Results 1 to 10 of 16
Thread: Audi A3 8P steering problem after steering replacement.
    Mexico
    Dear friends
    Have a problem with an Audi A3 8p platform after replacing steering rack and pinion set.
    Have performed 3 times now on complete basic setting and still traction control is on.
    Here the complete auto scan, please discard airbag messages since it is disconnected so far.
    Friday,09,June,2017,16:26:25:05043
    VCDS Version: 17.1.3.0
    Dealer/Shop Name: rpm
    VIN: WAUAC28P29A051240   License Plate: AUGUSTO2
    Mileage: 78980km-49075mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: WAUAC28P29A051240   Mileage: 78980km-49075miles
    04-Steering Angle -- Status: Cannot be reached 1100
    Address 01: Engine (CDA)       Labels: 06J-907-115-CDA.clb
       Part No SW: 8P7 907 115 D    HW: 8P0 907 115 Q
       Component: 1.8l R4/4V TFSI     0020
       Revision: AAH03---    Serial number: AUX7Z0H9FN10GF
       Coding: 0103000C24070060
       Shop #: WSC 66565 257 00032
       VCID: 3A7141CF754C2A91E7-806E
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 000 -
                        Mileage: 78957 km
                        Date: 2017.05.18
                        Time: 02:29:34
                        RPM: 759 /min
                        Load: 12.2 %
                        Temperature: 93.0°C
                        Temperature: 63.0°C
                        Absolute Pres.: 780.0 mbar
                        Voltage: 13.335 V
    006480 - Radiator Fan (V7)
                   P1950 - 000 - Movement Restricted / Jammed - Intermittent
                        Mileage: 78957 km
                        Date: 2017.05.18
                        Time: 02:29:34
    Readiness: 0010 0001
       Part No SW: 0AM 300 048 M    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 9032
       Revision: 00043014    Serial number: CU501111015248
       Shop #: WSC 50524 001 1048576
    006243 - Powertrain Data Bus
                   P1863 - 000 - Missing Message from Steering Angle Sensor
                        Fault Frequency: 97
                        Reset counter: 10
                        Mileage: 78951 km
                        Date: 2017.05.07
                        Time: 05:11:33
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Revision: 00H45001
       Coding: 11424012092700FB880D02E890190041B900
       Shop #: WSC 12345 123 119698
       VCID: 0005F3279310B041E9-8054
    02781 - ASR/ESP Button (E256)
                        Reset counter: 254
                        Mileage: 78959 km
                        Date: 2017.06.03
                        Time: 22:31:34
                        Count: 2
                        Count: 12
                        Count: 12800
                        Count: 156
                        Count: 50688
                        Reset counter: 254
                        Mileage: 78959 km
                        Date: 2017.06.03
                        Time: 22:31:34
                        Reset counter: 213
                        Mileage: 78957 km
                        Date: 2017.05.18
                        Time: 02:51:53
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 166
                        Count: 48640
                        Reset counter: 213
                        Mileage: 78957 km
                        Date: 2017.05.18
                        Time: 02:51:53
       Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
       Component: KlimavollautomatH09 0100
       Revision: 000846      Serial number: 8P0820043BG
       VCID: 72E1A9EF6DBC92D1EF-8026
    Address 09: Cent. Elect.        Labels: 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
       Component: Bordnetz-SG     H54 2801
       Revision: 00H54000    Serial number: 00000008957258
       Coding: 05AC2F01C0141380EF00001C4F00000000094E056401000100A000000000
       Shop #: WSC 06314 000 08192
       VCID: 48952B073BA0480161-801C
       Subsystem 1 - Part No: 8P1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H10 0040
       Coding: 00056595
       Shop #: WSC 06314
                        Fault Status: 01111100
                        Reset counter: 215
                        Mileage: 78902 km
                        Date: 2017.04.04
                        Time: 03:08:00
                        Voltage: 13.65 V
                        Reset counter: 215
                        Mileage: 78902 km
                        Date: 2017.04.04
                        Time: 03:08:00
                        Reset counter: 253
                        Mileage: 78562 km
                        Date: 2017.03.21
                        Time: 00:00:00
                        Voltage: 11.85 V
                        Reset counter: 253
                        Mileage: 78562 km
                        Date: 2017.03.21
                        Time: 00:00:00
                        Reset counter: 253
                        Mileage: 78562 km
                        Date: 2017.03.21
                        Time: 00:00:00
    Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003000000000
       Coding: 303142413039303030334A55304C38503053
       Shop #: WSC 06314 000 00000
       ROD: EV_Airba10AURB4.rod
       VCID: 49932E03E8AAB1097E-801C
       Serial number: 34928RB40000449FD52Y
       Serial number: 35028RB4000044A109EG
       Serial number: 35547RB40000462E464K
       Serial number: 35647RB40000462E472K
                        Mileage: 78968 km
                        Date: 2017.06.04
                        Time: 02:47:01
    9437467 - Igniter 2 for Driver's Airbag
                 B1001 1B [137] - Resistance Too High
                        Mileage: 78968 km
                        Date: 2017.06.04
                        Time: 02:47:01
                 U0155 00 [008] - -
                        Reset counter: 238
                        Mileage: 78561 km
                        Date: 2017.03.21
                        Time: 17:36:37
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0011102
       VCID: 41833623189A7949A6-8014
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
       Component: KOMBIINSTR. VDO H18 0830
       Revision: D0H18006    Serial number: 2249H006019103
       Coding: 0002128
       Shop #: WSC 20510 993 175101
       VCID: 448D3F3707886C618D-8010
                        Reset counter: 238
                        Reset counter: 238
                        Reset counter: 253
                        Mileage: 78951 km
                        Date: 2017.05.17
                        Time: 06:13:24
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K089250777
       Coding: ED801F061002020100
       Shop #: WSC 06314 123 12345
       VCID: 356B52F35C52C5E90A-8060
                        Fault Frequency: 134
                        Reset counter: 215
                        Mileage: 78957 km
                        Date: 2017.05.18
                        Time: 02:49:32
                        Reset counter: 215
                        Mileage: 78957 km
                        Date: 2017.05.18
                        Time: 02:49:32
       Revision: D0H18006    Serial number: AUX7Z0H9FN10GF
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
       Component: Tuer-SG         H03 0060
       Coding: 0000092
       VCID: 438F3C2B02866B59B4-8016
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 239    3501
       Revision: 00H17000
       VCID: 39735EC3704A2189EE-806C
       Part No: 8P0 959 433 K
       Component:    KSG          H11 0080
       Coding: 1880202002186D2D8505488AC677
       Component: Neigungssensor  005 0003
       Part No SW: 8P3 035 382 D    HW: 8P3 035 382 D
       Component: AB2 SUBWOOFERBOXH30 0160
       Revision: 00006       Serial number: 30659850321394
       VCID: 346D6FF75728DCE13D-8060
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
       Coding: 0000092
       Part No SW: 8P0 035 186 Q    HW: 8P0 035 186 Q
       Component: R Concert2+     H03 0270
       Revision: 00H03000    Serial number: AUZ1Z3H8964443
       Coding: 0130212
       VCID: 4085332713907041A9-8014
                        Reset counter: 238
                        Mileage: 78561 km
                        Date: 2017.03.21
                        Time: 17:36:37
                        Reset counter: 238
                        Mileage: 78561 km
                        Date: 2017.03.21
                        Time: 17:36:37
    00857 - CD Changer Unit (R41)
                        Reset counter: 238
                        Mileage: 78561 km
                        Date: 2017.03.21
                        Time: 17:36:37
    End-------------------------(Elapsed Time: 02:22)--------------------------
    Address 03: DTCs cleared
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Address 19,1K0 907 530 Q,recoded (Long Coding),from,ED801F061002020100,to,CD801F061002020100,(06314/123/12345),
    Address 19: DTCs cleared
    Address 19,1K0 907 530 Q,recoded (Long Coding),from,CD801F061002020100,to,ED801F061002020100,(06314/123/12345),
    Address 17,8P0 920 931 T,recoded (Short coding),from,0002128,to,0002128,(20510/993/175101),
    Address 17: DTCs cleared
    Address 17,8P0 920 931 T,channel 0,adapted from,---,to,000,
    Address 03,1K0 907 379 AP,recoded (Long Coding),from,11424012092700FB880D02E890190041B900,to,11424012092700FB880D02E890190041B800,(12345/123/119698),
    In ECU:
    In TCU:
    006243 - Powertrain Data Bus - Missing Message from Steering Angle Sensor
    In ABS:
    00778 - Steering Angle Sensor (G85) No Signal/Communication
    I think you're going to have to fix whatever is causing the Steering Angle Sensor to be incommunicado.
    Are all parts the correct ones for this car?
  3. Likes Ashraf6119 liked this post
    Mexico
    I assuming this is the right part for the vehicle, but there it did not happened with the previous steering rack and pinion. Is there a way to conding for not having the esp light on? Vehicle is a 100% track day vehicle.
    Mexico
    So far all wires seems to be ok, also part number is correct part for it. Any idea?.
    New User
    Jun 2017
    Is the steering angle sensor the same part as before? If it was removed from the vehicle, was it locked? Can the fault codes regarding steering wheel functions be removed when the wheel is connected? How did you inspect the wiring?
  7. Likes Jack@European_Parts, Uwe, Ashraf6119 liked this post
    Mexico
    Yes it is the same, I understand that steering angle sensor in this vehicle is just behind the steering wheel, correct?
    It was not removed from the vehicle and ca not know if it was locked or not.
    Yes it can be removed.
    Visually inspect the wiring as well as continuity with and ohm meter.
    Regards
    Ray
    Mexico
    Is there any procedure to check entire steering column communication? Or is there any procedure to check steering angle sensor functionality?
  10. #8
    Vőru, Estonia
    Does this even have a separate g85 sensor. My best guess, without diving into VIN code search is that g85 needs to be enabled in steering rack adaption along with other adaption chsnnels that cause the implausible signal faults.
    Volkswagen Golf MKV 2.0TDI-8V 4MOTION MY2007 SEAT LEON FR 1.8TSI MY2018 Some of the work I've done and cared to make a picture.
    Our webpage and Facebook page Heads up, it's in Estonian language.
    The world is my oyster...
  11. Likes Jetta ,97 liked this post
  12. #9
    Dallas (McKinney) ,TX ,USA
    I had Jetta with same faulty code and it turn out to be faulty Angel sensor.
    However , you need to make sure that car has Steering angle sensor, I think there was a cars made for ROW with out it ,and like mention above it need to correct in adaptation and Coding of module 44-Steering Assist.
    Immobilizer/ECU
    Mk6 cluster in Mk5 -CLIK
    email : marinmm2001@yahoo.com
  13. #10
    Vőru, Estonia
    Okay. Got over my lazyness and inserted VIN to PL24. According to it, it should have separate G85 sensor. From my experience, even if G85 is faulty the SWCM should broadcast G85 as a module to can network. Has something been tampered on this vehicle? - Like CAN wires in SWCM connector?
    What is the origin of the "new" rack? Used or Brand-New? Perhaps there is G85 also enabled in adaption and 2 G85 signal mixmatching with eachother?
  14. Likes Jack@European_Parts liked this post
