Results 1 to 4 of 4
Thread: Long COde Help with 2013 passat
    Mexico
    Need help with a 09 central long code on a 2013 VW Passat
    Customer complaint is that everytime car hits 20 km/hr central lock attempts to lock the car no matter if it is locked or not. (is it a normal condition?).
    Here the complete auto scan as well as a similar vehicle long code.
    6F200E38803B28D4800000003400082007F1A00042801920C6 0420040C70
    Wednesday,14,June,2017,17:58:06:05043
    VCDS Version: 17.1.3.0
    Dealer/Shop Name: rpm
    VIN: 1VWAH7A3XDC081881   License Plate: RAY2
    Mileage: 61600km-38276mi   Repair Order:
    Chassis Type: A3 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 46 4F 52 56 62 72 77
    VIN: 1VWAH7A3XDC081881   Mileage: 61600km-38276miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
       Component: 2,5l R5/4V      G01 4338
       Revision: T6H02---    Serial number:
       Coding: 0000075
       Shop #: WSC 09003 957 00200
       VCID: 73EFACEB12A69BD9E4-8026
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 73.0C
                        Temperature: 57.0C
                        Absolute Pres.: 780.0 mbar
       Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
       Component: AQ 250 6F           2251
       Revision: 00H97000    Serial number:
       Coding: 0000328
       VCID: 0201F92F5D1CA251FF-8056
       Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
       Revision: 00H31001
       Coding: C54BC0F5892A08FBA31303EC911A1061261000
       VCID: 7CFD87D7FFF8D4A1B5-8028
    02214 - Tire Pressure Warning
                        Reset counter: 119
                        Mileage: 61104 km
                        Date: 2017.05.15
                        Time: 20:51:18
                        Count: 32768
                        Count: 12800
                        Count: 16401
                        Count: 49152
                        Count: 512
       Part No SW: 561 907 426     HW: 561 907 426
       Component: AC Manuell    H02 0101
       Revision: 00001K07
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 58B5FB472300D881F1-800C
       Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
       Component: BCM PQ35 B+   021 0068
       Revision: BH021001
       Coding: 27200E38803B28D0800000003400082007F1A00042801920C60420040C70
       Shop #: WSC 20200 993 136720
       VCID: 438F3C2BC2866B59B4-8016
                        Fault Status: 00100011
                        Reset counter: 125
                        Mileage: 61608 km
                        Date: 2017.06.14
                        Time: 17:19:20
                        Voltage: 13.50 V
                        Reset counter: 125
                        Mileage: 61608 km
                        Date: 2017.06.14
                        Time: 17:19:20
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003ENM057682
       Coding: 00003548
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FE7A09BB68EBF3900-803A
       Serial number: 6940000Y120000N6B80I
       Coding: 303048
       Serial number: 3572MSME17146273ZZZO
       Serial number: 3582MSME5E617173ZZZ
       Serial number: 3516KSME7E713620ZZZT
       Serial number: 3526KSME7E443C20ZZZ-
       Serial number: 3556LSME7F38561FZZZB
       Serial number: 3566LSME3D19421FZZZ0
       Part No SW: 1K5 953 501 R    HW: 5K0 953 569 H
       Revision: FF010041    Serial number: 20120803101250
       Coding: 498A140000
       VCID: 3A7141CFBD4C2A91E7-806E
       Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
       Component: E221__MFL-YVJ  H07 0022
       Coding: 620000
       Part No SW: 561 920 860 B    HW: 561 920 860 B
       Component: KOMBI         H06 0705
       Coding: 330E01
       VCID: 1737B87BEE9E17F938-8042
       Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
       Component: J533  Gateway H50 1634
       Revision:   H50       Serial number: 04121203290248
       Coding: 461000
       VCID: 76E995FFC1D48EF1C3-8022
       Component: IMMO          H06 0705
       VCID: 6AD1B18F8D6C5A1157-803E
       Revision: A1001003    Serial number: 7662329988
       VCID: 29538E8340EA91099E-807C
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0005848847
       Coding: 0404D5
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BBFE44B52363399DC-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 125
    67074 - Motors for Central Locking
              B122B 01 [009] - Electrical Failure
                        Reset counter: 84
                        Mileage: 61519 km
                        Date: 2017.06.09
                        Time: 18:28:29
    67330 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Fault Frequency: 54
                        Reset counter: 125
                        Mileage: 61519 km
                        Date: 2017.06.09
                        Time: 18:28:29
    67584 - Warning Light for Front Door
              B11F5 01 [008] - Electrical Failure
                        Reset counter: 125
                        Mileage: 39985 km
                        Date: 2015.10.31
                        Time: 19:17:14
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 125
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
       Component: EZE_2         H50 1634
       Coding: 00000008
       VCID: 6FE7A09BBE8EBF3900-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0005847719
       Coding: 0404D4
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CBDE757573834A1D5-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
                        Reset counter: 85
                        Mileage: 61608 km
                        Date: 2017.06.14
                        Time: 17:37:53
                        Reset counter: 125
                        Mileage: 61608 km
                        Date: 2017.06.14
                        Time: 17:37:54
                        Reset counter: 124
                        Mileage: 60846 km
                        Date: 2017.05.06
                        Time: 18:15:45
                        Reset counter: 125
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
       Component: LOW NAR       H02 0006
       Revision: -----06S    Serial number: VWZ4Z6M3479205
       Coding: 03000400010000
       VCID: 234F9CAB22C64B59D4-8076
    00857 - CD Changer Unit (R41)
                        Reset counter: 165
                        Mileage: 39477 km
                        Date: 2015.10.27
                        Time: 12:48:03
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663606239
       Coding: 0510040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
    End-------------------------(Elapsed Time: 03:28)--------------------------
    Verified VCDS User Vasco Ferraz's Avatar
    Jan 2017
    Portugal
    Your client thinks that the car is locked and yet the computer tries to lock it again.
    However, the car has lots of errors related to the locks, meaning that the control module does not see the doors locked so it will try to lock them again.
    First you should repair all locks errors.
    Vasco Ferraz
  3. Likes Uwe, Ashraf6119 liked this post
    Mexico
    Lock errors came from a corrupted log code for shure. Been digging a lot in this forum and found the following log codes, any recommendation on which one could be the best??
    6F200E18902B08D408800001160004480071008640801D6064 8060000C70 2013 NAR CBUA
    6F200E1B802B2AD408880001160004480071008640A00D6064 8060000C70 2013 CBUA
    0008000000000000009800801400006403510088426D816064 80C7200041 2013 TDI CFFB
    Regards
    New User
    Jun 2017
    Try this:
    6F200E18802B28D408000000040000E0037100864080196064 8060000C70
    Isn't there a coding/adaptation for autolocking in 09?
