I originally posted this question in the New Users section but now am verified.
I want to dis-able the seat belt chimes and found this post which I cannot figure out how to do.
9. Disabling seatbelt reminder chimes.
Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
Check this option
[Do It!]
Ok I followed the directions up to [ Coding-07] then another window opens but shows nothing with [ Long Coding helper]?
It does warn you to copy down all the values as you can make a module non functional if you do the change wrong which I don't want to do.
Can anyone help with the instructions after I click on "Coding-07"?
I wish I had the program to take a snapshot of the window that opens when I click coding but I don't.
Here is my auto scan:
I have no idea how to post it any different sorry.........
[Select]
[17 - Instruments]
[Coding - 07]
Check this option
[Do It!]
Thursday,15,June,2017,12:35:13:27817
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: 3VWST71K66M704067 License Plate:
Mileage: 194660km-120956mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71K66M704067 Mileage: 194660km-120956miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2821901
Coding: 0050078
Shop #: WSC 66565 257 00032
VCID: 6492A55A525D75B7A91-8030
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Fault Status: 01110000
Mileage: 192904 km
Time: 11:32:38
RPM: 882 /min
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101000
Temperature: 6.3°C
Bin. Bits: 10110000
Readiness: 1 1 0 0 1
Part No SW: 02E 300 042 H HW: 02E 927 770 AE
Component: GSG DSG 070 0913
Revision: 04507000 Serial number: 00000507080615
Shop #: WSC 00066 000 00000
VCID: 186AC1AADE956157F59-804C
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
VCID: 40DA49CAE68509976D9-8014
Part No SW: 1K0 820 047 JT HW: 1K0 820 047 JT
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial number: 00000000000000
VCID: 7F580A36DBFBB66F543-802A
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000190365
Coding: 14018E234004180000140000001400000008730B5C
Shop #: WSC 23072 444 54704
VCID: 2A0E0B6270F9E3C753D-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 23072
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0072892
VCID: 2E0607724C118FE78F5-807A
Reset counter: 151
Mileage: 192970 km
Time: 11:38:48
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD049K6$
Coding: 0012627
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0A3D5A57O
Subsystem 3 - Serial number: 6342MSME0A2E442FN
Subsystem 4 - Serial number: 6351HSME08344327+
Subsystem 5 - Serial number: 6361HSME08124234Z
Subsystem 6 - Serial number: 63727SME077B5A5BG
Subsystem 7 - Serial number: 63827SME077B635CC
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78AAE12AFED58157159-802C
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023203
VCID: 2B000E667F03FACFA8B-807E
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001059019258
Coding: 3F3F0B60071002
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36362F12B441B727C75-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323E13025829AB07EBD-8066
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 037803281B09058F880F048051A0
Shop #: WSC 01416 999 58992
VCID: 74B2D51AE2BDE537391-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 37282216B34B4E2FDC3-8062
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0014
Revision: 00011000 Serial number: VWZ4Z7E2045968
Coding: 0010400
VCID: 201AE94A06C529970D9-8074
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313C1C0E5D2F901F927-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D04007E4117F4FFB6F-8078
014 - Defective
End----------(Elapsed Time: 01:06, VBatt start/end: 12.3V/12.3V)------
