Tiguan rerofit Cruise Control worked but G85 sensor fail!
bighead
New Member
Vietnam
HC811173 (?)
Hi everyone.
I am new VCDS user from Vietnam.
My Tiguan 2011 Trend 4Motion, 170Hp, 7speed DSG.
I want to retrofit Cruise Control. My Tig had MFSW and Tiptronic installed on 5K0 953 569 G.
I read on Ross Tech Wiki about Steering Wheel Control Module Versions and found that my 569 G must be replace to retrofit Cruise Control.
I bought a pack from ebay with 5K0 953 569 AH - Steering Control, 5K0 953 502 M and 5K0 953 521 DQ switchs.
After installation, I did some coding on 01-Engine and 16-Steering wheel and my retrofit Cruise Control worked well.
But the G85 sensor had error "00778 - Steering Angle Sensor (G85) - 004 - No Signal/Communication - Intermittent" on 03-ABS Brakes, 16-Steering wheel and 44-Steering Assist.
I cannot coding 44-Steering Assist to enable G85 so that Steering (Yellow light) and ESP, TMPS lights turn on.
Everytime I code 44-Steering Assist, there is an error "Coding Rejected, Error 31: Request out of range".
This is my scan
Wednesday,07,June,2017,17:54:14:63641
VCDS Version: 17.1.3.0
VIN: WVGZZZ5NZBW042629   License Plate:
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 72
VIN: WVGZZZ5NZBW042629   Mileage: 69260km-43036miles
16-Steering wheel -- Status: Sporadic communication error 1000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 06J 906 026 FL    HW: 06J 906 026 DA
   Component: MED17.5             7330
   Revision: AAH18---    Serial number:
   Coding: 04230010240F0160
   Shop #: WSC 01324 020 00200
   VCID: 79F90E423021CB89AE-802C
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 011 E    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H04 1203
   Revision: 00H04V01
   ROD: EV_TCMDQ500021_VW41.rod
   VCID: 24470F362F236661AD-8070
10730 - Databus
          U1121 00 [047] - Missing Message
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 16:55:05
                    Coolant temperature: -40 °C
                    Clutch: primary stat: New
                    selected gear: GANG N
                    Driving position: P
                    Engine torque: 0 Nm
                    Control Module temperature: 69 °C
                    Accelerator position: 14.0 %
                    DTC memory status: 255
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V25E 0006
   Revision: --H28---    Serial number: 00000003182004
   Coding: 0010564
   Shop #: WSC 40168 020 00200
   VCID: 3979CE4270A10B89EE-806C
                    Reset counter: 134
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 17:06:36
                    Speed: 2.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 173
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   VCID: 7EF31D5EE10FECB19B-802A
   Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
   Component: BCM PQ35 M    011 0035
   Revision: BC011001
   Coding: 44180A3880231AC0000800803000012043113088536D8D605C8800000040
   VCID: 377DC87A86B51DF918-8062
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 230810 03  32  0010
   Coding: 009795
   Component: RLS 110910 05  54  0403
   Coding: 03304D
                    Reset counter: 134
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 17:22:35
                        Term 15 Off
                    Voltage: 12.35 V
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5N0 919 475 B    HW: 5N0 919 475
   Component: PARKHILFE 4K  H07 0023
   Revision: --------    Serial number: 11131025305730
   Coding: 100102
   VCID: 387FCB468BAB128111-806C
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__200 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PJXR0TR
   Coding: 0012336
   VCID: 4C9787962F338E2145-8018
   Subsystem 1 - Serial number: 6332MTS622342510
   Subsystem 2 - Serial number: 6342MTS600222490
   Subsystem 3 - Serial number: 6351HTS64OI3E9KR
   Subsystem 4 - Serial number: 6361HTS6A0Q3E9KR
   Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20141104201671
   Coding: 109A140000
   Shop #: WSC 00020 999 00000
   ROD: EV_SMLSNGVOLWSXS.rod
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0052329
   Coding: 830000
   Part No SW: 5N0 920 872     HW: 5N0 920 872
   Component: KOMBI         H03 0406
   Coding: 110F01
   VCID: 6FED301AB665953900-803A
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 17:22:35
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 090910F2000740
   Coding: DDA27F0600020200006002
   VCID: 6DD12A127469672932-8038
                    Fault Status: 00110100
                    Reset counter: 134
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 17:22:33
                    Reset counter: 93
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 16:55:06
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
                    Reset counter: 138
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 16:55:04
   Component: IMMO          H03 0406
   VCID: 6ADB210E8D87701157-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
   Component: Tuer-SG         009 2101
   Coding: 0004534
   VCID: 377DC87A46B51DF918-8062
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.220 0802
   Revision: 1AH03831    Serial number: 00102530167501
   Coding: 0000258
   VCID: 3B75D44A7A9D3999FC-806E
                    Fault Status: 11100100
                    Reset counter: 94
                    Mileage: 69268 km
                    Date: 2017.06.07
                    Time: 16:55:04
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.00 V
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Coding: 0004534
   VCID: 387FCB464BAB128111-806C
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000086769
   Coding: 0023057
   VCID: 326BF96EADD7F8D12F-8066
Address 56: Radio
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
   Component: Tuer-SG         007 2102
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Coding: 0000144
End-------------------------(Elapsed Time: 02:27)--------------------------
After too many tried but failed, I reinstall my original 5K0 953 569 G pack but still an error "02546 - Steering Limit Stop - 005 - No or Incorrect Basic Setting / Adaptation - MIL ON".
I tried more than 10 times to do Procedures - Steering Limit Stop Adaptation but still Yellow light on Instrument.
This is my scan
Tuesday,13,June,2017,11:36:55:63641
VIN: WVGZZZ5NZBW042629   License Plate: 65A-054.68
Mileage: 69680km-43297miOK   Repair Order:
VIN: WVGZZZ5NZBW042629   Mileage: 69680km-43297miles
   Coding: 04230010240F0060
Readiness: 1000 0001
   Revision: 00H04V01
10809 - Databus
                    Mileage: 69685 km
                    Date: 2017.06.12
                    Time: 17:58:50
                    Engine speed: 762.00 /min
                    Driving position: P
                    Engine torque: 84 Nm
                    Control Module temperature: 95 °C
   Component: J104    C4 450 V265 0006
   Coding: 0010564
   Revision: 00003001
   Coding: 0000001002
   Revision: BC011001
   Coding: 44180A3880371AC0000800803000012043113088536D8D605C8800000040
   Coding: 009795
   Coding: 03304D
   Coding: 100102
   Coding: 0012336
   Part No SW: 5K0 953 501 AR    HW: 5K0 953 569 G
   Component: LENKS.MODUL   009 0136
   Revision: FF010038    Serial number: 20100910100710
   Coding: 1992040000
   VCID: 7AFB114EFD27C091A7-802E
   Coding: 830000
   Coding: 110F01
   Coding: FDA27F0600020200006002
                    Reset counter: 101
                    Mileage: 69685 km
                    Date: 2017.06.12
                    Time: 17:58:51
   Coding: 0000005
   Coding: 0004534
   Coding: 0000258
                    Fault Status: 11100101
                    Reset counter: 101
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.20 V
   Coding: 0004534
   Coding: 0023057
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:28)--------------------------
Address 02: DTCs cleared
Address 44: DTCs cleared
Address 19,7N0 907 530 ,recoded (Long Coding),from,FDA27F0600020200006002,to,FD827F0700020200006002,(01324/020/00200),
Address 19,7N0 907 530 ,recoded (Installation List),from,FD827F0700020200006002,to,FD827F0700020200006002,,
Address 19,7N0 907 530 ,recoded (Long Coding),from,FD827F0700020200006002,to,FD827F0600020200006002,(01324/020/00200),
Address 19: DTCs cleared
Address 19,7N0 907 530 ,recoded (Installation List),from,FD827F0600020200006002,to,FD827F0600020200006002,,
I think my G85 sensor 569 AH have problem(s) in optical part so it can not operation.
Can I repair G85 sensor or any code to active it?
Can I buy another Control Module with 5K0 953 569 T HW:016 - SW:0140 (about 120USD)
or 5K0 953 569H
or 5K0 953 569 AL (about 230USD) to install on already new 5K0 953 502 M and 5K0 953 521 DQ switchs?
Can I buy another complete pack with 5K0 953 549 B module and 5K0 953 513 M (or S) cruise switch (about 150USD) to install on my Tig?
Thank for support!!!
bighead
New Member
Vietnam
HC811173 (?)
Hi all.
I found my problems after disassembly my 569AH module and saw there is no G85 sensor module inside.
So that must be replace by another module such as 569H or 569AL..
Thank for reading!
Spacewalker
C?ID=159607
Correct
if SWCm have no "gold" ring on the back , is w.o G85
But i seen some cars with 5N1_APA which which not have G85 in SWCM
Steering rac also have it - and you no need 2 x G85
This same is when you use 1K0 steering rack with built in G85
maybe somebody know how to enable G85 in 5N1_APA ?
t
