Hi all, I have a Audi A8 and when the MAF sensor is connected, it fires up and immediately splutters and shuts off.
When I disconnect the MAF sensor, it starts and runs normally, can't seem to understand it. Bought a new MAF sensor and same issue with that
Any help would be greatly appreciated please. The rest of the faults don't worry me, just want the car running again.
Below is scan with MAF sensor disconnected then following scan is with MAF sensor connected.
Incidentally car had a new battery a year ago from Audi dealership.
SCAN TWO BELOW WITH MAF RECONNECTED
Thursday,15,June,2017,12:55:03:32179
VCDS Version: 17.1.3.0 (x64)
VIN: WAUZZZ4E46N000633 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77
VIN: WAUZZZ4E46N000633 Mileage: 121210km-75316miles
18-Aux. Heat -- Status: Sporadic communication error 1000
1E-Media Player 2 -- Status: Malfunction 0010
76-Park Assist -- Status: Sporadic communication error 1000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number: AUX3Z0E2360774
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2953D9EC808491099E-807C
005489 - Left Engine Mount Solenoid Valve (N144)
P1571 - 001 - Short to Plus
Fault Status: 01100001
Mileage: 121054 km
Date: 2017.05.29
Time: 17:43:41
Torque: 171.6 Nm
Voltage: 11.48 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
000260 - Mass Air Flow Sensor (G70)
P0104 - 001 - Intermittent
Mileage: 121054 km
Date: 2017.05.29
Time: 17:43:41
000258 - Mass Air Flow Sensor (G70)
P0102 - 001 - Signal too Low
Mileage: 121054 km
Date: 2017.05.29
Time: 19:41:42
RPM: 798 /min
Torque: 93.6 Nm
Duty Cycle: 80.9 %
Voltage: 11.40 V
Absolute Pres.: 999.6 mbar
Mass Air / Rev.: 470.0 mg/str
006256 - Transmission Mount Valve 1 (N262)
P1870 - 001 - Open Circuit
Mileage: 121054 km
Date: 2017.05.29
Time: 19:41:42
Readiness: 1 2 0 0 0
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0090
Revision: --H01--- Serial number: 4009612
Coding: 0000001
VCID: 254BD5DCEC9CB569BA-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 2241CEC0FDB24251DF-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E2360774
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58B5AC28EB6ED881F1-800C
Component: ELV XXXX
Reset counter: 249
Mileage: 120848 km
Date: 2017.05.05
Time: 18:59:42
00956 - Key 2
Reset counter: 249
Mileage: 120848 km
Date: 2017.05.05
Time: 18:59:42
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
VCID: 234FCBC4E2A84B59D4-8076
01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down
Fault Status: 00100011
Reset counter: 249
Mileage: 121052 km
Date: 2017.05.29
Time: 16:44:27
01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up
Reset counter: 249
Mileage: 121052 km
Date: 2017.05.29
Time: 16:44:27
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 F HW: 4E0 035 729 A
Component: Interfacebox H43 1110
Revision: 00000000 Serial number: 300CN057549348
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 318LS047515118
Subsystem 3 - Serial number: 7418.02.0500000000218B0123ÿ
Subsystem 4 - Serial number: 8B0123ÿ
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000063616
Coding: 1067025
VCID: 1C3DF038DFD674A115-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0143121
VCID: 3163318CA854E9C956-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00139548
Shop #: WSC 02313
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63CF8BC4A2280B5994-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65CB95DCAC1C75697A-8030
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 P HW: 4E0 920 950 P
Component: KOMBIINSTR. VDO H70 0400
Revision: D01 Serial number: AUDID3E2000191
Coding: 0000413
Shop #: WSC 00196 067 57207
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
VCID: 1A31F620D5E20A9107-804E
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 190030522700D4
Coding: FCFE7FDE2B7504
VCID: 2757DFD49690A77988-8072
Fault Frequency: 9
Reset counter: 7
Mileage: 120605 km
Date: 2017.04.18
Time: 12:21:25
Fault Frequency: 9
Reset counter: 7
Mileage: 120605 km
Date: 2017.04.18
Time: 12:21:25
01327 - Control Module for Parking Aid (J446)
Reset counter: 249
Mileage: 121054 km
Date: 2017.05.29
Time: 16:44:33
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7133901
VCID: 1B3FF324DAD873991C-804E
Reset counter: 244
Mileage: 120997 km
Date: 2017.05.18
Time: 15:19:44
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Reset counter: 249
Mileage: 120848 km
Date: 2017.05.05
Time: 18:59:42
00956 - Key 2
Reset counter: 249
Mileage: 120848 km
Date: 2017.05.05
Time: 18:59:42
Part No SW: 4E0 910 158 HW: 4E0 919 158
Component: KLIMA-STG. FOND 015 0210
Revision: 00000017 Serial number: 00000000025396
Coding: 0000000
VCID: 61C381CCB834194986-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 00196 210 90007
VCID: 2A5126E085829A1197-807E
01400 - Suspension Level Control
Fault Status: 00100001
Reset counter: 238
Component: Sitzmemory FS H08 0060
Coding: 3670122
01881 - Lumbar Support Height Adjustment Button (E335); Down
Fault Status: 01100011
Reset counter: 227
Mileage: 120468 km
Date: 2017.04.07
Time: 14:17:43
01880 - Lumbar Support Height Adjustment Button (E335); Up
Reset counter: 227
Mileage: 120468 km
Date: 2017.04.07
Time: 14:17:43
01877 - Belt Height Adjustment Button (E333); Down
Reset counter: 227
Mileage: 120468 km
Date: 2017.04.07
Time: 14:17:43
01876 - Belt Height Adjustment Button (E333); Up
Reset counter: 227
Mileage: 121052 km
Date: 2017.05.29
Time: 16:28:27
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H44 1060
Revision: 00000000 Serial number: 305CM057577044
VCID: 3B7F13A47A181399FC-806E
02261 - Data Medium
Fault Status: 00101110
Fault Frequency: 22
Reset counter: 10
Mileage: 120581 km
Date: 2017.04.17
Time: 16:51:22
Hex Value: 0x5941
Hex Value: 0x6E8D
Hex Value: 0x0900
Hex Value: 0x5D53
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000430700086
Coding: 0035968
VCID: 1D3BFD3CC4CC7DA9E2-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM002 0060
Coding: 0026926
VCID: 2045C4C8F3BE5041C9-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503160277
Coding: 0004349
Component: Heckdeckel P14H06 0070
Component: Neigungssensor H03 0020
01134 - Alarm Horn (H12)
Fault Status: 01101100
Reset counter: 130
Mileage: 104227 km
Date: 2014.05.01
Time: 15:41:27
Reset counter: 130
Mileage: 104227 km
Date: 2014.05.01
Time: 15:41:27
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000012473
Coding: 0000013
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000057124
Coding: 0010101
VCID: 1E39FA30C9CA66B1FB-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM002 0060
Coding: 0026926
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000221
02596 - Rear Brake Pads Worn
Fault Status: 01100010
Fault Frequency: 76
Reset counter: 195
Mileage: 120912 km
Date: 2017.05.13
Time: 16:00:28
Voltage: 12.11 V
Count: 60
008 - Implausible Signal
Fault Status: 01111000
Reset counter: 195
Mileage: 119224 km
Date: 2016.09.08
Time: 14:30:04
Voltage: 11.59 V
Count: 61
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 2649D2D0919ABE71B3-8072
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396C-057505957
Coding: 0000001
Fault Status: 00100111
Reset counter: 240
Mileage: 120454 km
Date: 2017.04.06
Time: 17:45:23
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 C
Component: TV analog TUNER H15 0270
Revision: 00000036 Serial number: 00000000047989
Coding: 0000001
Shop #: WSC 00196 210 65502
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000004165
Shop #: WSC 00551 210 84039
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 000915105D
Coding: 344530393135313035412056413030303039313531303544
Shop #: WSC 60782 001 1048576
02273 - Quiescent Current Stage 2
Mileage: 121054 km
Date: 2017.05.29
Time: 17:54:59
02276 - Quiescent Current Stage 5
Mileage: 121054 km
Date: 2017.05.29
Time: 17:55:09
02274 - Quiescent Current Stage 3
Mileage: 121054 km
Date: 2017.05.29
Time: 17:55:09
02277 - Quiescent Current Stage 6
Mileage: 121054 km
Date: 2017.05.29
Time: 17:55:29
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0026926
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 D HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0560
Revision: 00000000 Serial number: 00000502240077
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0026926
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720506401787
Coding: 0001108
VCID: 2143C1CCF8B45949C6-8074
Part No SW: 4E0 910 336 C HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007541172
Coding: 0010900
End-------------------------(Elapsed Time: 03:30)--------------------------
Thursday,15,June,2017,13:07:13:32179
Coding: 0011973
Mileage: 121216 km
Date: 2017.06.15
Time: 13:02:24
Torque: 167.7 Nm
Voltage: 11.93 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
Coding: 0000001
Coding: 0008357
Coding: 0412672
Component: ELV XXXX
00956 - Key 2
Fault Frequency: 0
Reset counter: 12
Mileage: 121216 km
Date: 2017.06.15
Time: 13:01:52
Coding: 3670112
Coding: 1067025
Coding: 0143121
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0431707
Coding: 0112141
Coding: 0000413
Coding: 0000001
Coding: 0412672
Component: ELV XXXX
00956 - Key 2
Fault Frequency: 0
Reset counter: 12
Mileage: 121216 km
Date: 2017.06.15
Time: 13:01:52
Coding: 0000000
Coding: 0015510
Coding: 3670122
Reset counter: 227
Mileage: 120468 km
Date: 2017.04.07
Time: 14:17:43
Reset counter: 227
Mileage: 120468 km
Date: 2017.04.07
Time: 14:17:43
Reset counter: 227
Mileage: 121052 km
Date: 2017.05.29
Time: 16:28:27
Reset counter: 227
Mileage: 121052 km
Date: 2017.05.29
Time: 16:28:27
Coding: 0035968
Coding: 0026926
Coding: 0004349
Reset counter: 130
Mileage: 104227 km
Date: 2014.05.01
Time: 15:41:27
Reset counter: 130
Mileage: 104227 km
Date: 2014.05.01
Time: 15:41:27
Coding: 0000013
Coding: 0010101
Coding: 0026926
Revision: AV1C1010
Coding: 0000221
Fault Frequency: 79
Reset counter: 195
Mileage: 120912 km
Date: 2017.05.13
Time: 16:00:28
Voltage: 12.11 V
Count: 60
Reset counter: 195
Mileage: 119224 km
Date: 2016.09.08
Time: 14:30:04
Voltage: 11.59 V
Count: 61
Coding: 0000018
Coding: 0000001
Reset counter: 240
Mileage: 120454 km
Date: 2017.04.06
Time: 17:45:23
Coding: 0000001
Coding: 0026926
Coding: 0026926
Coding: 0001108
Coding: 0010900
End-------------------------(Elapsed Time: 03:22)--------------------------
