Results 1 to 5 of 5
Thread: FYI Lamborghini Gallardo LP 2012 Performante HEX + NET WILL NOT WORK
    Jul 2015
    HEX + NET does not work on these cars. You cannot run a auto scan.
    You can connect to some individual modules that will display some rudimentary info.
    DO NOT GO TO AUTO TRANS AND THEM MEASURING BLOCKS- THE PROGRAM ACTIVATES THE EGEAR PUMP AND THE SHIFT FORK AUTOMATICALLY.
    If/when someone makes such a car available to us, we'll be happy to have a look at why it doesn't work.
    Ceterum censeo, delenda est Daesh.
  3. Likes Bruce, Eric liked this post
    16.4905 S, 151.7375 W
    - I have a few 2009 Gallardo LP and newer Auto-Scans that were sent to us by customers.
    In fact I am looking at a 2012 Gallardo one right now and I see VCDS does have communication with the following controllers:
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
    Address 09: Cent. Elect.
    Address 11: Engine II
    Address 16: Steering wheel
    Address 25: Immobilizer
    Address 46: Central Conv.
    Address 56: Radio
    Address 77: Telephone
    Are you choosing the correct Chassis Type from the pull-down menu in the Auto-Scan page?
    Chassis Type: BZ (40 - Lamborghini Gallardo (2008 > 2013))
    Scan: 01 02 03 09 11 16 17 25 37 46 54 56 6C 77
    If you can provide us with the attempted Auto-Scan results that may help.
    Thanks,
    drpeter
  5. Likes Dana, Uwe liked this post
    Dallas (McKinney) ,TX ,USA
    I scan Cluster and ECU on 2012 as well with out any problems .
    Immobilizer/ECU
    Mk6 cluster in Mk5 -CLIK
    email : marinmm2001@yahoo.com
  7. Likes Dana liked this post
  8. #5
    Jul 2015
    Now I selected the Lamborghini chassis from the drop down box in the Auto Scan menu (cables had to be used wifi did not have the option for the Lamborghini models)
    Still having and issues with the Auto trans menu when you go to basic setting it automatically starts to change the gears and this will result in going into limp mode.
    Any way to perform a e gear reset?
    Saturday,17,June,2017,12:19:44:55582
    VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
    VIN: ZHWGU8AJ9CLA12394   License Plate:
    Chassis Type: AJ (40 - Lamborghini Gallardo (2008 > 2013))
    VIN: ZHWGU8AJ9CLA12394   Mileage: 27570km-17131miles
    Address 01: Engine (   )       Labels: None
       Part No SW: 400 907 552 T    HW: 400 907 552
       Component: 5.2L V10HDZ/4V F   0040
       Revision: F2H09---    Serial number: XXXXXXXXXXXXXX
       Coding: 061000091B0F0020
       Shop #: WSC 53138 780 00100
       VCID: 24040E94E702E161AD-8070
                        Load: 0.0 %
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    001299 - Incorrect Immobilizer Key
                   P0513 - 008 -  - Intermittent
                        Mileage: 27573 km
                        RPM: 2107 /min
                        Load: 28.2 %
                        Temperature: 26.0C
                        Temperature: 30.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 10.668 V
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Fault Status: 01101000
                        Mileage: 27572 km
                        Load: 0.0 %
                        Temperature: 54.0C
                        Temperature: 36.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.446 V
    Readiness: 0110 0101
    Address 02: Auto Trans        Labels: 400-927-156-V1.clb
       Part No SW: 400 927 156 E    HW: CFC 311 L.0 2
       Component: L140 EGEAR MY10-11U 0030
       Revision: SBH02001    Serial number: 8FLNE131M
       Coding: 0000003
       VCID: 177E29582654BAF938-8042
       Subsystem 1 - Part No:
       Component: ‘ŽŒ‹Š ™˜—–•”“’   0rqp
    010119 - Clutch Temperature Too High
                   P2787 - 000 -  - Intermittent
                        Mileage: 27193 km
                        RPM: 1321 /min
                        RPM: 6 /min
                        Torque: 122.4 Nm
                        Temperature: 20.0C
                            58.00 %
    005983 - Transmission
                   P175F - 000 - Basic Settings Not Performed
                        Mileage: 27572 km
                        Torque: 0.0 Nm
                        Temperature: 0.0C
                            0.00 %
       Part No SW: 400 614 517 G    HW: 400 614 517 G
       Component: ESP 8.1         H03 0020
       Coding: 0004870
       Shop #: WSC 00099 780 00200
       VCID: 13665D4832AC96D944-8046
                000 -  -  - Intermittent
                        Fault Frequency: 52
                        Reset counter: 40
                        Mileage: 27180 km
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x0024
                        Hex Value: 0x0193
                        Hex Value: 0x0000
    Address 09: Cent. Elect.        Labels: 400-907-279.clb
       Part No: 400 907 279 A
       Component: int. Lastmodul  USA 0220
       Coding: 00023
       Shop #: WSC 51503
       VCID: 177E29587754BAF938-4AA4
    Address 11: Engine II        Labels: None
                        Load: 0.0 %
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 0.000 V
                        Mileage: 27573 km
                        RPM: 1815 /min
                        Load: 40.8 %
                        Temperature: 26.0C
                        Temperature: 30.0C
                        Voltage: 10.795 V
    Address 16: Steering wheel        Labels: 401-953-513.clb
       Part No: 401 953 513
       Component: Lenksulenmodul     0303
       Coding: 00011
       Shop #: WSC 51503
       VCID: 4FEE91388F04323920-4AC2
                49-00 - No Communications
       Part No SW: 403 920 900 G    HW: 403 920 900 G
       Component: KOMBI+WFS 4     H02 0010
       Revision: 0010        Serial number: 00000000000000
       Coding: 0001221
       Shop #: WSC 51503 780 00100
       VCID: 1268584C0CB69FD14F-5118
    01304 - Radio
    Address 25: Immobilizer        Labels: None
       Coding: 0001221
    01304 - Radio
    Address 37: Navigation        Labels: None
       Part No SW: 400 035 192 P    HW: 400 035 192 P
       Component: RNS-E PU US     H08 0210
       Revision: 0000005S    Serial number: AUZBZ7M7400077
       Coding: 0100643
       VCID: 187C2A642A4AB58131-50AE
                        Fault Status: 00101011
                        Reset counter: 25
                        Time Indication: 15
                        Mileage: 655350 km
                        Count: 2312
                        Clock: 11:39
                        Reset counter: 38
                        Date: 2010.10.21
                        Time: 13:11:52
                        Bin. Bits: 11011011
                        Bin. Bits:       11
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
       Part No: 8H0 959 433 L
       Component: Komfortgert T7B    5442
       Coding: 28460
       Shop #: WSC 51503
       VCID: 3D32DBF035A8B0A9C2-4AC2
       Subsystem 1 - Part No: 401959801D
       Component: Trsteuer.FS BRM 4100
       Subsystem 2 - Part No: 401959802D
       Component: Trsteuer.BF BRM 4100
    00955 - Key 1
                35-10 -  -  - Intermittent
    00956 - Key 2
    Address 56: Radio        Labels: None
       Coding: 0100643
                        Reset counter: 25
                        Time Indication: 15
                        Mileage: 655350 km
                        Count: 2312
                        Clock: 11:39
                        Reset counter: 38
                        Date: 2010.10.21
                        Time: 13:11:52
                        Bin. Bits: 11011011
                        Bin. Bits:       11
    Address 77: Telephone        Labels:
       VCID: 55E26350ACD848E9EA-FFFE
    End----------(Elapsed Time: 03:12, VBatt start/end: 12.3V/12.3V)-----------
