FYI Lamborghini Gallardo LP 2012 Performante HEX + NET WILL NOT WORK
SHARDUL
C?ID=248471
HEX + NET does not work on these cars. You cannot run a auto scan.
You can connect to some individual modules that will display some rudimentary info.
DO NOT GO TO AUTO TRANS AND THEM MEASURING BLOCKS- THE PROGRAM ACTIVATES THE EGEAR PUMP AND THE SHIFT FORK AUTOMATICALLY.
If/when someone makes such a car available to us, we'll be happy to have a look at why it doesn't work.
DrPeter
16.4905° S, 151.7375° W
- I have a few 2009 Gallardo LP and newer Auto-Scans that were sent to us by customers.
In fact I am looking at a 2012 Gallardo one right now and I see VCDS does have communication with the following controllers:
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 09: Cent. Elect.
Address 11: Engine II
Address 16: Steering wheel
Address 25: Immobilizer
Address 46: Central Conv.
Address 56: Radio
Address 77: Telephone
Are you choosing the correct Chassis Type from the pull-down menu in the Auto-Scan page?
Chassis Type: BZ (40 - Lamborghini Gallardo (2008 > 2013))
Scan: 01 02 03 09 11 16 17 25 37 46 54 56 6C 77
If you can provide us with the attempted Auto-Scan results that may help.
Thanks,
drpeter
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I scan Cluster and ECU on 2012 as well with out any problems .
SHARDUL
C?ID=248471
Now I selected the Lamborghini chassis from the drop down box in the Auto Scan menu (cables had to be used wifi did not have the option for the Lamborghini models)
Still having and issues with the Auto trans menu when you go to basic setting it automatically starts to change the gears and this will result in going into limp mode.
Any way to perform a e gear reset?
Saturday,17,June,2017,12:19:44:55582
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
VIN: ZHWGU8AJ9CLA12394   License Plate:
Chassis Type: AJ (40 - Lamborghini Gallardo (2008 > 2013))
VIN: ZHWGU8AJ9CLA12394   Mileage: 27570km-17131miles
Address 01: Engine (   )       Labels: None
   Part No SW: 400 907 552 T    HW: 400 907 552
   Component: 5.2L V10HDZ/4V F   ª0040
   Revision: F2H09---    Serial number: XXXXXXXXXXXXXX
   Coding: 061000091B0F0020
   Shop #: WSC 53138 780 00100
   VCID: 24040E94E702E161AD-8070
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -  - Intermittent
                    Mileage: 27573 km
                    RPM: 2107 /min
                    Load: 28.2 %
                    Temperature: 26.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 10.668 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Mileage: 27572 km
                    Temperature: 54.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.446 V
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 400-927-156-V1.clb
   Part No SW: 400 927 156 E    HW: CFC 311 L.0 2
   Component: L140 EGEAR MY10-11U 0030
   Revision: SBH02001    Serial number: 8FLNE131M
   Coding: 0000003
   VCID: 177E29582654BAF938-8042
   Subsystem 1 - Part No: þýûúùø÷öô
   Component: ‘��Ž�Œ‹Š ™˜—–•”“’   0rqp
010119 - Clutch Temperature Too High
               P2787 - 000 -  - Intermittent
                    Mileage: 27193 km
                    RPM: 1321 /min
                    RPM: 6 /min
                    Torque: 122.4 Nm
                    Temperature: 20.0°C
                        58.00 %
005983 - Transmission
               P175F - 000 - Basic Settings Not Performed
                    Mileage: 27572 km
                    Torque: 0.0 Nm
                    Temperature: 0.0°C
                        0.00 %
Address 03: ABS Brakes        Labels: None
   Part No SW: 400 614 517 G    HW: 400 614 517 G
   Component: ESP 8.1         H03 0020
   Coding: 0004870
   Shop #: WSC 00099 780 00200
   VCID: 13665D4832AC96D944-8046
            000 -  -  - Intermittent
                    Fault Frequency: 52
                    Reset counter: 40
                    Mileage: 27180 km
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0024
                    Hex Value: 0x0193
                    Hex Value: 0x0000
Address 09: Cent. Elect.        Labels: 400-907-279.clb
   Part No: 400 907 279 A
   Component: int. Lastmodul  USA 0220
   Coding: 00023
   Shop #: WSC 51503
   VCID: 177E29587754BAF938-4AA4
Address 11: Engine II        Labels: None
                    Voltage: 0.000 V
                    Mileage: 27573 km
                    RPM: 1815 /min
                    Load: 40.8 %
                    Temperature: 26.0°C
                    Temperature: 30.0°C
                    Voltage: 10.795 V
Address 16: Steering wheel        Labels: 401-953-513.clb
   Part No: 401 953 513
   Component: Lenksáulenmodul     0303
   Coding: 00011
   Shop #: WSC 51503
   VCID: 4FEE91388F04323920-4AC2
            49-00 - No Communications
Address 17: Instruments        Labels: None
   Part No SW: 403 920 900 G    HW: 403 920 900 G
   Component: KOMBI+WFS 4     H02 0010
   Revision: 0010        Serial number: 00000000000000
   Coding: 0001221
   Shop #: WSC 51503 780 00100
   VCID: 1268584C0CB69FD14F-5118
01304 - Radio
Address 25: Immobilizer        Labels: None
   Coding: 0001221
01304 - Radio
Address 37: Navigation        Labels: None
   Part No SW: 400 035 192 P    HW: 400 035 192 P
   Component: RNS-E PU US     H08 0210
   Revision: 0000005S    Serial number: AUZBZ7M7400077
   Coding: 0100643
   VCID: 187C2A642A4AB58131-50AE
                    Fault Status: 00101011
                    Reset counter: 25
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 2312
                    Clock: 11:39
                    Reset counter: 38
                    Date: 2010.10.21
                    Time: 13:11:52
                    Bin. Bits: 11011011
                    Bin. Bits:       11
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
   Part No: 8H0 959 433 L
   Component: Komfortgerát T7B    5442
   Coding: 28460
   Shop #: WSC 51503
   VCID: 3D32DBF035A8B0A9C2-4AC2
   Subsystem 1 - Part No: 401959801D
   Component: Tõrsteuer.FS BRM 4100
   Subsystem 2 - Part No: 401959802D
   Component: Tõrsteuer.BF BRM 4100
00955 - Key 1
            35-10 -  -  - Intermittent
00956 - Key 2
Address 56: Radio        Labels: None
   Coding: 0100643
                    Reset counter: 25
                    Time Indication: 15
                    Mileage: 655350 km
                    Count: 2312
                    Clock: 11:39
                    Reset counter: 38
                    Date: 2010.10.21
                    Time: 13:11:52
                    Bin. Bits: 11011011
                    Bin. Bits:       11
Address 77: Telephone        Labels:
   VCID: 55E26350ACD848E9EA-FFFE
End----------(Elapsed Time: 03:12, VBatt start/end: 12.3V/12.3V)-----------
