Results 1 to 7 of 7
Thread: 09 - Central Electronics faults - MK5 Golf (1K)
    Feb 2015
    Hi all,
    Looking at the below scan of my car, could you let me know the options to rectify please?
    Could this be a faulty 1K0 937 049 T module?
    Thursday,15,June,2017,21:41:41:20472
    VCDS Version: 17.1.3.0
    Dealer/Shop Name: S81 Diagnostics
    VIN: WVWZZZ1KZ5W086199   License Plate: YC05YPG
    Mileage: 146190km-90838mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ5W086199   Mileage: 146190km-90838miles
    56-Radio -- Status: Not registered 0001
    Address 01: Engine        Labels: None
       Part No SW: 06F 906 056 DE    HW: Hardware No
       Component: MED9.5.10        00 7224
       Revision: 00000000    Serial number: VWZ7Z0D0539519
       Coding: 0000072
       Shop #: WSC 00600 210 91852
       VCID: 6FE7DFF67ED2F43900-803A
       Subsystem 1 - Part No: 06F 907 807 F
       Component: NOX  0908280063 002 0409
       06F907807F  NOX  0908280063 002 0409
    19490 - Intake Air Temperature Sensor 2 (G299)
                P3034 - 002 - Signal too Large - Intermittent
    Readiness: 0000 0001
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0021122
       Shop #: WSC 01279 785 00200
       VCID: 3A713EA275106191E7-806E
       Part No: 1K0 907 044 AB
       Component: ClimatronicPQ35 066 0404
       VCID: 67D7B7D656222C7948-8032
    01810 - Actuating Motor for Temperature Flap; Right (V159)
                000 -  -  - Intermittent
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
       Component: Bordnetz-SG 1.0 H30 0704
       Revision: 00030000    Serial number: 00000000945140
       Coding: E5050E060004181E001400001400000000
       VCID: 40854C4A13CC3B41A9-8014
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00217125
    6 Faults Found:
    02398 - Control Circuit for Rear Windshield Washer Pump
                009 - Open or Short to Ground
    00156 - Control Circuit for Windshield Washer Pump
    02401 - Terminal 75x
    01800 - Light Switch (E1)
    00897 - Windshield Washer Pump (V5)
       Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
       Component: 02 AIRBAG VW8   023 0700
       Revision: 06023000    Serial number: 00385D0K0XZV
       Coding: 0012338
       Shop #: WSC 01268 785 00200
       VCID: 3163198EA866A2C956-8064
       Subsystem 1 - Serial number: 6332MSME50357E05
       Subsystem 2 - Serial number: 6342MSME48211405
       Subsystem 3 - Serial number: 6351HSME75416F03
       Subsystem 4 - Serial number: 6361HSME015A6A03
       Part No SW: 1K0 953 549 AM    HW: 1K0 953 549 AM
       Component: J0527           036 0071
       Coding: 0000012
       VCID: 7DFBF5BE24BE96A982-8028
       Part No: 1K0 920 961 A
       Component: KOMBIINSTRUMENT VDD 0814
       Coding: 0003403
       Shop #: WSC 00600 067 57207
       VCID: 2855F4EA9BBCE30181-807C
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0111
       Revision:   H07 01    Serial number: 251109F2001669
       Coding: E9807F06000002000003
       VCID: 69D3B1EE40361A095E-803C
                        Mileage: 146094 km
                        Time: 21:26:37
       Component: IMMO            VDD 0814
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0148
       Coding: 0000052
       VCID: 30651C8AA36CABC159-8064
    00943 - Heated Exterior Mirror; Driver Side (Z4)
       Part No: 1K2 909 144 G
       Component: EPS_ZFLS Kl.1       1301
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 98C802087F2D8505485FC69010
       Shop #: WSC 00000 785 00200
       VCID: 7BFFFBA63AAA9899BC-802E
       Subsystem 1 - Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
       Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
       Component: Radio FO3       021 0014
       Revision: 00021000    Serial number: VWZ7Z2G0009276
       Coding: 0010400
       Shop #: WSC 00221 210 64224
       VCID: 3777279646027CF918-8062
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 06 0213
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Coding: 0000016
    End-------------------------(Elapsed Time: 02:01)--------------------------
    May 2017
    Does the rear washer pump work?
    Does it leak? The design of these washer pump connections especially to the rear are a bit poor. This causes sometimes the pipe to leak inside the boot door and cause all shorts of electrical failures.
    Remove the boot lid inner cover and check first that the washer pipe is not leaking. The symptoms look a bit like it is.
    Feb 2015
    Nope, neither of the washer pumps work, no sign of water behind boot lid trim.
    All fuses are okay, and reversing lamp is working in a different car.
    May 2017
    Maybe the pump has then given it's final breath?
    Open or short to ground indicates that there's a short circuit somewhere. Either in the pump itself or in the wiring to the pump. You could of course remove the pump and try to run it with external 12v power to see if the pump really is the issue.
    Feb 2015
    Thank you,
    Can you confirm that 1J6955651 is the right part number for the pump?
    May 2017
    Sorry, looked first at the rear wiper motor.
    Pump is 1K6955651 according to ETKA.
  7. #7
    Feb 2015
    Ordered a new pump, will keep you updated
