Odd missing ECU output from Skoda Fabia using VCDS Beta 17.4.2.3 ...
JulianHicks
Kent, UK
C?ID=265735
And another strange issue on a different car with the latest Beta!
Ran an Autoscan earlier today on my friend's Skoda Fabia as he had the ABS light permanently on in the instrument panel. I've only just fully analysed the log and noticed that one of the ECUs [46 Central Convenience] is totally missing from the log. Here's the whole log from earlier today:
Wednesday,07,June,2017,18:27:08:53697
VCDS Version: 17.4.2.3
Data version: 20170505 DS270.4
VIN: TMBHS46Y423342652   License Plate:
Chassis Type: 6Y (6Y - David-Fabia)
Scan: 01 03 08 09 15 17 19 44 46
VIN: TMBHS46Y423342652   Mileage: 154440km-95964miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 AF
   Component: 1,9l R4 EDC 0000SG  1110
   Coding: 00002
   Shop #: WSC 13765
   VCID: 5BB5F00DC9F4419F39-4B00
   TMBHS46Y423342652     SKZ7Z0A1071169
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ASR.lbl
   Part No: 6Q0 907 379 D
   Component: ABS/ASR 5.7 FRONT   V20
   Coding: 00188
   Shop #: WSC 13765
   VCID: 3E7359993AA674B73E-5124
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0760
   VCID: 72EBBDA93E7EE0D70A-5140
Address 09: Cent. Elect.        Labels: 6Qx-937-049-B.lbl
   Part No: 6Q1 937 049 B
   Component: BORDNETZ-SG.        1S31
   Coding: 25754
   Shop #: WSC 13765
   VCID: 3A7B5589268E589702-5140
   Part No: 1C0 909 601 C
   Component: 02 AIRBAG VW51        02
   Coding: 12338
   Shop #: WSC 13765
   VCID: 204F87E1A01222472C-5140
Address 17: Instruments        Labels: 6Yx-9xx-xxx-17.lbl
   Part No: 6Y2 919 880 D
   Component: KOMBIINSTRUMENT VDO V09
   Coding: 16441
   Shop #: WSC 23032
   VCID: 489F3F4168623A0784-5124
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    1S31
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70EFB7A13072D2C7FC-5140
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 00110
   VCID: 306F77A1F0F292C7BC-5124
00816 - Power Steering Sensor (G250)
            30-00 - Open or Short to Plus
End-------------------------(Elapsed Time: 01:42)--------------------------
and here's an earlier scan from the same car.
Thursday,09,March,2017,16:22:52:53697
VCDS Version: 17.2.4.0
Data version: 20170203 DS267.2
Dealer/Shop Name: VAG.Scans
VIN: TMBHS46Y423342652   Mileage: 152170km-94554miles
   Coding: 00002
   Shop #: WSC 13765
   VCID: 5BB5F00DC9F441986E-4B00
   Coding: 00188
   Shop #: WSC 13765
   VCID: 3E7359993AA674B069-5124
   VCID: 72EBBDA93E7EE0D05D-5124
   Coding: 25754
   Shop #: WSC 13765
   VCID: 3A7B5589268E589055-5140
   Coding: 12338
   Shop #: WSC 13765
   VCID: 204F87E1A01222407B-5124
   Coding: 16441
   Shop #: WSC 23032
   VCID: 489F3F4168623A00D3-5140
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70EFB7A13072D2C0AB-5140
   Coding: 00110
   VCID: 306F77A1F0F292C0EB-5124
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 C
   Component: 0F Komfortgerát     0003
   Coding: 00067
   Shop #: WSC 13765
   VCID: 3B75508D29B461984E-4B00
   Subsystem 1 - Part No: 6Q2959802
   Component: 0F Tõrsteuer.FS TFK 0002
   Subsystem 2 - Part No: 6Q2959801
   Component: 0F Tõrsteuer.BF TFK 0002
End-------------------------(Elapsed Time: 01:49)--------------------------
Will try and run Beta and latest Prod code later this week ...
Julian
The first thing I would do is cold-boot the CCM. Those old Komfortgerát modules sometimes got in a mode where they refused any diagnostic connections.
JulianHicks
Kent, UK
C?ID=265735
Sorry, Uwe; don't understand what you mean by a 'cold boot' of the CCM ECU. :confused:
However, I reran the tests with both latest Prod version and the latest Beta that Eric described elsewhere.
Both runs didn't find the 46 ECU and gave me no indication. However, I did run both with Debug=1024 so there are debug files which I zipped and which I am about to email to Support@.
By the way; when I ran the Prod code I got one of those 'No faults, DTC not supported, broken communication' messages [described in my other recent Thread] on an ECU on the Skoda that's always worked before. Hopefully the Debug file from that event is included in the Zip.
Julian
Removed all power from it for a bit. This can be done by unplugging the CCM from the car's harness, removing the appropriate fuses, or disconnecting the car's battery.
JulianHicks
Kent, UK
C?ID=265735
OK; got it now:)
The car is going in for the ABS repair to the right wheel sensor shortly, so I'll see what I can scan after that's done.
Thanks - Julian
Eric
HC800000
FWIW the debugs confirmed that 46 simply wasn't answering the wakeup command, whether with 17.1.3 or the beta at the time (17.5.1).
