Results 1 to 5 of 5
Thread: audi a3
    Oct 2016
    audi a3
    16 reg, etron. car was in accident, front pass corner damaged, replaced headlight, but headlight will not work. I run basic settings which is all fine. been told it needs coding in some way for light to work, can anyone help.
    I run a full scan of car but were can I post it.
    Oct 2016
    here are the faults in headlight range module.
    5545200 - Output Stage for LED Headlamp; Left
    B149C F0 [137] - Not Coded
    Reset counter: 112
    Mileage: 5644 km
    Date: 2017.05.19
    Time: 02:27:55
    5335041 - Fan 2 for Left Headlamp
    C1168 01 [137] - Electrical Failure
    Reset counter: 112
    Mileage: 5644 km
    Date: 2017.05.19
    Time: 02:27:55
    5275648 - Left/Right Driving Switch-Over Active
    C1080 00 [009] - -
    Reset counter: 112
    Mileage: 5644 km
    Date: 2017.05.19
    Time: 02:27:55
    Please post a complete Auto-Scan for context.
    Oct 2016
    VIN: WAUZZZ8V7GA029305   License Plate: BU16OPT
    Mileage: 5644km-3507mi   Repair Order: mouse
    Chassis Type: 8V (5QE)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75
              8C BB BC C6
    VIN: WAUZZZ8V7GA029305   Mileage: 5644km-3507miles
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-CUKB)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AF    HW: 04E 907 309 F
       Component: 1.4l TFSI hy  H21 1602
       Revision: X3H21---
       Coding: 021D0012630401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906023AF 005004
       ROD: EV_ECM14TFS01104E906023AF_005.rod
       VCID: 64C77D356FFD91616D-8030
    Readiness: 1110 0001
    Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
       Part No SW: 0DD 300 045 L    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1110
       Revision: 00031033    Serial number: TFK01504290271
       Shop #: WSC 00099 780 00200
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021.rod
       VCID: 306FC1656B857DC159-8064
    18 Faults Found:
    32317 - Unknown Error Code
              U04B5 00 [002] - -
    10893 - Implausible Data Received from Battery Energy Control Module 2
              U0413 00 [002] - -
    60354 - ROD - Unknown Error Code
              - 00 [002]
    60355 - ROD - Unknown Error Code
              - 00 [002]
    60356 - ROD - Unknown Error Code
              - 00 [002]
    60357 - ROD - Unknown Error Code
              - 00 [002]
    60358 - ROD - Unknown Error Code
              - 00 [002]
    60359 - ROD - Unknown Error Code
              - 00 [002]
    60360 - ROD - Unknown Error Code
              - 00 [002]
    60361 - ROD - Unknown Error Code
              - 00 [002]
    60362 - ROD - Unknown Error Code
              - 00 [002]
    60363 - ROD - Unknown Error Code
              - 00 [002]
    60364 - ROD - Unknown Error Code
              - 00 [002]
    60365 - ROD - Unknown Error Code
              - 00 [002]
    60366 - ROD - Unknown Error Code
              - 00 [002]
    60367 - ROD - Unknown Error Code
              - 00 [002]
    60368 - ROD - Unknown Error Code
              - 00 [002]
    60369 - ROD - Unknown Error Code
              - 00 [002]
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
       Component: ESC           H31 0809
       Revision: 00000000    Serial number: 61805000001653
       Coding: 12F180A238223275017A060041C82948011C4C80608294F400A100788608
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
       VCID: 050140B184870869DA-8050
       Revision: 00021000    Serial number: 0373603503
       Coding: 030C0C
       VCID: 3A7BE34DBDF9B791E7-806E
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Part No SW: 8V0 820 043 G    HW: 8V0 820 043 G
       Component: AC Automat    H05 0040
       Revision: 20010000    Serial number: 00000000680232
       Coding: 0310000000000000000000000000100001000000
       ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
       ROD: EV_AirCondiFrontRDWAU37X.rod
       VCID: 3663F77D89E153F103-8062
       Subsystem 1 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
       Component: J848 HV-PTC  H09 0206
       Serial number: LM151973003807000080
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 61C888B7000000000001
       Subsystem 3 - Part No SW: 12E 820 803 E    HW: 12E 820 803 E
       Component: J842 eKK  H02 0005
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 AR    HW: 5Q0 937 084 AM
       Component: BCM MQBAB M+  H24 0175
       Serial number: 01061518300906
       Coding: 07051C46C25106FD038C5004B31407A80800000000000000000000000000
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 081F4985B3951501A1-805C
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150701  042 0580
       Serial number:         150704095216
       Coding: 0A47F7
       Serial number: 24072843
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 03 05 2015  00000664
       Serial number: 000000000ZY151612QBG
       Serial number: 00000000000032956532
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39291517103231
       Coding: 0000040011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 3C77E555B7CD89A1F5-8068
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR0118ZQ
       Coding: 98CCC0000C2000009C5400CA00C800000065
       VCID: 50AFA1E50B451DC139-8004
       Subsystem 1 - Part No SW: -----------    HW: 480 000 807 15
       Serial number: 357000000009019C751G
       Subsystem 2 - Part No SW: -----------    HW: 480 000 807 15
       Serial number: 35800000000CF09C751Y
       Subsystem 3 - Part No SW: -----------    HW: 480 400 907 15
       Serial number: 3510002AB1B7E8F2922H
       Subsystem 4 - Part No SW: -----------    HW: 480 400 907 15
       Serial number: 3520002B91B7E8F5521F
       Subsystem 5 - Part No SW: -----------    HW: 480 401 706 15
       Serial number: 3550002B91B5A872F2FP
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 906 15
       Serial number: 2280002BF1B65D50D35G
       Subsystem 7 - Part No SW: -----------    HW: 480 402 906 15
       Serial number: 2290002C31B65D537375
       Subsystem 8 - Part No SW: -----------    HW: 480 001 106 15
       Serial number: I0M000000004518DB411
       Subsystem 9 - Part No SW: -----------    HW: 480 001 106 15
       Serial number: I0N000000002318DB41+
    9451547 - Igniter 1 for pedestrian protection
              B1038 1B [137] - Resistance Too High
                        Mileage: 5644 km
                        Date: 2017.05.19
                        Time: 02:31:34
    9451803 - Igniter 2 for pedestrian protection
              B1039 1B [137] - Resistance Too High
                        Mileage: 5644 km
                        Date: 2017.05.19
                        Time: 02:31:34
       Part No SW: 8V0 953 521 ET    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 09061504220625
       Coding: 8418
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 102F61E5CBC55DC179-8044
       Part No SW: 8V0 920 972 E    HW: 8V0 920 972 E
       Component: KOMBI         H03 6421
       Coding: 27040C182B8026000103E8101200000000000000
       VCID: 408F91A5DB25ED41A9-8014
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5QE 907 530 D    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3225
       Revision: --------    Serial number: 28061510800304
       Coding: 0201001726F200005B001208580000000001010100010000000000000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013.rod
       VCID: 479D8AB9FE0BDA7968-8012
       Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 25 06 2015  D0067298
       Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
       Serial number: 3418827103
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
       Component: EBKV          H14 0182
       Serial number:   085430010331
       Coding: 03720100331902030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
       ROD: EV_BrakeBoostBoschMQBOMG_003.rod
       VCID: 4FADA299167B023920-801A
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861030715140819
       Revision: 00000000    Serial number: 15000173066007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_SK25.rod
       VCID: 3467CD759F9D41E13D-8060
       Serial number: 290615BFR19636
       Coding: 00109E205C01040000001002
       Shop #: WSC 06385 790 00021
       VCID: 43859EA9CA33F659B4-8016
       Component: EPS_MQB_ZFLS  125 1061
       Coding: C102
       ROD: EV_SteerAssisMQB_VW31.rod
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
       Component: VW370P3815010 H06 4492
       Revision: 00H06000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM09550115G0907080D 001018
       ROD: EV_DMCM09550115G0907080D.rod
       VCID: 285F29055355350181-807C
       Serial number: 260615BFP15139
       Coding: 001096205E01040000001002
       VCID: 428B9BADD529FF51BF-8016
       Coding: 011E00002B230200
       ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
       VCID: 3F8D9259A6DB92B9D0-806A
       Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7570
       Coding: 1F1F00
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 7050
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 7050
       Coding: E00100
                        Reset counter: 112
                        Mileage: 5644 km
                        Date: 2017.05.19
                        Time: 02:27:55
                        Reset counter: 112
                        Mileage: 5644 km
                        Date: 2017.05.19
                        Time: 02:27:55
              C1080 00 [009] -  -
                        Reset counter: 112
                        Mileage: 5644 km
                        Date: 2017.05.19
                        Time: 02:27:55
    Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-HGH1.clb
       Part No SW: 8V0 035 036 E    HW: 8V0 035 036 B
       Component: MU-H-LND-EU   H45 0397
       Serial number: A300G0F7551743
       Coding: 01739301FF00000021111101000A02102F00010701000100DE
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 Q    HW: -----------
       Component: ECE 2015/2016  --- 0122
       Component: DU High  H49 0014
       Serial number: AUZ8Z9FY203M0X
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
       Component: ControlUnit_H  H81 0816
       Serial number: C1000015051500020110
       Component: Gracenote  --- 1010
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Part No SW: 5QE 035 284 A    HW: 5QE 035 284 A
       Component: OCULowMQBEU   008 0561
       Coding: 0173930110809A0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
       Component: BECM          H05 0652
       Serial number: T4080016
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006036
       ROD: EV_BECM06020115C6915182_VW37.rod
       VCID: 3365CE699A9346D924-8066
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
       Component: BJB  H27 0240
       Cell Module Controller 1:
       Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0472
       Serial number: V013C1561320742
       Cell Module Controller 2:
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0472
       Serial number: V013C1561320743
       Cell Module Controller 3:
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0472
       Serial number: V013C1561320741
       Cell Module Controller 4:
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0472
       Serial number: V013C1561320732
       Cell Module Controller 5:
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0472
       Serial number: V013C1561320731
       Cell Module Controller 6:
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0472
       Serial number: V013C1561320730
       Cell Module Controller 7:
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0472
       Serial number: V013C1561320728
       Cell Module Controller 8:
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0472
       Serial number: V013C1561320729
    Address BB: Door Rear Drv (J388)       Labels: None
       Serial number: 200615BFJ15543
       Coding: 000096204001040000001002
       VCID: 458180B1C407C8699A-8010
    Address BC: Door Rear Pass (J389)       Labels: None
       Serial number: 200615BFJ15546
    Address C6: Batt. Chrg. (J1050)       Labels: None
       Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
       Component: OBC KOSTAL    H61 3017
       Revision: --------    Serial number: 2506150FP000QZ
       Coding: 115068203000
       ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
       ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
       VCID: 0C177595A7ED792185-8058
    End-------------------------(Elapsed Time: 05:38)--------------------------
    Try recoding the main 55 module with the coding that's already there: 011E00002B230200. I think the sub-systems get coded when the main module does.
  6. Likes Radiosolutions liked this post
