Results 1 to 10 of 11
Thread: No Start first few tries then CEL
    Jul 2016
    Clear codes then good for a week or 2, then same codes.
    Sunday,21,May,2017,08:54:18:05068
    VCDS Version: 17.1.3.0
    Data version: 20170220 DS267.3
    VIN: WA1CFAFPXBA081666   License Plate:
    Mileage: 98390km-61136mi   Repair Order:
    Chassis Type: FP (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 69 72 77
    VIN: WA1CFAFPXBA081666   Mileage: 98390km-61136miles
    Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8R0 907 115 H    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0003
       Revision: E1H19---
       Coding: 0121010A290F0960
       Shop #: WSC 08315 444 11710
       ASAM Dataset: EV_ECM20TFS0118R0907115H 001006
       ROD: EV_ECM20TFS0118K2907115AD.rod
       VCID: 39732959B84A5E89EE-806C
              U1113 00 [032] - -
              U1113 00 [032] - -
    7021 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [109] - -
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:22
                        Engine speed: 974.50 /min
                        Normed load value: 11.4 %
                        Coolant temperature: 69 C
                        Intake air temperature: 47 C
                        Voltage terminal 30: 12.887 V
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 8R0 927 158 E    HW: 0BK 927 156 N
       Component: 0BK 20TFSIUSA H08 0010
       Revision: --H08---
       Coding: 001112
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL551211 001013
       ROD: EV_TCMAL551211_001.rod
       VCID: 3F874741A66E70B9D0-806A
    12551 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [032] - -
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
    12554 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [032] - -
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
    12562 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [168] - -
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
    Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
       Component: ESP8 quattro  H06 0110
       Coding: 129D10
       VCID: 458B55A9CCB22A699A-8010
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x000F
                        Hex Value: 0xB99B
                        Hex Value: 0x00FF
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
       Part No SW: 8K0 907 064 CR    HW: 8K0 907 064 CR
       Component: BCM2 2.0      H05 0435
       Coding: 090500
       VCID: 02018EB59D1CDD51FF-8056
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000008524012
       Serial number: 2310000105260015
                        Fault Status: 00101101
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01070220111270
       Coding: 64002000
       Shop #: WSC 06335 123 12345
       VCID: 000584BD9310CF41E9-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000937946
       Coding: 6F0020F1013CA7010000090300007F7F4F1C660802000161000000
       VCID: 3C7D304DBF786BA1F5-8068
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 110122  H11 0050
       Serial number: 90243014110114023324
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 11262475
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000102110032
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003GPD0N102/
       Coding: 303633313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 47975FA1FEBE387968-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R1100003Q67
       Serial number: 6334MSME5B160A70D
       Serial number: 6344MSME5B326267G
       Serial number: 6352QSME3C065460D
       Serial number: 6362QSME4701275EI
       Serial number: 63732SME3E04036E0
       Serial number: 63832SME6D0834461
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KAV00070
       Coding: 000017
       VCID: 3D7B3D49A46262A9C2-8068
       Component: E221 - MFL  H04 0010
    Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 950 K    HW: 8R0 920 950 K
       Component: KOMBIINSTR.   H12 0258
       Revision: 00000000    Serial number: EJU309Z1C
       Coding: 8B1F22000300D705020000
       VCID: 3E793A45A96479B1DB-806A
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:14
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G111298558
       Coding: 00C303
       VCID: 010381B9981AC649E6-8054
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650447274
                        Reset counter: 143
                        Mileage: 97755 km
                        Date: 2017.05.08
                        Time: 07:54:53
                        Bin. Bits:    00000
                        Voltage: 12.50 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000012178471
       Coding: 011D03204000440004
       VCID: 4A916695E5ACC51177-801E
       Revision: 00002001    Serial number: 0142687706
       Coding: 0126063A20FA440084B0053200000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000355928
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F6717017E0E803940-807A
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0004000216836
       VCID: 49935999E0AACE097E-801C
       Revision: 00000003    Serial number: 00000000857977
       VCID: 346D186D9728A3E13D-8060
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:14
                        Voltage: 12.40 V
                        Count: 64
                        Hex Value: 0x0260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H06 0351
       Revision: 00000009    Serial number: AUZ5Z6K1528606
       Coding: 0502000201058500C359070000
       VCID: 468952A5F1B4217193-8012
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000112754547
       Coding: 010C03204000240004
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Component: Anhaenger     H07 0070
       Revision: 1A001001    Serial number: 00000124854806
       Coding: 0200000000000000
       VCID: 366922658154B1F103-8062
                        Reset counter: 143
                        Mileage: 98394 km
                        Date: 2017.05.21
                        Time: 08:43:13
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000112754548
       Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005108703
       Coding: 0010370
       VCID: 3D7B3D49646262A9C2-8068
    End-------------------------(Elapsed Time: 03:19)--------------------------
    Address 01: DTCs cleared
    I am afraid it won't start at all eventually.
    Connectors or ECU on it's way out?
    Thanks!
    Check all connections for corrosion and especially check the chassis to engine/trans ground strap or enhance.
    In addition check connections with all shared modules such as the brake module.
    Check all terminal relays.........and ignition switch.
  3. Likes WtA3WtQ5, Uwe, Ashraf6119 liked this post
    No start.... no crank? Or cranks but doesn't fire? "No start" is a bit open ended. Is there a back story on this? Flood car? Crashed? Wonky audio system installed (or any sort of non factory hardware)? Does this happen on hot days? Cold days? When Trump says something brilliant (sarcasms meter is off line, this statement is open ended)?
    With what little info we have, I agree with Jack.... my first guess is a poor electrical/mechanical connection somewhere... poor ground, loose fuse, green rot on a terminal, ect.
    Jef
  5. Likes Jack@European_Parts, Uwe, Ashraf6119 liked this post
  6. #4
    OP you could benefit from the JPPSG process......please have a look.
    Jul 2016
    No crank, click or anything. After a few tries then starts and CEL is on. I log and clear all codes and car runs perfect for a week or 2 then same codes. Runs fine when CEL is on.
    All stock and has all dealer software updates.
    Are there any ECU instructions Q5 specific for accessing ECU connectors.
    Thanks for the help.
    Yup its called the repair manual at Erwin and reading WD.
    Print to PDF.......
    https://erwin.audi.com/erwin/showHome.do
  9. Likes Ashraf6119 liked this post
  10. #7
    Jul 2014
    battery check, when it happens check for voltage on starter solenoid
  11. Likes Jack@European_Parts, Ashraf6119 liked this post
  12. #8
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Quote Originally Posted by WtA3WtQ5 View Post
    Was this problems there before or its just happened after the software updates.............?
    As there is this fault code stored in ABS System according to Wiki :
    01314 - Engine Control Module: No Communications
    Possible Causes
    CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
    Fault(s) stored in Engine Control Module
    Engine Control Module recently flashed or re-mapped
    Possible Solutions
    Check CAN-Databus Wiring/Connectors from/to Engine Control Module
    Check Measuring Value Blocks (MVB)
    Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
    Also worth checking the multi plug connections on the Transmission Module
    Edited: Also check the Engine Control Module Relay
  13. #9
    Jul 2016
    Quote Originally Posted by ivagp View Post
    Yes, it wouldn't hurt to check that after Jack's recommended items. From the fault codes I would bet I would get power there when it starts and no power when it doesn't.
  14. #10
    Jul 2016
    Quote Originally Posted by Ashraf6119 View Post
    Possible Causes
    Possible Solutions
    No recent updates, but the car was in for State Inspection at the dealer in May and all software was up to date.
