Micro-CAN and Altrack
need2boat
C?ID=187860
I'm novice user, bought a Micro-CAN from ROss-Tech back in 2013 when I bought my Jetta sportwagen tdi. Sadly the car is headed but I'm excited about the Altrack on order. Wanted to find out if my Micro-CAN is compatible with the Altrack of if I would need to upgrade. Also Should I update the Ross Tech software before I give it a go on the new car. I'm mostly interested in the tweaks for the locks and lights I'm not a heavy user.
Thanks in advance and if I posted this to the incorrect section just let me know.
It will almost certainly talk to most of the systems in the vehicle, and quite possibly all of them, depending on equipment.
Absolutely use current software.
Then post an Auto-Scan and we should be able to tell you if anything is missing that would warrant an upgrade.
need2boat
C?ID=187860
Sounds good. It will be a few weeks before the TDI is gone and the new car comes home. Bitter sweet about the whole thing and just getting my ducks in row.
cheers
Joe
need2boat
C?ID=187860
OK I know it's been a wile but I've gotten the car and and updated to 17.1.3 with MICO-CAN. I've already used it a bit but the mod that I'm having issues getting the Windows open/close with keyfob button depressed. I've got a 2017 Alltrack that's keyless and can't seem to find any of the Access controls when I go Adaptation - 10 and pull down the channel list I'm not finding anything of these.
(2)-Access control 2-Comfort opening-> “active”
(3)-Access control 2-Comfort closing-> “active”
(7)-Access control 2-Funk Komfort oeffnen-> “active”
(6)-Access control 2-Funk Komfort schliessen-> “active”
(27)-Access control 2-Menuesteurung Komfortbedienung einstellbar -> “adjustable”
In head unit, Car - Setup - Open and Close - Conv. opening (all windows or drivers window)
---------------------------------------------- AUTO SCAN-----------------------------------
Wednesday,05,July,2017,21:13:20:07553
VCDS Version: 17.1.3.0
VIN: 3VWM17AU5HM540989   License Plate:
Mileage: 2043km-1269mi   Repair Order:
Chassis Type: AU (3Q0)
Scan: 01 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 5F 75
VIN: 3VWM17AU5HM540989   Mileage: 2043km-1269miles
Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 311900122426002F1000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS0208V0906264J_VW37.rod
   VCID: 46ADB04AF9BA6C7193-8012
23126 - ROD - Unknown Error Code
          - 00 [096]
                    Mileage: 188 km
                    Date: 2017.06.30
                    Time: 12:20:14
                    Engine speed: 2348.50 /min
                    Normed load value: 34.5 %
                    Vehicle speed: 119 km/h
                    Coolant temperature: 90 ∞C
                    Intake air temperature: 42 ∞C
                    Voltage terminal 30: 13.476 V
                    Unlearning counter according OBD: 30
                    Engine: operating status: PL
                    FTL_SAE: 96.86274669 %
                    selected gear: 6th gear
                    Fuel level: 52 l
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 50987000000650
   Coding: 43FA6AA13424096C4080030880CC29C2562C9002C001943C00435050E009430000010312121212B435351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
   VCID: 002166529B1E8241E9-8054
Address 05: Acc/Start Auth.
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 02020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 4AB5847AEDA2881177-801E
          B10CD 00 [008] -  -
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 6 km
                    Date: 2011.01.01
                    Time: 09:07:36
                    Voltage terminal 30: 12.1 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                    CAN input signal(s) status-Back-up light: OFF
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86418031700LH
   Shop #: WSC 00066 790 00224
   ROD: EV_BCMBOSCH_017.rod
   VCID: 07337D4EBE30B579A8-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170222  043 0551
   Serial number: 97022066170304152641
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S6Y17M02D22H01M36S19
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST001FK7V200000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST001FKA9J00000
   Coding: 191800
527872 - Transport Mode Active
          U1105 00 [008] - -
                    Fault Frequency: 79
                    Reset counter: 52
                    Mileage: 6 km
                    Date: 2011.01.01
                    Time: 09:04:16
   Serial number: 003GCR07Y4J-
   VCID: 47B3BD4EFEB0757968-8012
   Occupant Detection:
   Serial number: IBH0000000000073LKEP
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 503 17
   Serial number: 35700000000D3084D22H
   Subsystem 3 - Part No SW: -----------    HW: 480 001 503 17
   Serial number: 358000000009A785D22T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 502 17
   Serial number: 3510001C5249E3B3026
   Subsystem 5 - Part No SW: -----------    HW: 480 401 603 17
   Serial number: 3520001C124CDB22F76C
   Subsystem 6 - Part No SW: -----------    HW: 480 400 204 17
   Serial number: 3550002C524F3841C151
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 204 17
   Serial number: 3560002C524F3840C162
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 26031708490273
   Coding: 0400
   ROD: EV_SMLSKLOMQB_SK48.rod
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BA41015A180CF0502086A001000000000000000
   VCID: 266D10CA59FA8C71B3-8072
          U1110 00 [008] - -
                    Reset counter: 62
                    Mileage: 42 km
                    Date: 2017.06.29
                    Time: 17:08:37
   Part No SW: 3Q0 907 530 B    HW: 3Q0 907 530 B
   Component: GW MQB Mid    514 5286
   Serial number: 29041700840344
   Coding: 0901000870085900FB0020080A0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07025
   ROD: EV_GatewConti_013.rod
   VCID: 2E7DE8EA710AC4314B-807A
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29170000219640107057
   Coding: 30FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0301950
   Serial number: HA1-00017.11.16
   Coding: 0001
   Revision: 00000000    Serial number: 17000085835002
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3449FA829F26EEE13D-8060
   Serial number: 18041706050CQ4
   Coding: 003A13200000020000000000
   VCID: 43ABA95ECA885959B4-8016
   Serial number: 00000000000006219371
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4F83956E16C0AD3920-801A
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H30 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA0344Q1
   VCID: 6DFF2FE6BC8C7F2932-8038
   Serial number: 2404170605015L
   VCID: 42A5AC5AD5925051BF-8016
   Serial number: 00000000000006067698
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 027302000000000051220002001808009F0108F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D7FEFE67C0CBF2972-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW02J39
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0570
   Coding: 02730202C2823A017F1E06020000
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:56)--------------------------
Address 17,5G1 920 840 B,channel IDE03867-Deactivate seat belt warning,adapted from,No ,to,Yes ,
Address 17,5G1 920 840 B,channel IDE06588-Ignition active message: actuator,adapted from,Driver door ,to,No display ,
DV52
C?ID=194404
need2boat: Hi and I repeat - I don't have the answer to your question - but just as a hunch, I suspect that your solution isn't in the "ZV Komfort" group (because the adaptation channels in your list relate to the general operation of the locking/unlocking facility) -but I'm guessing.
Just as an alternative suggestion, try playing with the specific sunroof channels in the BCM. Not sure if you are aware, but VW calls the sunroof "SAD" in these channels - I have no idea why since the German for sunroof is "Sonnendach".
So here are the SAD channels in the BCM:
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen​
If you are using OBD11, just ignore the leading "tags" and search for the "Parent" name" Access control 2
My guess (and it's just a guess) is that the highlighted channel above is your best-bet. Try setting this channel to not-active (again a guess)
