Saturday,17,June,2017,12:19:44:55582
VCDS Version: 17.1.3.0 (x64) HEX-NET CB: 0.4336.4
VIN: ZHWGU8AJ9CLA12394 License Plate:
Chassis Type: AJ (40 - Lamborghini Gallardo (2008 > 2013))
Scan: 01 02 03 09 11 16 17 25 37 46 54 56 6C 77
VIN: ZHWGU8AJ9CLA12394 Mileage: 27570km-17131miles
Address 01: Engine ( ) Labels: None
Part No SW: 400 907 552 T HW: 400 907 552
Component: 5.2L V10HDZ/4V F ª0040
Revision: F2H09--- Serial number: XXXXXXXXXXXXXX
Coding: 061000091B0F0020
Shop #: WSC 53138 780 00100
VCID: 24040E94E702E161AD-8070
Load: 0.0 %
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Mileage: 27573 km
RPM: 2107 /min
Load: 28.2 %
Temperature: 26.0°C
Temperature: 30.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.668 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 27572 km
Load: 0.0 %
Temperature: 54.0°C
Temperature: 36.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.446 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 400-927-156-V1.clb
Part No SW: 400 927 156 E HW: CFC 311 L.0 2
Component: L140 EGEAR MY10-11U 0030
Revision: SBH02001 Serial number: 8FLNE131M
Coding: 0000003
VCID: 177E29582654BAF938-8042
Subsystem 1 - Part No: þýûúùø÷öô
Component: ‘��Ž�Œ‹Š ™˜—–•”“’ 0rqp
010119 - Clutch Temperature Too High
P2787 - 000 - - Intermittent
Mileage: 27193 km
RPM: 1321 /min
RPM: 6 /min
Torque: 122.4 Nm
Temperature: 20.0°C
58.00 %
005983 - Transmission
P175F - 000 - Basic Settings Not Performed
Mileage: 27572 km
Torque: 0.0 Nm
Temperature: 0.0°C
0.00 %
Address 03: ABS Brakes Labels: None
Part No SW: 400 614 517 G HW: 400 614 517 G
Component: ESP 8.1 H03 0020
Coding: 0004870
Shop #: WSC 00099 780 00200
VCID: 13665D4832AC96D944-8046
Fault Frequency: 52
Reset counter: 40
Mileage: 27180 km
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x0193
Hex Value: 0x0000
Address 09: Cent. Elect. Labels: 400-907-279.clb
Part No: 400 907 279 A
Component: int. Lastmodul USA 0220
Coding: 00023
Shop #: WSC 51503
VCID: 177E29587754BAF938-4AA4
Address 11: Engine II Labels: None
Load: 0.0 %
Voltage: 0.000 V
Mileage: 27573 km
RPM: 1815 /min
Load: 40.8 %
Temperature: 26.0°C
Temperature: 30.0°C
Voltage: 10.795 V
Address 16: Steering wheel Labels: 401-953-513.clb
Part No: 401 953 513
Component: Lenksáulenmodul 0303
Coding: 00011
Shop #: WSC 51503
VCID: 4FEE91388F04323920-4AC2
49-00 - No Communications
Address 17: Instruments Labels: None
Part No SW: 403 920 900 G HW: 403 920 900 G
Component: KOMBI+WFS 4 H02 0010
Revision: 0010 Serial number: 00000000000000
Coding: 0001221
Shop #: WSC 51503 780 00100
VCID: 1268584C0CB69FD14F-5118
01304 - Radio
Address 25: Immobilizer Labels: None
Coding: 0001221
01304 - Radio
Address 37: Navigation Labels: None
Part No SW: 400 035 192 P HW: 400 035 192 P
Component: RNS-E PU US H08 0210
Revision: 0000005S Serial number: AUZBZ7M7400077
Coding: 0100643
VCID: 187C2A642A4AB58131-50AE
Fault Status: 00101011
Reset counter: 25
Time Indication: 15
Mileage: 655350 km
Count: 2312
Clock: 11:39
Reset counter: 38
Date: 2010.10.21
Time: 13:11:52
Bin. Bits: 11011011
Bin. Bits: 11
Address 46: Central Conv. Labels: 8E0-959-433-MAX.clb
Part No: 8H0 959 433 L
Component: Komfortgerát T7B 5442
Coding: 28460
Shop #: WSC 51503
VCID: 3D32DBF035A8B0A9C2-4AC2
Subsystem 1 - Part No: 401959801D
Component: Tõrsteuer.FS BRM 4100
Subsystem 2 - Part No: 401959802D
Component: Tõrsteuer.BF BRM 4100
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
Address 56: Radio Labels: None
Coding: 0100643
Reset counter: 25
Time Indication: 15
Mileage: 655350 km
Count: 2312
Clock: 11:39
Reset counter: 38
Date: 2010.10.21
Time: 13:11:52
Bin. Bits: 11011011
Bin. Bits: 11
Address 77: Telephone Labels:
VCID: 55E26350ACD848E9EA-FFFE
End----------(Elapsed Time: 03:12, VBatt start/end: 12.3V/12.3V)-----------
