Results 1 to 9 of 9
Thread: Help Coding for ESP MK60EC1
    Nov 2016
    Portugal
    Hi, I need help coding a hydraulic unit of a VW Golf 5.
    Miguel
    Monday,12,June,2017,15:09:59:52040
    VCDS Version: 17.1.3.0
    VIN: WVWZZZ1KZ9M348338   License Plate: 86-HZ-11
    Mileage: 199500km-123963mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ9M348338   Mileage: 199500km-123963miles
    03-ABS Brakes -- Status: Not registered 0011
    04-Steering Angle -- Status: Not registered 0001
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 TQ    HW: 03G 906 021 AB
       Component: R4 1,9L EDC  000SG  2186
       Revision: --H09---    Serial number: VWX7Z0I424C06H
       Coding: 0000031
       Shop #: WSC 00070 000 00000
       VCID: 0102114258C24249E6-8054
    005716 - Please check DTC Memory of Instrument Cluster
                   P1654 - 000 -
                        Mileage: 199502 km
                        Time: 14:36:58
                        RPM: 756 /min
                        Voltage: 14.21 V
                        Temperature: 32.4C
                        Temperature: 49.5C
                        Temperature: 37.8C
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       VCID: 74EC4896D77067E1FD-8020
                        Fault Status: 01100101
                        Reset counter: 227
                        Mileage: 199502 km
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 279
                        Count: 49408
                        Reset counter: 227
                        Mileage: 199502 km
                        Reset counter: 227
                        Mileage: 199502 km
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 270
                        Count: 49408
                        Reset counter: 227
                        Mileage: 199502 km
       Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 6FE647FA7E56443900-803A
    00532 - Supply Voltage B+
    00898 - Control Circuit A/C compressor
                010 - Open or Short to Plus
                013 - Check DTC Memory
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Revision: 00H54000    Serial number: 00000009437855
       Coding: 00890F2700041500470000001C00000000097B075C000120000000000000
       VCID: 32608E8EADE429D12F-8066
       Component: Wischer 080509 021  0501
       Coding: 00038805
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 1K5 919 475     HW: 1K5 919 475
       Component: PARKHILFE 8K  H07 0005
       Revision: --------    Serial number: 60730904304400
       Coding: 100002
       Component: 5P AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2C5H32
       Coding: 0013648
       VCID: 3D7AADB264BAE6A9C2-8068
       Subsystem 1 - Serial number: 6332MSME4473403EA
       Subsystem 2 - Serial number: 6342MSME4621573CC
       Subsystem 3 - Serial number: 6351HSME1C501317/
       Subsystem 4 - Serial number: 6361HSME0006106BZ
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000102
       VCID: 78F47CA60B180381D1-802C
       Part No SW: 1K0 920 874 M    HW: 1K0 920 874 M
       Component: KOMBIINSTRUMENT 3HL 2420
       Revision: V0005000    Serial number: VWX7Z0I424C06H
       Coding: 0003103
       VCID: 3776BF9A4686CCF918-8062
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 227
                        Mileage: 199502 km
                        Time: 14:28:02
                        Reset counter: 12
                        Mileage: 199502 km
                        Time: 14:48:42
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Revision:   H07 01    Serial number: 170309F1002065
       Coding: C1A07F06000202002002
       Shop #: WSC 80093 222 69422
                        Mileage: 199502 km
                        Time: 14:28:04
       Component: IMMO            3HL 2420
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Revision: 71009005    Serial number: 00000879998420
       Coding: 0000180
       VCID: 71E24182686252C916-8024
                        Reset counter: 227
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 69     2501
       Revision: 00H15000
       VCID: 2C5C90F68FC07F2165-8078
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 199502 km
                        Time: 14:51:26
                        Battery Volts: 13.4 V
                            DU
                        Temperature: 36.0C
                        Count: 9
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Coding: 8190020052830C7F2D0484057008CFC6F0FC00
       VCID: 030E1B4A42DE5059F4-8056
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Revision: 71009005    Serial number: 00000878498303
       Coding: 0000436
       VCID: 72E04E8E6D6469D1EF-8026
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 156 A    HW: 1K0 035 156 A
       Component: Radio         018 0041
       Revision: R0018000    Serial number: VWZAZ1I8914399
       Coding: 0000020002
       VCID: 214271C23802A249C6-8074
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
       Revision: 11006001    Serial number: 00000003927427
       Coding: 0000144
       VCID: 75EA75921C0A7EE9CA-8020
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
       Revision: 11006001    Serial number: 00000003904491
       Coding: 0000144
       VCID: 76E8729E010C75F1C3-8022
    End-------------------------(Elapsed Time: 02:13)--------------------------
    Why is 03-ABS "Not Registered" in this car's Gateway? You should fix that first.
    You should also tell us what happened to this car that zero'd out the coding in the ABS.
    And you should look in your Scans sub-folder to see if maybe you did a scan at some point before the coding was zero'd out, because using the original coding is a safer than anything anyone here can come up with, because there is always some amount of guesswork involved in building MK60EC1 codings from scratch.
  3. Likes Ashraf6119 liked this post
    Nov 2016
    Portugal
    I do not know the history of the car, I saw the customer with these problems, it was the first time I diagnosed the car. The coding that is in ABS is the one that came, I do not have any previous code.
    Nov 2016
    Portugal
    Why is 03-ABS "Not Registered" in this car's Gateway? You should fix that first. fixed
    Moving to Car Repair Support because I see nothing that indicates you are having a problem with VCDS itself.
    Something smells like "crap" here .......oh it's FOD !
    1K0-907-375AC is correct part not the one in the car.
    That's why we JPPSG !
    VIN: WVWZZZ1KZ9M348338 Time to un-pimp this thing ....https://www.youtube.com/watch?v=3g7SpDoWGYw
    Vehicle Identification No. WVWZZZ1KZ9M348338
    Model Golf 1.9 estate
    BlueMotion
    GOLF
    Date of production 16.05.2009
    Year 2009
    Sales type 1K5024
    Engine Code BLS
    Transmission Code KBL
    Axle drive 5S
    Equipment HQ
    Roof color 2T
    Exterior color / Paint Code 2T / C9X
    "Charism" 2H0 Without "drive select"
    "Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Activated carbon canister 1E0 Without activated charcoal canister
    Additional body covers, side 6EA Without additional side body covers
    (stone guard)
    Additional child seat anchors 3B4 Child seat anchor for
    child seat system ISOFIX
    Additional tires (winter tires) 2WA Without additional tires
    Additional warning lights 9TC Additional reflectors (door area)
    Air bag 4UF Driver's and front passenger air bag
    with front passenger air bag
    deactivation
    Air duct, front area VK0 Air duct, standard
    Antennas 8ZM Antenna
    Anti-theft protection system 7AL Anti-theft alarm system, passenger
    compartment control, backup horn and
    towing protection
    Auxiliary heating 9M0 Without auxiliary/parking heater
    Backrest release 3H0 Without backrest release for front seats
    Base engine TG0 4-cylinder diesel engine 1.9 L
    unit 03G.6
    Batteries J0N Battery 330 A (61 Ah)
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Body measures 5C0 Without special body measures
    Body style K8D Station Wagon Variant/Avant
    Brackets 3P1 Bracket for first aid kit and warning
    triangle
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Brake type, front 1ZM Disc brakes, front (Geomet D)
    Brake type, rear 1KF Disc brakes, rear
    Braking systems 1AT Electronic stabilization program (ESP)
    Breakaway interior mirror 4L2 Dipping breakaway interior rear view
    mirror
    Bumper 2JC Comfort bumpers
    Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
    Cassette and CD storage unit 4W0 Without cassette and CD storage unit
    CD changer/CD player 7A0 Without CD changer/CD player
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    Center armrest 6E3 Front center armrest
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    Child lock 4H3 Manual child lock
    Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
    Child seats QA0 Without child seat
    Chrome work package QJ0 Without aluminum/chrome work package
    Climatic zones 0Y1 Standard climatic zones
    Compass/traffic sign display QR0 Without compass/traffic sign display/
    traffic signs recognition
    Component part sets with country-specific design requirements B0A Component parts set without
    Components with special surface appearance 6FF Body-colored exterior mirror housings
    and various add-on parts
    Cruise control 8T0 Without cruise control system (CCS)
    Customized installation FC0 Without customized installation
    Delivery equipment 2A8 Delivery equipment for shipment
    Door and lid locking system 4K3 Radio remote controlled central locking
    operated from inside and safe securing
    Door and side trim panels 4AF Door and side trim panel in foam film
    and woven fabric
    Door pockets, front 3YQ Door pockets without insert mats
    Doors 0A2 4 doors
    Drawers under front seats QN0 Without drawers under front seats
    Drive layout 1X0 Front wheel drive
    Electric interface for external use UF0 Without electric interface
    Electronic map cooling system QS0 Without electronic map cooling system
    Emission standard 7GG Emission standard EU4 DPF
    Engine cooling system 8Z4 Moderate hot country
    Engine specifications D3W 4-cyl. turbo diesel engine 1.9 L/77 kW
    TDI with pump-jet injection system
    Base engine is T71/TG0/TD0/T5X
    Equipment levels A8B Basic equipment
    Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
    Exterior mirror setting 6XG Exterior mirrors: with memory function,
    electrically adjustable/heated
    Fire extinguisher 6A0 Without fire extinguisher
    First aid kit / warning triangle 1T2 Warning triangle
    Floor mats 0TD Front and rear floor mats
    Front fog light/additional headlight 8WA Without front fog light
    Front license plate bracket 6W1 License plate bracket front (large)
    Front seat, left 3TB Standard seat, front left
    Front seat, right 3SB Standard seat, front right
    Front stabilizer 0AH Front stabilizer
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Fuel systems 0F8 Cooled fuel system for diesel engine
    Fuel tank treatment 2LD Fuel tank without differentiation of
    special material treatment
    (fluorination/co-extrusion)
    Gearshift knob/handle 6Q2 Leather gearshift knob/handle
    General operating permit, alterations C14 Operating permit, alteration
    Generators 8GU Alternator 140 A
    Hand brake lever handle 6PC Leather hand brake lever handle
    Headlight 8BG Twin-headlight for driving on the right,
    with integrated high beam
    Headlight activation 8K0 Without special headlight
    activation
    Headlight washer system 8X0 Without headlight washer system
    Headlight-range adjustment 8Q1 Headlight-range adjustment
    Headrests 3J1 Height-adjustable headrests for front
    seats
    Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
    Heated washer nozzles 9T0 Without heated washer nozzles
    Heating and air conditioning system 9AP Climatic air-conditioning system
    (semi-automatic)
    Hill hold control UG0 Without hill hold control / hill descent
    control / comfort driving assist
    Horns 8Y0 Single-tone horn
    Identification plates 1EX Special identification plate for EC
    for M1 passenger vehicle
    Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
    Inserts 5MA Decorative inserts
    Installation differentiation for vehicle components 0EJ Installation differentiation for
    transmission MQ 250
    vehicle components
    Instrument inserts U5A Instrument insert, km/h speedometer
    Interior light in foot area 6T0 Without interior light in footwell
    Left exterior mirror 5SL Left exterior mirror: aspherical
    Left vanity mirror 4SD Left vanity mirror, illuminated
    Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking
    from outside
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection
    (unlockable)
    Luggage compartment cover 3U2 Sliding trunk cover
    Luggage compartment lining 5A2 Comfort trunk lining
    Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets
    on backrests
    Lumbar support 7P0 Without lumbar support
    in seat backrests
    Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
    Marten repeller UM0 Without marten repeller
    Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
    Multi-function display/trip computer 9Q5 Multi-function display with control
    Nameplate set 0NB Nameplate set in base trim
    Nameplates for sales name QD1 Nameplates for sales name
    Navigation device 7Q0 Without navigation device
    Operating voltage 9Z0 Operating voltage 12V
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE
    label
    Owner's manuals 0VJ Information kit in Portuguese
    Paint coating FB0 Standard paint coating
    Paint preservative/transit coating 5K5 Transit coating film with additional
    transport protection measures
    Park distance control 7X2 Park distance control, front and rear
    Partition 3CA Without partition
    Pedal cluster VF0 Standard pedal cluster
    Pedestrian protection VL0 Standard pedestrian protection measures
    Platform group class 7PA Platform group class 1
    Platform module floor pan, rear 4P3 Rear floor panel module, type 4
    Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating
    emergency light and radio antenna
    preparation
    Preparation for two-way radio installation 9D0 Without preparation for two-way radio
    installation
    Protective side molding 4B0 Without protective side molding
    Radios 8UA Radio with CD player
    Reading light 8S1 Reading light front
    Rear cargo area 3GD Plane rear cargo area
    Rear fog light 8TC Rear fog light for driving on the right
    Rear headrests 3T2 Three rear headrests
    Rear license plate bracket 6P1 License plate bracket rear (ECE)
    Rear seats 3NM Rear seat bench/backrest, split folding
    Rear spoiler 5J0 Without rear spoiler
    Rear stabilizer 0BG Rear stabilizer
    Rear window wiper and washer system 8M1 Rear window wiper and washer system
    with intermittent control
    Refrigerator 1W2 Glove compartment cooling system
    Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
    Restraint systems, front 3QT 3-point seat belts with tensioner and
    height adjustment, front
    Right exterior mirror 5RQ Right exterior mirror: convex
    Right vanity mirror 4TD Right vanity mirror illuminated
    Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Roof rails/roof load rack 3S2 Black roof rails
    Rough-road/sports version 2UC Sports version
    Safety headrest system 3K0 Without safety headrest system
    Scuff plates 7M5 Without protective film for scuff plate
    Seat adjustment 3L1 Manual height adjustment for left front
    seat
    Seat belt check 9P3 Seat belt reminder, electric contact in
    buckle
    Seat covering N0B Fabric seat covering
    Seat heater 4A0 Without seat heater
    Service interval prolongation QG1 Service interval prolongation
    Shock absorption, chassis, front G67 Front shock absorption
    Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
    Side air bag 4X3 Side air bag front with curtain air bag
    Side and rear windows 4KC Side and rear windows in heat-insulating
    glass
    Side lights 7R3 Side turn signal lights (white)
    Ski bag 3X0 Without load-through provision
    Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
    Socket 7B0 Without socket
    Spare wheel/breakdown set 1G8 Breakdown set
    Speaker installation 8RE 4 speakers (passive)
    Special alarm systems 9A0 Without taxi alarm system
    Special editions E0A No special edition
    Special labels/plates 2KY Labels/plates in Italian, Spanish and
    Portuguese
    Special registration measures 3M0 Without special measures
    Steering 1N3 Speed-related variable steering assist
    (Servotronic)
    Steering system arrangement L0L Left-hand drive vehicle
    Steering wheels 2ZB Leather multi-function steering wheel
    Sticker (customized or special edition) 0KA Without stickers and badges
    Supertone system and tone sequence control 9J0 Without supertone system and tone
    sequence control
    Telephone/telematics 9W0 W/o car phone preparation/installation
    Tire pressure warning light 7K0 Without tire pressure warning light
    Tire suppliers V0A Tires w/o specification of tire brand
    Tires H0R Tires 205/55 R16 91H
    optimized rolling resistance
    Tool kit and jack 1S1 Tool kit and jack
    Trailer hitch 1D0 Without trailer hitch
    Transmission specifications G0J 5-speed manual transmission
    different spread of gear ratio
    Trunk sill protection 2P1 Plastic trunk sill protection
    TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
    Type approval countries/countries with special requirements B16 Type approval Portugal
    Upgrading measures GP0 Vehicles w/o special upgrade measures
    Vehicle class differentiation units/platform components 0HM Vehicle class differentiation -1KM-
    Build status corresponds to production
    in Mexico
    Vehicle specifications F0A No special purpose vehicle, standard
    equipment
    Washer fluid level indicator 8W0 Without washer fluid level indicator
    Weight category front axle L55 Suspension range 55
    installation control only, no
    requirement forecast
    Weight category rear axle 0YE Weight range 5
    Wheel covers 1NL Covers for alloy wheels
    Wheels CM7 Alloy wheels 6.5J x 16
    Window regulator 4R4 Power windows with comfort operation and
    circuit breaker
    Windshield glass type 4GF Windshield in heat-insulating glass
    Windshield wiper intermittent control 8N4 Windshield wiper intermittent control
    with potentiometer (four speeds)
    PH1 Air conditioning Climatic
    PJA "Toronto" 4 alloy wheels 6.5J X 16 Tires
    205/55 R16
    PU2 Multi-function leather steering wheel
    RFA "RCD 210" 2 x 20 W, 4 speakers
    WD2 Anti-theft alarm system "Plus" incl.
    single door opening
    Coding: 0000031
    Revision: 00H35001
    Coding: 114B000C09260002880E00E7902100000000 LHD Strip
    134B000C09260002C80E00E7902100000000 RHD Strip
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  8. Likes Ashraf6119, Boki Ar liked this post
    Nov 2016
    Portugal
    Thanks for the reply.
    I can not get the abs to accept the code, it gives the error "31: request out of range"
    The abs was not changed, the car was coded wrong on Gateway and some cabling problems were resolved.
    A question I need some login code to do coding ?.
    Miguel
  10. #8
    Oct 2015
    UAE
    Hi , try 40168 for access.
  11. #9
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Or you can try this coding.....
    Coding: 133B200D092500FAC80D04ED901C0081B100
