Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 104
Thread: 2007 Passat with 2.5L 5-Cyl. Engine - ABS Coding?
  1. #21
    Mar 2015
    Australia
    If you change the ABS coding, it will require you to perform these again.
    So no need to calibrate these sensors until you have a valid ABS coding string that results in no more 'control module incorrectly coded' error
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|DAB RNS|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0
  2. #22
    Jun 2017
    Forgive my stupid questions ... I've only had VCDS for about a week, this is all new to me!
    So, when I'm changing the ABS coding, am I actually changing (rewriting) it in the ABS module itself? ... so it will communicate with the Jetta ECU? (through the CAN bus I assume).
  3. #23
    Mar 2015
    Australia
    I'm no expert no matter how fast and loose you want to play with the definition of the term, but have had to play with ABS coding quite a bit of late with an adaptive cruise retrofit.
    Yes when you change the coding you are updating the EEPROM config in the ABS module itself.
    ABS and ECU communicate with one another over the powertrain CANbus.
    The ECU will log a fault in sympathy with the ABS to show that there is a DTC on the ABS. But once the ABS is clear of faults you can erase all other faults that may have resulted from the incorrectly coded ABS module.
  4. Likes Uwe liked this post
  5. #24
    Jun 2017
    I'll have to get into this tomorrow.
    Many moons ago I put a 1968 6-cyl. Porsche flat 6 into a VW based dune buggy. 4 bolts held it in ... some ignition wires, generator wires (or was it an alternator?), and an oil pressure wire ... voila, it was done!
    Ah, for the good old days of VW engine swaps!
  6. Likes NZDubNurd, Uwe, kamold liked this post
  7. #25
    Quote Originally Posted by kamold View Post
    I feel the need to be pedantic here. VCDS asks the software it the module to update the EEPROM. The software in the module has a lot of plausibility checks in it, as evidenced by the fact that it rejects some values. In any case, that's not the same as updating the EEPROM config directly...
  8. Likes Ashraf6119 liked this post
  9. #26
    Mar 2015
    Australia
    Thank you for the clarification
  10. #27
    Jun 2017
    Well, the VCDS is fine, I did three scans today. Don't know what the problem was yesterday.
    I worked on the p2279 problem today. What's interesting is, if you disconnect the wire for the MAF/IAT ... the engine idles fine (probably in loop mode). I had another MAF/IAT sensor and switched them out ... no change. I also checked all the intake hoses, dip stick tube, and the air box ... didn't see any visible problems. I'll have to check the MAF/IAT fuse tomorrow, I forgot to do that.
    With the MAF/IAT disconnected, I continued on my search for a working code for the ABS. I found that I don't actually have to start the engine to read the faults for the newly programmed ABS codes. But after going through about 100 codes ... I think I need to find better way, a more scientific approach ... this would take FOREVER!
    I thought I read somewhere, that you can get VW codes direct from VW on-line ... is that true, or do I need to be a dealer?
    What I don't understand is, before I got VCDS ... I had no faults or dash lights for the steering G85 ... now, after I've made some VCDS changes, I do have a dash light ... and no power assist?
    At the end of the day today, I just disabled the ABS ... no more dash lights! I'll deal with the ABS later, after I get the engine issues resolved.
    Here's my last VCDS scan of today (I had my interior light fuse out when I was doing my coding - I also have no idea why I'm now getting a clutch peddle code F36, I never had it before!) ...
    Thursday,08,June,2017,14:06:56:23114
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    VIN: WVWBA71K78W315062   License Plate:
    Chassis Type: 1K (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 6D
              72
    VIN: WVWBA71K78W315062   Mileage: 219140km-136167miles
    03-ABS Brakes -- Status: Not registered 0011
    65-Tire Pressure -- Status: Not registered 0011
    Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
       Component: 2,5l R5/4V      G   1567
       Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
       Coding: 0000003
       Shop #: WSC 01279 785 00200
       VCID: 72BED2CB78AA85372BD-8026
    050197 - Implausible Data Received from ABS Control Module
                   U0415 - 008 -
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:21:08
                        Temperature: 56.0C
                        Temperature: -40.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 12.192 V
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 002 - Signal too High - MIL ON
                        Fault Status: 11100010
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:21:12
                        Temperature: 56.0C
                        Temperature: -40.0C
                        Voltage: 12.192 V
    005171 - Secondary Air Pump Relay (J299)
                   P1433 - 004 - Open Circuit - Intermittent
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:34:01
                        RPM: 273 /min
                        Load: 72.1 %
                        Temperature: 79.0C
                        Temperature: -40.0C
                        Voltage: 10.668 V
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 002 - Signal too Low - MIL ON
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:34:01
                        RPM: 283 /min
                        Load: 71.0 %
                        Temperature: 53.0C
                        Temperature: -40.0C
                        Voltage: 10.922 V
    001393 - Brake Switch (F)
                   P0571 - 008 - Implausible Signal
                        Mileage: 219140 km
                        Date: 2016.01.22
                        Time: 01:55:58
                        RPM: 761 /min
                        Load: 44.3 %
                        Speed: 8.0 km/h
                        Temperature: 72.0C
                        Temperature: -40.0C
                        Voltage: 14.224 V
    Readiness: 0110 1101
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
       Component: AQ 250 6F           1068
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 08114 444 84076
       VCID: 005A88034606A7A72D9-8054
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
       Component: ESP 440 C2     H015 0004
       Revision:  H015       Serial number: 0100005710
       Coding: 0013150
       Shop #: WSC 05311 000 00000
       VCID: 323E12CBB82AC537EBD-8066
                        Reset counter: 49
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:49:47
                        Reset counter: 49
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:49:47
                        Reset counter: 49
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:49:47
       Part No: 1K0 820 047 EB
       Component: Climatic PQ35   090 0505
       VCID: 688AB0A34E767FE7859-803C
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Revision: 00H46000    Serial number: 00000005468122
       Coding: 008C0F0340041A00470A00000F00000000285D435C0000
       Shop #: WSC 05311 123 12345
       VCID: 372823DF5348201FDC3-8062
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 05311
    02399 - Control Circuit for Terminal 30 for Interior Illumination
                009 - Open or Short to Ground
                        Fault Status: 01111001
                        Reset counter: 50
                        Mileage: 219137 km
                        Date: 2016.01.21
                        Time: 00:13:00
                        Voltage: 12.80 V
    00059 - Terminal 30 for Interior Lighting
                        Reset counter: 50
                        Mileage: 219137 km
                        Date: 2016.01.21
                        Time: 00:00:00
                        Voltage: 12.75 V
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0N AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3P2W7PWA
       Coding: 0012366
       Shop #: WSC 05311 000 08193
       VCID: 2E0606BBAC12E1D78F5-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000032EPS
       Subsystem 3 - Serial number: 0001.01.000000600000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME0E716159E†63
       Subsystem 5 - Serial number: 16159E†6342MSME105B60746†63
       Subsystem 6 - Serial number: B60746†6351HTS64IKQTM627†63
       Subsystem 7 - Serial number: QTM627†6361HTS6TLLE15C3U†63
       Subsystem 8 - Serial number: E15C3U†63727TS63IK2T6C39†63
       Subsystem 9 - Serial number: 2T6C39†63827TS63IKEPNQ25
       Subsystem 10 - Serial number: EPNQ25
       Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
       Revision: 00005000    Serial number: 3C9953507R
       Coding: 0002014
       VCID: 313C1DC7BD2CFE2F927-8064
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Revision: V0033000    Serial number: 00000000000000
       Coding: 0007205
       Shop #: WSC 01119 067 57207
       VCID: 333017CF4730CC3FE0B-8066
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0631304F6
       Coding: 3BFD0C0CD22002
       VCID: 211CED87EDCC4EAF027-8074
                        Reset counter: 50
                        Mileage: 219137 km
                        Date: 2016.01.22
                        Time: 01:46:17
       Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
       Component: Kompass         001 0002
       Revision: 00001000    Serial number: 1339817TQ3XP02
       Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
       Component:    IMMO         041 0364
       Revision: 00041000    Serial number: VWZCZ000000000
       Shop #: WSC 64713 001 1048576
       VCID: 2A0E0AAB90FA8DF753D-807E
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2801
       Coding: 0001205
       VCID: 36362EDB5442D917C75-8062
       Part No: 1K1 909 144 K
    02546 - Steering Limit Stop
                        Mileage: 9080 km
                        Temperature: 27.0C
                        Voltage: 14.60 V
                        Voltage: 14.30 V
       Component:    KSG PQ46 RDK 041 0213
       Coding: 13900E88D1032E521804141FF00A0F0E081800
       Part No: 1K0 959 702 K
       Coding: 0001204
       Revision:   013
       Coding: 0000013
                        Fault Status: 00101101
                        Reset counter: 90
                        Mileage: 219136 km
                        Date: 2016.01.22
                        Time: 01:51:33
                        Voltage: 14.18 V
                        Count: 236
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 50
                        Mileage: 219136 km
                        Date: 2016.01.22
                        Time: 01:32:30
                        Voltage: 12.21 V
                        Count: 172
    00650 - Clutch Pedal Switch (F36)
                        Fault Status: 00101010
                        Fault Frequency: 16
                        Reset counter: 90
                        Mileage: 219120 km
                        Date: 2016.01.20
                        Time: 20:00:48
                        Voltage: 13.25 V
                        Count: 71
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
       Component: Radio DE2       012 0015
       Revision: 00012000    Serial number: VWZ4Z7F6117447
       Coding: 0040400
       VCID: 1D64D177D1B46A4F26F-8048
       Part No: 3C9 959 703 A
       Component: Tuer-SG         021 2507
       Coding: 0000144
       Component:    RDK              0391
       Coding: 0100101
                        Fault Status: 00110100
                        Reset counter: 90
                        Mileage: 219097 km
                        Date: 2016.01.19
                        Time: 11:43:11
    00667 - Ambient Temperature Signal
                        Fault Status: 00111000
                        Reset counter: 90
                        Mileage: 219137 km
                        Date: 2016.01.21
                        Time: 00:00:50
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
       Component: J605  HECKDECKEL    0405
       Revision: 00H20001
       Shop #: WSC 23250 384 715754
       VCID: 303A18C3B626F7279D9-8064
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0405
       Subsystem 2 - Serial number: 0600H20001001C0055
    00317 - Rear Lid Control Module (J605)
                        Reset counter: 90
                        Mileage: 218433 km
                        Date: 2015.06.28
                        Time: 00:01:23
                        Fault Frequency: 10
                        Reset counter: 65
                        Reset counter: 90
                        Mileage: 218433 km
                        Date: 2015.11.13
                        Time: 00:00:02
       Part No: 3C9 959 704 A
       Coding: 0000144
    End----------(Elapsed Time: 01:15, VBatt start/end: 14.4V/14.4V)-----------
  11. #28
    Mar 2015
    Australia
    To test a coding string for the ABS only takes 2 seconds, doesn't need an ignition cycle, and only needs terminal 15. You can blast through a lot of possibilities in a pretty short time...
    Coding -> faults, new code -> faults, rinse repeat.
  12. #29
    Jun 2017
    Kamold, forgive my ignorance (I'm a VCDS child!) ... but what is terminal 15?
    You're basically saying that I "change the code ... check for faults ... change the code ... check for faults"? I've been turning the ignition off each time! Plus, I've never seen an ABS code that's less than 0010000 ... can't I start there? One more question ... I've noticed some posted ABS codes have a different WSC ... should I only use ABS codes that match my existing WSC? ... or should I change that as well?
  13. #30
    Mar 2015
    Australia
    Sorry terminal 15 just means you have the ignition set to accessories so everything is powered.
    WSC (workshop code) should normally just be a non-zero value eg 12345.
    Sure start at 1000 (not 10000).
    eg set coding to 1000, check fault codes (control module incorrectly coded) go straight back to coding and put in 1001 then check fault codes again just flip back and forward between coding and faults for ABS only.
    This technique is not suitable for all scenarios, some modules require a power cycle, some need to wait a set time to power off or so a soft reset. But it works for ABS coding...
