Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 12 jetta 2.5l abs module coding (MK60EC1)
  1. #21
    Okay now what about the Immobilizer?
    0x25 advanced ID?
  2. Likes Jetta ,97 liked this post
  3. #22
    Jun 2017
    Friday,16,June,2017,15:02:39:57792
    VCDS Version: Release 17.1.3 (x64)
    Address 25: Immobilizer
    Control Module Part Number: 5K0 953 234
    Component and/or Version: IMMO H04 0604
    Software Coding: 000000
    Work Shop Code: WSC 00000
    VCID: 6A9827F38D9E291157-803E
    Advanced Identification/FAZIT
    Identification: ZYS-000
    Date: 03.10.11
    Manufacturer number: 4131
    Test stand number: 1042
    Flash Status
    Flash Date: 00.00.00
    Software
    OSEK-OS: 03.14.00
    HiSpd Net: 01.12.01
    Misc.
    Hardware number: 5K0 953 234
    Workshop System Name: J334
    Equipment/PR Code: 2D2D2D2D2D2D2D2D
    Dataset Number: -----------
    Dataset Version: ----
    End of Line Equipment Level: ------------------
    ASAM Dataset: EV_Immo_UDS_VDD_RM09
    ASAM Dataset Revision: A03009
    Car Info
    Chassis Number: 3VWDP7AJ6CM129727
    Immobilizer
    Transponder ID (Current val.): F09B5499
    Transponder ID 1: F09B5499
    VCDS Info:
    Labels: 5K0-920-xxx-25.clb
  4. Likes Jetta ,97 liked this post
  5. #23
    Dallas (McKinney) ,TX ,USA
    Is this VIN same on Car : 3VWDP7AJ6CM129727?
    If it is , then tell customer go back to dealer and tell them to finish what they started .
    ABS coding is part of the cluster adaptation.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  6. #24
    Jun 2017
    I will check if so i tell customer to go back to dealer
  7. #25
    Try this OP
    B14B400C492608038D1202E6922E1061A70000
  8. #26
    Jun 2017
    Thanks guys jetta 97 and jack i check vin is the same i try the latest coding and is not working i will.send itbto tge dealer but thaks for your time guys...
  9. #27
    Please post the solution if you can to help others when they are done coding it.
