Results 1 to 6 of 6
Thread: Audi A4 (8K) cruise control retrofit problem
    Jan 2017
    We purchased a cruise control unit from the local Audi dealer for a 2009 Audi A4 2.0 TDI.
    Now, the engine accepts coding, but steering wheel controller does not ("coding rejected Error 31: request out of range").
    Could it be that the steering wheel controller hardware (8K0 953 568 D) does not support cruise control? The car does not have a multi-function steering wheel.
    Here's the auto scan:
    Friday,16,June,2017,11:11:35:57012
    VCDS Version: 17.1.3.0 (x64)
    VIN: WAUZZZ8K39A235164   License Plate: xxxx-xxx
    Mileage: 135490km-84189mi   Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 69 72
    VIN: WAUZZZ8K39A235164   Mileage: 135490km-84189miles
    16-Steering wheel -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CAGC)       Labels: 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 MG    HW: 03L 906 022 B
       Component: R4 2.0l TDI   H01 9978
       Revision: 11H01---
       Coding: 0104002C18072920
       Shop #: WSC 21788 002 104857
       ASAM Dataset: EV_ECM20TDI03L906022MG A01009
       ROD: EV_ECM20TDI03L906022.rod
       VCID: 76DA745DC91989F1C3-8022
    4332 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
                        Mileage: 135496 km
                        Date: 2017.06.16
                        Time: 09:56:44
                        Coolant temperature: 18 C
                        Intake air temperature: 19 C
                        Voltage terminal 30: 11.740 V
                        Crankshaft speed (RPM): 0.0 /min
                        Vehicle speed: 0.00 km/h
                        ACCI a Des: 0.000 m/s
                        Acceleration: 0.000 m/s
                        ACCI st State-Bit 0: 00000000
                        Cruise Control System (CCS): status-Bit 0: 00000100
                        ACCI st Brk Err mp-Bit 0: 00000000
    4984 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [101] - Electrical Fault
                        Mileage: 135496 km
                        Date: 2017.06.16
                        Time: 10:07:50
                        Engine speed: 849.00 /min
                        Normed load value: 38.4 %
                        Voltage terminal 30: 11.980 V
                        Crankshaft speed (RPM): 849.0 /min
                        Vehicle voltage terminal 30: 11960 mV
                        Coolant temperature: 18.5 C
                        Glow status-Bit 0: 00000000
                        Glow status-Bit 8: 00000000
                        Preheat time: 0 ms
                        Fuel temperature: 17.5 C
    4985 - Cylinder 2 Glow Plug Circuit (Q11)
              P0672 00 [101] - Electrical Fault
                        Mileage: 135496 km
                        Date: 2017.06.16
                        Time: 10:07:50
                        Preheat time: 0 ms
    4987 - Cylinder 4 Glow Plug Circuit (Q13)
              P0674 00 [101] - Electrical Fault
                        Mileage: 135496 km
                        Date: 2017.06.16
                        Time: 10:07:50
                        Preheat time: 0 ms
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
       Component: ESP8 front    H04 0240
       Coding: 168500
       Shop #: WSC 61000 205 76828
       VCID: 7CCE6675FF35D3A1B5-8028
       Part No SW: 8K0 907 064 M    HW: 8K0 907 064 M
       Component: BCM2 1.1      H80 0145
       Coding: 030200
       Shop #: WSC 06325 000 00000
       VCID: 3A42A06DB5812D91E7-806E
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0509000018560008
       Component: J764 ELV MLB  H36 0042
       Serial number: 0209000025204014
       Part No SW: 8T1 820 043 T    HW: 8T1 820 043 T
       Component: KLIMA 1 ZONE  H06 0150
       Revision: A0000000    Serial number: 01240420091409
       Coding: 34000000
       VCID: 42B2D88DDD516551BF-8016
    00256 - A/C Pressure/Temperature Sensor (G395)
                        Fault Status: 00100001
                        Fault Frequency: 7
                        Reset counter: 165
                        Mileage: 135460 km
                        Date: 2017.06.15
                        Time: 15:08:57
                        Temperature: 25.0C
                        Temperature: 83.0C
                        Load: 100.0 %
                        Absolute Pres.: 30.0 bar
                        RPM: 1960 /min
                        Speed: 96.0 km/h
                        Current: 0.410 A
                        Temperature: 38.0C
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063     HW: 8K0 907 063
       Component: BCM1 1.0      H26 0253
       Revision: 01026001    Serial number: 00000000256083
       Coding: 6900C0B10034A7000001000000005F5F0014260800000101000000
       VCID: 6CEE56358F55432125-8038
       Component: WWS 270409  H06 0070
       Serial number: SWF09040275208
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10455414
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 Q    HW: 8K0 941 531 Q
       Component: E1 - LDS  H07 0090
       Serial number: 00000000002004090697
                        Fault Status: 00101100
                        Reset counter: 137
                        Mileage: 134203 km
                        Date: 2017.05.18
                        Time: 13:35:00
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
       Component: AirbagVW-AU10 H37 0520
       Serial number: 003EFD0260JT
       Coding: 30343435363030303030554A304C384B3053
       VCID: 41B0D781D0577E49A6-8014
       Serial number: 6334MSME48150C058
       Serial number: 6344MSME440435699
       Serial number: 6352QSME47273C3AP
       Serial number: 6362QSME3A224614A
       Serial number: 63732SME3D224010O
       Serial number: 63832SME5B274700-
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8K0 953 568 D    HW: 8K0 953 568 D
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90319IDK000GB
       VCID: 3B4CA569BABB1499FC-806E
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 900 C    HW: 8K0 920 900 C
       Component: KOMBIINSTR.   H18 0224
       Revision: 00000000    Serial number: 9DS33DR49
       Coding: 0F00100002000008010000
       VCID: 2A62902D45219D1197-807E
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0095
       Revision: GB300043    Serial number: 4300G0941980B7
       Coding: 000303
       VCID: 4BACF5A9EA1BA4194C-801E
       Component: J367-BDM  H06 0160
       Serial number: 19071CB1170309
                000 -  -
                        Fault Frequency: 16
                        Reset counter: 125
                        Mileage: 133384 km
                        Date: 2017.05.02
                        Time: 09:05:00
                        Fault Frequency: 16
                        Reset counter: 125
                        Mileage: 133384 km
                        Date: 2017.05.02
                        Time: 09:05:00
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 E    HW: 8K0 959 793 E
       Revision:             Serial number: 0000008828868
       Coding: 011002204000410001
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0118131259
       Coding: 0100062020390040012002
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 72
                        Mileage: 133384 km
                        Date: 2017.05.02
                        Time: 09:25:26
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 72
                        Mileage: 133384 km
                        Date: 2017.05.02
                        Time: 09:25:26
                        Reset counter: 165
                        Mileage: 135496 km
                        Date: 2017.06.16
                        Time: 08:34:49
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 E    HW: 8K0 959 792 E
       Revision:             Serial number: 0000008809776
       VCID: 41B0D781D8577E49A6-8014
       Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
       Component: EPB Audi B8   H08 0080
       Revision: 00000003    Serial number: 00000000357763
       VCID: 335C8D4992EBDCD924-8066
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H02 0310
       Revision: 00000005    Serial number: AUZ5Z6I1205234
       Coding: 05000480040201000119070000
       VCID: 44BEDE95C7456B618D-8010
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
    03138 - Input AUX IN
                        Fault Status: 01101011
                        Reset counter: 72
                        Mileage: 133384 km
                        Date: 2017.05.02
                        Time: 09:13:04
    Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000101011410
       Coding: 010002204000210001
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
       Component: Anhaenger     H08 0080
       Revision: 1A002002    Serial number: 00000119179749
       Coding: 0100000000000000
    02565 - Trailer; Right Turn Signals (M63)
                        Fault Status: 11101010
                        Reset counter: 106
                        Mileage: 134605 km
                        Date: 2017.06.03
                        Time: 09:06:00
    Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
       Revision:             Serial number: 0000101011417
    End-------------------------(Elapsed Time: 02:06)--------------------------
    Jan 2017
    Quote Originally Posted by Pekka Perkeles View Post
    We purchased a cruise control unit ...
    CC unit number: 8K0-953-502-BG-4PK
    Certainly on the previous 8E/8H platform cruise control wouldn't work with an SCSM that didn't support an MFSW - I had to replace the SCSM to get cruise working on a 2005 8E B6 S4 I used to own.
    Hopefully someone will be able confirm if this is also true on the 8K platform...
  4. Likes Dana liked this post
    Jan 2015
    Bosnia and Herzegovina
    8K0 953 568 D doesnt support cruise control you need one of the following
    KOSTAL:
    8K0 953 568 B: CCS, MFSW, Board Computer (only for audi A5, to 2009?* different airbag connector?*, also without index to index C, does not fit A4 8K!)
    8K0 953 568 GB: no CCS, Board Computer, no MFSW
    8K0 953 568 E: CCS, Board Computer, no MFSW
    8K0 953 568 F: CCS, MFSW, Board Computer, no ACC!
    8K0 953 568 G: CCS, ACC, MFSW, Board Computer, ...
    FL:
    8K0 953 568 J: no CCS, Board Computer, no MFSW
    8K0 953 568 K: CCS, Board Computer, no MFSW
    8K0 953 568 L: CCS, MFSW, Board Computer, no ACC!
    8K0 953 568 M: CCS, Board Computer, MFSW, ACC
    VALEO (from 1/2011):
    8R0 953 568 H: no CCS, Board Computer, no MFSW
    8R0 953 568 J: CCS, Board Computer, no MFSW!
    8R0 953 568 K: MFSW?, CCS, Board Computer, no ACC
    8R0 953.568 M: CCS, Board Computer, MFSW, ACC
    FL:
    8R0 953 568 N: no CCS, Board Computer, no MFSW
    8R0 953 568 P: CCS, Board Computer, no MFSW
    8R0 953 568 Q: CCS, MFSW, Board Computer, no ACC!
    8R0 953 568 R: CCS, MFSW, ACC, Side Assist, Board Computer
    8R0 953 568 S: CCS,Board Computer, MFSW, ACC
    Steering column lever and steering column stalks must be from the same manufacturer!
    8R0 ... = VALEO
    8K0 ... = KOSTAL
    4G0 ... = VALEO
    4G8 ... = KOSTAL
    also coding
    01 (engine control unit)
    byte 6 bit 0 Activate
    16 (steering column control unit)
    byte 2 bit 2 activate
    i'll ask Dana to make a table from this data
  6. Likes Uwe liked this post
    Jan 2017
    Quote Originally Posted by m87a View Post
    8K0 953 568 D doesnt support cruise control you need one of the following:
    I've now purchased that one.
    also coding
    Thank you.
    I will install new hardware next week and try coding again. Do I need an updated VCDS/definitions?
    Thanks! I was off the week you posted and just noticed this thread. Our B8 CCS Wiki page is limited at this time:
    http://wiki.ross-tech.com/wiki/index...rofitting_(8T)
    .. but I should be able to create a page (like the Golf based modules) with a chart. Feel free to bump this back up or PM me.
    The current version of VCDS should work fine. I would change that #16 coding from 000001 -to- 000005 using the Long coding helper when the new module is installed.
  9. Likes Uwe, m87a liked this post
