Results 1 to 2 of 2
Thread: Parking Lights OFF with Terminal S OFF
    Mar 2016
    Norway
    Question Parking Lights OFF with Terminal S OFF
    Is this possible on MK7 Golf? I want my parking lights to turn off when I shut down the engine. I have KESSY so parking lights remain on until I open the door...
    Quote Originally Posted by Drive View Post
    Drive: In the BCM on my mk7 there is an adaptation channel titled Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus which I'm reliably informed by Mr Google translates in English to Driving light and parking light - parking light out from LDS = ABL and S-Contact
    Now, LDS is what VW calls the rotary-light-switch and ABL is (I think) the German Abblendlicht (or Dipped headlights) and S-Contact is the switch inside the ignition key lock that detects when the key is inserted.
    So, IMHO there is sufficient correlation in the name of this adaptation channel with elements of the long coding descriptor for Byte 15, Bit 5 in your picture for it to be a worthy contender as a solution - I think.
    I suggest that you investigate the setting for this channel on your BCM. If it's currently set to active - try changing the value and see what happens.
    VW Golf MkVII (103TSI) my13
  3. Likes Uwe liked this post
