No Start first few tries then CEL
WtA3WtQ5
C?ID=139976
Clear codes then good for a week or 2, then same codes.
Sunday,21,May,2017,08:54:18:05068
VCDS Version: 17.1.3.0
VIN: WA1CFAFPXBA081666   License Plate:
Mileage: 98390km-61136mi   Repair Order:
Chassis Type: FP (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 69 72 77
VIN: WA1CFAFPXBA081666   Mileage: 98390km-61136miles
Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 H    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0003
   Revision: E1H19---
   Coding: 0121010A290F0960
   Shop #: WSC 08315 444 11710
   ASAM Dataset: EV_ECM20TFS0118R0907115H 001006
   ROD: EV_ECM20TFS0118K2907115AD.rod
   VCID: 39732959B84A5E89EE-806C
          U1113 00 [032] - -
          U1113 00 [032] - -
7021 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [109] - -
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:22
                    Engine speed: 974.50 /min
                    Normed load value: 11.4 %
                    Coolant temperature: 69 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.887 V
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 E    HW: 0BK 927 156 N
   Component: 0BK 20TFSIUSA H08 0010
   Revision: --H08---
   Coding: 001112
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL551211 001013
   ROD: EV_TCMAL551211_001.rod
   VCID: 3F874741A66E70B9D0-806A
12551 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
12554 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
12562 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [168] - -
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0110
   Coding: 129D10
   VCID: 458B55A9CCB22A699A-8010
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000F
                    Hex Value: 0xB99B
                    Hex Value: 0x00FF
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
   Part No SW: 8K0 907 064 CR    HW: 8K0 907 064 CR
   Component: BCM2 2.0      H05 0435
   Coding: 090500
   VCID: 02018EB59D1CDD51FF-8056
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0811000008524012
   Serial number: 2310000105260015
                    Fault Status: 00101101
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01070220111270
   Coding: 64002000
   Shop #: WSC 06335 123 12345
   VCID: 000584BD9310CF41E9-8054
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000937946
   Coding: 6F0020F1013CA7010000090300007F7F4F1C660802000161000000
   VCID: 3C7D304DBF786BA1F5-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 110122  H11 0050
   Serial number: 90243014110114023324
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 11262475
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000102110032
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GPD0N102/
   Coding: 303633313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 47975FA1FEBE387968-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R1100003Q67
   Serial number: 6334MSME5B160A70D
   Serial number: 6344MSME5B326267G
   Serial number: 6352QSME3C065460D
   Serial number: 6362QSME4701275EI
   Serial number: 63732SME3E04036E0
   Serial number: 63832SME6D0834461
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KAV00070
   Coding: 000017
   VCID: 3D7B3D49A46262A9C2-8068
   Component: E221 - MFL  H04 0010
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 K    HW: 8R0 920 950 K
   Component: KOMBIINSTR.   H12 0258
   Revision: 00000000    Serial number: EJU309Z1C
   Coding: 8B1F22000300D705020000
   VCID: 3E793A45A96479B1DB-806A
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:14
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G111298558
   Coding: 00C303
   VCID: 010381B9981AC649E6-8054
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650447274
                    Fault Frequency: 8
                    Reset counter: 143
                    Mileage: 97755 km
                    Date: 2017.05.08
                    Time: 07:54:53
                    Bin. Bits:    00000
                    Voltage: 12.50 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000012178471
   Coding: 011D03204000440004
   VCID: 4A916695E5ACC51177-801E
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0142687706
   Coding: 0126063A20FA440084B0053200000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000355928
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
   Component: DSP STD       H11 0440
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 2F6717017E0E803940-807A
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0004000216836
   VCID: 49935999E0AACE097E-801C
   Revision: 00000003    Serial number: 00000000857977
   VCID: 346D186D9728A3E13D-8060
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:14
                    Voltage: 12.40 V
                    Count: 64
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000009    Serial number: AUZ5Z6K1528606
   Coding: 0502000201058500C359070000
   VCID: 468952A5F1B4217193-8012
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000112754547
   Coding: 010C03204000240004
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H07 0070
   Revision: 1A001001    Serial number: 00000124854806
   Coding: 0200000000000000
   VCID: 366922658154B1F103-8062
                    Reset counter: 143
                    Mileage: 98394 km
                    Date: 2017.05.21
                    Time: 08:43:13
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000112754548
   Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
   Component: FSE_256x BT     H42 0650
   Revision: 00000000    Serial number: 00000005108703
   Coding: 0010370
   VCID: 3D7B3D49646262A9C2-8068
End-------------------------(Elapsed Time: 03:19)--------------------------
Address 01: DTCs cleared
I am afraid it won't start at all eventually.
Connectors or ECU on it's way out?
Thanks!
Check all connections for corrosion and especially check the chassis to engine/trans ground strap or enhance.
In addition check connections with all shared modules such as the brake module.
Check all terminal relays.........and ignition switch.
Jef
HQ
No start.... no crank? Or cranks but doesn't fire? "No start" is a bit open ended. Is there a back story on this? Flood car? Crashed? Wonky audio system installed (or any sort of non factory hardware)? Does this happen on hot days? Cold days? When Trump says something brilliant (sarcasms meter is off line, this statement is open ended)?
With what little info we have, I agree with Jack.... my first guess is a poor electrical/mechanical connection somewhere... poor ground, loose fuse, green rot on a terminal, ect.
WtA3WtQ5
C?ID=139976
No crank, click or anything. After a few tries then starts and CEL is on. I log and clear all codes and car runs perfect for a week or 2 then same codes. Runs fine when CEL is on.
All stock and has all dealer software updates.
Are there any ECU instructions Q5 specific for accessing ECU connectors.
Thanks for the help.
Ashraf6119
C?ID=174194
Was this problems there before or its just happened after the software updates.............?
As there is this fault code stored in ABS System according to Wiki :
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Engine Control Module recently flashed or re-mapped
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
Also worth checking the multi plug connections on the Transmission Module
Edited: Also check the Engine Control Module Relay
WtA3WtQ5
C?ID=139976
battery check, when it happens check for voltage on starter solenoid
Yes, it wouldn't hurt to check that after Jack's recommended items. From the fault codes I would bet I would get power there when it starts and no power when it doesn't.
WtA3WtQ5
C?ID=139976
Possible Causes
Possible Solutions
No recent updates, but the car was in for State Inspection at the dealer in May and all software was up to date.
