Results 1 to 3 of 3
Thread: How to disable the seat belt chimes?
    Verified VCDS User redrooster's Avatar
    Apr 2017
    Canada
    I originally posted this question in the New Users section but now am verified.
    I want to dis-able the seat belt chimes and found this post which I cannot figure out how to do.
    9. Disabling seatbelt reminder chimes.
    Turn off the annoying "Bing bong" when you move the car on the driveway without your seatbelt fastened.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 0 and in bit 4 you'll see the selectable option: "Seat Belt Warning inactive"
    Check this option
    [Do It!]
    Ok I followed the directions up to [ Coding-07] then another window opens but shows nothing with [ Long Coding helper]?
    It does warn you to copy down all the values as you can make a module non functional if you do the change wrong which I don't want to do.
    Can anyone help with the instructions after I click on "Coding-07"?
    I wish I had the program to take a snapshot of the window that opens when I click coding but I don't.
    Here is my auto scan:
    I have no idea how to post it any different sorry.........
    Thursday,15,June,2017,12:35:13:27817
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    VIN: 3VWST71K66M704067   License Plate:
    Mileage: 194660km-120956mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWST71K66M704067   Mileage: 194660km-120956miles
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H01---    Serial number: VWZ7Z0E2821901
       Coding: 0050078
       Shop #: WSC 66565 257 00032
       VCID: 6492A55A525D75B7A91-8030
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 192904 km
                        Time: 11:32:38
                        RPM: 882 /min
                        Voltage: 14.21 V
                        Bin. Bits: 00101000
                        Temperature: 6.3C
                        Bin. Bits: 10110000
    Readiness: 1 1 0 0 1
       Part No SW: 02E 300 042 H    HW: 02E 927 770 AE
       Component: GSG DSG         070 0913
       Revision: 04507000    Serial number: 00000507080615
       VCID: 186AC1AADE956157F59-804C
       Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
       Revision: 00T12001
       Coding: 0021122
       VCID: 40DA49CAE68509976D9-8014
       Part No SW: 1K0 820 047 JT    HW: 1K0 820 047 JT
       Component: Climatic PQ35   143 1515
       Revision: 00143034    Serial number: 00000000000000
       VCID: 7F580A36DBFBB66F543-802A
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000190365
       Coding: 14018E234004180000140000001400000008730B5C
       Shop #: WSC 23072 444 54704
       VCID: 2A0E0B6270F9E3C753D-807E
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0402
       Coding: 00065493
       Shop #: WSC 23072
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0072892
       VCID: 2E0607724C118FE78F5-807A
                        Reset counter: 151
                        Mileage: 192970 km
                        Time: 11:38:48
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1S AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD049K6$
       Coding: 0012627
       Subsystem 1 - Part No: 1K0 959 339 E
       Component: BF-Gewichtsens. 006 0005
       Subsystem 2 - Serial number: 6332MSME0A3D5A57O
       Subsystem 3 - Serial number: 6342MSME0A2E442FN
       Subsystem 4 - Serial number: 6351HSME08344327+
       Subsystem 5 - Serial number: 6361HSME08124234Z
       Subsystem 6 - Serial number: 63727SME077B5A5BG
       Subsystem 7 - Serial number: 63827SME077B635CC
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0010021
       VCID: 78AAE12AFED58157159-802C
       Part No: 1K0 920 952 D
       Component: KOMBIINSTRUMENT 3HL 1212
       Coding: 0023203
       VCID: 2B000E667F03FACFA8B-807E
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001059019258
       Coding: 3F3F0B60071002
       Component: IMMO            3HL 1212
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2377
       Coding: 0001269
       VCID: 36362F12B441B727C75-8062
       Part No: 1K1 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 323E13025829AB07EBD-8066
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 037803281B09058F880F048051A0
       Shop #: WSC 01416 999 58992
       VCID: 74B2D51AE2BDE537391-8020
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 37282216B34B4E2FDC3-8062
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio DE2       011 0014
       Revision: 00011000    Serial number: VWZ4Z7E2045968
       Coding: 0010400
       VCID: 201AE94A06C529970D9-8074
    00003 - Control Module
                014 - Defective
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2434
       Coding: 0000144
       VCID: 313C1C0E5D2F901F927-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       Revision: 00800000    Serial number:
       VCID: 2D04007E4117F4FFB6F-8078
                014 - Defective
    End----------(Elapsed Time: 01:06, VBatt start/end: 12.3V/12.3V)------
    Your cluster is too old to support Long Coding.
    As shown in the ballon help that should pop up on the coding screen for your cluster, the seat belt warning is in these two digits:
    xx??xxx: Options
    C02,+00 = No Options
    C03,+01 = Brake Pad Warning
    C04,+02 = Seatbelt Warning
    C05,+04 = Washer Fluid Warning
    C06,+16 = Sedan (only VW Jetta)
    Right now the value in there is 23. Subtract 2 from 23, gives you 21.
    So change your instrument cluster coding from:
    0023203
    to:
    0021203
    Apr 2017
    Canada
    Wow thanks for the very fast reply.
    I just went out and followed your instructions and it worked!
    This was one of the things I wanted to do to justify me buying the software.
    Again thanks for your help Uwe.
  4. Likes Uwe liked this post
