I have been following a thread in the "support" forum, however it wont let me post there yet as i am apparently not yet verified. anyway. here's the background. GF's car popped the P2404 code a few years ago. She took it to local mechanic who replaced the LDP twice, and of course that didn't solve the problem. Well, somehow they made it pass smog, but of course the check engine light was never off for long. Come 2 years later, vehicle registration is due again, and hence we have to smog it again.
So far I have done the following.
1) replaced J757 fuse
2) verified resistance in LDP pump was as specified in manual.
3) i am currently renting a Ross Tech cable. I have run the 071 test multiple times. First few times it aborted. A couple weeks later, i was able to work on car again. Performed the 071 test with the N80 line crimped. Aborted the test 2 times. Next I ran without the crimp on the N80, and it passed. So now i'm even more confused.
here's the autoscan. any advice is appreciated.
Thursday,25,May,2017,19:37:01:17781
VCDS Version: 17.1.3.0 (x64)
VIN: WAUDH74F56N103506 License Plate: RUNNING
Mileage: 150800km-93702mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 42 46 47 4F 52 53 56
61 62 65 72 77
VIN: WAUDH74F56N103506 Mileage: 150800km-93702miles
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 22162 444 53437
VCID: 2B556E758A4045196C-807E
009220 - EVAP Leak Detection Pump Sense Circuit
P2404 - 006 - Implausible Signal - MIL ON
Fault Status: 10100001
Reset counter: 40
Mileage: 137912 km
Date: 2016.03.02
Time: 12:13:32
RPM: 1440 /min
Mass Air / Rev.: 103.6 mg/str
Temperature: 31.5°C
Overrun
Voltage: 14.08 V
Speed: 44.0 km/h
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4104086
Shop #: WSC 02325 785 00200
VCID: 26439F4191A27871B3-8072
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Coding: 0020895
VCID: 2D51606DB4544B2972-8078
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10600700278780
Coding: 0000011
Shop #: WSC 02323 785 00200
VCID: 63C5C655A210CD5994-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303J$057509997
Coding: 0000003
VCID: 21498C5DF88C9F49C6-8074
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000262891
Subsystem 3 - Serial number: 0125.10.050000000100010671ÿ
Subsystem 4 - Serial number: 010671ÿ
Fault Frequency: 36
Reset counter: 147
Mileage: 144896 km
Date: 2016.08.14
Time: 15:48:59
Bin. Bits: 10
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000199279
Coding: 0524326
VCID: 5BB5FEB59A60F599DC-800E
Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
Component: ILM Fahrer H15 0190
Coding: 0010103
Shop #: WSC 02335 785 00200
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7260216
VCID: 1B35BEB5DAE0B5991C-804E
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 A HW: 4E0 035 593 A
Component: SDAR
Revision: 0000000 Serial number: AUZ4Z7D80
VCID: 2541984DECA47369BA-8070
Reset counter: 206
Mileage: 138853 km
Date: 2016.04.12
Time: 07:54:51
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0270
Revision: 12H29000 Serial number: 00359D0A6EJ-
Coding: 0013878
VCID: 2A5B6B7185BA5C1197-807E
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0C5F6564E
Subsystem 3 - Serial number: 6342CSME0D025C5A9
Subsystem 4 - Serial number: 6352QSME06183D2FP
Subsystem 5 - Serial number: 6362QSME054D310DH
Subsystem 6 - Serial number: 63734SME055A4163Z
Subsystem 7 - Serial number: 63834SME066E13492
00532 - Supply Voltage B+
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90054052950646
Coding: 0002021
VCID: 66C3DF415122B87173-8032
Component: Lenkradmodul H07 0080
Fault Status: 01100010
Mileage: 137888 km
Date: 2016.02.29
Time: 15:00:44
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H11 0630
Revision: 00100000 Serial number: 4R812DVA5
Coding: 0019263
Shop #: WSC 00001 067 57207
VCID: 1E33B7A1C9F2A0B1FB-804A
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805A2681F1
Coding: 6CFE53C51B1904
Shop #: WSC 03164 444 52200
VCID: 275D924596A8617988-8072
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Coding: 0035435
Shop #: WSC 02327 785 00200
VCID: 2C576D698F4E422165-8078
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01008313330000
Coding: 4618301
VCID: 2E536761B95230314B-807A
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 21S00001 Serial number: 02610050167360
Coding: 0000006
VCID: 1D31B0ADC4F4BBA9E2-8048
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000009583
Coding: 0002114
VCID: 5EB3F7A18972E0B1BB-800A
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00000000 Serial number: ™‚
Coding: 0035435
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DB1F0AD8474FBA9A2-8008
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394J%057629762
VCID: 23458655E2908D59D4-8076
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000141655
Shop #: WSC 03109 444 64620
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2510230170
Coding: 344630393135313035432056413032353130323330313730
Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
Fault Frequency: 19
Mileage: 137888 km
Date: 2016.02.29
Time: 12:07:03
02273 - Quiescent Current Stage 2
Fault Frequency: 19
Mileage: 137888 km
Date: 2016.02.29
Time: 12:07:03
02276 - Quiescent Current Stage 5
Fault Frequency: 10
Mileage: 137888 km
Date: 2016.02.29
Time: 12:13:39
02274 - Quiescent Current Stage 3
Fault Frequency: 10
Mileage: 137888 km
Date: 2016.02.29
Time: 12:13:39
02277 - Quiescent Current Stage 6
Fault Frequency: 6
Mileage: 149524 km
Date: 2017.05.07
Time: 01:39:19
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0035370
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900013371
Coding: 0062221
VCID: 224B8351FD8A8451DF-8076
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0035370
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007521483
Coding: 0010900
End-------------------------(Elapsed Time: 02:40)--------------------------
