Results 1 to 8 of 8
Thread: Remove a key ?
    Dec 2016
    Question Remove a key ?
    My car has 3 keys adapted .. I was only handed 2 of them when I purchased the car.
    I have no clue what key is missing, so I suppose I will need to clear all 3 keys
    and re-addapt the two keys I do have ..
    Is there a proper procedure to remove "the third" key, given my specific car model using VCDS ?
    (You already have seen my autoscan plenty times in other threads here, so I wont repeat it again)
    Generally, the only way to do that is to clear all the matching, then re-match the remaining keys.
    Your car is a 4G-Chassis A6, right?
    Dec 2016
    Well, just to be absolutely sure, I will let you be the judge of that.
    I am quite sure you can tell every nut and bolt from the VIN.
    Me, on the other hand would make assumptions based solely on
    production year, and that may be a bit of a slugish diagnose
    So, - VIN and all .. :
    Friday,09,June,2017,16:47:18:39361
    VCDS Version: 17.4.2.3 (x64)  HEX-NET CB: 0.4341.4
    Data version: 20170505 DS270.4
    VIN: WAUZZZ4G7DN016839   License Plate:
    Mileage: 110978km-68958mi   Repair Order:
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 3B 42 44 46 52 53 56
              5F 62 6D 72 8F 90
    VIN: WAUZZZ4G7DN016839   Mileage: 110978km-68958miles
    Address 01: Engine (J623-CHVA)       Labels: None
       Part No SW: 4G0 907 552 H    HW: 4G0 907 552 D
       Component: 2.8l V6 FSI   H07 0001
       Revision: --H07---
       Coding: 0A030034042401020000
       ASAM Dataset: EV_ECM28FSI0214G0907552H 001001
       ROD: EV_ECM28FSI0214G0907552H.rod
       VCID: 2F2EDAD176848D3FA5-807A
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 4G1 927 155 E    HW: 0AW 927 156 K
       Component: 0AW 28AVS RdW H04 0003
       Revision: --H04---    Serial number: 0000000175
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMVL381 A02431
       ROD: EV_TCMVL381.rod
       VCID: 2E10C7D5718E8437AE-807A
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
       Coding: 02A187014085E180CB00
       VCID: 3620EFB589DEBCF7E6-8062
       Part No SW: 4H0 907 064 CH    HW: 4H0 907 064 CH
       Component: BCM2 2.0      H32 0421
       Coding: 01A83046000000000000
       VCID: 71AA1CA9A830DBCFF3-8024
    Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
       Component: KLIMA 4 ZONEN H13 0070
       Serial number: 01061200041357
       Coding: 4601007801
       VCID: 628863E575D670577A-8036
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 CB    HW: 4H0 907 063 B
       Revision: 13012002    Serial number: 00000001335007
       Coding: 6900C0108074A7E08105008300005F5FCF9CC2082E080201000008406001
       Shop #: WSC 46238 001 1048576
       VCID: 6A980BC585E62817B2-803E
       Component: WWS57X 120510  H35 0080
       Serial number:         120524040552
       Coding: 0045F7
       Serial number: 20327853
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
       Component: E1 - LDS  H07 0044
       Serial number: 30 05 2012  00000124
       Serial number: 9CE80136000000000001
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061215300196
       Coding: 88C305
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       VCID: 77BE22B1CE5485FF3D-8022
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Revision: --------    Serial number: 003JG008X834
       Coding: 30323436313330303333554A304C34473053
       Serial number: 3575HRB405L1D5MK4OVA
       Serial number: 3585HRB40531D5MK885+
       Serial number: 3515JRB401A4UI5CCPFZ
       Serial number: 3525JRB405518E5E81BJ
       Serial number: 3554VRB400A4UH26OGH1
       Serial number: 3564VRB400A4UH26EP6X
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Revision: 00000000    Serial number: 20120612001418
       Coding: 000014
       VCID: 302CD9AD63BA92C7BC-8064
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0009
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 932 B    HW: 4G8 920 932 B
       Component: TBenRdw       H79 0515
       Revision: 28460207    Serial number: 658040612596038
       Coding: 13AE08000341000C010000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K.rod
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000563319
       Coding: 00CD073000
       ASAM Dataset: EV_GatewPkoUDS 001013
       ROD: EV_GatewPkoUDS_001.rod
       VCID: 70AC19ADAB3AD2C7FC-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790523990
       Voltage stabilizer:
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Revision: AA001002
       Coding: 01018264747464545425363E00
       VCID: 7CB43D9DFF72A6A750-8028
    Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
       Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
       Component: KLIMA FOND    H07 0070
       Serial number: 13061200040339
       Coding: 20
       Component: SARA 6D       H02 0053
       Revision: --------    Serial number: EJ1BPA82003RMD
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       Component: TSG FA        H03 0506
       Coding: 011F16004000628002080002
       VCID: 47DE9271F634357F8D-8012
    Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
       Part No SW: 4G0 909 144 AA    HW: 4G0 909 144 G
       Component: RCEPS         H35 0013
       Revision: 00001000    Serial number: 0011572879
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       VCID: 689C71CD93EA1A07A4-803C
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0176409948
       Coding: 0100062000B93000833008040801030F0000000000000000000000000000
       Component: TSG BF        H03 0506
       VCID: 46C09F75F13E2C7776-8012
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000370676
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2B16CEC1429CF11F89-807E
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230EQ0C2542753
       Coding: 010003020100000001
       VCID: 230626E1224C395F31-8076
       Part No SW: 4G0 035 666 H    HW: 4G0 035 666 H
       Component: H-BN-EU       H49 0526
       Revision: --------    Serial number: 189F.0C7511281
       Coding: 050100000303E1ED07908F3E00000003E00001020000000000
       VCID: 2D12C0D97488FF2F97-8078
       Subsystem 1 - Part No: 8R0 060 884 ED
       Component: EUR 2017  2402
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Serial number: AUZ8ZDC9401PJYK
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LF8000VD
       Component: CD-Database  3638
       Component: TSG HL        H03 0506
       Coding: 010F14004000628002080002
       VCID: 49DA9449E020C30F9B-801C
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Part No SW: 4G5 959 107 A    HW: 4G5 959 107
       Component: HDSG-Modul    H01 0038
       Revision: 13001001    Serial number: 125201117
       Coding: 111104C000
       ASAM Dataset: EV_HDSGAu571 001001
       ROD: EV_HDSGAu571.rod
       VCID: 302CD9AD6BBA92C7BC-8064
       Component: TSG HR        H03 0506
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 312ADCA960B09BCFB3-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 3228D3A565B6A0D7CA-8066
    End-------------------------(Elapsed Time: 01:35)--------------------------
  4. Likes Uwe liked this post
    Yes... WAUZZZ4G7DN016839
    '4G' in the 7th and 8th digit, and the 'D' in the 10th digit indicates it is a 2013 model (which may very well have been produced in 2012).
    Dec 2016
    Thank you, - I learned something :-)
    Does that allow you to infer a proper procedure for my purpose ?
    Quote Originally Posted by Michael D. Frederiksen View Post
    Yes, proper procedure is take car to dealer and have them clear key matching and re-learn the two keys you have. Sorry, not something you can do with VCDS.
    Dec 2016
    Thank you :-)
  9. Likes Uwe liked this post
  10. #8
    Nov 2016
    I had the same situation with my S4.
    When I bought it I only got 2 keys - the 3rd plastic 'emergency' key was missing, likely broken? (although the holder to fit in the ignition is present). Initially I thought nothing of it as 2 keys is plenty but recently whilst looking through the settings I saw that 3 were activated and felt uncomfortable that there might be a working key out there which could fall into the wrong hands.
    I had the car serviced a couple of weeks ago at the local Audi dealer and they recoded to just the 2 keys. Initially they quoted me a 60 recode fee but then did it FOC whilst in for service.
    2014 Audi S4 Avant, 'black edition'.
  11. Likes Uwe liked this post
