Results 1 to 2 of 2
Thread: GTI Mk5 errors
    Verified VCDS User Alfonso's Avatar
    Jan 2017
    Mexico
    Question GTI Mk5 errors
    I am reviewing a GTI 2008, I have found several errors but some worries me more than others.
    I have reviewed the connections of the shift paddles, I do not see anything wrong, the changes do them correctly, but the error is not removed.
    This is the Scan;
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56
    VIN: WVWFW71K78W109565   Mileage: 107470km-66778miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83N58QW
       Coding: 040300431C070160
       Shop #: WSC 35566 001 1048576
       VCID: 3424CC5957DCA1E13D-8060
    000665 - Boost Pressure Regulation
                   P0299 - 002 - Control Range Not Reached
                        Fault Status: 01100010
                        Mileage: 107091 km
                        Time: 01:32:42
                        RPM: 3886 /min
                        Load: 71.0 %
                        Speed: 76.0 km/h
                        Temperature: 85.0C
                        Temperature: 31.0C
                        Absolute Pres.: 770.0 mbar
                        Voltage: 13.843 V
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow - Intermittent
                        Mileage: 107344 km
                        Time: 21:22:59
                        RPM: 767 /min
                        Load: 15.3 %
                        Temperature: 76.0C
                        Temperature: 33.0C
                        Absolute Pres.: 780.0 mbar
                        Voltage: 13.716 V
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AE
       Component: GSG DSG         081 1407
       Revision: 04608010    Serial number: 00000708200310
       Shop #: WSC 01279 785 00200
       VCID: 1C7404F9DF4C09A115-8048
       Revision: 00H11001
       Coding: 0004738
       VCID: 73A60F451252E6D9E4-8026
       Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
       Component: ClimatronicPQ35 120 1111
       Revision: 00120021    Serial number: 00000000000000
       VCID: 79BA3D6D303E9C89AE-802C
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 01000007459738
       Coding: E78F8F21400415004714000014000000000877075C000100000000000000
       Shop #: WSC 01287 785 00200
       VCID: 71AA054D684ED4C916-8024
       Component: Wischer 040102 021  0501
       Coding: 00038805
       Shop #: WSC 01287
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00208933
       Shop #: WSC 01287
       Component: 37 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FX7GZ
       Coding: 0013111
       Shop #: WSC 01269 785 00200
       VCID: 3D32E97D649660A9C2-8068
       Subsystem 1 - Serial number: 6332MSME2E6530012
       Subsystem 2 - Serial number: 6342MSME2673786EP
       Subsystem 3 - Serial number: 6352QSME3B1B7923O
       Subsystem 4 - Serial number: 6362QSME3D260F3DX
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           036 0070
       Coding: 0012122
       VCID: 014A558D58EEC449E6-8054
    01749 - Switch for Tiptronic in Steering Wheel (E439); Down
       Part No SW: 1K6 920 874     HW: 1K6 920 874
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0G83N58QW
       Coding: 0007103
       Shop #: WSC 37300 993 06626
       VCID: 70AC00496344DDC119-8024
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 050907F1000518
       Coding: ED811F060012020000
       VCID: 302CC049A3C49DC159-8064
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T23DL03
       VCID: 7DB2297D2416A0A982-8028
       Component: IMMO            VDD 1216
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Component: Tuer-SG         006 120A
       Coding: 0000052
       VCID: 383CF8694BB4458111-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Shop #: WSC 00000 028 00001
       VCID: 3522F15D5CA6B8E90A-8060
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Coding: 819002085103087F2D04840570084A0690BC00
       Component: LIN BACKUP HORN H07 9001
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Coding: 0000052
       VCID: 393AFD6D70BE5C89EE-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74A40C59175CE1E1FD-8020
       Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
       Component: Radio PM6       018 0035
       Revision: 00018000    Serial number: VWZ5Z7G2167422
       Coding: 0040401
       VCID: 2A18D2218518E71197-807E
    End----------(Elapsed Time: 01:07, VBatt start/end: 12.6V/12.5V)-----------
    Sunday,11,June,2017,10:51:31:59342
    VCDS Version: 17.1.3.0  HEX-NET CB: 0.4334.4
    VIN: WVWFW71K78W109565   License Plate: 333XXX
    Mileage: 107470km-66778mi   Repair Order:
                    Address 01: Engine
    Control Module Part Number: 1K0 907 115 Q
      Component and/or Version: 2.0l R4/4V TFSI     0020
               Software Coding: 040300431C070160
                Work Shop Code: WSC 35566
    Advanced Identification
         Identification: BPG-810
         Revision: 5BH16---
         Date: 01.09.07
         Test stand number: 1348
         Manufacturer number: 0160
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Programming Status: 00000000
         Required Conditions: 00000001
    Software
         A000
         A4.9.6
    Misc.
         Hardware number: 8P0 907 115 B
    Car Info
         Chassis Number: WVWFW71K78W109565
    VCDS Info:
           Readiness: 06F-907-115-AXX.crd
