Results 11 to 20 of 27
Thread: 12 jetta 2.5l abs module coding (MK60EC1)
    I can help fix this through the mail with a complete documentation trail to prove ownership.
    The dual identity will be combined in all eeproms to verify the path.
  2. #12
    Jun 2017
    And if the gymg dont want to.do it they need to take it back to the dealer to tbem to fix that right?
  3. #13
    I would see if dealer would correct it free first but most likely wont take responsibility from what I have witnessed.
  4. Likes Ashraf6119 liked this post
  5. #14
    Jun 2017
    Ok I witnessed that too. Just let me know what is next step thanks..
  6. #15
    Go to contact form in my signature & start a written record request for immobilizer at website.
  7. #16
    Yup correct module is the VIN the same in 0x25 advanced ID and 0x01-08-081 or advanced ID?
    Vehicle Identification No. 3VWDP7AJ6CM129727
    Model Jetta
    JEM
    Date of production 20.03.2012
    Year 2012
    Sales type 162WS3
    Engine Code CBUA
    Transmission Code MAN
    Axle drive 6A
    Equipment NT
    Roof color A1
    Exterior color / Paint Code A1 / 041
  8. Likes Jetta ,97 liked this post
  9. #17
    Dallas (McKinney) ,TX ,USA
    You did not answer Jacks, and Mine question, is it VIN in cluster , ECU and car match?
    To see VIn in 25-Immobilzer and 01-Engine go to advance ID .
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  10. #18
    Time for JPPSG and verify for FOD!
  11. Likes protekorl, Jetta ,97 liked this post
  12. #19
    Jun 2017
    Im sorry guys has been a crazy day at the shop. I will check asap and sorry again
  13. #20
    Jun 2017
    Friday,16,June,2017,13:27:11:57792
    VCDS Version: Release 17.1.3 (x64)
    Address 01: Engine
    Control Module Part Number: 07K 906 055 CJ
    Component and/or Version: 2,5l R5/4V G01 3691
    Software Coding: 0000075
    Work Shop Code: WSC 00066
    VCID: 78BC0DBB0B328B81D1-802C
    Advanced Identification
    Identification: ZSC-864
    Revision: T4H06---
    Date: 11.03.12
    Test stand number: 7825
    Manufacturer number: 0160
    Flash Status
    Programming Attempts: 0
    Successful Attempts: 0
    Programming Status: 00000000
    Required Conditions: 00000000
    Flash Tool Code: 00000 000 00000
    Flash Date: 00.00.00
    Software
    P0101
    M14VA0
    Misc.
    Hardware number: 07K 907 309 B
    Immo Challenge: A5 5F 15 21
    Car Info
    Chassis Number: 3VWDP7AJ6CM129727
    Engine code: CBU
    VCDS Info:
    Labels: 07K-906-055-CBT.clb
    Readiness: 06A-906-032-BGP.crd
    Friday,16,June,2017,13:31:09:57792
    Address 25: Immobilizer
    Control Module Part Number: 5K0 953 234
    Component and/or Version: IMMO H04 0604
    Software Coding: 000000
    Work Shop Code: WSC 00000
    VCID: 6A9827F38D9E291157-803E
    Advanced Identification/FAZIT
    Identification: ZYS-000
    Date: 03.10.11
    Manufacturer number: 4131
    Test stand number: 1042
    Flash Status
    Software
    OSEK-OS: 03.14.00
    HiSpd Net: 01.12.01
    Misc.
    Hardware number: 5K0 953 234
    Workshop System Name: J334
    Equipment/PR Code: 2D2D2D2D2D2D2D2D
    Dataset Number: -----------
    Dataset Version: ----
    End of Line Equipment Level: ------------------
    ASAM Dataset: EV_Immo_UDS_VDD_RM09
    ASAM Dataset Revision: A03009
    Car Info
    Immobilizer
    Transponder ID (Current val.): F09B5499
    Transponder ID 1: F09B5499
    VCDS Info:
    Labels: 5K0-920-xxx-25.clb
  14. Likes Jack@European_Parts, Jetta ,97 liked this post
