Results 1 to 3 of 3
Thread: Tiguan rerofit Cruise Control worked but G85 sensor fail!
    New User
    May 2017
    Vietnam
    Hi everyone.
    I am new VCDS user from Vietnam.
    My Tiguan 2011 Trend 4Motion, 170Hp, 7speed DSG.
    I want to retrofit Cruise Control. My Tig had MFSW and Tiptronic installed on 5K0 953 569 G.
    I read on Ross Tech Wiki about Steering Wheel Control Module Versions and found that my 569 G must be replace to retrofit Cruise Control.
    I bought a pack from ebay with 5K0 953 569 AH - Steering Control, 5K0 953 502 M and 5K0 953 521 DQ switchs.
    After installation, I did some coding on 01-Engine and 16-Steering wheel and my retrofit Cruise Control worked well.
    But the G85 sensor had error "00778 - Steering Angle Sensor (G85) - 004 - No Signal/Communication - Intermittent" on 03-ABS Brakes, 16-Steering wheel and 44-Steering Assist.
    I cannot coding 44-Steering Assist to enable G85 so that Steering (Yellow light) and ESP, TMPS lights turn on.
    Everytime I code 44-Steering Assist, there is an error "Coding Rejected, Error 31: Request out of range".
    This is my scan
    Wednesday,07,June,2017,17:54:14:63641
    VCDS Version: 17.1.3.0
    VIN: WVGZZZ5NZBW042629   License Plate:
    Chassis Type: 5N (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 72
    VIN: WVGZZZ5NZBW042629   Mileage: 69260km-43036miles
    16-Steering wheel -- Status: Sporadic communication error 1000
    Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
       Part No SW: 06J 906 026 FL    HW: 06J 906 026 DA
       Component: MED17.5             7330
       Revision: AAH18---    Serial number:
       Coding: 04230010240F0160
       Shop #: WSC 01324 020 00200
       VCID: 79F90E423021CB89AE-802C
    Readiness: 1110 0001
    Address 02: Auto Trans (J217)       Labels: 0BH-927-711.clb
       Part No SW: 0BH 300 011 E    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H04 1203
       Revision: 00H04V01
       ROD: EV_TCMDQ500021_VW41.rod
       VCID: 24470F362F236661AD-8070
    10730 - Databus
              U1121 00 [047] - Missing Message
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 16:55:05
                        Coolant temperature: -40 C
                        Clutch: primary stat: New
                        selected gear: GANG N
                        Driving position: P
                        Engine torque: 0 Nm
                        Control Module temperature: 69 C
                        Accelerator position: 14.0 %
                        DTC memory status: 255
    Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
       Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
       Component: J104    C4 450 V25E 0006
       Revision: --H28---    Serial number: 00000003182004
       Coding: 0010564
       Shop #: WSC 40168 020 00200
       VCID: 3979CE4270A10B89EE-806C
                        Reset counter: 134
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 17:06:36
                        Speed: 2.0 km/h
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.00 V
                        Bin. Bits: 00011111
                        Count: 173
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
       Revision: 00003001
       Coding: 0000001002
       VCID: 7EF31D5EE10FECB19B-802A
       Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
       Component: BCM PQ35 M    011 0035
       Revision: BC011001
       Coding: 44180A3880231AC0000800803000012043113088536D8D605C8800000040
       VCID: 377DC87A86B51DF918-8062
       Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS 230810 03  32  0010
       Coding: 009795
       Component: RLS 110910 05  54  0403
       Coding: 03304D
                        Reset counter: 134
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 17:22:35
                            Term 15 Off
                        Voltage: 12.35 V
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5N0 919 475 B    HW: 5N0 919 475
       Component: PARKHILFE 4K  H07 0023
       Revision: --------    Serial number: 11131025305730
       Coding: 100102
       VCID: 387FCB468BAB128111-806C
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__200 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PJXR0TR
       Coding: 0012336
       VCID: 4C9787962F338E2145-8018
       Subsystem 1 - Serial number: 6332MTS622342510
       Subsystem 2 - Serial number: 6342MTS600222490
       Subsystem 3 - Serial number: 6351HTS64OI3E9KR
       Subsystem 4 - Serial number: 6361HTS6A0Q3E9KR
       Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20141104201671
       Coding: 109A140000
       Shop #: WSC 00020 999 00000
       ROD: EV_SMLSNGVOLWSXS.rod
       Serial number: 0052329
       Coding: 830000
       Part No SW: 5N0 920 872     HW: 5N0 920 872
       Component: KOMBI         H03 0406
       Coding: 110F01
       VCID: 6FED301AB665953900-803A
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 134
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 17:22:35
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 090910F2000740
       Coding: DDA27F0600020200006002
       VCID: 6DD12A127469672932-8038
                        Fault Status: 00110100
                        Reset counter: 134
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 17:22:33
                        Reset counter: 93
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 16:55:06
       Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
       Component: Haldex 4Motion      0042
       Coding: 0000005
                        Reset counter: 138
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 16:55:04
       Component: IMMO          H03 0406
       VCID: 6ADB210E8D87701157-803E
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
       Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
       Component: Tuer-SG         009 2101
       Coding: 0004534
       VCID: 377DC87A46B51DF918-8062
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.220 0802
       Revision: 1AH03831    Serial number: 00102530167501
       Coding: 0000258
       VCID: 3B75D44A7A9D3999FC-806E
                        Fault Status: 11100100
                        Reset counter: 94
                        Mileage: 69268 km
                        Date: 2017.06.07
                        Time: 16:55:04
                        (no units): 4.0
                        Voltage: 12.00 V
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
       Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
       Coding: 0004534
       VCID: 387FCB464BAB128111-806C
       Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
       Component: J540 EPB4  VW-53083 0006
       Revision:   H18       Serial number: 00000000086769
       Coding: 0023057
       VCID: 326BF96EADD7F8D12F-8066
    Address 56: Radio
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
       Component: Tuer-SG         007 2102
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:27)--------------------------
    After too many tried but failed, I reinstall my original 5K0 953 569 G pack but still an error "02546 - Steering Limit Stop - 005 - No or Incorrect Basic Setting / Adaptation - MIL ON".
    I tried more than 10 times to do Procedures - Steering Limit Stop Adaptation but still Yellow light on Instrument.
    This is my scan
    Tuesday,13,June,2017,11:36:55:63641
    VIN: WVGZZZ5NZBW042629   License Plate: 65A-054.68
    Mileage: 69680km-43297miOK   Repair Order:
    VIN: WVGZZZ5NZBW042629   Mileage: 69680km-43297miles
       Coding: 04230010240F0060
    Readiness: 1000 0001
       Revision: 00H04V01
    10809 - Databus
                        Mileage: 69685 km
                        Date: 2017.06.12
                        Time: 17:58:50
                        Engine speed: 762.00 /min
                        Driving position: P
                        Engine torque: 84 Nm
                        Control Module temperature: 95 C
       Component: J104    C4 450 V265 0006
       Coding: 0010564
       Revision: 00003001
       Coding: 0000001002
       Revision: BC011001
       Coding: 44180A3880371AC0000800803000012043113088536D8D605C8800000040
       Coding: 009795
       Coding: 03304D
       Coding: 100102
       Coding: 0012336
       Part No SW: 5K0 953 501 AR    HW: 5K0 953 569 G
       Component: LENKS.MODUL   009 0136
       Revision: FF010038    Serial number: 20100910100710
       Coding: 1992040000
       VCID: 7AFB114EFD27C091A7-802E
       Coding: 830000
       Coding: 110F01
       Coding: FDA27F0600020200006002
                        Reset counter: 101
                        Mileage: 69685 km
                        Date: 2017.06.12
                        Time: 17:58:51
       Coding: 0000005
       Coding: 0004534
       Coding: 0000258
                        Fault Status: 11100101
                        Reset counter: 101
                        (no units): 4.0
                        Voltage: 12.20 V
       Coding: 0004534
       Coding: 0023057
    Address 56: Radio
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:28)--------------------------
    Address 02: DTCs cleared
    Address 44: DTCs cleared
    Address 19,7N0 907 530 ,recoded (Long Coding),from,FDA27F0600020200006002,to,FD827F0700020200006002,(01324/020/00200),
    Address 19,7N0 907 530 ,recoded (Installation List),from,FD827F0700020200006002,to,FD827F0700020200006002,,
    Address 19,7N0 907 530 ,recoded (Long Coding),from,FD827F0700020200006002,to,FD827F0600020200006002,(01324/020/00200),
    Address 19: DTCs cleared
    Address 19,7N0 907 530 ,recoded (Installation List),from,FD827F0600020200006002,to,FD827F0600020200006002,,
    I think my G85 sensor 569 AH have problem(s) in optical part so it can not operation.
    Can I repair G85 sensor or any code to active it?
    Can I buy another Control Module with 5K0 953 569 T HW:016 - SW:0140 (about 120USD)
    or 5K0 953 569H
    or 5K0 953 569 AL (about 230USD) to install on already new 5K0 953 502 M and 5K0 953 521 DQ switchs?
    Can I buy another complete pack with 5K0 953 549 B module and 5K0 953 513 M (or S) cruise switch (about 150USD) to install on my Tig?
    Thank for support!!!
  2. Likes Uwe liked this post
  3. #2
    New User
    May 2017
    Vietnam
    Hi all.
    I found my problems after disassembly my 569AH module and saw there is no G85 sensor module inside.
    So that must be replace by another module such as 569H or 569AL..
    Thank for reading!
    Jun 2014
    Poland
    Correct
    if SWCm have no "gold" ring on the back , is w.o G85
    But i seen some cars with 5N1_APA which which not have G85 in SWCM
    Steering rac also have it - and you no need 2 x G85
    This same is when you use 1K0 steering rack with built in G85
    maybe somebody know how to enable G85 in 5N1_APA ?
    t
    HOT HOT HOT VW Touran 2005 CCS via MFSW HOT HOT HOT
