Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Incorrect labels
    Why do you think you need a scan tool to get the timing belt right?
  2. #12
    Verified VCDS-Lite User
    Jun 2017
    Because I want to check all the values before I start to ensure they are the same when I've finished. I have seen that block 093 shows how far out the cams are and I want to get them exactly right after I've replaced the belt. I have all the locking tools etc but I want to get it as perfect as possible and thought VCDS could help achieve that.
    Should I not bother? Also I'm sure that in future I will need to observe other measuring blocks and it seems my engine is mapped differently from the others so it renders VCDS no help except diagnosing DTCs.
    I hope that's clear! Appreciate your help!
    Russell
  3. #13
    Disclaimer: I'm not a professional mechanic, just a guy who decided to make a scan tool affordable enough that people could work on these cars themselves. But here's my two cents:
    A timing belt on an engine like that isn't an "analog" or "stepless" thing. You either have it positioned right, or you're off one or more teeth on one of the sprockets. If you're off one or more teeth, my experience is that it will run like crap (if at all).
    A scan tool is used on VE TDI engines to set the pump timing, which is indeed stepless.
    The blocks you're looking for in the 09x range are used to check the timing of the cams on engines that have variable valve timing by means hydraulic of actuators in the head. They are not used to check the that the timing belt is set up correctly.
    Someone please correct me if I'm wrong about any of this.
  4. #14
    Jun 2017
    And the community loves you for it! A great tool that unlocks the potential of what's possible for the diyer.
    Thank you for the clarification. I was alerted to using the scan tool on the forum thread below:
    http://www.audizine.com/forum/showth...ition-question
    I guess they are talking about the diesel version.
    Thanks for the advice anyway.
    Russell
  5. #15
    Jun 2017
    Answered my own question by creating a label file in VCDS.
    If you have an ACK engine and use VCDS then find the label folder and file 078-907-551-ACK.lbl. Then replace the text in the file with this:
    ; VCDS Label File
    ; Audi A4 (8D) / Audi A6 (4B)
    ; Component: Engine (#01) - ACK/ALG/APR
    ; P/N: 4D0-907-551-???
    ; includes coding and adaptation
    ; This file is part of a redirection package,
    ; make sure you have all of the following files.
    ; 4D-01.LBL
    ; 078-907-551-ACK.LBL  (2.8l E   @ 193 HP - ACK/ALG/APR)
    ; created on 26/Mar/2008 by Sebastian Stange (Sebastian@Ross-Tech.com)
    ;amended on 1/Dec/2017 by Russell Hammond(russell.hammond@virgin.net
    ; last modification: 1/Dec/2017
    ; requires VCDS 803.0 or newer
    ; measuring blocks & basic setting
    000,0,General
    000,1,Coolant Temp G62,,Specification: 177...203 (85.0...105.0 C)
    000,2,Engine Load,,Specification: 21...34 (15.0...26.0 %)
    000,3,Engine Speed G28,,Specification: 67...73 (650...750 RPM)
    000,4,Throttle Valve,Angle,1...7 (0.40...2.75 %)
    000,5,idling spd ctrl,,Specification: 126...135 (-1.5...+1.5 %)
    000,6,Learned value,air mas idling spd,Specification: 124...140 (-3.0...+5.0 %)
    000,7,Mixture Ad cntrl,Bank 1 Value,Specification: 122...136 (-4.0...+4.0 %)
    000,8,Mixture Ad cntrl,Bank 2 Value,Specification: 122...136 (-4.0...+4.0 %)
    000,9,Mixture Ad learnt,Bank 1 Value,Specification: 108...148 (-4.0...+4.0 %)
    000,10,Mixture Ad learnt,Bank 2 Value,Specification: 108...148 (-4.0...+4.0 %)
    001,0,Basic function ign timing
    001,1,Idle Speed,620-740A/+120F
    001,2,Engine load,, (injection period per crankshaft revolution)
    001,3,Thrttle valve ang,0...5 <
    001,4,Ignition timing,9...15
    002,0,Basic function MAF reading
    002,1,Engine Speed,(G28),Range: 0...6800 RPM\nSpecification (Idle): 620...860 RPM
    002,2,Engine load,1.0...2.5, (injection period per crankshaft revolution)
    002,3,Injection period ,1.0...4.0, (per engine cycle)
    002,4,Intake air mass,3.0...5.0
    ;003 usually 004
    003,0,Basic function temps
    003,1,Engine speed
    003,2,Battery voltage,10..14.5
    003,3,Coolant temp, 80..105
    003,4,Intake air temp
    ;004 usually 003 or 005
    004,0,Idling speed state
    004,1,Thrttle valve ang,0....5
    004,2,Idling air mass,-0.7...+0.7, learned (automatics: not in drive position)
    004,3,Idling air mass,-0.7...+0.7, learned (automatics: drive engaged)
    004,4,Operating state,, Idling Part throttle Full throttle Overrun Enrichment
    005,0,Idling speed stabilisation
    005,1,Engine speed act
    005,2,Engine speed spec
    005,3,idle speed cntrl,-10...+10,Control value for idling speed stabilisation
    005,4,Air mass,3.0...5.0
    ; 006 usually 001
    006,0,short term fuel trim,Low values=too rich High values=too lean
    006,1,Idling speed
    006,2,idle speed cntrl,-10...+10,Control value for idling speed stabilisation
    006,3,Bank 1,-10...+10,Lambda control
    006,4,Bank 2,-10...+10,Lambda control
    ;007 usually 032
    007,0,learnt fuel trim,Low values=too rich High values=too lean
    007,1,Bank 1 part,-10...+10, part throttle multiplicative
    007,2,Bank 2 part,-10...+10, part throttle multiplicative
    007,3,Bank 1 idle,-10...+10, idle additive
    007,4,Bank 2 idle,-10...+10, idle additive
    008,0,Lambda/o2 learned values with speed
    008,1,Idling speed
    008,2,Inj period,1.00...3.00, per engine cycle
    008,3,Bank 1 idle,-10...+10, idle additive
    008,4,Bank 2 idle,-10...+10, idle additive
    ;009 usually 033
    009,0,Lambda/02 voltage
    009,1,Bank 1,0.00...1.00,rich = 0.7...1.1.lean=0.0...0.3 V.
    009,2,Bank 2,0.00...1.00,rich = 0.7...1.1.lean=0.0...0.3 V.
    009,3,charc filtr valve,0...99 %,0% closed 99% open
    009,4,correction,0.6...1.1,0.6-1 too too rich 1.01 and 1.10 too lean
    ;010 usually 070
    010,0,Fuel tank breather
    010,1,charc filtr valve,0...99 %,0% closed 99% open
    010,2,filter correction,0.6...1.1,0.6-1 too too rich 1.01 and 1.10 too lean
    010,3,Filter fill level,-5...+95,-5 no vapours +95 completely full
    010,4,intake rate,0.00...1.50,proportion of intake coming from filter
    011,0,Fuel consumption
    011,1,Engine speed
    011,2,Engine load,1.0...2.5, (injection period per crankshaft revolution)
    011,3,Road speed,km/h
    011,4,Fuel consumption,0.8...1.8 ltr./h
    ;012 usually 022
    012,0,Knock control with speed
    012,1,Engine speed
    012,2,ign timing retard, cylinder 1,0...12
    012,3,ign timing retard, cylinder 2,0...12
    012,4,ign timing retard, cylinder 3,0...12
    013,0,Knock control with load (must be +40%)
    013,1,Engine load, 0...10 ms
    013,2,ign timing retard, cylinder 1,0...12
    013,3,ign timing retard, cylinder 2,0...12
    013,4,ign timing retard, cylinder 3,0...12
    ;014 usually 023 and 024
    014,0,Knock control with speed
    014,1,Engine speed
    014,2,ign timing retard, cylinder 4,0...12
    014,3,ign timing retard, cylinder 5,0...12
    014,4,ign timing retard, cylinder 6,0...12
    015,0,Knock control with load (must be +40%)
    015,1,Engine load, 0...10 ms
    015,2,ign timing retard, cylinder 4,0...12
    015,3,ign timing retard, cylinder 5,0...12
    015,4,ign timing retard, cylinder 6,0...12
    016,0,speed load timing,retard the ignition timing as soon as pinking also mixture is enriched
    016,1,Engine speed
    016,2,Engine load,0...10 ms
    016,3,Ignition timing, -20...+40
    016,4,Total ign retard,0.0...72.0
    017,0,knock sensor,more than 50 % between smallest and largest signals could be corrosion on connector.
    017,1,Engine speed
    017,2,volts cylinder 1,0.50...1.40
    017,3,volts cylinder 2,0.50...1.40
    017,4,volts cylinder 3,0.50...1.40
    018,0,knock sensor,more than 50 % between smallest and largest signals could be corrosion on connector.
    018,1,Engine speed
    018,2,volts cylinder 4,0.50...1.40
    018,3,volts cylinder 5,0.50...1.40
    018,4,volts cylinder 6,0.50...1.40
    019,0,Torque reduction
    019,1,Engine speed
    019,2,Engine load,0.0...10.0
    019,3,Required,0...410, torque required to shift gear
    019,4,Actual,-100...300, actual torque
    ;020 usually 050
    020,0,Operating conditions
    020,1,Engine speed
    020,2,Gear selector pos, Neutral or Gear
    020,3,air con idle spd,incr func status,speed is increased when batt v is low.
    020,4,Aircon compressor,, Compr.ON or Compr.OFF
    021,0,Operating conditions for lambda control
    021,1,Engine speed
    021,2,Engine load,0.0...10.0, injection period per crankshaft revolution
    021,3,Coolant temp, min 55
    021,4,Lambda control, OFF/ON,If Lambda control off engine controlled by engine map.
    022,ignore
    023,0,Throttle valve positioner adaption
    023,1,learning status,01000000
    023,2,Min. stop,72...95 %,of throttle valve positioner
    023,3,Emergency stop,60...92 %,of throttle valve positioner
    023,4,Max. stop,34...70 %, of throttle valve positioner
    024,0,Traction control,,When loss of traction is recognised how the engine torque is reduced to prevent wheel spin can be assessed in this display group
    024,1,Engine speed
    024,2,rdction stages,0 ... 12
    024,3,ABS Reqd torque,-100...410
    024,4,Actual torque,-100...300
    025,0,system status,The display shows which systems are being activated by the engine control unit
    025,1,Engine speed
    025,2,Engine load,0.0...10.0
    025,3,System status,123,1 Energy statement for heating-up Cat 2 Intake manifold change-over 3 Camshaft adjustment
    025,4,(Unallocated)
    ;026 usually 090
    026,0,Camshaft timing,To bring the camshaft into the adjusted position accelerate the vehicle in 1st gear from rest
    026,1,Engine speed
    026,2,Engine load,0.0...10.0
    026,3,cam timing, cntrl bank 1,-3.0 ... 6.0 idle 16.0 ... 25.0 adjusted
    026,4,cam timing, cntrl bank 2,-3.0 ... 6.0 idle 16.0 ... 25.0 adjusted
    027,0,Camshaft timing system
    027,1,system status,123,1 Energy statement for heating-up Cat 2 Intake manifold change-over 3 Camshaft adjustment
    027,2,(unallocated)
    027,3,cam timing, cntrl bank 1,-3.0 ... 6.0 idle 16.0 ... 25.0 adjusted
    027,4,cam timing, cntrl bank 2,-3.0 ... 6.0 idle 16.0 ... 25.0 adjusted
    028,0,ignore until 095
    095,0,Basic Function load timing and coolant
    095,1,Engine speed
    095,2,Engine load,0.0...10.0
    095,3,Ignition timing,12.0
    095,4,Coolant temp,-40...125
    096,0, ignore
    097,0, ignore
    ;098 similar to 003
    098,0,Throttle valve potentiometer
    098,1,voltage,0...5
    098,2,idling pos volts,0...5
    098,3,state, idling / part load
    098,4,Adaption status,in prog OK or ERR,adaption of throttle valve control part
    099,0,Lambda control , the lambda mixture control is de-activated when in "Basic setting" mode and activated when selected in "Read measured value block" mode
    099,1,Engine speed
    099,2,Coolant temp
    099,3,Lambda mixture control,-10...+10
    099,4,Basic setting, ON/OFF,press keys 4 & 8 to switch between "Basic setting" and "Read measured value block".
    ; coding
    C00,Engine (J220) Coding
    C01,??xxx: Emissions
    C02,02 = MVEG I (non-EU Members)
    C03,04 = MVEG II (EU Members)
    C04,05 = MVEG III (with Sec. Air Injection)
    C05,08 = China and Russia/GUS
    C06,xx?xx: Powertrain
    C07,0 = Front-Wheel-Drive without ASR
    C08,1 = Front-Wheel-Drive with ASR
    C09,2 = All-Wheel-Drive without ASR
    C10,3 = All-Wheel-Drive with ASR
    C11,xxx?x: Transmission
    C12,0 = 5-Speed Manual Transmission
    C13,5 = 5-Speed Automatic Transmission (01V)
    C14,xxxx?: Model
    C15,1 = Audi A4 (8D)
    C16,2 = Audi A6 (4B)
    C17,3 = Audi A8 (4D)
    ; adaptation
    A001,0,Idle Speed
    A001,1,Engine Speed,(actual)
    A001,2,Engine Speed,(specified)
    A001,3,A/C Readiness,,Range: A/C-Low / A/C-High
    A001,4,A/C Compressor,,Range: Compr.OFF/Compr.ON
    A091,0,Immobilizer Status
    A091,5,Immobilizer Status (Read Only)
    A091,6,0 = Immobilizer not matched (NEW)
    A091,7,1 = Immobilizer disabled
    A091,8,4 = Immobilizer matched (System OK)
  6. Likes Uwe, PetrolDave liked this post
  7. #16
    Quote Originally Posted by scaphan View Post
    May we include your changes in the label file set distributed with VCDS?
  8. Likes PetrolDave liked this post
  9. #17
    Jun 2017
    Yes sure. Happy to help.
  10. Likes PetrolDave liked this post
