Need help with a 09 central long code on a 2013 VW Passat
Customer complaint is that everytime car hits 20 km/hr central lock attempts to lock the car no matter if it is locked or not. (is it a normal condition?).
Here the complete auto scan as well as a similar vehicle long code.
6F200E38803B28D4800000003400082007F1A00042801920C60420040C70
Wednesday,14,June,2017,17:58:06:05043
VCDS Version: 17.1.3.0
Dealer/Shop Name: rpm
VIN: 1VWAH7A3XDC081881 License Plate: RAY2
Mileage: 61600km-38276mi Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 46 4F 52 56 62 72 77
VIN: 1VWAH7A3XDC081881 Mileage: 61600km-38276miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 DD HW: 07K 907 309 A
Component: 2,5l R5/4V G01 4338
Revision: T6H02--- Serial number:
Coding: 0000075
Shop #: WSC 09003 957 00200
VCID: 73EFACEB12A69BD9E4-8026
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 73.0°C
Temperature: 57.0°C
Absolute Pres.: 780.0 mbar
Part No SW: 09G 927 750 LH HW: 09G 927 750 LH
Component: AQ 250 6F 2251
Revision: 00H97000 Serial number:
Coding: 0000328
VCID: 0201F92F5D1CA251FF-8056
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Revision: 00H31001
Coding: C54BC0F5892A08FBA31303EC911A1061261000
VCID: 7CFD87D7FFF8D4A1B5-8028
02214 - Tire Pressure Warning
Reset counter: 119
Mileage: 61104 km
Date: 2017.05.15
Time: 20:51:18
Count: 32768
Count: 12800
Count: 16401
Count: 49152
Count: 512
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 561 907 426 HW: 561 907 426
Component: AC Manuell H02 0101
Revision: 00001K07
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 58B5FB472300D881F1-800C
Part No SW: 5K0 937 085 S HW: 5K0 937 085 S
Component: BCM PQ35 B+ 021 0068
Revision: BH021001
Coding: 27200E38803B28D0800000003400082007F1A00042801920C60420040C70
Shop #: WSC 20200 993 136720
VCID: 438F3C2BC2866B59B4-8016
Fault Status: 00100011
Reset counter: 125
Mileage: 61608 km
Date: 2017.06.14
Time: 17:19:20
Term 15 On
Voltage: 13.50 V
Reset counter: 125
Mileage: 61608 km
Date: 2017.06.14
Time: 17:19:20
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM057682
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FE7A09BB68EBF3900-803A
Serial number: 6940000Y120000N6B80I
Coding: 303048
Serial number: 3572MSME17146273ZZZO
Serial number: 3582MSME5E617173ZZZ
Serial number: 3516KSME7E713620ZZZT
Serial number: 3526KSME7E443C20ZZZ-
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME7F38561FZZZB
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME3D19421FZZZ0
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 501 R HW: 5K0 953 569 H
Revision: FF010041 Serial number: 20120803101250
Coding: 498A140000
VCID: 3A7141CFBD4C2A91E7-806E
Subsystem 1 - Part No SW: 561 959 537 HW: 561 959 537
Component: E221__MFL-YVJ H07 0022
Coding: 620000
Part No SW: 561 920 860 B HW: 561 920 860 B
Component: KOMBI H06 0705
Coding: 330E01
VCID: 1737B87BEE9E17F938-8042
Part No SW: 7N0 907 530 AH HW: 7N0 907 530 AH
Component: J533 Gateway H50 1634
Revision: H50 Serial number: 04121203290248
Coding: 461000
VCID: 76E995FFC1D48EF1C3-8022
Component: IMMO H06 0705
VCID: 6AD1B18F8D6C5A1157-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662329988
VCID: 29538E8340EA91099E-807C
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0005848847
Coding: 0404D5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BBFE44B52363399DC-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 125
67074 - Motors for Central Locking
B122B 01 [009] - Electrical Failure
Reset counter: 84
Mileage: 61519 km
Date: 2017.06.09
Time: 18:28:29
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Fault Frequency: 54
Reset counter: 125
Mileage: 61519 km
Date: 2017.06.09
Time: 18:28:29
67584 - Warning Light for Front Door
B11F5 01 [008] - Electrical Failure
Reset counter: 125
Mileage: 39985 km
Date: 2015.10.31
Time: 19:17:14
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 125
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AH
Component: EZE_2 H50 1634
Coding: 00000008
VCID: 6FE7A09BBE8EBF3900-803A
Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0005847719
Coding: 0404D4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CBDE757573834A1D5-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Reset counter: 85
Mileage: 61608 km
Date: 2017.06.14
Time: 17:37:53
Reset counter: 125
Mileage: 61608 km
Date: 2017.06.14
Time: 17:37:54
Reset counter: 124
Mileage: 60846 km
Date: 2017.05.06
Time: 18:15:45
Reset counter: 125
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0006
Revision: -----06S Serial number: VWZ4Z6M3479205
Coding: 03000400010000
VCID: 234F9CAB22C64B59D4-8076
00857 - CD Changer Unit (R41)
Reset counter: 165
Mileage: 39477 km
Date: 2015.10.27
Time: 12:48:03
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663606239
Coding: 0510040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
End-------------------------(Elapsed Time: 03:28)--------------------------
