2018 Atlas, 3.6 FSI VR6 (CDVC) maps
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Full Atlas support (as shown here) requires minor code and data updates, just finished by Ross-Tech, presumably to be published in the next Beta and HEX-NET/HEX-V2 codeblocks.
A HEX-NET or HEX-V2 interface is required for access to all modules. A legacy HEX-USB+CAN interface will not work with addresses 4B, CA, D6, or D7 due to known technology limitations, but it seems okay with the rest on very light testing.
Friday,09,June,2017,20:30:00:21122
VCDS Version: 17.5.1.1 (x64)  HEX-NET CB: 0.4342.4
Data version: 20170602 DS272.0
Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
Workshop Code: 444 08607 000001
VIN: 1V2NR2CA0JC502209   License Plate: 2018ATLAS
Mileage: 883km-548mi   Repair Order: BETA1751-HNU-RedirUpdates
Chassis Type: CA (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
          52 5F 69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NR2CA0JC502209   Mileage: 883km-548miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC)       Labels: None
   Part No SW: 03H 906 026 J    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H20 4748
   Revision: 52H20000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 07645 128 28888
   ASAM Dataset: EV_ECM36FSI01103H906026J 001003
   ROD: EV_ECM36FSI01103H906026E.rod
   VCID: 2C14C5D84759B527E8-8078
   CAN Converter 01:
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 A    HW: 09G 927 158
   Component: AISIN AQ8     206 3387
   Coding: 0000000100000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   ROD: EV_TCMAQ450031.rod
   VCID: 312AD4AC607BD8CFDB-8064
   Revision: 00000000    Serial number: 50697000000109
   Coding: 44FC6B8D84201A6EC5790300A2CC6922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77BE2AB4CE9FC6FF55-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0430197433
   Coding: 0F2000070F
   ROD: EV_KessyHellaMQBAB_VW41.rod
   VCID: 3C34F598B73925A778-8068
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58006600
   Part No SW: 3CN 907 044 F    HW: 3CN 907 044 F
   Component: Climatronic   H05 1802
   Revision: 00001K01
   Coding: 16020626200014001104110C1210150C
   ASAM Dataset: EV_ACClimaBHBVW416 002007
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 42C88B60D5DD535732-8016
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BG    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H34 0236
   Serial number: 7041011802ÿÿÿÿ
   ROD: EV_BCMBOSCH_017_VW27.rod
   VCID: 7F4EC294E6AFFEBF1D-802A
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  046 0120
   Serial number: S6Y17M01D31H15M40S26
   Coding: 00B86D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z363302
   Coding: 150000
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00117011700010527
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0163999
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0164122
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0182946
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0246621
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0038
   Serial number: 000308417617023
   Coding: 0271667151
   ASAM Dataset: EV_EPHVA2CAU3700000 009032
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4FEEB254168FAE3FAD-801A
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0620
   Coding: 320007C959FFC728949C810530401600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002005
   ROD: EV_ACCBOSCHVW416.rod
0836 - Databus
                    Fault Frequency: 227
                    Reset counter: 84
                    Mileage: 322 km
                    Date: 2017.06.03
                    Time: 18:35:42
                    Dynamic environmental data: 02 8D
                    Control Module temperature: 65 °C
                    Voltage terminal 15: 13.6 V
                    Velocity_vehicle_reference: 3.08 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.91 m/s²
1236 - Databus
                    Reset counter: 74
                    Mileage: 572 km
                    Date: 2017.06.05
                    Time: 19:28:40
                    Control Module temperature: 51 °C
                    Voltage terminal 15: 12.8 V
                    Velocity_vehicle_reference: 0.86 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.07 m/s²
   Part No SW: 3Q0 959 655 BC    HW: 3Q0 959 655 BC
   Component: Airbag VW21   004 0503
   Revision: --------    Serial number: 003SUM49OKEP
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 004C41689B51814764-8054
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J170006OQEB0P
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 001 601 17
   Serial number: 35700000000E643DB12Q
   Subsystem 3 - Part No SW: -----------    HW: 454 001 601 17
   Serial number: 35800000000B843DB12Q
   Subsystem 4 - Part No SW: -----------    HW: 454 801 002 17
   Serial number: 35100BE8B0F0F000000/
   Subsystem 5 - Part No SW: -----------    HW: 454 802 301 17
   Serial number: 352009E26BE0E000000.
   Subsystem 6 - Part No SW: -----------    HW: 454 802 812 16
   Serial number: 35500DCF80E0E0000003
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 812 16
   Component: FrontSensor_P  304 0149
   Serial number: 35600FAFB0E0E0000007
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 11011704400586
   Coding: 0C10
   VCID: 03464E648A479A5F79-8056
   Part No SW: 3CN 920 891 A    HW: 3CN 920 891 A
   Component: KOMBI         404 3192
   Coding: 0BA40F1DEF88CF0502886B0B5001000020000000
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Fault Frequency: 9
                    Reset counter: 83
                    Mileage: 605 km
                    Date: 2017.06.06
                    Time: 17:14:31
   Component: GW MQB High   515 5286
   Serial number: 20021700840033
   Coding: 0B0500347F087300FB0722581E0F00010000070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 2F2ED2D4764FCE3FCD-807A
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Serial number: 29160001817810016366
   Coding: 36FFFF
   Serial number: 6858452904
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0860
   Serial number: 0001255
231017 - Voltage Converter Temporary Malfunction
          U4EF45B FB [008] - Overcurrent in Secondary Circuit
                    Reset counter: 70
                    Mileage: 322 km
                    Date: 2017.06.03
                    Time: 20:21:59
                    Supply voltage: Terminal 30: 13.5 V
                    Terminal 15: On
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00002.12.16
   Coding: 0301
   ROD: EV_AllWheelContrHA1VW37X_004_VW37.rod
   VCID: 4AD8A340EDED8B17FA-801E
   Serial number: 17000007942012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW41.rod
   VCID: 71AA14ACA0FB98CF9B-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Component: Sitzmemory    H08 0021
   Serial number: Y0006PL516752
   Coding: 0010000000000500018280808080000000008100000000F400
   ROD: EV_SeatMemorDriveSide_VW41.rod
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0427420305
   Coding: 02012103
   ROD: EV_HREntryHella_VW32.rod
   Lane Change Assistant 2:
   Serial number: 27121606050HIT
   Coding: 003F1B205200020000000000
   ROD: EV_DCUDriveSideEWMAXCONT_VW27.rod
   VCID: 43C68E64CAC75A5F39-8016
   Serial number: 00000000000005469691
   Coding: 011000
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Revision: 00000000    Serial number: 0001417184
   Coding: 01010311004001
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: 40CC8168DBD1414724-8014
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H30 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA02RF4C
   Coding: 2214060002A00A2A000000000000
   ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
   ROD: EV_AMPMst12C3Gen2ALPI.rod
   VCID: 6D9208DCBCC37C2FBF-8038
Address 4B: Multifunc. Module (J745)       Labels: None
   Component: FCM MQB Low   001 0286
   Serial number: 14021700840110
   Coding: 000000070100135200010000000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_VW27.rod
   VCID: 72A81BA0A5FDA3D762-8026
   Serial number: 221216060500N8
   Coding: 003F13205E00020000000000
   ROD: EV_DCUPasseSideEWMAXCONT_VW27.rod
   Serial number: 00000000000005472451
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3QF 035 876     HW: 3QF 035 876
   Component: MU-S-NS-US    840 0755
   Coding: 021406020000000051220002001808001F0500E401200005CE
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 075E5A74BE7FB67F25-8052
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H40 8074
   Serial number: VWZ6ZDT0050741
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0430201804
   Coding: 0200000200000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG008159
   Coding: 01140604A30F20000000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   VCID: 383CE988830109879C-806C
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0988
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 41CA846CD0DB484F2B-8014
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0570
   Coding: 02140602C2823A017F1E06020000
   ROD: EV_OCULowMQB_VW32.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 15011712K20431
   Coding: 000401060001020100221355C050490084000E200020
   ROD: EV_MFKBoschMQBB_VW36.rod
   VCID: 3B36F684B237229F71-806E
Address CA: Sunroof (J245)       Labels: None
   Component: SAD_STG_1     013 0005
   Coding: 00804074160C
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3D32F89CAC232CAF4F-8068
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 7BB63684F2B7E29F31-802E
0800 - Bulb for Low-Beam Headlamp
          U4F5256 F6 [040] - Over-Temp Protection Active
                    Reset counter: 0
                    Mileage: 163 km
                    Date: 2017.05.25
                    Time: 17:28:37
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H06 0003
                    Reset counter: 0
                    Mileage: 322 km
                    Date: 2017.06.03
                    Time: 19:41:37
End----------(Elapsed Time: 02:17, VBatt start/end: 14.0V/14.0V)-----------
Keithuk
Stoke on Trent, England
C?ID=122432
ETKA only shows CDVC 206Kw 280PS 3.6 12/2016- FSI no model name. So I've added this one to my app.
That AutoScan shows VCDS Version: 17.5.1.1 currently it only shows VCDS Release 17.1.3. Is that only for HEX-NET or HEX-V2?
NEtech
C?ID=56995
Well Partslink24 does:
17.5.1 was made available to the forum membership here last weekend. It was subsequently published on our Beta Page with one updated data file a couple of days ago.
It works with all interfaces we've made/sold since 2004, however, the legacy interfaces do have technical limitations that prevent them from communicating with some modules in the latest cars.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
This scan is basically from the current public Beta, with a little extra hand-retouching of labels and redirects, and an alpha channel CB update that teaches HEX-NET and HEX-V2 about the brand-new 4B module address. Those updates will make their way out to everyone in due course. As always, HEX-USB+CAN users will get the benefit of the Desktop updates, but unfortunately there's nothing that can be done about access to certain new modules mentioned above.
Jason
Keithuk
C?ID=122432
I was going to ask if you know the transmission code that NETech shows? QVK shows in my PDF file but as with the CDVC it only shows the year 2016- not the model. There are a few codes with years only and no model. If they know the code they should know the models that use this code.
QVK isn't in last months PDF, CDVC is.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I'm not sure what document you're referring to. You mentioned earlier you couldn't find it in ETKA, but I was chatting with my parts guy when I was in about a month ago, and he happened to mention all the Atlas stuff had landed in ETKA for them, and this was a week or more before they had even shown up at dealers. So US dealers with ETKA updates have it just fine, as does PL24. I believe the Atlas is a US-only model so I'm not sure if VW will push that data to dealers elsewhere.
Jason
Keithuk
C?ID=122432
ETKA shows engine codes and transmission code from Audi, Seat, Skoda & VW. I click print and save them as a PDF file. I've been making an VAG Engine & Transmission Codes app for a few years that shows them all. At the moment there are 6,865 engine codes and 15,851 transmission codes. When I update ETKA every month I save 8 new PDF files and check it which my app. I update new models with any new dates and info.
Manufacturer: VW, Date(s) Used: 12/2016-, Model: Atlas SUV, Engine Code: CDVC, 206Kw, 280PS, 3.6 Ltr, 6 Cyls , Remarks: Fuel Stratified Injection (FSI) VR6 V6
Manufacturer: VW, Date(s) Used: 12/2016-, Model: Atlas SUV, Transmission Code: QVK, Transmission Type: 8A
As I've said there are a lot of codes shown with the date but no model, CDVC and QVK which have now been added thanks to this thread.
I've uploaded last months PDF files which these codes don't show. If anyone wants these 8 PDF files, or if anyone wants my new app PM me ;)
These have been posted on a few forums. You can Google VAG Engine & Transmission Codes. This app isn't a popular than my EOBD II Fault Codes software which you can also Google.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Cold engine, engine off.
Sat overnight, OAT 70F.
;SW:03H-906-026-J   HW:03H-907-309-K ---  Engine
;Component:VR6 3.6l FSI  H20 4748, Coding:012A003244740108B0000000000000000000000000000000
;EV_ECM36FSI01103H906026J,001003,EV_ECM36FSI01103H906026E.rod
;Friday,16,June,2017,06:20:09:21122
;VCDS Version: Beta 17.6.0 (x64)  Data version: 20170602 DS274
;VCID: 2C14C5D84759B5274F-8078
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),1V2NR2CA0JC50220,
IDE00019,Voltage terminal 30,12.100, V
IDE00020-ENG104207,Terminal 15 status-Bit 0,1,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,32, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),15.3, %
IDE00084,Absolute load value,0.0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,14.5, %
IDE00090-ENG104207,selected gear-Bit 0,0,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
IDE00100,Engine torque,0.0, Nm
IDE00148,Median injection timing,0.000, ms
IDE00150,Pressure in brake booster,161.48, hPa
IDE00151,Oil fill level,66.400, mm
IDE00152,Oil warning threshold,28.000, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00159,Timing angle retardation cylinder 5,0.0, °
IDE00160,Timing angle retardation cylinder 6,0.0, °
IDE00167,Exhaust temperature 1 bank 1,20.9, °C
IDE00168,Exhaust temperature 1 bank 2,20.9, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00173,Cruise Control System: specified speed,0,
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-15.000, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-15.000, °
IDE00178,Camshaft adjustment intake bank 1: specified value,25.000, °
IDE00179,Camshaft adjustment intake bank 1: actual value,25.000, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.00, °
IDE00186,Fuel low pressure: actual value,559.7, kPa
IDE00187,Coolant temperature at engine start,32.3, °C
IDE00188,Fuel high pressure: actual value,0.5595, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,24.9, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,29.8, °C
IDE00201,High fuel pressure: specified value,6.3845, MPa
IDE00202,Low fuel pressure: specified value,550.0, kPa
IDE00304,Fuel level,39.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,0.22, g/s
IDE00348,Intake air temperature,29, °C
IDE00349,Throttle valve position: normed,5.1, %
IDE00350,Air mass: specified value,13.2, kg/h
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG104207,Cruise Control System (CCS): status-Bit 0,0,
IDE00357,Fuel temperature,31.5, °C
IDE00358,Limitation: torque,469.8, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,985.63, hPa
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.02, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,737.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,364.8, mV
IDE00405,Crankshaft speed (RPM),0.0, /min
IDE00407-ENG104207,Rail pressure regulation: status-Bit 0,0,
IDE00407-ENG28465,Rail pressure regulation: status-Byte,00000000 ,
IDE00412-ENG104207,Starter control: terminal 50-Bit 0,0,
IDE00413-ENG104207,Starter control: Interlock- or P/N-signal-Bit 0,17,
IDE00414-ENG104207,Starter control: relay 1-Bit 0,0,
IDE00416-ENG104207,Starter control: terminal 50 acknowledgment-Bit 0,0,
IDE00417-ENG104207,Starter control: shut-off conditions 1-Bit 0,0,
IDE00417-ENG101796,Starter control: shut-off conditions 1-Bit 8,0,
IDE00443-ENG104207,Accelerator pedal: switch positions-Bit 0,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450-ENG124478,Operating Instructions-Test_Program_Requested Action,0,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,98, kPa
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG104207,Activation of oil pressure switch valve-Bit 0,0,
IDE00497-ENG104207,Status of oil pressure switches-Bit 0,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,21, °C
IDE00559-MAS04135,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value,1.012, lambda
IDE00559-MAS04136,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current,127.996, mA
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.455, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00565-MAS04135,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Oxygen sensor value,1.012, lambda
IDE00565-MAS04136,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Current,127.996, mA
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.455, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,2.000, lambda
IDE00583,Throttle valve specified value,1.6, %
IDE00584,Distance driven since erasing DTC memory,1175, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,55.3, %
IDE00592-MAS04113,Oxygen sensor control status-Oxygen sensor control 1 status,Not available,
IDE00592-MAS04114,Oxygen sensor control status-Oxygen sensor control 2 status,Not available,
IDE00593,Ignition timing adjustment cylinder 1,0.0, °
IDE00595-MAS01839,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 1,installed,
IDE00595-MAS01840,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 2,installed,
IDE00595-MAS04115,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 3,not installed,
IDE00595-MAS04116,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 4,not installed,
IDE00595-MAS04117,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 1,installed,
IDE00595-MAS04118,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 2,installed,
IDE00595-MAS04119,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 3,not installed,
IDE00595-MAS04120,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 4,not installed,
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00598,Long term adaptation of mixture formation bank 2,4.7, %
IDE00601-MAS00317,Monitoring status since erasing DTC memory-Malfunction Indicator Lamp,OFF,
IDE00601-MAS00328,Monitoring status since erasing DTC memory-Monitoring of ignition misfires,activated,
IDE00601-MAS00329,Monitoring status since erasing DTC memory-Monitoring of fuel system,activated,
IDE00601-MAS00330,Monitoring status since erasing DTC memory-Monitoring of entire system,activated,
IDE00601-MAS00331,Monitoring status since erasing DTC memory-Ignition misfire test,Unknown,
IDE00601-MAS00332,Monitoring status since erasing DTC memory-Fuel system test,Unknown,
IDE00601-MAS00333,Monitoring status since erasing DTC memory-Entire system test,completed successfully,
IDE00601-MAS00503,Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries,0,
IDE00601-MAS04092,Monitoring status since erasing DTC memory-Monitoring of compression ignition,Not supported,
IDE00601-ENG20482,Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared,00,
IDE00602-MAS04092,Monitoring status in current driving cycle-Monitoring of compression ignition,Not supported,
IDE00602-ENG20399,Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle,No,
IDE00602-ENG20507,Monitoring status in current driving cycle-Comprehensive component monitoring completed,completed successfully,
IDE00602-ENG20447,Monitoring status in current driving cycle-Comprehensive component monitoring enabled,activated,
IDE00602-ENG20496,Monitoring status in current driving cycle-Fuel system monitoring completed,not completed successfully,
IDE00602-ENG20425,Monitoring status in current driving cycle-Fuel system monitoring enabled,activated,
IDE00602-ENG20449,Monitoring status in current driving cycle-Misfire monitoring completed,completed successfully,
IDE00602-ENG20506,Monitoring status in current driving cycle-Misfire monitoring enabled,activated,
IDE00603,Number of driving cycles since erasing DTC memory,36,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00605,Short term adaptation of mixture formation bank 2,0.0, %
IDE00608,Type of fuel,Petrol,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,17.924, mm
IDE00700,ESI: maximum oil level in service interval,20.128, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00000,
IDE00739,Test of oxygen sensors bank 2: Delta-Lambda,0.00000,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,21.0, °C
IDE01076,Time since ignition off,32973, s
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01236-ENG104207,Coolant recirculation pump-Bit 0,0,
IDE01260,Generator power,0.0123888, W
IDE01266-ENG104207,Coolant shut-off valve-Bit 0,2,
IDE01267,Height correction,0.97290,
IDE01378,High fuel pressure: control deviation,5.8475, MPa
IDE01385-ENG104207,Wear index-Bit 0,0,
IDE01385-ENG101796,Wear index-Bit 8,0,
IDE01386-ENG104207,Soot index-Bit 0,0,
IDE01386-ENG101796,Soot index-Bit 8,0,
IDE01405-ENG104207,Status of starter activation-Bit 0,0,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01639,Dynamic factor O2 sensors bank 2 or bank 4 before cat. conv.,1.0000,
IDE01641-ENG104207,Result of oxygen sensor test bank 1 after catalytic converter-Bit 0,0,
IDE01641-ENG28465,Result of oxygen sensor test bank 1 after catalytic converter-Byte,00000000 ,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.455, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.455, V
IDE01647-ENG129417,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 379,235,
IDE01649,Throttle valve position 1,6.91, %
IDE01650,Throttle valve position 2,15.3, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,0.0, %
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01678-ENG129413,Result of O2 sensor test ready bank 2 after cat. conv.-Test_Program_Channel 114,235,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire sum counter,0,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,12100, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.42, %
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,8.1421,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01877-ENG104207,Operating condition of idle speed control-Bit 0,0,
IDE01877-ENG103108,Operating condition of idle speed control-Bitregister,00000000 ,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01887,Adaptation of Fuel Pump (FP),-28.0, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,4.001, %
IDE01899,Load value: corrected specified value,79.29, %
IDE01901,Lost torque adaptation: idle,-3.6, Nm
IDE01902,Lost torque adaptation A/C compressor,0.1, Nm
IDE01903,Lost torque adaptation driving mode,-2.7, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,2.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.94562,
IDE01911,Leakage air,0.0, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,15.9998,
IDE01914-ENG104207,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bit 0,2,
IDE01914-ENG103108,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bitregister,00000010 ,
IDE01916,Leakage recognition from oxygen sensor control,15.9998,
IDE01917,Leakage after throttle valve,0.000,
IDE01918,Leakage before throttle valve,0.000,
IDE01919-ENG104207,Leakage recognition: status-Bit 0,212,
IDE01919-ENG103108,Leakage recognition: status-Bitregister,11010100 ,
IDE01920,Oxygen sensor: mixture correction with active diagnosis,-0.0000,
IDE01922,Vehicle distance driven,1340, km
IDE01923,Control module distance driven,1338885, m
IDE01928,Close cam shaft angle at quantity control valve,110.0, °
IDE01929,Open cam shaft angle at quantity control valve,-98.2, °
IDE01930,High pressure regulation: adaptation value,0.0000, MPa
IDE01932,High pressure pump injection volume,327.67, mm³
IDE01975,Numb.of misfir.: cylinder 1,351,
IDE01976,Numb.of misfir.: cylinder 2,322,
IDE01977,Numb.of misfir.: cylinder 3,160,
IDE01978,Numb.of misfir.: cylinder 4,167,
IDE02115-ENG104207,Adjustment requirements for basic setting-Bit 0,178,
IDE02115-ENG103108,Adjustment requirements for basic setting-Bitregister,10110010 ,
IDE02116,Exhaust gas temperature before catalytic converter,20.99, °C
IDE02117,Relative load value,66.19, %
IDE02118,Oxygen sensor bank 1 sensor 1: voltage,0.000, V
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,-0.03, MPa
IDE02540-ENG104207,Longitudinal acceleration sensor: status-Bit 0,0,
IDE02756-ENG104207,Number of manual engine starts-Bit 0,241,
IDE02756-ENG102612,Number of manual engine starts-Bit 16,0,
IDE02756-ENG101717,Number of manual engine starts-Bit 24,0,
IDE02756-ENG101796,Number of manual engine starts-Bit 8,0,
IDE02757-ENG104207,Number of automatic engine starts-Bit 0,241,
IDE02757-ENG102612,Number of automatic engine starts-Bit 16,0,
IDE02757-ENG101717,Number of automatic engine starts-Bit 24,0,
IDE02757-ENG101796,Number of automatic engine starts-Bit 8,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,7, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,7, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,26,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,6,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,13,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,20,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,-1560281088, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,2130837504, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,45,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,9,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,5,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,6,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,2017,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,2017,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG103639,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99665,Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG100535,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG99682,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG101771,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG104020,Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03190-ENG103316,Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature,0,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.497, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.768, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.235, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,160,
IDE03364,Numb.of misfir.: cylinder 6,188,
IDE03393-ENG104207,Selector lever position-Bit 0,8,
IDE03583-ENG104207,Engine shut-down overrides-Bit 0,17,
IDE03584-ENG104207,Engine starting requirements-Bit 0,0,
IDE03585,System status for the start/stop function master,2,
IDE03586-ENG104207,Starting requirements for active participants-Bit 0,0,
IDE03586-ENG101796,Starting requirements for active participants-Bit 8,0,
IDE03587-MAS00075,Stop overrides for active participants-Brake control module,not active,
IDE03587-MAS00077,Stop overrides for active participants-Immobilizer,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00798,Stop overrides for active participants-Transmission Control Module (TCM),not active,
IDE03587-MAS00829,Stop overrides for active participants-Access and start authorization,not active,
IDE03588-MAS00075,System malfunctions for active participants start/stop-Brake control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00798,System malfunctions for active participants start/stop-Transmission Control Module (TCM),not active,
IDE03588-MAS00829,System malfunctions for active participants start/stop-Access and start authorization,not active,
IDE03589-ENG104207,Error status for start-stop related sensors-Bit 0,2,
IDE03660,Longitudinal acceleration,0.190, m/s²
IDE03692-ENG104207,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,202,
IDE03692-ENG103108,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bitregister,11001010 ,
IDE03693-ENG104207,Monitoring status of additional Onboard Diagnosis-Bit 0,229,
IDE03693-ENG103108,Monitoring status of additional Onboard Diagnosis-Bitregister,11100101 ,
IDE03694-ENG104207,Result of test of fuel supply system partial throttle-Bit 0,0,
IDE03694-ENG28465,Result of test of fuel supply system partial throttle-Byte,00000000 ,
IDE03696-ENG104207,Result test of oxygen sensor heater after catalytic converter-Bit 0,0,
IDE03696-ENG28465,Result test of oxygen sensor heater after catalytic converter-Byte,00000000 ,
IDE03697-ENG104207,Result test of oxygen sensor heater before catalytic converter-Bit 0,4,
IDE03697-ENG28465,Result test of oxygen sensor heater before catalytic converter-Byte,00000100 ,
IDE03698-ENG104207,Result of dynamic test of oxygen sensor before cat. converter-Bit 0,0,
IDE03698-ENG28465,Result of dynamic test of oxygen sensor before cat. converter-Byte,00000000 ,
IDE03699-ENG104207,Result of test of oxygen sensor before catalytic converter-Bit 0,4,
IDE03699-ENG28465,Result of test of oxygen sensor before catalytic converter-Byte,00000100 ,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03703-ENG104207,Result catalytic converter diagnosis test-Bit 0,0,
IDE03703-ENG28465,Result catalytic converter diagnosis test-Byte,00000000 ,
IDE03707-ENG104207,Result of NPulse test-Bit 0,170,
IDE03707-ENG28465,Result of NPulse test-Byte,10101010 ,
IDE03708-ENG104207,Result of test 2 of oxygen sensor before catalytic converter-Bit 0,0,
IDE03708-ENG28465,Result of test 2 of oxygen sensor before catalytic converter-Byte,00000000 ,
IDE03709,Angle difference actual-specified camshaft adjuster,0.000, °
IDE03710-ENG104207,Result of camshaft diagnostic test-Bit 0,0,
IDE03710-ENG28465,Result of camshaft diagnostic test-Byte,00000000 ,
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03794,Long-term fuel trim bank 2 at idle,0.33, %
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03806-ENG104207,Oxygen sensor bank 1 sensor 1: status-Bit 0,0,
IDE03806-ENG28465,Oxygen sensor bank 1 sensor 1: status-Byte,00000000 ,
IDE03807-ENG104207,Oxygen sensor bank 1 sensor 2: status-Bit 0,0,
IDE03807-ENG28465,Oxygen sensor bank 1 sensor 2: status-Byte,00000000 ,
IDE03808-ENG104207,Oxygen sensor bank 2 sensor 1: status-Bit 0,0,
IDE03808-ENG28465,Oxygen sensor bank 2 sensor 1: status-Byte,00000000 ,
IDE03809-ENG104207,Oxygen sensor bank 2 sensor 2: status-Bit 0,0,
IDE03809-ENG28465,Oxygen sensor bank 2 sensor 2: status-Byte,00000000 ,
IDE03810,Oxygen sensor bank 2 sensor 1: specified value,15.9998,
IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,235,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,0.000, Ohm
IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03823-ENG129414,Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125,0,
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,0.00, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,0.000, %
IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,235,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,209,
IDE03837-ENG129416,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 2115,213,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.01132,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03968-ENG104207,Camshaft adaptation results-Bit 0,0,
IDE03968-ENG28465,Camshaft adaptation results-Byte,00000000 ,
IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,Not available,
IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,0, kPa
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,430, kPa
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,Available,
IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,0, °C
IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,Not available,
IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,0, kPa
IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,Not available,
IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,0, kPa
IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,Not available,
IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,0, °C
IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,Not available,
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,installed,
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,33, °C
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,installed,
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,32, °C
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,0.000000, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,0.000000, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,0.000000, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,0.000000, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,0.000000, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,0.000000, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04241,Counter start bef dew pt end f O2 sensor bef cat conv bank2,0,
IDE04242,Counter start bef dew pt end f O2 sensor beh fr cat conv bank1,0,
IDE04243,Counter start bef dew pt end f O2 sensor beh fr cat conv bank2,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04245,Count start bef dew pt end f O2 sensor beh main cat conv bank2,0,
IDE04302-ENG104207,Bypass valve for high press turbocharger turbine inlet: status-Bit 0,0,
IDE04302-ENG102612,Bypass valve for high press turbocharger turbine inlet: status-Bit 16,0,
IDE04302-ENG101717,Bypass valve for high press turbocharger turbine inlet: status-Bit 24,0,
IDE04302-ENG101796,Bypass valve for high press turbocharger turbine inlet: status-Bit 8,0,
IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
IDE04410,Intake manifold pressure: target value,268.91, hPa
IDE04414,Cat conv temp: modeled,20, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04654-ENG104207,CAN status - engine control module-Bit 0,0,
IDE04655-ENG104207,CAN status - transmission control module-Bit 0,0,
IDE04656-ENG104207,CAN status - brake control module 1-Bit 0,0,
IDE04657-ENG104207,CAN status - brake control module 2-Bit 0,0,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,0,
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.1, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,823.98, hPa
IDE04887,Powertrain target torque,-843.2, Nm
IDE04889,Target torque for combustion engine crankshaft level,-46.6, Nm
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE04937,Sensor for engine block temperature: raw value,33.0, °C
IDE05128,Intake air temperature in intake manifold bank 1,28.5, °C
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
IDE05138,Shut-off timer: last engine shut-off time,32991, s
IDE05140,Intake manifold pressure raw value,0.00, hPa
IDE05228,Operating hour counter,1746, min
IDE05240-ENG104207,Request for A/C compressor power reduction-Bit 0,0,
IDE05241-ENG104207,A/C compressor release status-Bit 0,0,
IDE05261-ENG104207,Gear position sensor: last valid value-Bit 0,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG104207,Heat request from heater to thermal management-Bit 0,3,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,20.3, °C
IDE05438,Rear cat conv temp main cat conv model value,20.99, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,20.99, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0486, rad
IDE05444,Air filling: specified value,15.84, %
IDE05445,Pressure before throttle valve of pressure sensor,985.47, hPa
IDE05447,Leak recog from oxygen sensor control bank 2,15.9998,
IDE05448,Long term adaptation of mixture form bank 2 at partial load,1.04175,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,131070, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,131070, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00497,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00311,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0.0000,
IDE05473,Cat converter oxygen storage capacity ref standardized bank 2,0.0000,
IDE05474,Main cat converter OSC age correction factor,0.945,
IDE05475,Main cat converter OSC age correction factor bank 2,0.859,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
IDE05479,Misfire recognition reference moment,0.000, %
IDE05480-ENG104207,Evap. emiss. can. purge reg. valve short trip result-Bit 0,0,
IDE05480-ENG28465,Evap. emiss. can. purge reg. valve short trip result-Byte,00000000 ,
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG104207,Irregular shutdown of the counter control mod-Bit 0,0,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05487,Coolant temperature linearized value,32.959, °C
IDE05488,Coolant temperature modeled value,32.3, °C
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,255,
IDE05797,Throttle valve adapter: specified value,1.700, %
IDE05928,Fuel consumption since DTC memory last erased,14.471, l/100km
IDE06006,Idle speed specified value,800, /min
IDE06017,Camshaft position deviation from reference position,-0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,29.1, °C
IDE06023-ENG104207,BDE operating mode flag register-Bit 0,1,
IDE06023-ENG28465,BDE operating mode flag register-Byte,00000001 ,
IDE06039,Required RPM at idle speed,800.0, /min
IDE06040,High fuel pressure: regulator output value,3.5645, MPa
IDE06041-ENG104207,PDTC drive cycle conditions status-Bit 0,0,
IDE06043,Cylinder head temperature: actual value,32.7, °C
IDE06045-ENG104207,Output DTM status-Bit 0,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,161.52, hPa
IDE06053-ENG104207,Test of mixture adaptation bank 1: status-Bit 0,0,
IDE06053-ENG28465,Test of mixture adaptation bank 1: status-Byte,00000000 ,
IDE06054-ENG104207,Test of mixture adaptation bank 2: status-Bit 0,0,
IDE06054-ENG28465,Test of mixture adaptation bank 2: status-Byte,00000000 ,
IDE06098,Sensor control factor: output value,1.00000,
IDE06192,Knock sensor: cylinder 2: voltage,16.768, V
IDE06193,Knock sensor: cylinder 3: voltage,16.768, V
IDE06194,Knock sensor: cylinder 4: voltage,16.768, V
IDE06195,Knock sensor: cylinder 1: voltage,16.768, V
IDE06255,Vehicle lateral acceleration,-0.01, g
IDE06256,Vehicle lateral acceleration: raw value,-0.01, g
IDE06257,Vehicle inclination acceleration angle: raw value,-12.557, m/s²
IDE06386,Oil level: static measurement,17.400, mm
IDE06387,Oil level: last valid dynamic value,19.372, mm
IDE06388,Oil level: condition for static measurement fulfilled,1,
IDE06393,Oil level: dynamic average value,19.368, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.500, m/s²
IDE06446-ENG104207,Status: incline angle-Bit 0,1,
IDE06495,Results of testing of crankcase ventilation successful,0,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567-ENG104207,Start-stop function deactivation frequency counter-Bit 0,59,
IDE06567-ENG101796,Start-stop function deactivation frequency counter-Bit 8,0,
IDE06568-ENG104207,Stop prevention by driver frequency counter-Bit 0,70,
IDE06568-ENG101796,Stop prevention by driver frequency counter-Bit 8,1,
IDE06569-ENG104207,Vehicle stopped frequency counter-Bit 0,212,
IDE06569-ENG101796,Vehicle stopped frequency counter-Bit 8,3,
IDE06610-ENG104207,Vehicle standstill with stop frequency counter-Bit 0,41,
IDE06610-ENG101796,Vehicle standstill with stop frequency counter-Bit 8,1,
IDE06647-ENG104207,Start-stop switch status-Bit 0,1,
IDE06702-ENG104207,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0,0,
IDE06702-ENG102612,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16,128,
IDE06702-ENG101717,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24,130,
IDE06702-ENG101796,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8,0,
IDE06703-ENG104207,Drivetrain coordinator: ACC fault status-Bit 0,0,
IDE06703-ENG101796,Drivetrain coordinator: ACC fault status-Bit 8,0,
IDE06704-ENG104207,Drivetrain coordinator: brake fault status-Bit 0,0,
IDE06706-ENG104207,ACC variants-Bit 0,2,
IDE06708-ENG104207,Cruise control switch actuation-Bit 0,0,
IDE06708-ENG101796,Cruise control switch actuation-Bit 8,32,
IDE06709-ENG104207,ACC variants (coding)-Bit 0,3,
IDE06711-ENG104207,Cruise control system: temporary deactivation-Bit 0,255,
IDE06758,Air mass since engine start,0.00, kg
IDE06759,Cam shaft adaptation inlet: counter,5,
IDE06760,Camshaft adaptation: exhaust: counter,5,
IDE06761,Adaptation val cyl 5 with slow diagnosis,1.00000,
IDE06762,Adaptation val cyl 5 with fast diagnosis,1.00000,
IDE06763,Adaptation val cyl 6 with slow diagnosis,1.00000,
IDE06764,Adaptation val cyl 6 with fast diagnosis,1.00000,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG104207,Brake actuated status-Bit 0,0,
IDE06956-ENG104207,Driver-side belt buckle status-Bit 0,2,
IDE06957,Unfiltered clutch input rpm,0.0, /min
IDE07050-ENG104207,Starter control: release conditions-Bit 0,94,
IDE07050-ENG101796,Starter control: release conditions-Bit 8,70,
IDE07051-ENG104207,Engaged gear: raw signal-Bit 0,255,
IDE07164,Number injections,0,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG104207,Overrun cut-off-Bit 0,0,
IDE07233-ENG104207,Bit string for status of oil level-Bit 0,2,
IDE07233-ENG101796,Bit string for status of oil level-Bit 8,4,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,1,
IDE07238,Status of power transfer,0.00,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07475,Throttle valve position 2,6.79, %
IDE07573,Throttle valve adapter: actual value,6.93, %
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07840-ENG104207,Status plausibility accelerator pedal to brake pedal-Bit 0,0,
IDE07904-ENG104207,Brake test switch status-Bit 0,0,
IDE07905-ENG104207,Brake light switch status-Bit 0,0,
IDE07906-ENG104207,Upper clutch switch: status-Bit 0,0,
IDE08071-ENG104207,Remote start cancellation reason store 1-Bit 0,0,
IDE08071-ENG101796,Remote start cancellation reason store 1-Bit 8,64,
IDE08072-ENG104207,Remote start cancellation reason store 2-Bit 0,0,
IDE08072-ENG101796,Remote start cancellation reason store 2-Bit 8,64,
IDE08073-ENG104207,Remote start cancellation reason store 3-Bit 0,1,
IDE08073-ENG101796,Remote start cancellation reason store 3-Bit 8,0,
IDE08074-ENG104207,Remote start cancellation reason store 4-Bit 0,0,
IDE08074-ENG101796,Remote start cancellation reason store 4-Bit 8,0,
IDE08075-ENG104207,Remote start cancellation reason store 5-Bit 0,0,
IDE08075-ENG101796,Remote start cancellation reason store 5-Bit 8,0,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
IDE09693-ENG104207,Charisma driving program: system status-Bit 0,0,
IDE09695-ENG104207,Charisma driving program: target value from coordinator-Bit 0,2,
IDE09696-ENG104207,Charisma driving program: CAN output value-Bit 0,2,
IDE09925-ENG104207,Intake camshaft bank 1: adaption error cause-Bit 0,0,
IDE09926-ENG104207,Outlet camshaft bank 1: adaption error cause-Bit 0,0,
IDE10041-ENG104207,Intake camshaft bank1 active operating mode-Bit 0,0,
IDE10041-ENG101796,Intake camshaft bank1 active operating mode-Bit 8,0,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.03, s
IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.03, s
IDE10994-ENG104207,Poor start counter at start-stop-Bit 0,0,
IDE10994-ENG101796,Poor start counter at start-stop-Bit 8,0,
IDE11115-ENG104207,Start/stop driver request: counter restart by starter-Bit 0,6,
IDE11115-ENG101796,Start/stop driver request: counter restart by starter-Bit 8,0,
IDE11116-ENG104207,Start/stop driver request: counter internal-motor restart-Bit 0,5,
IDE11116-ENG101796,Start/stop driver request: counter internal-motor restart-Bit 8,0,
IDE11293,Fuel consumption difference: injectors/sensors,0.387, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,2.188, l
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.771, V
IDE12923,Lambda regulation: bank 1: output value,1.00000,
IDE12924,Lambda regulation: bank 2: output value,1.00000,
IDE12927,Lambda regulation: bank 2: filtered average output value,1.00000,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00000,
IDE12935,Ignition angle: bank 2 raw value,0.0, °
IDE12936,Ignition angle: bank 1 raw value,0.0, °
MAS15845,Fuel: tank fill level,39.0, l
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.00, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,14.46, kg
ENG101413,Calibration Identification,03H026J 4748FVA,
ENG99697,Calibration Verification Number,01 FF BD AE,
ENG126402-ENG104207,Cruise_control_shutoff_conditions_irreversible-Bit 0,0,
ENG126402-ENG101796,Cruise_control_shutoff_conditions_irreversible-Bit 8,0,
ENG111031-ENG104207,DFC_status_error_debounced_counter-Bit 0,0,
ENG111031-ENG101796,DFC_status_error_debounced_counter-Bit 8,0,
ENG111033-ENG104207,DFC_status_tested_counter-Bit 0,199,
ENG111033-ENG101796,DFC_status_tested_counter-Bit 8,2,
ENG111032-ENG104207,DFC_status_untested_counter-Bit 0,96,
ENG111032-ENG101796,DFC_status_untested_counter-Bit 8,1,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,-EngineControl,
ENG111034,Engine_temperature_modelbased_substitute_value,27.8, °C
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,0.0, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,14 00 3C 00 A1 00 38 00 3C 00 34 00 3C 00 3A 00 3C 00 37 00 3C 00 59 00 3C 00 00 00 00 00 10 00 09 00 38 00 3C 00 34 00 3C,
ENG107236,Knock_sensor_cylinder_5_voltage,16.768, V
ENG107237,Knock_sensor_cylinder_6_voltage,16.768, V
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG107964,Oxygen_sensor_bank_2_sensor_1_voltage,0.000, V
ENG109006,Spark_efficiency_deviation_at_idle_maximum,85.2, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,28.1, %
ENG121093-ENG104207,State_of_cruise_control_or_speedlimiter-Bit 0,0,
Elapsed Time: 00:41
Cold engine, engine at idle.
Sat overnight, OAT 70F, startup, map run started within ~15 seconds of startup.
;Friday,16,June,2017,06:21:49:21122
IDE00019,Voltage terminal 30,13.120, V
IDE00021,Engine speed,750.967, /min
IDE00025,Coolant temperature,35, °C
IDE00078,Time since engine start,31, s
IDE00083,Throttle valve position (absolute),12.9, %
IDE00084,Absolute load value,18.8, %
IDE00085,Normed load value,24.7, %
IDE00100,Engine torque,60.9, Nm
IDE00148,Median injection timing,1.124, ms
IDE00150,Pressure in brake booster,57.73, hPa
IDE00151,Oil fill level,48.200, mm
IDE00167,Exhaust temperature 1 bank 1,527.8, °C
IDE00168,Exhaust temperature 1 bank 2,519.1, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-14.891, °
IDE00178,Camshaft adjustment intake bank 1: specified value,18.000, °
IDE00179,Camshaft adjustment intake bank 1: actual value,17.594, °
IDE00186,Fuel low pressure: actual value,559.9, kPa
IDE00188,Fuel high pressure: actual value,4.4995, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,25.0, °C
IDE00201,High fuel pressure: specified value,4.4840, MPa
IDE00347,Air mass: actual value:,5.08, g/s
IDE00349,Throttle valve position: normed,2.7, %
IDE00350,Air mass: specified value,18.6, kg/h
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00357,Fuel temperature,32.3, °C
IDE00371,Fuel consumption,1.86, l/h
IDE00375,Generator: load signal,32.23, %
IDE00380,Coolant fan 1: activation,32.02, %
IDE00405,Crankshaft speed (RPM),751.0, /min
IDE00407-ENG104207,Rail pressure regulation: status-Bit 0,1,
IDE00407-ENG28465,Rail pressure regulation: status-Byte,00000001 ,
IDE00417-ENG104207,Starter control: shut-off conditions 1-Bit 0,1,
IDE00443-ENG104207,Accelerator pedal: switch positions-Bit 0,9,
IDE00477,Torque request: sum of auxiliary aggregate,16.2, Nm
IDE00497-ENG104207,Status of oil pressure switches-Bit 0,5,
IDE00559-MAS04135,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value,1.019, lambda
IDE00559-MAS04136,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current,128.004, mA
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.805, V
IDE00565-MAS04135,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Oxygen sensor value,1.002, lambda
IDE00565-MAS04136,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Current,127.980, mA
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.780, V
IDE00582,Equivalence ratio target value,0.998, lambda
IDE00583,Throttle valve specified value,3.5, %
IDE00592-MAS04113,Oxygen sensor control status-Oxygen sensor control 1 status,Closed control circuit,
IDE00592-MAS04114,Oxygen sensor control status-Oxygen sensor control 2 status,Closed control circuit,
IDE00593,Ignition timing adjustment cylinder 1,9.0, °
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00598,Long term adaptation of mixture formation bank 2,5.5, %
IDE00604,Short term adaptation of mixture formation bank 1,-3.1, %
IDE00605,Short term adaptation of mixture formation bank 2,-2.3, %
IDE01076,Time since ignition off,33033, s
IDE01260,Generator power,593.774, W
IDE01266-ENG104207,Coolant shut-off valve-Bit 0,3,
IDE01267,Height correction,0.97296,
IDE01378,High fuel pressure: control deviation,0.0220, MPa
IDE01405-ENG104207,Status of starter activation-Bit 0,2,
IDE01641-ENG104207,Result of oxygen sensor test bank 1 after catalytic converter-Bit 0,160,
IDE01641-ENG28465,Result of oxygen sensor test bank 1 after catalytic converter-Byte,10100000 ,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.797, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.772, V
IDE01649,Throttle valve position 1,3.83, %
IDE01650,Throttle valve position 2,12.5, %
IDE01678-ENG129413,Result of O2 sensor test ready bank 2 after cat. conv.-Test_Program_Channel 114,213,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01834,Battery voltage,13200, mV
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01875,Required torque adjustment by idling regulator,-0.937, %
IDE01876,Adaptation of loss torque,0.1, Nm
IDE01877-ENG104207,Operating condition of idle speed control-Bit 0,1,
IDE01877-ENG103108,Operating condition of idle speed control-Bitregister,00000001 ,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01884,Camshaft adjustment intake bank 1: activation,43.127, %
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01893,Fuel pump: specified value,51.427, %
IDE01899,Load value: corrected specified value,78.07, %
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.94983,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.95105,
IDE01911,Leakage air,-0.1, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG104207,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bit 0,170,
IDE01914-ENG103108,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bitregister,10101010 ,
IDE01916,Leakage recognition from oxygen sensor control,1.0623,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG104207,Leakage recognition: status-Bit 0,220,
IDE01919-ENG103108,Leakage recognition: status-Bitregister,11011100 ,
IDE01928,Close cam shaft angle at quantity control valve,45.0, °
IDE01929,Open cam shaft angle at quantity control valve,-21.6, °
IDE01932,High pressure pump injection volume,-10.24, mm³
IDE02115-ENG104207,Adjustment requirements for basic setting-Bit 0,158,
IDE02115-ENG103108,Adjustment requirements for basic setting-Bitregister,10011110 ,
IDE02116,Exhaust gas temperature before catalytic converter,359.31, °C
IDE02117,Relative load value,18.26, %
IDE02756-ENG104207,Number of manual engine starts-Bit 0,242,
IDE03583-ENG104207,Engine shut-down overrides-Bit 0,5,
IDE03585,System status for the start/stop function master,3,
IDE03587-MAS00124,Stop overrides for active participants-A/C,active,
IDE03589-ENG104207,Error status for start-stop related sensors-Bit 0,0,
IDE03660,Longitudinal acceleration,0.352, m/s²
IDE03693-ENG104207,Monitoring status of additional Onboard Diagnosis-Bit 0,161,
IDE03693-ENG103108,Monitoring status of additional Onboard Diagnosis-Bitregister,10100001 ,
IDE03696-ENG104207,Result test of oxygen sensor heater after catalytic converter-Bit 0,144,
IDE03696-ENG28465,Result test of oxygen sensor heater after catalytic converter-Byte,10010000 ,
IDE03699-ENG104207,Result of test of oxygen sensor before catalytic converter-Bit 0,228,
IDE03699-ENG28465,Result of test of oxygen sensor before catalytic converter-Byte,11100100 ,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03709,Angle difference actual-specified camshaft adjuster,0.234, °
IDE03711,Mass flow through throttle valve,19.0, kg/h
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,6.252, %
IDE03806-ENG104207,Oxygen sensor bank 1 sensor 1: status-Bit 0,3,
IDE03806-ENG28465,Oxygen sensor bank 1 sensor 1: status-Byte,00000011 ,
IDE03807-ENG104207,Oxygen sensor bank 1 sensor 2: status-Bit 0,14,
IDE03807-ENG28465,Oxygen sensor bank 1 sensor 2: status-Byte,00001110 ,
IDE03808-ENG104207,Oxygen sensor bank 2 sensor 1: status-Bit 0,3,
IDE03808-ENG28465,Oxygen sensor bank 2 sensor 1: status-Byte,00000011 ,
IDE03809-ENG104207,Oxygen sensor bank 2 sensor 2: status-Bit 0,14,
IDE03809-ENG28465,Oxygen sensor bank 2 sensor 2: status-Byte,00001110 ,
IDE03810,Oxygen sensor bank 2 sensor 1: specified value,1.0000,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,388.000, Ohm
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,216,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.19, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,35.986, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,366.000, Ohm
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,146.48, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,37.003, %
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,4380, kPa
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,42, °C
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,155.775650, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,148.811321, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,203.092119, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,202.614175, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,97.722507, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,91.116636, kJ
IDE04410,Intake manifold pressure: target value,332.73, hPa
IDE04414,Cat conv temp: modeled,240, °C
IDE04651,Torque request: A/C compressor,8.8, Nm
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04685,Setpoint generation interior torque,62.6, Nm
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04858,Brake booster low pressure actual value,935.98, hPa
IDE04887,Powertrain target torque,-1105.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,-46.3, Nm
IDE04937,Sensor for engine block temperature: raw value,33.1, °C
IDE05128,Intake air temperature in intake manifold bank 1,29.3, °C
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,33033, s
IDE05241-ENG104207,A/C compressor release status-Bit 0,1,
IDE05332-ENG104207,Heat request from heater to thermal management-Bit 0,2,
IDE05438,Rear cat conv temp main cat conv model value,252.81, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,243.95, °C
IDE05444,Air filling: specified value,18.59, %
IDE05447,Leak recog from oxygen sensor control bank 2,1.0027,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,20200, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,17400, Ohm
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,720.39, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,720.23, °C
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,10.0, kg/h
IDE05479,Misfire recognition reference moment,13.780, %
IDE05488,Coolant temperature modeled value,33.0, °C
IDE05797,Throttle valve adapter: specified value,3.976, %
IDE06006,Idle speed specified value,750, /min
IDE06020,Intake air temperature in intake manifold bank raw value,30.0, °C
IDE06039,Required RPM at idle speed,750.0, /min
IDE06040,High fuel pressure: regulator output value,-0.0825, MPa
IDE06041-ENG104207,PDTC drive cycle conditions status-Bit 0,36,
IDE06043,Cylinder head temperature: actual value,43.4, °C
IDE06049,Pressure in brake booster: raw value,45.63, hPa
IDE06098,Sensor control factor: output value,1.01590,
IDE06192,Knock sensor: cylinder 2: voltage,0.269, V
IDE06193,Knock sensor: cylinder 3: voltage,0.356, V
IDE06194,Knock sensor: cylinder 4: voltage,0.430, V
IDE06195,Knock sensor: cylinder 1: voltage,0.278, V
IDE06256,Vehicle lateral acceleration: raw value,0.00, g
IDE06386,Oil level: static measurement,17.332, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06495,Results of testing of crankcase ventilation successful,3,
IDE06702-ENG102612,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16,0,
IDE06758,Air mass since engine start,0.64, kg
IDE06956-ENG104207,Driver-side belt buckle status-Bit 0,3,
IDE06957,Unfiltered clutch input rpm,747.5, /min
IDE07050-ENG104207,Starter control: release conditions-Bit 0,12,
IDE07050-ENG101796,Starter control: release conditions-Bit 8,98,
IDE07164,Number injections,3123,
IDE07242,Heater support pump: spec. value,39.74, %
IDE07475,Throttle valve position 2,3.78, %
IDE07573,Throttle valve adapter: actual value,4.00, %
IDE10041-ENG104207,Intake camshaft bank1 active operating mode-Bit 0,1,
IDE10302,Time since engine start,70.6, s
IDE10303,Integrated air masse at first engine start,0.6578, kg
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,2.254, l
IDE12355,ESI: consumption equivalent of the engine control module,0.00000052,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.656, V
IDE12923,Lambda regulation: bank 1: output value,1.01843,
IDE12924,Lambda regulation: bank 2: output value,0.97406,
IDE12927,Lambda regulation: bank 2: filtered average output value,0.97379,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.01767,
IDE12935,Ignition angle: bank 2 raw value,7.5, °
IDE12936,Ignition angle: bank 1 raw value,8.3, °
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.61, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,14.76, kg
ENG111033-ENG104207,DFC_status_tested_counter-Bit 0,119,
ENG111033-ENG101796,DFC_status_tested_counter-Bit 8,3,
ENG111032-ENG104207,DFC_status_untested_counter-Bit 0,176,
ENG111032-ENG101796,DFC_status_untested_counter-Bit 8,0,
ENG111034,Engine_temperature_modelbased_substitute_value,33.8, °C
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,18.8, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,14 00 3C 00 A2 00 38 00 3C 00 34 00 3C 00 3A 00 3C 00 37 00 3C 00 59 00 3C 00 00 00 00 00 10 00 09 00 38 00 3C 00 34 00 3C,
ENG107236,Knock_sensor_cylinder_5_voltage,0.474, V
ENG107237,Knock_sensor_cylinder_6_voltage,0.366, V
Elapsed Time: 00:42
Engine +80*C, engine at idle
Hot idle, end of ~35 minute drive cycle started above. S/S was active for drive cycle but deactivated by push-button temporarily to capture end of drive state.
;SW:03H-906-026-J   HW:03H-907-309-K ---  Engine
;Component:VR6 3.6l FSI  H20 4748, Coding:012A003244740108B0000000000000000000000000000000
;EV_ECM36FSI01103H906026J,001003,EV_ECM36FSI01103H906026E.rod
;Friday,16,June,2017,07:04:18:21122
;VCDS Version: Beta 17.6.0 (x64)  Data version: 20170602 DS274
;VCID: 2C14C5D84759B5274F-8078
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),1V2NR2CA0JC50220,
IDE00019,Voltage terminal 30,12.880, V
IDE00020-ENG104207,Terminal 15 status-Bit 0,1,
IDE00021,Engine speed,694.469, /min
IDE00025,Coolant temperature,89, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,2580, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,15.3, %
IDE00085,Normed load value,22.4, %
IDE00086,Accelerator position,14.5, %
IDE00090-ENG104207,selected gear-Bit 0,0,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
IDE00100,Engine torque,48.5, Nm
IDE00148,Median injection timing,1.048, ms
IDE00150,Pressure in brake booster,78.24, hPa
IDE00151,Oil fill level,53.264, mm
IDE00152,Oil warning threshold,33.420, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00159,Timing angle retardation cylinder 5,0.0, °
IDE00160,Timing angle retardation cylinder 6,0.0, °
IDE00167,Exhaust temperature 1 bank 1,518.6, °C
IDE00168,Exhaust temperature 1 bank 2,505.1, °C
IDE00173,Cruise Control System: specified speed,0,
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-15.000, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-14.984, °
IDE00179,Camshaft adjustment intake bank 1: actual value,17.945, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,5.14, °
IDE00186,Fuel low pressure: actual value,493.4, kPa
IDE00187,Coolant temperature at engine start,87.8, °C
IDE00188,Fuel high pressure: actual value,2.5940, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,44.6, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,94.2, °C
IDE00201,High fuel pressure: specified value,2.5935, MPa
IDE00202,Low fuel pressure: specified value,490.0, kPa
IDE00304,Fuel level,34.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,3.44, g/s
IDE00348,Intake air temperature,31, °C
IDE00349,Throttle valve position: normed,2.0, %
IDE00350,Air mass: specified value,13.1, kg/h
IDE00355-ENG104207,Cruise Control System (CCS): status-Bit 0,0,
IDE00357,Fuel temperature,78.8, °C
IDE00358,Limitation: torque,469.8, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,986.21, hPa
IDE00371,Fuel consumption,1.31, l/h
IDE00375,Generator: load signal,35.46, %
IDE00392,Accelerator pedal: sensor voltage 1,737.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,364.8, mV
IDE00405,Crankshaft speed (RPM),705.0, /min
IDE00412-ENG104207,Starter control: terminal 50-Bit 0,0,
IDE00413-ENG104207,Starter control: Interlock- or P/N-signal-Bit 0,17,
IDE00414-ENG104207,Starter control: relay 1-Bit 0,0,
IDE00416-ENG104207,Starter control: terminal 50 acknowledgment-Bit 0,0,
IDE00417-ENG101796,Starter control: shut-off conditions 1-Bit 8,0,
IDE00445,Unlearning counter according OBD,255,
IDE00450-ENG124478,Operating Instructions-Test_Program_Requested Action,0,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,98, kPa
IDE00477,Torque request: sum of auxiliary aggregate,12.1, Nm
IDE00496-ENG104207,Activation of oil pressure switch valve-Bit 0,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,21, °C
IDE00559-MAS04135,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value,1.008, lambda
IDE00559-MAS04136,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current,127.988, mA
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.695, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00565-MAS04135,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Oxygen sensor value,0.991, lambda
IDE00565-MAS04136,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Current,127.961, mA
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.730, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, lambda
IDE00583,Throttle valve specified value,2.7, %
IDE00584,Distance driven since erasing DTC memory,1202, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,48.2, %
IDE00593,Ignition timing adjustment cylinder 1,13.5, °
IDE00595-MAS01839,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 1,installed,
IDE00595-MAS01840,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 2,installed,
IDE00595-MAS04115,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 3,not installed,
IDE00595-MAS04116,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 4,not installed,
IDE00595-MAS04117,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 1,installed,
IDE00595-MAS04118,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 2,installed,
IDE00595-MAS04119,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 3,not installed,
IDE00595-MAS04120,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 4,not installed,
IDE00597,Long term adaptation of mixture formation bank 1,-8.6, %
IDE00598,Long term adaptation of mixture formation bank 2,0.8, %
IDE00601-MAS00317,Monitoring status since erasing DTC memory-Malfunction Indicator Lamp,OFF,
IDE00601-MAS00328,Monitoring status since erasing DTC memory-Monitoring of ignition misfires,activated,
IDE00601-MAS00329,Monitoring status since erasing DTC memory-Monitoring of fuel system,activated,
IDE00601-MAS00330,Monitoring status since erasing DTC memory-Monitoring of entire system,activated,
IDE00601-MAS00331,Monitoring status since erasing DTC memory-Ignition misfire test,Unknown,
IDE00601-MAS00332,Monitoring status since erasing DTC memory-Fuel system test,Unknown,
IDE00601-MAS00333,Monitoring status since erasing DTC memory-Entire system test,completed successfully,
IDE00601-MAS00503,Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries,0,
IDE00601-MAS04092,Monitoring status since erasing DTC memory-Monitoring of compression ignition,Not supported,
IDE00601-ENG20482,Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared,00,
IDE00602-MAS04092,Monitoring status in current driving cycle-Monitoring of compression ignition,Not supported,
IDE00602-ENG20399,Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle,No,
IDE00602-ENG20507,Monitoring status in current driving cycle-Comprehensive component monitoring completed,completed successfully,
IDE00602-ENG20447,Monitoring status in current driving cycle-Comprehensive component monitoring enabled,activated,
IDE00602-ENG20496,Monitoring status in current driving cycle-Fuel system monitoring completed,completed successfully,
IDE00602-ENG20425,Monitoring status in current driving cycle-Fuel system monitoring enabled,not activated,
IDE00602-ENG20449,Monitoring status in current driving cycle-Misfire monitoring completed,completed successfully,
IDE00602-ENG20506,Monitoring status in current driving cycle-Misfire monitoring enabled,activated,
IDE00603,Number of driving cycles since erasing DTC memory,37,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00605,Short term adaptation of mixture formation bank 2,0.0, %
IDE00608,Type of fuel,Petrol,
IDE00612,Target position of EVAP canister valve,19.2, %
IDE00699,ESI: minimum oil level in service interval,17.924, mm
IDE00700,ESI: maximum oil level in service interval,20.128, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00000,
IDE00739,Test of oxygen sensors bank 2: Delta-Lambda,0.00000,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,21.0, °C
IDE01076,Time since ignition off,0, s
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,228,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01236-ENG104207,Coolant recirculation pump-Bit 0,0,
IDE01260,Generator power,292.181, W
IDE01266-ENG104207,Coolant shut-off valve-Bit 0,2,
IDE01267,Height correction,0.97351,
IDE01378,High fuel pressure: control deviation,-0.0005, MPa
IDE01385-ENG104207,Wear index-Bit 0,0,
IDE01385-ENG101796,Wear index-Bit 8,0,
IDE01386-ENG104207,Soot index-Bit 0,0,
IDE01386-ENG101796,Soot index-Bit 8,0,
IDE01405-ENG104207,Status of starter activation-Bit 0,0,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,237,
IDE01639,Dynamic factor O2 sensors bank 2 or bank 4 before cat. conv.,1.0000,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.689, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.724, V
IDE01647-ENG129417,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 379,213,
IDE01649,Throttle valve position 1,2.78, %
IDE01650,Throttle valve position 2,11.8, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,27.0, %
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,228,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,228,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,223,
IDE01773,Misfire sum counter,0,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,12880, mV
IDE01869,Long-term fuel trim bank 1 at idle,-1.03, %
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,209,
IDE01873,Test of catalytic converter: measured value,9.0686,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,219,
IDE01875,Required torque adjustment by idling regulator,-0.043, %
IDE01876,Adaptation of loss torque,-1.4, Nm
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,56.354, %
IDE01887,Adaptation of Fuel Pump (FP),-28.6, kPa
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,47.252, %
IDE01899,Load value: corrected specified value,70.52, %
IDE01901,Lost torque adaptation: idle,-3.7, Nm
IDE01902,Lost torque adaptation A/C compressor,-1.3, Nm
IDE01903,Lost torque adaptation driving mode,-2.8, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,2.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.98108,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.95178,
IDE01911,Leakage air,-1.0, kg/h
IDE01916,Leakage recognition from oxygen sensor control,0.9490,
IDE01919-ENG104207,Leakage recognition: status-Bit 0,4,
IDE01919-ENG103108,Leakage recognition: status-Bitregister,00000100 ,
IDE01920,Oxygen sensor: mixture correction with active diagnosis,-0.0000,
IDE01922,Vehicle distance driven,1367, km
IDE01923,Control module distance driven,1365950, m
IDE01928,Close cam shaft angle at quantity control valve,38.7, °
IDE01929,Open cam shaft angle at quantity control valve,-16.6, °
IDE01930,High pressure regulation: adaptation value,0.0000, MPa
IDE01932,High pressure pump injection volume,0.56, mm³
IDE01975,Numb.of misfir.: cylinder 1,355,
IDE01976,Numb.of misfir.: cylinder 2,331,
IDE01977,Numb.of misfir.: cylinder 3,162,
IDE01978,Numb.of misfir.: cylinder 4,171,
IDE02115-ENG104207,Adjustment requirements for basic setting-Bit 0,223,
IDE02115-ENG103108,Adjustment requirements for basic setting-Bitregister,11011111 ,
IDE02116,Exhaust gas temperature before catalytic converter,424.21, °C
IDE02117,Relative load value,14.04, %
IDE02118,Oxygen sensor bank 1 sensor 1: voltage,0.000, V
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,-0.03, MPa
IDE02540-ENG104207,Longitudinal acceleration sensor: status-Bit 0,0,
IDE02756-ENG102612,Number of manual engine starts-Bit 16,0,
IDE02756-ENG101717,Number of manual engine starts-Bit 24,0,
IDE02756-ENG101796,Number of manual engine starts-Bit 8,0,
IDE02757-ENG104207,Number of automatic engine starts-Bit 0,247,
IDE02757-ENG102612,Number of automatic engine starts-Bit 16,0,
IDE02757-ENG101717,Number of automatic engine starts-Bit 24,0,
IDE02757-ENG101796,Number of automatic engine starts-Bit 8,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,237,
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,7, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,7, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,26,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,6,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,13,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,20,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,-1560281088, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,2130837504, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,45,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,9,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,5,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,6,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,2017,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,2017,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG103639,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99665,Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG100535,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG99682,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG101771,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG104020,Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03190-ENG103316,Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature,0,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.497, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.768, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.235, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,162,
IDE03364,Numb.of misfir.: cylinder 6,190,
IDE03393-ENG104207,Selector lever position-Bit 0,8,
IDE03583-ENG104207,Engine shut-down overrides-Bit 0,4,
IDE03584-ENG104207,Engine starting requirements-Bit 0,0,
IDE03585,System status for the start/stop function master,1,
IDE03586-ENG104207,Starting requirements for active participants-Bit 0,0,
IDE03586-ENG101796,Starting requirements for active participants-Bit 8,0,
IDE03587-MAS00075,Stop overrides for active participants-Brake control module,not active,
IDE03587-MAS00077,Stop overrides for active participants-Immobilizer,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00798,Stop overrides for active participants-Transmission Control Module (TCM),not active,
IDE03587-MAS00829,Stop overrides for active participants-Access and start authorization,not active,
IDE03588-MAS00075,System malfunctions for active participants start/stop-Brake control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00798,System malfunctions for active participants start/stop-Transmission Control Module (TCM),not active,
IDE03588-MAS00829,System malfunctions for active participants start/stop-Access and start authorization,not active,
IDE03589-ENG104207,Error status for start-stop related sensors-Bit 0,8,
IDE03660,Longitudinal acceleration,0.236, m/s²
IDE03692-ENG104207,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,0,
IDE03692-ENG103108,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bitregister,00000000 ,
IDE03693-ENG104207,Monitoring status of additional Onboard Diagnosis-Bit 0,0,
IDE03693-ENG103108,Monitoring status of additional Onboard Diagnosis-Bitregister,00000000 ,
IDE03694-ENG104207,Result of test of fuel supply system partial throttle-Bit 0,198,
IDE03694-ENG28465,Result of test of fuel supply system partial throttle-Byte,11000110 ,
IDE03696-ENG104207,Result test of oxygen sensor heater after catalytic converter-Bit 0,212,
IDE03696-ENG28465,Result test of oxygen sensor heater after catalytic converter-Byte,11010100 ,
IDE03697-ENG104207,Result test of oxygen sensor heater before catalytic converter-Bit 0,4,
IDE03697-ENG28465,Result test of oxygen sensor heater before catalytic converter-Byte,00000100 ,
IDE03698-ENG104207,Result of dynamic test of oxygen sensor before cat. converter-Bit 0,4,
IDE03698-ENG28465,Result of dynamic test of oxygen sensor before cat. converter-Byte,00000100 ,
IDE03703-ENG104207,Result catalytic converter diagnosis test-Bit 0,4,
IDE03703-ENG28465,Result catalytic converter diagnosis test-Byte,00000100 ,
IDE03707-ENG104207,Result of NPulse test-Bit 0,170,
IDE03707-ENG28465,Result of NPulse test-Byte,10101010 ,
IDE03708-ENG104207,Result of test 2 of oxygen sensor before catalytic converter-Bit 0,4,
IDE03708-ENG28465,Result of test 2 of oxygen sensor before catalytic converter-Byte,00000100 ,
IDE03709,Angle difference actual-specified camshaft adjuster,-0.164, °
IDE03710-ENG104207,Result of camshaft diagnostic test-Bit 0,4,
IDE03710-ENG28465,Result of camshaft diagnostic test-Byte,00000100 ,
IDE03711,Mass flow through throttle valve,12.7, kg/h
IDE03794,Long-term fuel trim bank 2 at idle,-0.28, %
IDE03807-ENG104207,Oxygen sensor bank 1 sensor 2: status-Bit 0,10,
IDE03807-ENG28465,Oxygen sensor bank 1 sensor 2: status-Byte,00001010 ,
IDE03809-ENG104207,Oxygen sensor bank 2 sensor 2: status-Bit 0,10,
IDE03809-ENG28465,Oxygen sensor bank 2 sensor 2: status-Byte,00001010 ,
IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,239,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,210.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.38, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,28.583, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,202.000, Ohm
IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03823-ENG129414,Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125,0,
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,147.19, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,31.320, %
IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,221,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,2,
IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,209,
IDE03837-ENG129416,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 2115,213,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99194,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03968-ENG104207,Camshaft adaptation results-Bit 0,4,
IDE03968-ENG28465,Camshaft adaptation results-Byte,00000100 ,
IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,Not available,
IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,0, kPa
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,2440, kPa
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,Available,
IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,0, °C
IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,Not available,
IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,0, kPa
IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,Not available,
IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,0, kPa
IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,Not available,
IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,0, °C
IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,Not available,
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,installed,
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,94, °C
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,installed,
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,89, °C
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,9158.007091, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,8400.431495, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,13188.885524, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,12984.444919, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,11804.230151, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,10521.411019, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04241,Counter start bef dew pt end f O2 sensor bef cat conv bank2,0,
IDE04242,Counter start bef dew pt end f O2 sensor beh fr cat conv bank1,0,
IDE04243,Counter start bef dew pt end f O2 sensor beh fr cat conv bank2,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04245,Count start bef dew pt end f O2 sensor beh main cat conv bank2,0,
IDE04302-ENG104207,Bypass valve for high press turbocharger turbine inlet: status-Bit 0,0,
IDE04302-ENG102612,Bypass valve for high press turbocharger turbine inlet: status-Bit 16,0,
IDE04302-ENG101717,Bypass valve for high press turbocharger turbine inlet: status-Bit 24,0,
IDE04302-ENG101796,Bypass valve for high press turbocharger turbine inlet: status-Bit 8,0,
IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
IDE04410,Intake manifold pressure: target value,299.53, hPa
IDE04414,Cat conv temp: modeled,500, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,9.0, Nm
IDE04654-ENG104207,CAN status - engine control module-Bit 0,0,
IDE04655-ENG104207,CAN status - transmission control module-Bit 0,0,
IDE04656-ENG104207,CAN status - brake control module 1-Bit 0,0,
IDE04657-ENG104207,CAN status - brake control module 2-Bit 0,0,
IDE04685,Setpoint generation interior torque,48.6, Nm
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.1, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,907.97, hPa
IDE04887,Powertrain target torque,-816.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,-33.0, Nm
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE04937,Sensor for engine block temperature: raw value,94.3, °C
IDE05128,Intake air temperature in intake manifold bank 1,32.3, °C
IDE05138,Shut-off timer: last engine shut-off time,0, s
IDE05140,Intake manifold pressure raw value,0.00, hPa
IDE05228,Operating hour counter,1782, min
IDE05240-ENG104207,Request for A/C compressor power reduction-Bit 0,0,
IDE05261-ENG104207,Gear position sensor: last valid value-Bit 0,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG104207,Heat request from heater to thermal management-Bit 0,3,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,20.3, °C
IDE05438,Rear cat conv temp main cat conv model value,502.14, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,478.14, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0531, rad
IDE05444,Air filling: specified value,14.44, %
IDE05445,Pressure before throttle valve of pressure sensor,986.02, hPa
IDE05447,Leak recog from oxygen sensor control bank 2,0.9509,
IDE05448,Long term adaptation of mixture form bank 2 at partial load,1.02902,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,4432, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,5352, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00583,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00177,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,720.06, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,719.66, °C
IDE05470,Cat converter oxygen storage capacity,434.0, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,0.0000,
IDE05473,Cat converter oxygen storage capacity ref standardized bank 2,0.0000,
IDE05474,Main cat converter OSC age correction factor,0.930,
IDE05475,Main cat converter OSC age correction factor bank 2,0.859,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,7.2, kg/h
IDE05479,Misfire recognition reference moment,10.080, %
IDE05480-ENG104207,Evap. emiss. can. purge reg. valve short trip result-Bit 0,128,
IDE05480-ENG28465,Evap. emiss. can. purge reg. valve short trip result-Byte,10000000 ,
IDE05482,Tank venting adaptation factor,0.734,
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG104207,Irregular shutdown of the counter control mod-Bit 0,0,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05487,Coolant temperature linearized value,94.157, °C
IDE05488,Coolant temperature modeled value,52.5, °C
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.98401,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.99429,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.98126,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.02164,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.99487,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00516,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.99460,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.03253,
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,255,
IDE05797,Throttle valve adapter: specified value,2.829, %
IDE05928,Fuel consumption since DTC memory last erased,14.447, l/100km
IDE06006,Idle speed specified value,700, /min
IDE06017,Camshaft position deviation from reference position,-0.07, °
IDE06020,Intake air temperature in intake manifold bank raw value,32.8, °C
IDE06023-ENG104207,BDE operating mode flag register-Bit 0,1,
IDE06023-ENG28465,BDE operating mode flag register-Byte,00000001 ,
IDE06039,Required RPM at idle speed,700.0, /min
IDE06040,High fuel pressure: regulator output value,0.0050, MPa
IDE06041-ENG104207,PDTC drive cycle conditions status-Bit 0,167,
IDE06043,Cylinder head temperature: actual value,89.2, °C
IDE06045-ENG104207,Output DTM status-Bit 0,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,78.20, hPa
IDE06053-ENG104207,Test of mixture adaptation bank 1: status-Bit 0,140,
IDE06053-ENG28465,Test of mixture adaptation bank 1: status-Byte,10001100 ,
IDE06054-ENG104207,Test of mixture adaptation bank 2: status-Bit 0,140,
IDE06054-ENG28465,Test of mixture adaptation bank 2: status-Byte,10001100 ,
IDE06098,Sensor control factor: output value,1.00308,
IDE06192,Knock sensor: cylinder 2: voltage,0.508, V
IDE06193,Knock sensor: cylinder 3: voltage,0.664, V
IDE06194,Knock sensor: cylinder 4: voltage,0.601, V
IDE06195,Knock sensor: cylinder 1: voltage,0.576, V
IDE06255,Vehicle lateral acceleration,-0.01, g
IDE06256,Vehicle lateral acceleration: raw value,-0.01, g
IDE06257,Vehicle inclination acceleration angle: raw value,-12.557, m/s²
IDE06386,Oil level: static measurement,14.460, mm
IDE06387,Oil level: last valid dynamic value,19.372, mm
IDE06393,Oil level: dynamic average value,19.460, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.531, m/s²
IDE06446-ENG104207,Status: incline angle-Bit 0,1,
IDE06495,Results of testing of crankcase ventilation successful,11,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567-ENG104207,Start-stop function deactivation frequency counter-Bit 0,59,
IDE06567-ENG101796,Start-stop function deactivation frequency counter-Bit 8,0,
IDE06568-ENG104207,Stop prevention by driver frequency counter-Bit 0,72,
IDE06568-ENG101796,Stop prevention by driver frequency counter-Bit 8,1,
IDE06569-ENG104207,Vehicle stopped frequency counter-Bit 0,222,
IDE06569-ENG101796,Vehicle stopped frequency counter-Bit 8,3,
IDE06610-ENG104207,Vehicle standstill with stop frequency counter-Bit 0,48,
IDE06610-ENG101796,Vehicle standstill with stop frequency counter-Bit 8,1,
IDE06647-ENG104207,Start-stop switch status-Bit 0,0,
IDE06702-ENG104207,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0,0,
IDE06702-ENG101717,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24,128,
IDE06702-ENG101796,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8,0,
IDE06703-ENG104207,Drivetrain coordinator: ACC fault status-Bit 0,0,
IDE06703-ENG101796,Drivetrain coordinator: ACC fault status-Bit 8,0,
IDE06704-ENG104207,Drivetrain coordinator: brake fault status-Bit 0,0,
IDE06706-ENG104207,ACC variants-Bit 0,2,
IDE06708-ENG104207,Cruise control switch actuation-Bit 0,0,
IDE06708-ENG101796,Cruise control switch actuation-Bit 8,32,
IDE06709-ENG104207,ACC variants (coding)-Bit 0,3,
IDE06711-ENG104207,Cruise control system: temporary deactivation-Bit 0,255,
IDE06758,Air mass since engine start,8.01, kg
IDE06759,Cam shaft adaptation inlet: counter,0,
IDE06760,Camshaft adaptation: exhaust: counter,1,
IDE06761,Adaptation val cyl 5 with slow diagnosis,0.99210,
IDE06762,Adaptation val cyl 5 with fast diagnosis,1.00543,
IDE06763,Adaptation val cyl 6 with slow diagnosis,1.02673,
IDE06764,Adaptation val cyl 6 with fast diagnosis,1.04010,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG104207,Brake actuated status-Bit 0,0,
IDE06957,Unfiltered clutch input rpm,700.0, /min
IDE07050-ENG104207,Starter control: release conditions-Bit 0,28,
IDE07050-ENG101796,Starter control: release conditions-Bit 8,66,
IDE07051-ENG104207,Engaged gear: raw signal-Bit 0,255,
IDE07164,Number injections,29680,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG104207,Overrun cut-off-Bit 0,0,
IDE07233-ENG104207,Bit string for status of oil level-Bit 0,2,
IDE07233-ENG101796,Bit string for status of oil level-Bit 8,4,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,1,
IDE07238,Status of power transfer,0.00,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07475,Throttle valve position 2,2.56, %
IDE07573,Throttle valve adapter: actual value,2.73, %
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07840-ENG104207,Status plausibility accelerator pedal to brake pedal-Bit 0,0,
IDE07904-ENG104207,Brake test switch status-Bit 0,0,
IDE07905-ENG104207,Brake light switch status-Bit 0,0,
IDE07906-ENG104207,Upper clutch switch: status-Bit 0,0,
IDE08071-ENG104207,Remote start cancellation reason store 1-Bit 0,0,
IDE08071-ENG101796,Remote start cancellation reason store 1-Bit 8,64,
IDE08072-ENG104207,Remote start cancellation reason store 2-Bit 0,0,
IDE08072-ENG101796,Remote start cancellation reason store 2-Bit 8,64,
IDE08073-ENG104207,Remote start cancellation reason store 3-Bit 0,1,
IDE08073-ENG101796,Remote start cancellation reason store 3-Bit 8,0,
IDE08074-ENG104207,Remote start cancellation reason store 4-Bit 0,0,
IDE08074-ENG101796,Remote start cancellation reason store 4-Bit 8,0,
IDE08075-ENG104207,Remote start cancellation reason store 5-Bit 0,0,
IDE08075-ENG101796,Remote start cancellation reason store 5-Bit 8,0,
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.09, s
IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.33, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.12, s
IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.07, s
IDE09693-ENG104207,Charisma driving program: system status-Bit 0,0,
IDE09695-ENG104207,Charisma driving program: target value from coordinator-Bit 0,5,
IDE09696-ENG104207,Charisma driving program: CAN output value-Bit 0,5,
IDE09925-ENG104207,Intake camshaft bank 1: adaption error cause-Bit 0,0,
IDE09926-ENG104207,Outlet camshaft bank 1: adaption error cause-Bit 0,0,
IDE10041-ENG101796,Intake camshaft bank1 active operating mode-Bit 8,0,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,2618.6, s
IDE10303,Integrated air masse at first engine start,23.3014, kg
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.07, s
IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.04, s
IDE10994-ENG104207,Poor start counter at start-stop-Bit 0,0,
IDE10994-ENG101796,Poor start counter at start-stop-Bit 8,0,
IDE11115-ENG104207,Start/stop driver request: counter restart by starter-Bit 0,6,
IDE11115-ENG101796,Start/stop driver request: counter restart by starter-Bit 8,0,
IDE11116-ENG104207,Start/stop driver request: counter internal-motor restart-Bit 0,6,
IDE11116-ENG101796,Start/stop driver request: counter internal-motor restart-Bit 8,0,
IDE11293,Fuel consumption difference: injectors/sensors,-1.082, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,5.656, l
IDE12355,ESI: consumption equivalent of the engine control module,0.00000020,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.609, V
IDE12923,Lambda regulation: bank 1: output value,1.00452,
IDE12924,Lambda regulation: bank 2: output value,0.98099,
IDE12927,Lambda regulation: bank 2: filtered average output value,0.98261,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00290,
IDE12935,Ignition angle: bank 2 raw value,17.3, °
IDE12936,Ignition angle: bank 1 raw value,18.0, °
MAS15845,Fuel: tank fill level,34.0, l
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,15.68, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,15.11, kg
ENG101413,Calibration Identification,03H026J 4748FVA,
ENG99697,Calibration Verification Number,01 FF BD AE,
ENG126402-ENG104207,Cruise_control_shutoff_conditions_irreversible-Bit 0,0,
ENG126402-ENG101796,Cruise_control_shutoff_conditions_irreversible-Bit 8,0,
ENG111031-ENG104207,DFC_status_error_debounced_counter-Bit 0,0,
ENG111031-ENG101796,DFC_status_error_debounced_counter-Bit 8,0,
ENG111033-ENG104207,DFC_status_tested_counter-Bit 0,235,
ENG111032-ENG104207,DFC_status_untested_counter-Bit 0,60,
ENG111034,Engine_temperature_modelbased_substitute_value,95.3, °C
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,13.8, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,14 00 3D 00 A2 00 39 00 3D 00 35 00 3D 00 3B 00 3D 00 38 00 3D 00 5A 00 3D 00 00 00 00 00 10 00 09 00 39 00 3D 00 35 00 3D,
ENG107236,Knock_sensor_cylinder_5_voltage,0.732, V
ENG107237,Knock_sensor_cylinder_6_voltage,0.542, V
Elapsed Time: 00:41
Engine +80*C, engine off.
Ignition off and on after drive cycle above.
;Friday,16,June,2017,07:05:58:21122
IDE00019,Voltage terminal 30,12.280, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,91, °C
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),15.3, %
IDE00084,Absolute load value,0.0, %
IDE00085,Normed load value,0.0, %
IDE00100,Engine torque,0.0, Nm
IDE00148,Median injection timing,0.000, ms
IDE00150,Pressure in brake booster,74.30, hPa
IDE00151,Oil fill level,64.040, mm
IDE00152,Oil warning threshold,32.428, mm
IDE00167,Exhaust temperature 1 bank 1,499.2, °C
IDE00168,Exhaust temperature 1 bank 2,480.5, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-15.000, °
IDE00178,Camshaft adjustment intake bank 1: specified value,25.000, °
IDE00179,Camshaft adjustment intake bank 1: actual value,25.000, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.00, °
IDE00186,Fuel low pressure: actual value,565.6, kPa
IDE00187,Coolant temperature at engine start,89.3, °C
IDE00188,Fuel high pressure: actual value,3.4570, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,44.1, °C
IDE00196,Engine oil temperature,84.3, °C
IDE00201,High fuel pressure: specified value,5.0000, MPa
IDE00202,Low fuel pressure: specified value,550.0, kPa
IDE00347,Air mass: actual value:,0.24, g/s
IDE00348,Intake air temperature,33, °C
IDE00349,Throttle valve position: normed,5.1, %
IDE00350,Air mass: specified value,10.3, kg/h
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00357,Fuel temperature,88.5, °C
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.02, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00393,Accelerator pedal: sensor voltage 2,366.2, mV
IDE00405,Crankshaft speed (RPM),0.0, /min
IDE00407-ENG104207,Rail pressure regulation: status-Bit 0,0,
IDE00407-ENG28465,Rail pressure regulation: status-Byte,00000000 ,
IDE00417-ENG104207,Starter control: shut-off conditions 1-Bit 0,0,
IDE00443-ENG104207,Accelerator pedal: switch positions-Bit 0,8,
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00497-ENG104207,Status of oil pressure switches-Bit 0,0,
IDE00559-MAS04135,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value,1.012, lambda
IDE00559-MAS04136,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current,127.996, mA
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.675, V
IDE00565-MAS04135,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Oxygen sensor value,1.012, lambda
IDE00565-MAS04136,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Current,127.996, mA
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.815, V
IDE00582,Equivalence ratio target value,2.000, lambda
IDE00583,Throttle valve specified value,1.6, %
IDE00592-MAS04113,Oxygen sensor control status-Oxygen sensor control 1 status,Not available,
IDE00592-MAS04114,Oxygen sensor control status-Oxygen sensor control 2 status,Not available,
IDE00593,Ignition timing adjustment cylinder 1,0.0, °
IDE00597,Long term adaptation of mixture formation bank 1,-3.1, %
IDE00598,Long term adaptation of mixture formation bank 2,1.6, %
IDE00612,Target position of EVAP canister valve,0.0, %
IDE01076,Time since ignition off,49, s
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01260,Generator power,0.0123888, W
IDE01378,High fuel pressure: control deviation,1.3970, MPa
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01641-ENG104207,Result of oxygen sensor test bank 1 after catalytic converter-Bit 0,0,
IDE01641-ENG28465,Result of oxygen sensor test bank 1 after catalytic converter-Byte,00000000 ,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.670, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.802, V
IDE01647-ENG129417,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 379,235,
IDE01649,Throttle valve position 1,6.93, %
IDE01650,Throttle valve position 2,15.3, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,0.0, %
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01667-ENG127371,Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619,235,
IDE01678-ENG129413,Result of O2 sensor test ready bank 2 after cat. conv.-Test_Program_Channel 114,235,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
IDE01834,Battery voltage,12260, mV
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,0.000, %
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01877-ENG104207,Operating condition of idle speed control-Bit 0,0,
IDE01877-ENG103108,Operating condition of idle speed control-Bitregister,00000000 ,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000000 ,
IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01887,Adaptation of Fuel Pump (FP),-28.8, kPa
IDE01893,Fuel pump: specified value,4.001, %
IDE01899,Load value: corrected specified value,69.63, %
IDE01902,Lost torque adaptation A/C compressor,-1.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
IDE01911,Leakage air,-1.1, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG104207,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bit 0,2,
IDE01914-ENG103108,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bitregister,00000010 ,
IDE01916,Leakage recognition from oxygen sensor control,0.9607,
IDE01917,Leakage after throttle valve,0.000,
IDE01918,Leakage before throttle valve,0.000,
IDE01919-ENG104207,Leakage recognition: status-Bit 0,212,
IDE01919-ENG103108,Leakage recognition: status-Bitregister,11010100 ,
IDE01928,Close cam shaft angle at quantity control valve,63.4, °
IDE01929,Open cam shaft angle at quantity control valve,-51.5, °
IDE01932,High pressure pump injection volume,126.91, mm³
IDE02115-ENG104207,Adjustment requirements for basic setting-Bit 0,243,
IDE02115-ENG103108,Adjustment requirements for basic setting-Bitregister,11110011 ,
IDE02116,Exhaust gas temperature before catalytic converter,371.76, °C
IDE02117,Relative load value,57.68, %
IDE02756-ENG104207,Number of manual engine starts-Bit 0,242,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03583-ENG104207,Engine shut-down overrides-Bit 0,16,
IDE03585,System status for the start/stop function master,2,
IDE03589-ENG104207,Error status for start-stop related sensors-Bit 0,0,
IDE03660,Longitudinal acceleration,0.146, m/s²
IDE03692-ENG104207,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,202,
IDE03692-ENG103108,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bitregister,11001010 ,
IDE03693-ENG104207,Monitoring status of additional Onboard Diagnosis-Bit 0,229,
IDE03693-ENG103108,Monitoring status of additional Onboard Diagnosis-Bitregister,11100101 ,
IDE03694-ENG104207,Result of test of fuel supply system partial throttle-Bit 0,0,
IDE03694-ENG28465,Result of test of fuel supply system partial throttle-Byte,00000000 ,
IDE03696-ENG104207,Result test of oxygen sensor heater after catalytic converter-Bit 0,0,
IDE03696-ENG28465,Result test of oxygen sensor heater after catalytic converter-Byte,00000000 ,
IDE03698-ENG104207,Result of dynamic test of oxygen sensor before cat. converter-Bit 0,0,
IDE03698-ENG28465,Result of dynamic test of oxygen sensor before cat. converter-Byte,00000000 ,
IDE03699-ENG104207,Result of test of oxygen sensor before catalytic converter-Bit 0,132,
IDE03699-ENG28465,Result of test of oxygen sensor before catalytic converter-Byte,10000100 ,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,1,
IDE03703-ENG104207,Result catalytic converter diagnosis test-Bit 0,0,
IDE03703-ENG28465,Result catalytic converter diagnosis test-Byte,00000000 ,
IDE03708-ENG104207,Result of test 2 of oxygen sensor before catalytic converter-Bit 0,0,
IDE03708-ENG28465,Result of test 2 of oxygen sensor before catalytic converter-Byte,00000000 ,
IDE03709,Angle difference actual-specified camshaft adjuster,0.000, °
IDE03710-ENG104207,Result of camshaft diagnostic test-Bit 0,0,
IDE03710-ENG28465,Result of camshaft diagnostic test-Byte,00000000 ,
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03806-ENG104207,Oxygen sensor bank 1 sensor 1: status-Bit 0,0,
IDE03806-ENG28465,Oxygen sensor bank 1 sensor 1: status-Byte,00000000 ,
IDE03807-ENG104207,Oxygen sensor bank 1 sensor 2: status-Bit 0,0,
IDE03807-ENG28465,Oxygen sensor bank 1 sensor 2: status-Byte,00000000 ,
IDE03808-ENG104207,Oxygen sensor bank 2 sensor 1: status-Bit 0,0,
IDE03808-ENG28465,Oxygen sensor bank 2 sensor 1: status-Byte,00000000 ,
IDE03809-ENG104207,Oxygen sensor bank 2 sensor 2: status-Bit 0,0,
IDE03809-ENG28465,Oxygen sensor bank 2 sensor 2: status-Byte,00000000 ,
IDE03810,Oxygen sensor bank 2 sensor 1: specified value,1.0000,
IDE03811-ENG129422,Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977,235,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,11124.000, Ohm
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,12318.000, Ohm
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,0.00, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,0.000, %
IDE03827-ENG129418,Conversion test Bank 2: result-Test_Program_Channel 487,235,
IDE03830-ENG129410,Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021,235,
IDE03968-ENG104207,Camshaft adaptation results-Bit 0,0,
IDE03968-ENG28465,Camshaft adaptation results-Byte,00000000 ,
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,3790, kPa
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,92, °C
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,92, °C
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,0.000000, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,0.000000, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,0.000000, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,0.000000, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,0.000000, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,0.000000, kJ
IDE04410,Intake manifold pressure: target value,246.09, hPa
IDE04414,Cat conv temp: modeled,370, °C
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,0,
IDE04858,Brake booster low pressure actual value,911.99, hPa
IDE04887,Powertrain target torque,-518.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,-30.5, Nm
IDE04937,Sensor for engine block temperature: raw value,92.7, °C
IDE05128,Intake air temperature in intake manifold bank 1,33.8, °C
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,1,
IDE05138,Shut-off timer: last engine shut-off time,66, s
IDE05241-ENG104207,A/C compressor release status-Bit 0,0,
IDE05438,Rear cat conv temp main cat conv model value,369.27, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,350.57, °C
IDE05442,Roadway slope angle acceleration interface: calculated,0.0509, rad
IDE05444,Air filling: specified value,12.40, %
IDE05445,Pressure before throttle valve of pressure sensor,986.25, hPa
IDE05447,Leak recog from oxygen sensor control bank 2,0.9746,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,131070, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,131070, Ohm
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
IDE05479,Misfire recognition reference moment,0.000, %
IDE05480-ENG104207,Evap. emiss. can. purge reg. valve short trip result-Bit 0,0,
IDE05480-ENG28465,Evap. emiss. can. purge reg. valve short trip result-Byte,00000000 ,
IDE05482,Tank venting adaptation factor,0.000,
IDE05487,Coolant temperature linearized value,92.760, °C
IDE05488,Coolant temperature modeled value,84.8, °C
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05797,Throttle valve adapter: specified value,1.700, %
IDE06006,Idle speed specified value,800, /min
IDE06017,Camshaft position deviation from reference position,-0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,34.1, °C
IDE06039,Required RPM at idle speed,800.0, /min
IDE06040,High fuel pressure: regulator output value,0.5720, MPa
IDE06041-ENG104207,PDTC drive cycle conditions status-Bit 0,0,
IDE06043,Cylinder head temperature: actual value,92.6, °C
IDE06049,Pressure in brake booster: raw value,74.30, hPa
IDE06053-ENG104207,Test of mixture adaptation bank 1: status-Bit 0,0,
IDE06053-ENG28465,Test of mixture adaptation bank 1: status-Byte,00000000 ,
IDE06054-ENG104207,Test of mixture adaptation bank 2: status-Bit 0,0,
IDE06054-ENG28465,Test of mixture adaptation bank 2: status-Byte,00000000 ,
IDE06098,Sensor control factor: output value,1.00000,
IDE06192,Knock sensor: cylinder 2: voltage,16.768, V
IDE06193,Knock sensor: cylinder 3: voltage,16.768, V
IDE06194,Knock sensor: cylinder 4: voltage,16.768, V
IDE06195,Knock sensor: cylinder 1: voltage,16.768, V
IDE06386,Oil level: static measurement,16.960, mm
IDE06388,Oil level: condition for static measurement fulfilled,1,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,0,
IDE06495,Results of testing of crankcase ventilation successful,0,
IDE06567-ENG104207,Start-stop function deactivation frequency counter-Bit 0,60,
IDE06569-ENG104207,Vehicle stopped frequency counter-Bit 0,223,
IDE06647-ENG104207,Start-stop switch status-Bit 0,1,
IDE06702-ENG102612,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16,128,
IDE06758,Air mass since engine start,0.00, kg
IDE06759,Cam shaft adaptation inlet: counter,5,
IDE06760,Camshaft adaptation: exhaust: counter,5,
IDE06761,Adaptation val cyl 5 with slow diagnosis,1.00000,
IDE06762,Adaptation val cyl 5 with fast diagnosis,1.00000,
IDE06763,Adaptation val cyl 6 with slow diagnosis,1.00000,
IDE06764,Adaptation val cyl 6 with fast diagnosis,1.00000,
IDE06956-ENG104207,Driver-side belt buckle status-Bit 0,3,
IDE06957,Unfiltered clutch input rpm,0.0, /min
IDE07050-ENG104207,Starter control: release conditions-Bit 0,94,
IDE07050-ENG101796,Starter control: release conditions-Bit 8,70,
IDE07164,Number injections,0,
IDE07475,Throttle valve position 2,6.81, %
IDE07573,Throttle valve adapter: actual value,6.93, %
IDE09572,O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich,0.00, s
IDE09573,O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich,0.00, s
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09575,O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean,0.00, s
IDE10041-ENG104207,Intake camshaft bank1 active operating mode-Bit 0,0,
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE11293,Fuel consumption difference: injectors/sensors,-1.137, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,5.664, l
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.771, V
IDE12923,Lambda regulation: bank 1: output value,1.00000,
IDE12924,Lambda regulation: bank 2: output value,1.00000,
IDE12927,Lambda regulation: bank 2: filtered average output value,1.00000,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00000,
IDE12935,Ignition angle: bank 2 raw value,0.0, °
IDE12936,Ignition angle: bank 1 raw value,0.0, °
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.00, kg
ENG105150,Air_mass_integral_for_thermostat_diagnosis_limit_value,7.91, kg
ENG111033-ENG104207,DFC_status_tested_counter-Bit 0,189,
ENG111033-ENG101796,DFC_status_tested_counter-Bit 8,2,
ENG111032-ENG104207,DFC_status_untested_counter-Bit 0,106,
ENG111032-ENG101796,DFC_status_untested_counter-Bit 8,1,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,-EngineControl,
ENG111034,Engine_temperature_modelbased_substitute_value,93.8, °C
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,0.0, kg/h
ENG107236,Knock_sensor_cylinder_5_voltage,16.768, V
ENG107237,Knock_sensor_cylinder_6_voltage,16.768, V
ENG110574,Lambdacoordination_homogeneous_mode_range_limited_commanded_value,1.0000,
ENG107964,Oxygen_sensor_bank_2_sensor_1_voltage,0.000, V
ENG109006,Spark_efficiency_deviation_at_idle_maximum,85.2, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,28.1, %
ENG121093-ENG104207,State_of_cruise_control_or_speedlimiter-Bit 0,0,
Elapsed Time: 00:41
Engine +80*C, engine at idle
Engine started and idled after ignition cycle above.
;SW:03H-906-026-J   HW:03H-907-309-K ---  Engine
;Component:VR6 3.6l FSI  H20 4748, Coding:012A003244740108B0000000000000000000000000000000
;EV_ECM36FSI01103H906026J,001003,EV_ECM36FSI01103H906026E.rod
;Friday,16,June,2017,07:07:28:21122
;VCDS Version: Beta 17.6.0 (x64)  Data version: 20170602 DS274
;VCID: 2C14C5D84759B5274F-8078
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),1V2NR2CA0JC50220,
IDE00019,Voltage terminal 30,13.140, V
IDE00020-ENG104207,Terminal 15 status-Bit 0,1,
IDE00021,Engine speed,697.969, /min
IDE00025,Coolant temperature,89, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,33, s
IDE00083,Throttle valve position (absolute),12.5, %
IDE00084,Absolute load value,16.1, %
IDE00085,Normed load value,23.9, %
IDE00086,Accelerator position,14.5, %
IDE00090-ENG104207,selected gear-Bit 0,0,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
IDE00100,Engine torque,50.7, Nm
IDE00148,Median injection timing,1.252, ms
IDE00150,Pressure in brake booster,86.48, hPa
IDE00151,Oil fill level,53.332, mm
IDE00152,Oil warning threshold,32.588, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00159,Timing angle retardation cylinder 5,0.0, °
IDE00160,Timing angle retardation cylinder 6,0.0, °
IDE00167,Exhaust temperature 1 bank 1,487.5, °C
IDE00168,Exhaust temperature 1 bank 2,463.1, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00173,Cruise Control System: specified speed,0,
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-15.000, °
IDE00178,Camshaft adjustment intake bank 1: specified value,18.000, °
IDE00179,Camshaft adjustment intake bank 1: actual value,17.766, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.00, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,5.03, °
IDE00186,Fuel low pressure: actual value,561.6, kPa
IDE00187,Coolant temperature at engine start,92.3, °C
IDE00188,Fuel high pressure: actual value,2.7060, MPa
IDE00192,Coolant temperature at radiator outlet: actual value,46.0, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,86.2, °C
IDE00201,High fuel pressure: specified value,2.7030, MPa
IDE00304,Fuel level,34.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,3.99, g/s
IDE00348,Intake air temperature,37, °C
IDE00349,Throttle valve position: normed,2.4, %
IDE00350,Air mass: specified value,14.8, kg/h
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG104207,Cruise Control System (CCS): status-Bit 0,0,
IDE00357,Fuel temperature,89.3, °C
IDE00358,Limitation: torque,469.8, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,986.41, hPa
IDE00371,Fuel consumption,1.37, l/h
IDE00375,Generator: load signal,38.68, %
IDE00380,Coolant fan 1: activation,41.79, %
IDE00392,Accelerator pedal: sensor voltage 1,738.6, mV
IDE00393,Accelerator pedal: sensor voltage 2,364.8, mV
IDE00405,Crankshaft speed (RPM),707.5, /min
IDE00407-ENG104207,Rail pressure regulation: status-Bit 0,1,
IDE00407-ENG28465,Rail pressure regulation: status-Byte,00000001 ,
IDE00412-ENG104207,Starter control: terminal 50-Bit 0,0,
IDE00413-ENG104207,Starter control: Interlock- or P/N-signal-Bit 0,17,
IDE00414-ENG104207,Starter control: relay 1-Bit 0,0,
IDE00416-ENG104207,Starter control: terminal 50 acknowledgment-Bit 0,0,
IDE00417-ENG104207,Starter control: shut-off conditions 1-Bit 0,1,
IDE00417-ENG101796,Starter control: shut-off conditions 1-Bit 8,0,
IDE00443-ENG104207,Accelerator pedal: switch positions-Bit 0,9,
IDE00445,Unlearning counter according OBD,255,
IDE00450-ENG124478,Operating Instructions-Test_Program_Requested Action,0,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,98, kPa
IDE00477,Torque request: sum of auxiliary aggregate,17.8, Nm
IDE00496-ENG104207,Activation of oil pressure switch valve-Bit 0,0,
IDE00497-ENG104207,Status of oil pressure switches-Bit 0,5,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,21, °C
IDE00559-MAS04135,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Oxygen sensor value,1.005, lambda
IDE00559-MAS04136,Current of oxygen sensor bank 1 sensor 1 (broadband sensor)-Current,127.984, mA
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.645, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00565-MAS04135,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Oxygen sensor value,1.007, lambda
IDE00565-MAS04136,Current of oxygen sensor bank 2 sensor 1 (broadband sensor)-Current,127.988, mA
IDE00566-MAS04121,Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage,0.785, V
IDE00566-MAS04122,Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, lambda
IDE00583,Throttle valve specified value,2.7, %
IDE00584,Distance driven since erasing DTC memory,1202, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,48.2, %
IDE00592-MAS04113,Oxygen sensor control status-Oxygen sensor control 1 status,Closed control circuit,
IDE00592-MAS04114,Oxygen sensor control status-Oxygen sensor control 2 status,Closed control circuit,
IDE00593,Ignition timing adjustment cylinder 1,11.0, °
IDE00595-MAS01839,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 1,installed,
IDE00595-MAS01840,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 2,installed,
IDE00595-MAS04115,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 3,not installed,
IDE00595-MAS04116,Allocation of oxygen sensors-Oxygen sensor bank 1: sensor 4,not installed,
IDE00595-MAS04117,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 1,installed,
IDE00595-MAS04118,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 2,installed,
IDE00595-MAS04119,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 3,not installed,
IDE00595-MAS04120,Allocation of oxygen sensors-Oxygen sensor bank 2: sensor 4,not installed,
IDE00597,Long term adaptation of mixture formation bank 1,-8.6, %
IDE00598,Long term adaptation of mixture formation bank 2,0.0, %
IDE00601-MAS00317,Monitoring status since erasing DTC memory-Malfunction Indicator Lamp,OFF,
IDE00601-MAS00328,Monitoring status since erasing DTC memory-Monitoring of ignition misfires,activated,
IDE00601-MAS00329,Monitoring status since erasing DTC memory-Monitoring of fuel system,activated,
IDE00601-MAS00330,Monitoring status since erasing DTC memory-Monitoring of entire system,activated,
IDE00601-MAS00331,Monitoring status since erasing DTC memory-Ignition misfire test,Unknown,
IDE00601-MAS00332,Monitoring status since erasing DTC memory-Fuel system test,Unknown,
IDE00601-MAS00333,Monitoring status since erasing DTC memory-Entire system test,completed successfully,
IDE00601-MAS00503,Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries,0,
IDE00601-MAS04092,Monitoring status since erasing DTC memory-Monitoring of compression ignition,Not supported,
IDE00601-ENG20482,Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared,00,
IDE00602-MAS04092,Monitoring status in current driving cycle-Monitoring of compression ignition,Not supported,
IDE00602-ENG20399,Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle,No,
IDE00602-ENG20507,Monitoring status in current driving cycle-Comprehensive component monitoring completed,completed successfully,
IDE00602-ENG20447,Monitoring status in current driving cycle-Comprehensive component monitoring enabled,activated,
IDE00602-ENG20496,Monitoring status in current driving cycle-Fuel system monitoring completed,not completed successfully,
IDE00602-ENG20425,Monitoring status in current driving cycle-Fuel system monitoring enabled,activated,
IDE00602-ENG20449,Monitoring status in current driving cycle-Misfire monitoring completed,completed successfully,
IDE00602-ENG20506,Monitoring status in current driving cycle-Misfire monitoring enabled,activated,
IDE00603,Number of driving cycles since erasing DTC memory,37,
IDE00604,Short term adaptation of mixture formation bank 1,1.6, %
IDE00605,Short term adaptation of mixture formation bank 2,-1.6, %
IDE00608,Type of fuel,Petrol,
IDE00699,ESI: minimum oil level in service interval,17.924, mm
IDE00700,ESI: maximum oil level in service interval,20.128, mm
IDE00727,Test steps still to be performed,0,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00000,
IDE00739,Test of oxygen sensors bank 2: Delta-Lambda,0.00000,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,21.7, °C
IDE01076,Time since ignition off,95, s
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01236-ENG104207,Coolant recirculation pump-Bit 0,0,
IDE01260,Generator power,546.65, W
IDE01266-ENG104207,Coolant shut-off valve-Bit 0,2,
IDE01267,Height correction,0.97363,
IDE01378,High fuel pressure: control deviation,0.0110, MPa
IDE01385-ENG104207,Wear index-Bit 0,0,
IDE01385-ENG101796,Wear index-Bit 8,0,
IDE01386-ENG104207,Soot index-Bit 0,0,
IDE01386-ENG101796,Soot index-Bit 8,0,
IDE01405-ENG104207,Status of starter activation-Bit 0,2,
IDE01639,Dynamic factor O2 sensors bank 2 or bank 4 before cat. conv.,1.0000,
IDE01641-ENG104207,Result of oxygen sensor test bank 1 after catalytic converter-Bit 0,160,
IDE01641-ENG28465,Result of oxygen sensor test bank 1 after catalytic converter-Byte,10100000 ,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.646, V
IDE01645,Oxygen sensor voltage bank 2 after catalytic converter,0.782, V
IDE01649,Throttle valve position 1,3.08, %
IDE01650,Throttle valve position 2,12.2, %
IDE01678-ENG129413,Result of O2 sensor test ready bank 2 after cat. conv.-Test_Program_Channel 114,213,
IDE01773,Misfire sum counter,9,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,8,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,1,
IDE01834,Battery voltage,13240, mV
IDE01869,Long-term fuel trim bank 1 at idle,-0.94, %
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01873,Test of catalytic converter: measured value,9.0686,
IDE01875,Required torque adjustment by idling regulator,-0.491, %
IDE01876,Adaptation of loss torque,-0.3, Nm
IDE01877-ENG104207,Operating condition of idle speed control-Bit 0,1,
IDE01877-ENG103108,Operating condition of idle speed control-Bitregister,00000001 ,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,49.725, %
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,50.472, %
IDE01899,Load value: corrected specified value,70.05, %
IDE01901,Lost torque adaptation: idle,-3.2, Nm
IDE01902,Lost torque adaptation A/C compressor,-0.3, Nm
IDE01903,Lost torque adaptation driving mode,-2.8, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,2.1, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.98944,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.95178,
IDE01914-ENG104207,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bit 0,170,
IDE01914-ENG103108,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bitregister,10101010 ,
IDE01916,Leakage recognition from oxygen sensor control,0.9668,
IDE01917,Leakage after throttle valve,-1.000,
IDE01918,Leakage before throttle valve,-1.000,
IDE01919-ENG104207,Leakage recognition: status-Bit 0,220,
IDE01919-ENG103108,Leakage recognition: status-Bitregister,11011100 ,
IDE01920,Oxygen sensor: mixture correction with active diagnosis,-0.0000,
IDE01922,Vehicle distance driven,1367, km
IDE01923,Control module distance driven,1365950, m
IDE01928,Close cam shaft angle at quantity control valve,40.2, °
IDE01929,Open cam shaft angle at quantity control valve,-18.2, °
IDE01930,High pressure regulation: adaptation value,0.0000, MPa
IDE01932,High pressure pump injection volume,0.41, mm³
IDE01975,Numb.of misfir.: cylinder 1,355,
IDE01976,Numb.of misfir.: cylinder 2,339,
IDE01977,Numb.of misfir.: cylinder 3,162,
IDE01978,Numb.of misfir.: cylinder 4,172,
IDE02115-ENG104207,Adjustment requirements for basic setting-Bit 0,223,
IDE02115-ENG103108,Adjustment requirements for basic setting-Bitregister,11011111 ,
IDE02116,Exhaust gas temperature before catalytic converter,425.66, °C
IDE02117,Relative load value,14.20, %
IDE02118,Oxygen sensor bank 1 sensor 1: voltage,0.000, V
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,-0.03, MPa
IDE02540-ENG104207,Longitudinal acceleration sensor: status-Bit 0,0,
IDE02756-ENG104207,Number of manual engine starts-Bit 0,243,
IDE02756-ENG102612,Number of manual engine starts-Bit 16,0,
IDE02756-ENG101717,Number of manual engine starts-Bit 24,0,
IDE02756-ENG101796,Number of manual engine starts-Bit 8,0,
IDE02757-ENG104207,Number of automatic engine starts-Bit 0,247,
IDE02757-ENG102612,Number of automatic engine starts-Bit 16,0,
IDE02757-ENG101717,Number of automatic engine starts-Bit 24,0,
IDE02757-ENG101796,Number of automatic engine starts-Bit 8,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03189-ENG102843,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density,0, counts
IDE03189-ENG102547,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost,0, counts
IDE03189-ENG103808,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption,7, counts
IDE03189-ENG101159,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random,7, counts
IDE03189-ENG104187,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode,0, counts
IDE03189-ENG100165,Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior,0, counts
IDE03189-ENG99535,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density,0,
IDE03189-ENG103192,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost,0,
IDE03189-ENG99739,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption,26,
IDE03189-ENG100597,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random,6,
IDE03189-ENG101689,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100582,Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior,0,
IDE03189-ENG101720,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density,0,
IDE03189-ENG100669,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost,0,
IDE03189-ENG100932,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption,13,
IDE03189-ENG101264,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random,20,
IDE03189-ENG102430,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101165,Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior,0,
IDE03189-ENG101829,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density,0, km
IDE03189-ENG99286,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost,0, km
IDE03189-ENG102800,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption,-1560281088, km
IDE03189-ENG102751,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random,2130837504, km
IDE03189-ENG101356,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode,0, km
IDE03189-ENG99669,Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior,0, km
IDE03189-ENG103828,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density,0,
IDE03189-ENG103959,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost,0,
IDE03189-ENG102465,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption,45,
IDE03189-ENG102710,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random,9,
IDE03189-ENG103568,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100877,Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior,0,
IDE03189-ENG101280,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density,0,
IDE03189-ENG99226,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost,0,
IDE03189-ENG101471,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption,5,
IDE03189-ENG102877,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random,6,
IDE03189-ENG100198,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG101676,Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior,0,
IDE03189-ENG103694,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density,0,
IDE03189-ENG104142,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost,0,
IDE03189-ENG100353,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption,2017,
IDE03189-ENG100878,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random,2017,
IDE03189-ENG101433,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode,0,
IDE03189-ENG100557,Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:,0,
IDE03190-ENG100538,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost,0, counts
IDE03190-ENG100036,Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature,0, counts
IDE03190-ENG103639,Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature,0, counts
IDE03190-ENG102427,Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost,0,
IDE03190-ENG99459,Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature,0,
IDE03190-ENG99665,Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature,0,
IDE03190-ENG99329,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost,0,
IDE03190-ENG100944,Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature,0,
IDE03190-ENG100535,Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature,0,
IDE03190-ENG102737,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost,0, km
IDE03190-ENG101377,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature,0, km
IDE03190-ENG99682,Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature,0, km
IDE03190-ENG102760,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost,0,
IDE03190-ENG103163,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature,0,
IDE03190-ENG101771,Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature,0,
IDE03190-ENG100816,Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost,0,
IDE03190-ENG104013,Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature,0,
IDE03190-ENG104020,Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature,0,
IDE03190-ENG103223,Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost,0,
IDE03190-ENG103563,Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature,0,
IDE03190-ENG103316,Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature,0,
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.497, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.768, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.235, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03363,Numb.of misfir.: cylinder 5,162,
IDE03364,Numb.of misfir.: cylinder 6,190,
IDE03393-ENG104207,Selector lever position-Bit 0,8,
IDE03583-ENG104207,Engine shut-down overrides-Bit 0,4,
IDE03584-ENG104207,Engine starting requirements-Bit 0,0,
IDE03585,System status for the start/stop function master,1,
IDE03586-ENG104207,Starting requirements for active participants-Bit 0,0,
IDE03586-ENG101796,Starting requirements for active participants-Bit 8,0,
IDE03587-MAS00075,Stop overrides for active participants-Brake control module,not active,
IDE03587-MAS00077,Stop overrides for active participants-Immobilizer,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00798,Stop overrides for active participants-Transmission Control Module (TCM),not active,
IDE03587-MAS00829,Stop overrides for active participants-Access and start authorization,not active,
IDE03588-MAS00075,System malfunctions for active participants start/stop-Brake control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00798,System malfunctions for active participants start/stop-Transmission Control Module (TCM),not active,
IDE03588-MAS00829,System malfunctions for active participants start/stop-Access and start authorization,not active,
IDE03589-ENG104207,Error status for start-stop related sensors-Bit 0,8,
IDE03660,Longitudinal acceleration,0.333, m/s²
IDE03693-ENG104207,Monitoring status of additional Onboard Diagnosis-Bit 0,161,
IDE03693-ENG103108,Monitoring status of additional Onboard Diagnosis-Bitregister,10100001 ,
IDE03696-ENG104207,Result test of oxygen sensor heater after catalytic converter-Bit 0,144,
IDE03696-ENG28465,Result test of oxygen sensor heater after catalytic converter-Byte,10010000 ,
IDE03697-ENG104207,Result test of oxygen sensor heater before catalytic converter-Bit 0,4,
IDE03697-ENG28465,Result test of oxygen sensor heater before catalytic converter-Byte,00000100 ,
IDE03699-ENG104207,Result of test of oxygen sensor before catalytic converter-Bit 0,228,
IDE03699-ENG28465,Result of test of oxygen sensor before catalytic converter-Byte,11100100 ,
IDE03700-ENG127325,Status adaptation dew point end-Test_Program_Channel 860,2,
IDE03707-ENG104207,Result of NPulse test-Bit 0,170,
IDE03707-ENG28465,Result of NPulse test-Byte,10101010 ,
IDE03709,Angle difference actual-specified camshaft adjuster,0.102, °
IDE03711,Mass flow through throttle valve,14.1, kg/h
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03794,Long-term fuel trim bank 2 at idle,-0.37, %
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,6.252, %
IDE03806-ENG104207,Oxygen sensor bank 1 sensor 1: status-Bit 0,3,
IDE03806-ENG28465,Oxygen sensor bank 1 sensor 1: status-Byte,00000011 ,
IDE03807-ENG104207,Oxygen sensor bank 1 sensor 2: status-Bit 0,10,
IDE03807-ENG28465,Oxygen sensor bank 1 sensor 2: status-Byte,00001010 ,
IDE03808-ENG104207,Oxygen sensor bank 2 sensor 1: status-Bit 0,3,
IDE03808-ENG28465,Oxygen sensor bank 2 sensor 1: status-Byte,00000011 ,
IDE03809-ENG104207,Oxygen sensor bank 2 sensor 2: status-Bit 0,10,
IDE03809-ENG28465,Oxygen sensor bank 2 sensor 2: status-Byte,00001010 ,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,312.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,216,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,146.99, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,27.707, %
IDE03822-ENG101533,Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121,276.000, Ohm
IDE03822-ENG127296,Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03823-ENG129414,Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125,0,
IDE03824,Heated oxygen sensor bank 2: sensor 1: resistance,147.27, Ohm
IDE03825,Heated oxygen sensor bank 2: sensor 1: activation,30.823, %
IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,209,
IDE03837-ENG129416,Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 2115,213,
IDE03876,Misfires per 1000 revolutions of cylinder 5,0,
IDE03877,Misfires per 1000 revolutions of cylinder 6,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99194,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,Not available,
IDE04016-MAS03336,Fuel Pressure Regulation-Fuel pressure 1: specified value,0, kPa
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,2600, kPa
IDE04016-MAS03337,Fuel Pressure Regulation-Fuel pressure 1: actual value,Available,
IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,0, °C
IDE04016-MAS03338,Fuel Pressure Regulation-Fuel temperature 1,Not available,
IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,0, kPa
IDE04016-MAS03339,Fuel Pressure Regulation-Fuel pressure 2: specified value,Not available,
IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,0, kPa
IDE04016-MAS03340,Fuel Pressure Regulation-Fuel pressure 2: actual value,Not available,
IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,0, °C
IDE04016-MAS03341,Fuel Pressure Regulation-Fuel temperature 2,Not available,
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,installed,
IDE04083-MAS03426,Coolant temperatures-Coolant temperature sensor 1,94, °C
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,installed,
IDE04083-MAS03427,Coolant temperatures-Coolant temperature sensor 2,89, °C
IDE04234,Heat quantity f dew pt end before cat conv bank 1: modeled,89.819359, kJ
IDE04235,Heat quantity f dew pt end before cat conv bank 2: modeled,87.293083, kJ
IDE04236,Heat quantity f dew pt end behind fr cat conv bank 1: modeled,90.843525, kJ
IDE04237,Heat quantity f dew pt end behind fr cat conv bank 2: modeled,88.334318, kJ
IDE04238,Heat quantity f dew pt end behind main cat conv bank 1: modeled,98.285798, kJ
IDE04239,Heat quantity f dew pt end behind main cat conv bank 2: modeled,95.520550, kJ
IDE04240,Counter start bef dew pt end f O2 sensor bef cat conv bank1,0,
IDE04241,Counter start bef dew pt end f O2 sensor bef cat conv bank2,0,
IDE04242,Counter start bef dew pt end f O2 sensor beh fr cat conv bank1,0,
IDE04243,Counter start bef dew pt end f O2 sensor beh fr cat conv bank2,0,
IDE04244,Count start bef dew pt end f O2 sensor beh main cat conv bank1,0,
IDE04245,Count start bef dew pt end f O2 sensor beh main cat conv bank2,0,
IDE04302-ENG104207,Bypass valve for high press turbocharger turbine inlet: status-Bit 0,0,
IDE04302-ENG102612,Bypass valve for high press turbocharger turbine inlet: status-Bit 16,0,
IDE04302-ENG101717,Bypass valve for high press turbocharger turbine inlet: status-Bit 24,0,
IDE04302-ENG101796,Bypass valve for high press turbocharger turbine inlet: status-Bit 8,0,
IDE04324,Long term adaptation of oxygen sensor control: bank 2,0.0, %
IDE04410,Intake manifold pressure: target value,307.97, hPa
IDE04414,Cat conv temp: modeled,460, °C
IDE04604,Accelerator pedal travel,0.00, %
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,0,
IDE04651,Torque request: A/C compressor,9.0, Nm
IDE04654-ENG104207,CAN status - engine control module-Bit 0,0,
IDE04655-ENG104207,CAN status - transmission control module-Bit 0,0,
IDE04656-ENG104207,CAN status - brake control module 1-Bit 0,0,
IDE04657-ENG104207,CAN status - brake control module 2-Bit 0,0,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04685,Setpoint generation interior torque,49.7, Nm
IDE04689-ENG127289,Starter control: Start interruption status-Test_Program_B TRUE UBYTE,1,
IDE04691,Calculated reducing transmission intervention torque,1000.0, Nm
IDE04692,Reducing desired torque intervention of ESP,50000.1, Nm
IDE04693,Increasing desired torque intervention of ESP,-50000.0, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,0,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04858,Brake booster low pressure actual value,903.98, hPa
IDE04887,Powertrain target torque,-838.1, Nm
IDE04889,Target torque for combustion engine crankshaft level,-33.6, Nm
IDE04933,Number of fill level decreases,0,
IDE04934,Last odometer reading since fill level decrease,0, km
IDE04935,Next to last odometer reading since fill level decrease,0, km
IDE04936,3. Last odometer reading since fill level decrease,0, km
IDE04937,Sensor for engine block temperature: raw value,94.1, °C
IDE05128,Intake air temperature in intake manifold bank 1,37.5, °C
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,95, s
IDE05140,Intake manifold pressure raw value,0.00, hPa
IDE05228,Operating hour counter,1782, min
IDE05240-ENG104207,Request for A/C compressor power reduction-Bit 0,0,
IDE05241-ENG104207,A/C compressor release status-Bit 0,1,
IDE05261-ENG104207,Gear position sensor: last valid value-Bit 0,14,
IDE05327,Activation for electrical reserve coolant pump in HT circuit,0.00, %
IDE05332-ENG104207,Heat request from heater to thermal management-Bit 0,3,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,20.3, °C
IDE05438,Rear cat conv temp main cat conv model value,461.62, °C
IDE05439,Rear cat conv temp main cat conv bank 2 model value,437.50, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05444,Air filling: specified value,14.91, %
IDE05445,Pressure before throttle valve of pressure sensor,986.33, hPa
IDE05447,Leak recog from oxygen sensor control bank 2,0.9370,
IDE05448,Long term adaptation of mixture form bank 2 at partial load,1.02902,
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,9192, Ohm
IDE05450,Oxygen sensor 2 bank 2 internal resistance limit value,9554, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00583,
IDE05463,Oxy sensor 1 bank 2 char curve offset,0.00177,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,720.23, °C
IDE05469,Oxygen sensor 1 bank 2 ceramic temp,720.62, °C
IDE05472,Cat converter oxygen storage capacity ref standardized,0.0000,
IDE05473,Cat converter oxygen storage capacity ref standardized bank 2,0.0000,
IDE05474,Main cat converter OSC age correction factor,0.930,
IDE05475,Main cat converter OSC age correction factor bank 2,0.859,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,7.4, kg/h
IDE05479,Misfire recognition reference moment,10.165, %
IDE05484,Power steering pump desired actual moment for idling control,0.0, Nm
IDE05485-ENG104207,Irregular shutdown of the counter control mod-Bit 0,0,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05487,Coolant temperature linearized value,93.958, °C
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,255,
IDE05797,Throttle valve adapter: specified value,3.096, %
IDE05928,Fuel consumption since DTC memory last erased,14.447, l/100km
IDE06006,Idle speed specified value,700, /min
IDE06020,Intake air temperature in intake manifold bank raw value,38.2, °C
IDE06023-ENG104207,BDE operating mode flag register-Bit 0,1,
IDE06023-ENG28465,BDE operating mode flag register-Byte,00000001 ,
IDE06039,Required RPM at idle speed,700.0, /min
IDE06040,High fuel pressure: regulator output value,0.0035, MPa
IDE06041-ENG104207,PDTC drive cycle conditions status-Bit 0,36,
IDE06043,Cylinder head temperature: actual value,89.3, °C
IDE06045-ENG104207,Output DTM status-Bit 0,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,78.44, hPa
IDE06053-ENG104207,Test of mixture adaptation bank 1: status-Bit 0,128,
IDE06053-ENG28465,Test of mixture adaptation bank 1: status-Byte,10000000 ,
IDE06054-ENG104207,Test of mixture adaptation bank 2: status-Bit 0,128,
IDE06054-ENG28465,Test of mixture adaptation bank 2: status-Byte,10000000 ,
IDE06098,Sensor control factor: output value,1.01318,
IDE06192,Knock sensor: cylinder 2: voltage,0.527, V
IDE06193,Knock sensor: cylinder 3: voltage,0.728, V
IDE06194,Knock sensor: cylinder 4: voltage,0.645, V
IDE06195,Knock sensor: cylinder 1: voltage,0.542, V
IDE06255,Vehicle lateral acceleration,-0.01, g
IDE06256,Vehicle lateral acceleration: raw value,-0.01, g
IDE06257,Vehicle inclination acceleration angle: raw value,-12.557, m/s²
IDE06386,Oil level: static measurement,17.128, mm
IDE06387,Oil level: last valid dynamic value,19.372, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06393,Oil level: dynamic average value,19.460, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06434-ENG112927,Oxygen control: bank 1: sensor 1: release status-Blrnd A,1,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.531, m/s²
IDE06446-ENG104207,Status: incline angle-Bit 0,1,
IDE06495,Results of testing of crankcase ventilation successful,2,
IDE06496,Results of testing of crankcase ventilation unsuccessful,0,
IDE06567-ENG101796,Start-stop function deactivation frequency counter-Bit 8,0,
IDE06568-ENG104207,Stop prevention by driver frequency counter-Bit 0,72,
IDE06568-ENG101796,Stop prevention by driver frequency counter-Bit 8,1,
IDE06569-ENG101796,Vehicle stopped frequency counter-Bit 8,3,
IDE06610-ENG104207,Vehicle standstill with stop frequency counter-Bit 0,48,
IDE06610-ENG101796,Vehicle standstill with stop frequency counter-Bit 8,1,
IDE06647-ENG104207,Start-stop switch status-Bit 0,0,
IDE06702-ENG104207,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 0,0,
IDE06702-ENG102612,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 16,0,
IDE06702-ENG101717,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 24,128,
IDE06702-ENG101796,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bit 8,0,
IDE06703-ENG104207,Drivetrain coordinator: ACC fault status-Bit 0,0,
IDE06703-ENG101796,Drivetrain coordinator: ACC fault status-Bit 8,0,
IDE06704-ENG104207,Drivetrain coordinator: brake fault status-Bit 0,0,
IDE06706-ENG104207,ACC variants-Bit 0,2,
IDE06708-ENG104207,Cruise control switch actuation-Bit 0,0,
IDE06708-ENG101796,Cruise control switch actuation-Bit 8,32,
IDE06709-ENG104207,ACC variants (coding)-Bit 0,3,
IDE06711-ENG104207,Cruise control system: temporary deactivation-Bit 0,255,
IDE06758,Air mass since engine start,0.27, kg
IDE06760,Camshaft adaptation: exhaust: counter,4,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG104207,Brake actuated status-Bit 0,0,
IDE06957,Unfiltered clutch input rpm,700.5, /min
IDE07050-ENG104207,Starter control: release conditions-Bit 0,12,
IDE07050-ENG101796,Starter control: release conditions-Bit 8,98,
IDE07051-ENG104207,Engaged gear: raw signal-Bit 0,255,
IDE07164,Number injections,2457,
IDE07170,Clutch K0: torque,0.0, Nm
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG104207,Overrun cut-off-Bit 0,0,
IDE07233-ENG104207,Bit string for status of oil level-Bit 0,2,
IDE07233-ENG101796,Bit string for status of oil level-Bit 8,4,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,1,
IDE07238,Status of power transfer,0.00,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07475,Throttle valve position 2,2.91, %
IDE07573,Throttle valve adapter: actual value,3.08, %
IDE07665,Accel. pedal kick-down recognition: voltage threshold,4125.2, mV
IDE07840-ENG104207,Status plausibility accelerator pedal to brake pedal-Bit 0,0,
IDE07904-ENG104207,Brake test switch status-Bit 0,0,
IDE07905-ENG104207,Brake light switch status-Bit 0,0,
IDE07906-ENG104207,Upper clutch switch: status-Bit 0,0,
IDE08071-ENG104207,Remote start cancellation reason store 1-Bit 0,0,
IDE08071-ENG101796,Remote start cancellation reason store 1-Bit 8,64,
IDE08072-ENG104207,Remote start cancellation reason store 2-Bit 0,0,
IDE08072-ENG101796,Remote start cancellation reason store 2-Bit 8,64,
IDE08073-ENG104207,Remote start cancellation reason store 3-Bit 0,1,
IDE08073-ENG101796,Remote start cancellation reason store 3-Bit 8,0,
IDE08074-ENG104207,Remote start cancellation reason store 4-Bit 0,0,
IDE08074-ENG101796,Remote start cancellation reason store 4-Bit 8,0,
IDE08075-ENG104207,Remote start cancellation reason store 5-Bit 0,0,
IDE08075-ENG101796,Remote start cancellation reason store 5-Bit 8,0,
IDE09693-ENG104207,Charisma driving program: system status-Bit 0,0,
IDE09695-ENG104207,Charisma driving program: target value from coordinator-Bit 0,5,
IDE09696-ENG104207,Charisma driving program: CAN output value-Bit 0,5,
IDE09925-ENG104207,Intake camshaft bank 1: adaption error cause-Bit 0,0,
IDE09926-ENG104207,Outlet camshaft bank 1: adaption error cause-Bit 0,0,
IDE10041-ENG104207,Intake camshaft bank1 active operating mode-Bit 0,1,
IDE10041-ENG101796,Intake camshaft bank1 active operating mode-Bit 8,0,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,71.3, s
IDE10303,Integrated air masse at first engine start,0.3015, kg
IDE10630,O2 sensor upstrm. of cat.: delay time transf. rich -> lean,0.00, s
IDE10631,O2 sens.upstrm. of cat. bank 2: delay time transf.rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,0.0, kPa
IDE10670,O2 sensor upstrm. of cat.: filter constant transf. rich -> lean,0.07, s
IDE10671,O2 sens.upstrm. of cat. B. 2: filter const.transf. rich -> lean,0.04, s
IDE10994-ENG104207,Poor start counter at start-stop-Bit 0,0,
IDE10994-ENG101796,Poor start counter at start-stop-Bit 8,0,
IDE11115-ENG104207,Start/stop driver request: counter restart by starter-Bit 0,6,
IDE11115-ENG101796,Start/stop driver request: counter restart by starter-Bit 8,0,
IDE11116-ENG104207,Start/stop driver request: counter internal-motor restart-Bit 0,6,
IDE11116-ENG101796,Start/stop driver request: counter internal-motor restart-Bit 8,0,
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,5.691, l
IDE12355,ESI: consumption equivalent of the engine control module,0.00000020,
IDE12915,Throttle 1: bank 1: position sensor 1: raw voltage,0.621, V
IDE12923,Lambda regulation: bank 1: output value,1.01288,
IDE12924,Lambda regulation: bank 2: output value,0.98554,
IDE12927,Lambda regulation: bank 2: filtered average output value,0.98355,
IDE12928,Lambda regulation: bank 1: filtered average output value,1.00949,
IDE12935,Ignition angle: bank 2 raw value,16.5, °
IDE12936,Ignition angle: bank 1 raw value,16.5, °
MAS15845,Fuel: tank fill level,34.0, l
ENG105149,Air_mass_integral_for_thermostat_diagnosis_actual_value,0.28, kg
ENG101413,Calibration Identification,03H026J 4748FVA,
ENG99697,Calibration Verification Number,01 FF BD AE,
ENG126402-ENG104207,Cruise_control_shutoff_conditions_irreversible-Bit 0,0,
ENG126402-ENG101796,Cruise_control_shutoff_conditions_irreversible-Bit 8,0,
ENG111031-ENG104207,DFC_status_error_debounced_counter-Bit 0,0,
ENG111031-ENG101796,DFC_status_error_debounced_counter-Bit 8,0,
ENG111033-ENG104207,DFC_status_tested_counter-Bit 0,89,
ENG111033-ENG101796,DFC_status_tested_counter-Bit 8,3,
ENG111032-ENG104207,DFC_status_untested_counter-Bit 0,206,
ENG111032-ENG101796,DFC_status_untested_counter-Bit 8,0,
ENG111034,Engine_temperature_modelbased_substitute_value,95.3, °C
ENG107045,Intake_manifold_model_air_mass_flow_filtered_value,13.9, kg/h
ENG100634,In-use Per Tr: 16 or 20 cou*sec O2 Sens Mon Con Enc Cou B 1,14 00 3D 00 A3 00 39 00 3D 00 35 00 3D 00 3B 00 3D 00 38 00 3D 00 5A 00 3D 00 00 00 00 00 10 00 09 00 39 00 3D 00 35 00 3D,
ENG107236,Knock_sensor_cylinder_5_voltage,0.703, V
ENG107237,Knock_sensor_cylinder_6_voltage,0.552, V
Elapsed Time: 00:41
Keithuk
Stoke on Trent, England
C?ID=122432
You can Goole VAG Engine & Transmission Codes I've posted my app on a few forums. If anyone wants my new version please PM me?
Keithuk
C?ID=122432
A quick update I installed another months updates for ETKA and saved all new PDF files.
I noticed there was VW Teramont which I had to Google.
https://en.wikipedia.org/wiki/Volkswagen_Atlas The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
Manufacturer: VW, Date(s) Used: 11/2016-, Model: Teramont, Engine Code: CUGA, 162Kw, 220PS, 2.0 Ltr, 4 Cyls , Remarks: Turbo Fuel Stratified Injection (TFSI) Remarks: The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
Manufacturer: VW, Date(s) Used: 11/2016-, Model: Teramont, Engine Code: DBFA, 132Kw, 179PS, 2.0 Ltr, 4 Cyls , Remarks: Turbo Fuel Stratified Injection (TFSI) Remarks: The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
Manufacturer: VW, Date(s) Used: 11/2016-, Model: Teramont, Engine Code: DDKA, 220Kw, 299PS, 2.5 Ltr, 6 Cyls , Remarks: Fuel Stratified Injection (FSI) Remarks: The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
And a few transmissions:
Manufacturer: VW, Date(s) Used: 11/2016-, Model: Teramont, Transmission Code: QTD, Transmission Type: 7A, Remarks: The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
Manufacturer: VW, Date(s) Used: 11/2016-, Model: Teramont, Transmission Code: QJR, Transmission Type: 7A, Remarks: The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
Manufacturer: VW, Date(s) Used: 11/2016-, Model: Teramont, Transmission Code: QJQ, Transmission Type: 7A, Remarks: The Atlas will be marketed as the Volkswagen Teramont when production (in Shanghai) and sales begin in China in 2017
It still doesn't show a model for CDVC
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Adaptation map from 09-Central Electronics:
;SW:5Q0-937-085-BG   HW:5Q0-937-085-BG ---  Cent. Elect.
;Component:BCM MQBAB HNA H34 0236, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,017001,EV_BCMBOSCH_017.rod
;Sunday,22,October,2017,13:30:54:43302
;VCDS Version: Beta 17.9.3 (x64)  Data version: 20170721 DS283.0
;VCID: 7F580996D777EE9F1A3-802A
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,Unabhaengig_der_Fahrzeuggeschwindigkeit ,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,30 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Horn_verbaut ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,52 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 03 58 ,5
IDE05144-Read parameter address,FE 03 58 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,20.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.50 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,50.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,50.50 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,50.00 °C,30
IDE06507-MAS13132-Button in center console-Function of button 3,NOT-DEFINED ,8
IDE06507-MAS13135-Button in center console-Function of button 4,Steering wheel heater ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remotestart,installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08577-Garage door opener: use of GPS data,not active ,1
IDE08578-Garage door opener: bi-directional communic.,active ,1
IDE08580-Garage door opener: increasing transm. power,not active ,1
IDE08583-Garage door opener: no. of channels,3 channels ,1
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,not active ,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,not active ,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,not active ,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,not active ,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,not active ,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,not active ,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,not active ,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,not active ,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,not active ,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,not active ,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,not active ,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,not active ,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,not active ,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,not active ,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,not active ,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,not active ,2
IDE08585-Garage door opener: activation via remote key,not active ,1
IDE08778-Garage door opener: surround. target area,30 m,1
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,installed ,9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,10 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,10 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel,installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10308-Garage door opener: support door name,not active ,1
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10350-Garage door opener: programming antenna,External antenna ,1
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000101  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00010000  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,2.0 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,single-color ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG141966-Front_wiper-Frontwischertyp,Direct ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,minimize ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,10 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,2A ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,1A ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Brake light ,16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,minimize ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,10 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,29 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,0A ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Brake light ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,10 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,10 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,37 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,09 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,41 - LED Kleinleistung ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Brake light ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4A ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 00 8A 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 00 8A 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 29 09 00 37 18 00 FF 00 00 00 00 00 00 00 00 00 09 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 1A 00 2A 08 00 0A 18 00 80 00 00 00 00 00 00 2B 0A 00 29 08 00 0A 18 00 80 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4,-8.00 mm/%,62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn,-8.00 mm/%,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Verbundlenkerhinterachse ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,0 ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,5.0 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG122979-ENG141969-Networking-UGDO,installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 ,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,20.0 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin 31 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
ENG122929-RLS_LIN_Communication,4 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,1
ENG122935-RLS_Washer_Front,15 s,1
ENG122926-RLS_wiper_position_parking,15 s,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM,0.00 s,21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,50 lx,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,16.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,25.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,30.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,50.0 ,10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
Elapsed Time: 02:44
Adaptation map from 4B-Multifunc. Module:
;SW:3Q0-907-338   HW:3Q0-907-338 ---  Multifunc. Module
;Component:FCM MQB Low   001 0286, Coding:000000070100135200010000000000000000000000000000000000000000
;EV_MultiModulContiVW48X,001010,EV_MultiModulContiVW48X.rod
;Sunday,22,October,2017,13:37:16:43302
;VCDS Version: Beta 17.9.3 (x64)  Data version: 20170721 DS283.0
;VCID: 72BED0A29425B3F765D-8026
IDE00001-Production mode,not active ,3
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,No ,1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,No ,1
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,active ,1
IDE03642-Presentation mode,not active ,1
IDE03679-Adaptive light functions,active ,1
IDE08418-Matrix light: total dimming,100 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,0 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,0 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,0 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,0 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,0 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,0 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,0 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,0 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,0 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,0 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,0 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,0 %,12
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:07
Atlas123
New Member
It looks like you have additional light control modules in D6 and D7. Are there adaptation channels in those modules?
Yes, they should have these:
IDE00036 - Vehicle equipment code
IDE00047 - Parameter set version
IDE00048 - Parameter set part number
