Mileage: 106682 km
Date: 2017.06.10
Time: 17:15:12
0086 - Rear Right Wheel Speed Sensor
C101D 29 [008] - Signal Implausible
Reset counter: 69
Mileage: 106682 km
Date: 2017.06.10
Time: 17:15:12
Part No SW: 5F0 907 044 A HW: 5F0 907 044 A
Component: Climatronic H02 0503
Revision: 00001K05
Coding: 00000004200100011105004000101000
Shop #: WSC 12345 123 12345
ROD: EV_ACClimaBHBVW37X_002.rod
VCID: 247E62DA2F933761AD-8070
Air quality sensor:
327940 - Motor for Left Temperature Flap
B108C 71 [008] - Actuator stuck
Reset counter: 107
Mileage: 106677 km
Date: 2017.06.10
Time: 16:47:10
Voltage terminal 30: 12.2 V
Outside air temperature: 17.0 °C
Interior temperature: 29.3 °C
Left temperature flap - actual value: 85
Left temperature flap - actual value: 27.0 %
Left temperature flap - specified value: 25
328196 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Reset counter: 107
Mileage: 106680 km
Date: 2017.06.10
Time: 16:54:12
Voltage terminal 30: 11.6 V
Outside air temperature: 18.0 °C
Interior temperature: 28.5 °C
Right temperature flap: actual value: 74
Right temperature flap: actual value: 24.0 %
Right temperature flap: specified value: 48
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011308700426
Coding: 08001946C2C102FB4BE44000401C07081008000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 46BAD852F9EF257193-8012
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130318 041 0574
Serial number: 130326035958
Coding: 0BC5FD
Component: RLFS 024 0042
Serial number: Y13M04D06H03M24S39S2
Coding: 00885D
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231308202247
Coding: 0031051011
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000_VW37.rod
Part No SW: 3Q0 959 655 R HW: 3Q0 959 655 R
Component: Airbag VW20 011 0186
Revision: -------- Serial number: 003NPP5V7JX%
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 4DA8E77E1C99D62952-8018
Subsystem 1 - Part No SW: ----------- HW: 454 001 603 13
Serial number: 3576U0000009B1343C08
Subsystem 2 - Part No SW: ----------- HW: 454 002 403 13
Serial number: 3586U000000A76243C0A
Subsystem 3 - Part No SW: ----------- HW: 454 801 403 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R2A107300000000M
Subsystem 4 - Part No SW: ----------- HW: 454 801 403 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R84A42100000000T
Subsystem 5 - Part No SW: ----------- HW: 454 801 302 13
Component: FrontSensor_D 114 0149
Serial number: 3556V76EAD400000000I
Part No SW: 5Q0 953 507 AN HW: 5Q0 953 549 A
Revision: -------- Serial number: 04041304220068
Coding: AC00
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 023204429547D951FF-8056
Part No SW: 5F0 920 870 F HW: 5F0 920 870 F
Component: KOMBI 336 0556
Coding: 07A502086984000800087A02000000
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 2B6C89E6424DF8196C-807E
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 125 1109
Revision: -------- Serial number: 0000508532
Coding: 030100F42B086400EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 345E929A9F73A7E13D-8060
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0100
Serial number: 000000000A0645050313
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004050365332
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000057243659
Coding: 00100320DC00020000001000
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000151396
Coding: 310000
Coding: 11
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D48B7BEAC3966A9C2-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000056244561
VCID: 01300B4E9041C249E6-8054
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000131183
Coding: 290000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Component: LWR-ECU 005 0080
Coding: 048A000009000000
ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
VCID: 75D86F9ED489FEE9CA-8020
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 846 HW: 5F0 035 846
Component: MU-S-N-ER 039 0171
Serial number: E1F03103130409
Coding: 04731001FF0A000021110001000800002F0106040100010046
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE_VW37.rod
VCID: 65F83FDE64290E697A-8030
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H45 0020
Serial number: SEZ8Z9N5600CUK
Subsystem 2 - Part No SW: 5F0 919 866 C HW: -----------
Component: ECE 2013 --- 0021
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
Component: MQB_MFK H05 0050
Serial number: 00000039868
Coding: 0101010001000004000500000000000100
ROD: EV_MFKBoschAU370.rod
End-------------------------(Elapsed Time: 03:24)--------------------------
