Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 12 jetta 2.5l abs module coding (MK60EC1)
    Jun 2017
    Im new at forum and have a 12 jetta 2.5 where after replace the instrument cluster and send it to the dealer to relearn the inmobilizer, now i have a code on the abs module of no coding. I check the auto scan and the current codes and is 00000000000000000000 is any way i can find that coding for the abs module.
    this is the auto scan. please help thanks...
    Wednesday,14,June,2017,16:19:31:57792
    VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4341.4
    VIN: 3VWDP7AJ6CM129727   License Plate:
    Mileage: 114860km-71370mi   Repair Order:
    Chassis Type: AJ (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
    VIN: 3VWDP7AJ6CM129727   Mileage: 114860km-71370miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 CJ    HW: 07K 907 309 B
       Component: 2,5l R5/4V      G01 3691
       Revision: T4H06---    Serial number:
       Coding: 0000075
       Shop #: WSC 00066 067 57207
       VCID: 78BC0DBB0B328B81D1-802C
    001169 - Secondary Air Injection System: Bank 1
                   P0491 - 000 - Insufficient Flow
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 18:28:04
                        RPM: 1357 /min
                        Load: 48.2 %
                        Temperature: 29.0C
                        Temperature: 27.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.970 V
    Readiness: 0010 1101
       Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
       Component: AQ 250 6F           1914
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 004C655B53E2C341E9-8054
       Revision: 00H31001
       VCID: 7DB21CAFE410AEA982-8028
                        Reset counter: 134
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 21:01:37
                        Count: 16391
                        Count: 12
                        Count: 24576
                        Count: 195
                        Count: 45824
                        Count: 256
                        Count: 9984
       Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
       Component: J301  Klimaanlage   0203
       Revision: 2001010S    Serial number: 00000000829944
       VCID: 6FAE36E77E7CCC3900-803A
    Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0251
       Revision: B2066001    Serial number: 04371069121166
       Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
       VCID: 2F2EF6E77EFC8C3940-807A
       Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  004 3464
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Serial number: 14102584130731195057
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Serial number: 0088301
       Coding: 020000
       Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3464
       Coding: 800000
       Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586130801204452
       Coding: 800000
    00975 - Heated Rear Window (Z1)
                        Fault Status: 00100110
                        Reset counter: 174
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 20:48:08
    03591 - Control Circuit for Horn
                        Reset counter: 134
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 20:51:25
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   014 0808
       Serial number: 003GTM03J2BJ
       Coding: 00003936
       Shop #: WSC 05234 444 100159
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3424F98B9FDAAFE13D-8060
       Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
       Component: BF-Gewichtss.  H10 0045
       Serial number: 6940000Y120000C9XD0.
       Coding: 303036
       Serial number: 3572MSME3C76056AZZZ%
       Serial number: 3582MSME3530107AZZZN
       Serial number: 3516KSME715F5717ZZZ.
       Serial number: 3526KSME2F5D5717ZZZ2
       Serial number: 3556LSME145B7714ZZZY
       Serial number: 3566LSME07227C15ZZZV
       Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
       Component: KOMBI         H04 0604
       Coding: 270201
       Shop #: WSC 19565 002 1048576
       VCID: 2A18E7F34D1EE91197-807E
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0251
       Revision: B2066001
       Coding: 102200
       VCID: 70AC359BA342D3C119-8024
    01304 - Radio
                        Reset counter: 134
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 21:02:39
    02078 - Media Player Position 3 (R120)
                        Reset counter: 134
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 21:02:39
       Component: IMMO          H04 0604
       VCID: 6A9827F38D9E291157-803E
    Address 2E: Media Player 3
    Address 56: Radio
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H12 2902
       Revision: 1B001001    Serial number: 00007661732039
       Coding: 0A10040000010110
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 271E1EC75E0CD47988-8072
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 133
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 18:59:52
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 133
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 18:59:52
    0022 - Radio
              U1066 00 [009] - No Communication
                        Reset counter: 133
                        Mileage: 114869 km
                        Date: 2017.06.08
                        Time: 18:59:52
    End----------(Elapsed Time: 02:07, VBatt start/end: 12.0V/11.9V)-----------
    Address 03: DTCs cleared
    Address 01: DTCs clearedding is 000000000000000000000 is any way you guys can help me to find the old code......
    Did you run an Auto-Scan prior to removing the original instrument cluster? VCDS automatically saves a "hidden" copy of Auto-Scans in the \Ross-Tech\VCDS\Scans folder. Take a look in there.
    If you didn't run Auto-Scan prior to removing the instrument cluster... now you know why you should. If no one captured the ABS coding prior, reply back and we'll see what we can do.
    Jef
  3. Likes Ashraf6119 liked this post
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Try this coding and let us know..........
    a13b800d09240003851201e690200002200000
    I'm in my office now, got in early and took a look at this. Based on my research, your ABS coding should be:
    B14B400C492408038D1202E692201061A71000
    You may also find our wiki page helpful:
    http://wiki.ross-tech.com/wiki/index...onics_(MK60EC1)
    Jef
  6. Likes Uwe liked this post
    I would like to know why if the dealer installed a cluster or relearned the immobilizer why did they not recode the ABS because it is in fact part of the work procedure?
  8. Likes Uwe, Jetta ,97 liked this post
  9. #6
    Coding: 0000075
    Coding: 0000840
    Revision: 00H31001
    B14B400C492408038D1202E692201061A71000 JEF
    A13B800D09240003851201D690200002200000 ASH
    0000000009240003001200E690200000000000 VIN Stripped LHD
    B14B440C492608008D1322E6921E1061A70000 From donor
    B14B440C492408038D1202E692201061A70000 Try this...........
    Donor abstract matched config
    VIN: 3VWDP7AJ6CM346825
    Component: 2,5l R5/4V G01 1156
    Coding: 0000075
    Address 02: Auto Trans Labels: 09G-927-750.lbl
    Component: AQ 250 6F 2041
    Revision: 00H97000 Serial number:
    Coding: 0000840
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: B14B440C492608008D1322E6921E1061A70000
  10. #7
    Dallas (McKinney) ,TX ,USA
    Exactly same question, Coding ABS is part of the job.
    Or VIN in cluster and car do not match , then online ABS coding can not be done.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  11. Likes Jack@European_Parts, Uwe liked this post
  12. #8
    You gained another star Marin.....
    Very good point in follow up but vw will change the identity of every other controller in car to donor identity.
    So OP now the question is does the Vin number match the actual chassis?
  13. Likes Jetta ,97 liked this post
  14. #9
    Jun 2017
    Jef and Jack thanks for reply the cluster was replace with a use one the customer swap the clusters before send it to the dealer after that he have this coding code on abs module i tell him to tell the dealer to code that module at the same time they work with the inst cluster but they didn't. Now im stuck with the problem and thats why i dont have the auto scan eather.
  15. #10
    Jun 2017
    I try the coding but is giving me error12 sub function not supported or invalid format
