Thursday,27,April,2017,15:03:24:29052
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: WVGFF9BP8BD004232 License Plate:
Mileage: 89595km-55671mi Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 65 69 6C 6D 72
VIN: WVGFF9BP8BD004232 Mileage: 89595km-55671miles
Address 01: Engine (J623-CGRA) Labels: 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H15 8688
Revision: M7H15---
Coding: 002A0012433600000000
Shop #: WSC 51677 002 1048576
ASAM Dataset: EV_ECM36FSI01103H906023B 002006
ROD: EV_ECM36FSI01103H906023B.rod
VCID: 211CEC2CF14EFDCF027-8074
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1870
Coding: 001368
Shop #: WSC 64538 001 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001.rod
VCID: 2A0E0B008C783E9753D-807E
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 E HW: 7P0 907 379 A
Component: MK25A H33 0416
Revision: -------- Serial number: 401210010EC010
Coding: 5B7613C349242557DAF6C89692D4A4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 3FD84A5467FAAB3F143-806A
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H23 0208
Coding: 0D860F00000000000000
VCID: 72BED36064A836572BD-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000094578014
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: 4686200A80
VCID: 79ACE44C395E450F6A7-802C
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000918344
Coding: 2600D013973C7F010020180300005D0C431C660882010261000000020000
VCID: 313C1C6CA12E4D4F927-8064
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110115 31 0020
Serial number: 90243400110118064720
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10110301
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000003012100162
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R07FJ06
Address 10: Park/Steer Assist (J446) Labels: 7P6-919-475.clb
Part No SW: 7P6 919 475 HW: 7P6 919 475
Component: PARKHILFE 8K H03 0016
Revision: -------- Serial number: 55931101203623
Coding: 318501
ASAM Dataset: EV_VW526ParkiAssis2 001008
ROD: EV_VW526ParkiAssis2.rod
VCID: 55F488FCF586416F2EF-8000
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag02D H05 0023
Revision: -------- Serial number: 003JX0019YT%
Coding: 000000000000000000000000000000003244
VCID: 40DA49A81A04D4C76D9-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1090401AJA
Serial number: 3575LRB405F08V2MCPMA
Serial number: 3585LRB405F08V2M80QT
Serial number: 3515RRB405J6V144OH9V
Serial number: 3525RRB405J6V144M92F
Serial number: 3555NRB405706OG21P74
Serial number: 3565NRB405706OG2MPAT
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 B HW: 7P6 953 507 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KAD00024
Coding: 000C15
VCID: 323E1360A4287657EBD-8066
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0048029
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H12 0239
Revision: 10240061 Serial number: 658090111593017
Coding: 8B7732022B00CF05010004
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 46D65FB03820FAF7575-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000084911
Coding: 0021032600
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 382A214842D49C07D59-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650474859
12290 - Quiescent Current
U1406 00 [008] - Too High
Fault Frequency: 45
Reset counter: 152
Mileage: 89208 km
Date: 2017.04.16
Time: 20:33:59
Voltage terminal 30: 12.3 V
Voltage terminal 15: 0.0 V
Control Module temperature: 37 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
U140B 00 [008] - -
Fault Frequency: 17
Reset counter: 152
Mileage: 89208 km
Date: 2017.04.16
Time: 23:34:27
Voltage terminal 30: 12.2 V
Control Module temperature: 28 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002249561
Coding: 00581B0000004001000001010101202020202121202020
VCID: 343215785E3C7867F91-8060
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000111535835
Coding: 011D17205E00453005080000
VCID: 3C223D58766CB027311-8068
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0141182515
Coding: 01861E382839509583B00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 284103354
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO11186821
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO1120436Y
Coding: 191100
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 7P6 035 466 HW: 7P6 035 466
Component: DSP Prem H01 0090
Revision: 00001001 Serial number: 10811000350202
VCID: 75B4E87C15C6216F0EF-8020
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000111916612
VCID: 3B203E447362B71F38B-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A10C150001A
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 3534287C55C6616FCEF-8060
Slave 3:
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
VCID: 7CA2FD58366C7027711-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 471AX0B7551862
Coding: 020007010000000001
VCID: 2412E538EEDCE8E7691-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 D HW: 7P6 035 664
Component: H-BN-NA H43 0706
Revision: -------- Serial number: 445AJ0B7510105
Coding: 020200050040E1EF41022B0E00000003F00801010000000000
VCID: 392C244C795E850F2A7-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H24 0045
Serial number: VWZ8Z9K290042L
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Reset counter: 88
Mileage: 89202 km
Date: 2017.04.16
Time: 18:06:44
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
Reset counter: 88
Mileage: 89202 km
Date: 2017.04.16
Time: 18:06:42
Voltage: 14.20 V
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000112092518
Coding: 011C17200000253005080000
VCID: 3A2E3B407C588E1723D-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000019859
ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 B HW: 7P0 907 383 B
Component: Anhaenger H07 0100
Revision: 5A001001 Serial number: 00000141189455
Coding: 020D000000000000
VCID: 372822744F4A937FDC3-8062
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J0Y0444
Coding: 0130001
VCID: 37282274434A937FDC3-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 353000012
Coding: 0533310103
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000111821994
End----------(Elapsed Time: 02:02, VBatt start/end: 14.5V/14.5V)-----------
