Intermittent failure caused by ABS sensors
downtime
C?ID=280813
I installed the upgraded WHT003864A ABS rear wheel sensors and recoded my ABS to support the new sensors as preparation to ACC retrofit. No errors on dash but I see two errors on vcds autoscan. These are not there constantly, they appear after the car speed exceeds 80km/h. No lights on dash just these two errors show up in VCDS scan.
My sensors are ATE made but not OEM.
You can see the errors in the following full auto scan.
Thursday,08,June,2017,19:29:44:18632
VCDS Version: 17.4.2.3
Data version: 20170505 DS270.4
VIN: VSSZZZ5FZDR039344   License Plate: OTV910
Mileage: 106578km-66224mi   Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: VSSZZZ5FZDR039344   Mileage: 106578km-66224miles
Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 A    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 5541
   Revision: WAH08---
   Coding: 01250032232401080000
   Shop #: WSC 00049 770 00125
   ASAM Dataset: EV_ECM12TFS01104E906016A 001006
   ROD: EV_ECM12TFS01104E906016A_AU37.rod
   VCID: 20766ECA3B8B2B472C-8074
17158 - Databus
                    Mileage: 106491 km
                    Date: 2017.06.06
                    Time: 16:47:17
                    Coolant temperature: 60 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 12.415 V
                    Unlearning counter according OBD: 30
                    Mass flow through throttle valve: 0.0 kg/h
   Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4512
   Revision: 00043014    Serial number: CU501303286885
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 49A0D36EE8F1CA0F9B-801C
   Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
   Component: ESC           H75 0333
   Coding: 20EE6A9220231275007A060401C7240456044800608024F200295020C0
   Shop #: WSC 00049 770 00104
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
   ROD: EV_Brake1UDSContiMK100ESP_008.rod
   VCID: 3A42BCA2BD17519702-806E
0070 - Rear Left Wheel Speed Sensor
          C101C 29 [008] - Signal Implausible
                    Reset counter: 94
                    Mileage: 106543 km
                    Date: 2017.06.08
                    Time: 10:47:00
0086 - Rear Right Wheel Speed Sensor
          C101D 29 [008] - Signal Implausible
                    Reset counter: 94
                    Mileage: 106543 km
                    Date: 2017.06.08
                    Time: 10:47:00
   Part No SW: 5F0 907 044 A    HW: 5F0 907 044 A
   Component: Climatronic   H02 0503
   Revision: 00001K05
   Coding: 00000004200100011105004000101000
   ROD: EV_ACClimaBHBVW37X_002.rod
   VCID: 247E62DA2F93376748-8070
327940 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator stuck
                    Reset counter: 93
                    Mileage: 106424 km
                    Date: 2017.06.05
                    Time: 15:46:09
                    Voltage terminal 30: 12.4 V
                    Outside air temperature: 15.5 °C
                    Interior temperature: 40.8 °C
                    Left temperature flap - actual value: 159
                    Left temperature flap - actual value: 63.5 %
                    Left temperature flap - specified value: 25
328196 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Reset counter: 94
                    Mileage: 106424 km
                    Date: 2017.06.05
                    Time: 15:46:10
                    Voltage terminal 30: 12.3 V
                    Right temperature flap: actual value: 114
                    Right temperature flap: actual value: 43.0 %
                    Right temperature flap: specified value: 18
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011308700426
   Coding: 08001946C2C102FB4BE44000401C07081008000000000000000000000000
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46BAD852F9EF257776-8012
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130318  041 0574
   Serial number:         130326035958
   Coding: 0BC5FD
   Component: RLFS  024 0042
   Serial number: Y13M04D06H03M24S39S2
   Coding: 00885D
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231308202247
   Coding: 0031051011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
13637426 - Databus
                    Reset counter: 85
                    Mileage: 106491 km
                    Date: 2017.06.06
                    Time: 16:47:17
   Part No SW: 3Q0 959 655 R    HW: 3Q0 959 655 R
   Component: Airbag VW20   011 0186
   Revision: --------    Serial number: 003NPP5V7JX%
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_VW48.rod
   VCID: 4DA8E77E1C99D62FB7-8018
   Subsystem 1 - Part No SW: -----------    HW: 454 001 603 13
   Serial number: 3576U0000009B1343C08
   Subsystem 2 - Part No SW: -----------    HW: 454 002 403 13
   Serial number: 3586U000000A76243C0A
   Subsystem 3 - Part No SW: -----------    HW: 454 801 403 13
   Serial number: 3516R2A107300000000M
   Subsystem 4 - Part No SW: -----------    HW: 454 801 403 13
   Serial number: 3526R84A42100000000T
   Subsystem 5 - Part No SW: -----------    HW: 454 801 302 13
   Serial number: 3556V76EAD400000000I
   Part No SW: 5Q0 953 507 AN    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 04041304220068
   Coding: AC00
   ROD: EV_SMLSKLOMQB_009_SE37.rod
   VCID: 023204429547D9571A-8056
   Part No SW: 5F0 920 870 F    HW: 5F0 920 870 F
   Component: KOMBI         336 0556
   Coding: 07A502086984000800087A02000000
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2B6C89E6424DF81F89-807E
16776970 - Databus
                    Reset counter: 95
                    Mileage: 106577 km
                    Date: 2017.06.08
                    Time: 18:15:54
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000508532
   Coding: 030100F42B086400EF0006481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 345E929A9F73A7E7D8-8060
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0100
   Serial number: 000000000A0645050313
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004050365332
131668 - Headlight Range Control Module
          U101E 00 [008] - No Communication
                    Reset counter: 95
                    Mileage: 106577 km
                    Date: 2017.06.08
                    Time: 18:15:55
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000057243659
   Coding: 00100320DC00020000001000
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000151396
   Coding: 310000
   Coding: 11
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D48B7BEAC3966AF27-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000056244561
   VCID: 01300B4E9041C24F03-8054
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000131183
   Coding: 290000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 0000000000000000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75D86F9ED489FEEF2F-8020
10490624 - No End-of-Line Programming
          B2013 00 [137] -  -
                    Reset counter: 55
                    Mileage: 106577 km
                    Date: 2017.06.08
                    Time: 18:31:27
13636352 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 55
                    Mileage: 106577 km
                    Date: 2017.06.08
                    Time: 18:31:27
5275220 - Headlight
                    Reset counter: 55
                    Mileage: 106577 km
                    Date: 2017.06.08
                    Time: 18:31:27
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5F0 035 846     HW: 5F0 035 846
   Component: MU-S-N-ER     039 0171
   Serial number: E1F03103130409
   Coding: 04731001FF0A000021110001000800002F0106040100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE_VW37.rod
   VCID: 65F83FDE64290E6F9F-8030
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H45 0020
   Serial number: SEZ8Z9N5600CUK
   Subsystem 2 - Part No SW: 5F0 919 866 C    HW: -----------
   Component:  ECE 2013  --- 0021
1590 - invalid data record
          B2005 00 [008] -  -
                    Reset counter: 94
                    Mileage: 106577 km
                    Date: 2017.06.08
                    Time: 16:58:03
                    Voltage terminal 30: 12.2 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0050
   Serial number: 00000039868
   Coding: 0101010001000004000500000000000100
   ROD: EV_MFKBoschAU370.rod
End-------------------------(Elapsed Time: 03:29)--------------------------
ABS coding before the sensor change :
   Coding: 20EE6A9220231275007A060401C7240456044800608024F200290020C0
   VCID: 3A42BCA2BD175191E7-806E
And after :
Any ideas are the sensors faulty or coding not correct? Or maybe I've missed some calibration routine?
Admins, can you please delete this post : http://forums.ross-tech.com/showthread.php?7731-Seat-Leon-ACC&p=98205&viewfull=1#post98205
It's the same question but in ACC thread. This is a separate issue so I think it deserves it's own thread.
Moving to Retrofits.
downtime
C?ID=280813
Any tips for this one please?
barstanders
C?ID=277262
Hello Downtime.
What i think you need to do is to update the software ABS and Engine.
See my car tekst.
Address 01: Engine (J623-CJZB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 E HW: 04E 907 309 A
Component: 1.2l R4 TSI H08 7695
Revision: WAH08---
Coding: 01110032232415082000
Shop #: WSC 51969 000 1048576
ASAM Dataset: EV_ECM12TFS01104E906016E 001011
ROD: EV_ECM12TFS01104E906016.rod
VCID: 2468B6F82F7D016191-8070
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
Shop #: WSC 12345 123 123465
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DDEA39CEC5790A9BE-8028
The fault on the 10 en 17 have to do with the wrong settings ore missing update on the ABS.
You can olso try to change the valeu 50 to FO this maybe help it.
I olso now when i retrofitt the PLA i have change the rear abs sensors to WHT003864A.
But you dont need to change when you retrofitt to ACC.
This what i have read somewhere. please google XaGiCo DOSSIER VCDS VW GOLF MKVII 1.5
downtime
C?ID=280813
Thank you Barstanders for the information.
So is it possible to update the ABS software from A => AC or would I need to change the complete ABS module? According to ETKA A should be ok for 8T5 = distance control plus cruise control, so I would presume that the ABS should be fine for these sensors as well?
I have the software update for the engine but I haven't had the guts to run it with VCP. I will have the software for engine and DSG updated at the next service.
I will try to F0 value in byte26 as well.
The ABS sensors are required for DSG as it will also introduce front assist with stop & go functionality. Manual gearbox does not need the ABS sensor change as it does not have stop & go.
barstanders
C?ID=277262
If you download the PDF you see on page 218 the retrofitting ACC.
The olso changing byte 24 on the abs.
Update is possible but i have done it by the VW not VCP!!
downtime
C?ID=280813
Thanks. I have the XAGICOs pdf downloaded :) According to the instructions there I did the coding for the ABS sensors. Initially before changing the code, there were all sorts of errors in ABS and it was also visible on the center display, after changing the code, all the errors disappeared. Now only this intermittent error after certain speed has been exceeded.
I'll check the other coding option.
And yes, I won't update the engine software with VCP. I did update headlight control module with that and it lost all the parameter data, I had to reparametrize the unit. Now if that happens to ECU and it loses all the IMMO data as well. Then that's not good.
Vasco Ferraz
Portugal
C?ID=288561
I believe that the IMMO data is stored in a dedicated EEPROM. A ECU flash won't mess with the IMMO EEPROM.
My statement needs confirmation.
downtime
C?ID=280813
Nailed it! :) F0 did the trick, no errors anymore even after higher speeds :)
Thank you, this was an excellent advice.
barstanders
C?ID=277262
Hello downtime,
Happy for you..
Please post a full scan for in the futher when i want to look foor it.
downtime
C?ID=280813
Sorry for the long reply time.
Here's the full scan with working ABS code for WHT003864A rear sensors.
Thursday,22,June,2017,20:40:28:18632
VCDS Version: 17.1.3.0
Dealer/Shop Name: Chop shop
Mileage: 107596km-66857mi   Repair Order:
VIN: VSSZZZ5FZDR039344   Mileage: 107596km-66857miles
   Revision: WAH08---
   VCID: 20766ECA3B8B2B41C9-8074
Readiness: 1110 0001
   ROD: EV_TCMDQ200021.rod
   VCID: 49A0D36EE8F1CA097E-801C
   Coding: 20EE6A9220231275007A060401C7240456044800608024F20029F020C0
   Revision: 00001K05
   VCID: 247E62DA2F933761AD-8070
   VCID: 46BAD852F9EF257193-8012
   Coding: 0BC5FD
   Coding: 00885D
   Coding: 0031051011
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 4DA8E77E1C99D62952-8018
   Coding: AC00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 023204429547D951FF-8056
   VCID: 2B6C89E6424DF8196C-807E
   VCID: 345E929A9F73A7E13D-8060
   Coding: 002000
   Coding: 310000
   Coding: 11
   VCID: 3D48B7BEAC3966A9C2-8068
   VCID: 01300B4E9041C249E6-8054
   Coding: 290000
   Coding: 048A000009000000
   VCID: 75D86F9ED489FEE9CA-8020
   VCID: 65F83FDE64290E697A-8030
End-------------------------(Elapsed Time: 03:22)--------------------------
