Results 1 to 2 of 2
Thread: Engine codes but no MIL. MAF CAT O2 Audi S6 2007 5.2l
    Jun 2017
    I was just resetting some codes and enabling features on a lovely s6. Foolishly I didnt think to delve in further and get readings from the faulty components. but where to start?
    005495 - Right Engine Mount Solenoid Valve (N145)
                   P1577 - 004 - Open Circuit - Intermittent
    Mileage: 168322 km
    000104 - MAP/MAF <-> Throttle Position Correlation
                   P0068 - 002 -
    Mileage: 168322 km
    001056 - Catalyst System; Bank 1
                   P0420 - 002 - Efficiency Below Threshold - Intermittent
    Mileage: 169480 km
    000345 - Oxygen (Lambda) Sensor B2 S2
                   P0159 - 004 - Response too Slow - Intermittent
    Mileage: 169480 km
    004416 - Oxygen (Lambda) Sensor; B2 S2
                   P1140 - 008 - Internal Resistance too High - Intermittent
    Mileage: 169682 km
    The vehicle was purchased and serviced with 168322 Km I presume this is the milleage.
    Can someone please confirm that the freeze frame data is when the error first occurred?
    I see no "Tips" on the website for the o2 sensor Response too Slow . and presume P1140 - 008 - Internal Resistance too High is the same as 17522/P1114
    Does anybody else think it is strange that both solenoid and MAF should occur at the same time? Do you think t points to disturbed wiring whilst servicing it? I didnt check properly as time was of the essence.
    The fact that the majority are intermittent is what makes me wonder.
    Any thoughts on this and where to start would be appreciated.. Full log below:
    Wednesday,14,June,2017,15:23:23:17923
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 17.1.3.0
    VIN: WAUZZZ4F47N138957   License Plate:
    Mileage: 170230km-105776mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 11 31 15 16 17 19 1E 36 37 42 46 47
              4F 52 53 55 56 61 62 72 76 77
    VIN: WAUZZZ4F47N138957   Mileage: 170230km-105776miles
       Part No SW: 4F1 910 552 C    HW: 4F1 907 552
       Component: 5.2L V10/4V FSI    ª0060
       Revision: 59H14---    Serial number:
       Coding: 01050003190F0160
       Shop #: WSC 02335 785 00200
       VCID: 2446692AE79DFC61AD-8070
                        Fault Frequency: 242
                        Mileage: 168322 km
                        Date: 2017.03.02
                        Time: 17:03:59
                        RPM: 1287 /min
                        Load: 17.6 %
                        Temperature: 100.0°C
                        Temperature: 67.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.430 V
                   P0068 - 002 -
                        Mileage: 168322 km
                        Date: 2017.03.02
                        Time: 17:03:59
                   P0420 - 002 - Efficiency Below Threshold – Intermittent
                        Mileage: 169480 km
                        Date: 2017.04.18
                        Time: 11:57:23
                        RPM: 1381 /min
                        Load: 22.3 %
                        Speed: 49.0 km/h
                        Temperature: 34.0°C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 14.605 V
                        Mileage: 169480 km
                        Date: 2017.04.18
                        Time: 11:57:23
                        Mileage: 169682 km
                        Date: 2017.04.23
                        Time: 18:51:27
                        RPM: 1905 /min
                        Load: 16.9 %
                        Speed: 40.0 km/h
                        Temperature: 61.0°C
                        Temperature: 29.0°C
                        Voltage: 14.478 V
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0PDU5V
       Coding: 0013381
       Shop #: WSC 02325 785 00200
       VCID: 2958781E80BF21099E-807C
       Subsystem 1 - Serial number: 6332CSME4E1B541CD
       Subsystem 2 - Serial number: 6342CSME15405B1C1
       Subsystem 3 - Serial number: 6352QSME241341697
       Subsystem 4 - Serial number: 6362QSME233841638
       Subsystem 5 - Serial number: 63734SME2959083F9
       Subsystem 6 - Serial number: 63834SME21483E4D8
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
                014 - Defective - Intermittent - MIL ON
       Part No SW: 4F2 910 156 M    HW: 09E 927 156 C
       Component: AG6 09E 5,2 FSI RdW 0030
       Revision: --H01---    Serial number:        0102919
       VCID: 2F6C9606BE5B4F3940-807A
       Part No SW: 4F0 910 517 P    HW: 4F0 614 517 P
       Component: ESP 8.0 quattro H05 0070
       Coding: 0020920
       VCID: 3168907EA86F59C956-8064
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100711886
       Coding: 0000019
       Shop #: WSC 02323 785 00200
       VCID: 63C42A36A213BB5994-8036
       Subsystem 1 - Part No: 4F0 910 132 G
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F1 910 732 D    HW: 4E0 035 729
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 350CR077767523
       Coding: 0010002
       VCID: 2540742EECA70569BA-8070
       Subsystem 2 - Serial number: 00000000687215
       Subsystem 3 - Serial number: 0102.03.070000000100010296ÿ
       Subsystem 4 - Serial number: 010296ÿ
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 Q
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000000368239
       Coding: 0525322
       VCID: 1C3651CADFEDC4A115-8048
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Coding: 0015121
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R199)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H20 0850
       Revision: 00000000
       VCID: 2B5482164A4333196C-807E
    Address 11: Engine II        Labels: Redir Fail!
       Coding: 0013381
       Revision: 00H08000    Serial number: 90054070610178
       Coding: 0102141
       VCID: 66C233225121CE7173-8032
       Part No SW: 4F0 910 930 C    HW: 4F0 920 980 P
       Component: KOMBIINSTR. M73 H20 0170
       Revision: 00200000    Serial number: 5H235CW27
       Coding: 2113448
       Shop #: WSC 80093 222 69422
       VCID: 23446A36E293FB59D4-8076
    Address 19: CAN Gateway        Labels: 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 130080730102F4
       Coding: ECFEF3CC3B3104
       VCID: 275C7E2696AB177988-8072
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H44 0390
       Revision: 00044000    Serial number: AUZ5ZBG3177169
       VCID: 1A3A57D2D5D9BA9107-804E
       Coding: 0091138
       VCID: 61C8203EB80FA94986-8034
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 L
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 364CU077648262
       VCID: 3B74B2567A23A399FC-806E
       Component: TSG FA          H12 0120
       Revision: 00-00000
       Coding: 0002810
       Shop #: WSC 02327 785 00200
       VCID: 2C56810A8F4D342165-8078
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01036867280000
       Coding: 0139771
       VCID: 2E528B02B95146314B-807A
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H10 0240
       Revision: PROD_01     Serial number: 00000000018033
       Coding: 0000017
       Revision:             Serial number: 00000000408171
       Coding: 0011104
       VCID: 5EB21BC2897196B1BB-800A
       Component: TSG BF          H12 0120
       Revision: 00-00000
       Coding: 0002810
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0008021
       Shop #: WSC 02324 785 00200
       VCID: 204E653AF385E041C9-8074
       Coding: 0000016
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 394CV077747332
       Shop #: WSC 00443 210 91141
       Revision: 00000000    Serial number: 00000000164525
       Shop #: WSC 00443 210 10237
       Component: von VA0  2703053387
       Coding: 344630393135313035442056413032373033303533333837
       Shop #: WSC 00000 384 00290
       Coding: 0002090
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0002090
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06230705914249
       Coding: 0201106
       Shop #: WSC 65535 551 00000
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007664382
       Coding: 0010920
    End---------------------(Elapsed Time: 02:47, udsna)-----------------------
    Quote Originally Posted by champagnecharly View Post
    Yes, that's supposed to be the first occurrence of that stored fault. If Fault Frequency is greater than 1, then the fault has occurred since then.
  3. Likes champagnecharly liked this post
