Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 104
Thread: 2007 Passat with 2.5L 5-Cyl. Engine - ABS Coding?
  1. #41
    Jun 2017
    One question, when I was looking at the coding for the ECU today, when you go into "coding", there's a pop-up balloon with coding info in it ... and it says something to the effect of (should have taken a screen shot of it) ...
    0000x?x
    +1 = ABS Brakes
    +2 = Airbags
    +3 = Climate Control
    0000xx?
    4 = Manual Transmission
    5 = Automatic Transmission
    The above may be inaccurate, but you get the idea ... what does this mean? If it's accurate, then my ECU is coded wrong.
  2. #42
    Jun 2017
    And concerning the EPB ... what if you were to leave it fully connected to power, but disconnect it from the CANbus altogether ... then disable it (in ABS and the CANbus, and anywhere else?).
    It would simply be a 12V electrical device in the car that was fully functional, but not "seen" by the electrical system.
    Although obviously, Auto-Hold would not work.
  3. #43
    Mar 2015
    Australia
    Quote Originally Posted by Geoffzie View Post
    0000x?x
    +1 = ABS Brakes
    +2 = Airbags
    0000xx?
    Using that example your ECU coding would be 0000065 if you have ABS, airbags, climate control and an Auto transmission.
    The EPB is a fickle controller. Unless it is properly coded and connected it will not function, just throw faults.
    There may well be some way of getting it to work but it's well beyond my meager levels of expertise unfortunately...
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|DAB RNS|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0
  4. #44
    Jun 2017
    Interesting, here's a 2013 VW Passat 2.5L listed under "Reference Scans and Maps" ... it has no EPB! So maybe they simply don't pair up the 2.5 engine with the EPB for some reason ...
    http://forums.ross-tech.com/showthre...ssat-2-5L-CBUA
  5. #45
    Mar 2015
    Australia
    Yeah the NMS is not a B7 Passat....at least not in the RoW sense.
    Its some sort of mutant mashup of a Passat and a Jetta.
    So I don't know what the best path towards a working car for you is...is it easier to lose the EPB and install a manual park brake, is there some way to integrate an EPB into a NMS, is it all a bridge too far?
  6. #46
    Jun 2017
    Thanks for all your help, I guess I'll just have to do more research on the ABS.
    Yesterday, I eliminated the "Trunk Elec." fault. Apparently, it was looking for an electric trunk release (I've got a wagon) ... or something. I unchecked it in the CANbus coding (I think), and the fault went away. I really do have to remember to document exactly what changes I'm making.
    I've still got a Brake Light Sw. fault and a Secondary Air Injection Relay fault that I've got to figure out (wiring issues). The Jetta uses a 4-terminal brake light switch ... the Passat uses a 3-terminal. That's probably why the Cruise Control will turn on, but it won't "set". The SAI works fine, so I may have wired it in a way that the Passat system doesn't "see".
    Other than those two things, and the ABS issue (some or all of which may be causing the EPC light and EPB lights to come on) ... everything else seems to work fine. The EPB works fine, it gives me a fault simply because it can't "talk" with the ABS unit. If I can eliminate that line of communication, then maybe I can eliminate the Parking Brake fault ... and pave the way for a Jetta or newer Passat ABS pump.
    I'll let you know what the outcome is, or if I have any other questions.
    Here's my last scan from yesterday (I recoded the ABS controller with the original Passat coding, then disabled ABS) ...
    VIN: WVWBA71K78W315062   License Plate:
    Chassis Type: 1K (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 6D 72
    VIN: WVWBA71K78W315062   Mileage: 219260km-136241miles
    03-ABS Brakes -- Status: Not registered 0011
    6D-Trunk Elect. -- Status: Not registered 0001
    Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
       Component: 2,5l R5/4V      G   1567
       Revision: 1NH01---    Serial number: VWX7Z0H33N97Z2
       Coding: 0000003
       Shop #: WSC 01279 785 00200
       VCID: 72BED2CB78AA85372BD-8026
    050197 - Implausible Data Received from ABS Control Module
                   U0415 - 008 -
                        Fault Status: 01101000
                        Mileage: 219253 km
                        Date: 2017.06.10
                        Time: 13:55:42
                        Load: 0.0 %
                        Temperature: 87.0C
                        Temperature: 56.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 12.446 V
    005171 - Secondary Air Pump Relay (J299)
                   P1433 - 004 - Open Circuit - Intermittent
                        Mileage: 219253 km
                        RPM: 288 /min
                        Load: 68.2 %
                        Temperature: 60.0C
                        Temperature: 51.0C
                        Voltage: 11.176 V
    001393 - Brake Switch (F)
                   P0571 - 008 - Implausible Signal
                        Mileage: 219260 km
                        Date: 2017.06.10
                        Time: 14:32:29
                        RPM: 1195 /min
                        Load: 16.1 %
                        Speed: 34.0 km/h
                        Temperature: 81.0C
                        Temperature: 50.0C
                        Voltage: 14.097 V
    Readiness: 0010 1100
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
       Component: AQ 250 6F           1068
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 08114 444 84076
       VCID: 005A88034606A7A72D9-8054
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
       Component: ESP 440 C2     H015 0004
       Revision:  H015       Serial number: 0100005710
       Coding: 0048571
       Shop #: WSC 05311 000 00000
       VCID: 323E12CBB82AC537EBD-8066
                000 -  -
                        Reset counter: 51
                        Mileage: 219262 km
                        Date: 2017.06.10
                        Time: 16:36:39
                000 -  -
                        Reset counter: 51
                        Mileage: 219262 km
                        Date: 2017.06.10
                        Time: 16:36:39
       Part No: 1K0 820 047 EB
       Component: Climatic PQ35   090 0505
       VCID: 688AB0A34E767FE7859-803C
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Revision: 00H46000    Serial number: 00000005468122
       Coding: 008C0F0340041A00470A00000F00000000285D435C0000
       Shop #: WSC 05311 123 12345
       VCID: 372823DF5348201FDC3-8062
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 05311
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0N AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3P2W7PWA
       Coding: 0012366
       Shop #: WSC 05311 000 08193
       VCID: 2E0606BBAC12E1D78F5-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000032EPS
       Subsystem 3 - Serial number: 0001.01.000000600000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME0E716159E†63
       Subsystem 5 - Serial number: 16159E†6342MSME105B60746†63
       Subsystem 6 - Serial number: B60746†6351HTS64IKQTM627†63
       Subsystem 7 - Serial number: QTM627†6361HTS6TLLE15C3U†63
       Subsystem 8 - Serial number: E15C3U†63727TS63IK2T6C39†63
       Subsystem 9 - Serial number: 2T6C39†63827TS63IKEPNQ25
       Subsystem 10 - Serial number: EPNQ25
       Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
       Component: J0527               0015
       Revision: 00005000    Serial number: 3C9953507R
       Coding: 0102014
       VCID: 313C1DC7BD2CFE2F927-8064
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Component: KOMBIINSTRUMENT VD1 4240
       Revision: V0033000    Serial number: 00000000000000
       Coding: 0007205
       Shop #: WSC 01119 067 57207
       VCID: 333017CF4730CC3FE0B-8066
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0631304F6
       Coding: 3BFD0C04D22002
       VCID: 211CED87EDCC4EAF027-8074
                000 -  -
                        Reset counter: 52
                        Mileage: 219253 km
                        Date: 2017.06.10
                        Time: 14:12:28
       Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
       Component: Kompass         001 0002
       Revision: 00001000    Serial number: 1339817TQ3XP02
       Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
       Component:    IMMO         041 0364
       Revision: 00041000    Serial number: VWZCZ000000000
       Shop #: WSC 64713 001 1048576
       VCID: 2A0E0AAB90FA8DF753D-807E
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2801
       Coding: 0001205
       VCID: 36362EDB5442D917C75-8062
       Part No: 1K1 909 144 K
       Component: EPS_ZFLS Kl.5   D06 1701
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 RDK 041 0213
       Coding: 13900E88D1032E521804141FF00A0F0E083C00
       Part No: 1K0 959 702 K
       Coding: 0001204
       Revision:   013
       Coding: 0000013
    01316 - ABS Control Module
                        Fault Status: 00101101
                        Reset counter: 92
                        Mileage: 219256 km
                        Date: 2017.06.10
                        Time: 16:40:01
                        Voltage: 14.18 V
                        Count: 236
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
       Component: Radio DE2       012 0015
       Revision: 00012000    Serial number: VWZ4Z7F6117447
       Coding: 0040400
       VCID: 1D64D177D1B46A4F26F-8048
       Part No: 3C9 959 703 A
       Component: Tuer-SG         021 2507
       Coding: 0000144
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
       Component: J605  HECKDECKEL    0405
       Revision: 00H20001
       Shop #: WSC 23250 384 715754
       VCID: 303A18C3B626F7279D9-8064
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0405
       Subsystem 2 - Serial number: 0600H20001001C0055
       Part No: 3C9 959 704 A
       Coding: 0000144
    End----------(Elapsed Time: 01:11, VBatt start/end: 14.3V/14.3V)-----------
  7. #47
    Jun 2017
    I forgot to ask, is there any way to program the correct Passat VIN number into the ECU? Any dangers or side-effects of doing so?
  8. #48
    Jun 2017
    Today I fixed the Secondary Air Injection Pump Relay problem.
    Apparently, there are several electrical components on these cars that must be run through the J271 relay ... because the car continues to do functions and calculations ... even up to 15 minutes AFTER the car is turned off, and the J271 relay powers them to do that! The Secondary Air Injection Pump Relay is one of those components.
    I had it wired into a fuse that turns off with the ignition ... so hence, I got the following error code ...
    005173 - Secondary Air Pump Relay (J299)
    P1435 - 002 - Short to Ground - Intermittent
    Fault Frequency: 8
    Mileage: 219399 km
    RPM: 281 /min
    Load: 72.5 %
    Temperature: 88.0C
    Temperature: 44.0C
    Voltage: 11.303 V
    I rewired it into an unused fuse that feeds off of Relay J271 and ... the code is gone! Now I've just got the brake light switch and the ABS pump to deal with.
    By the end of this week I hope to take the car into the VW dealer, to see if I qualify for the 12-year rust through warranty.
  9. Likes Uwe liked this post
  10. #49
    Jun 2017
    After much research, yesterday I ordered a used 2008 VW Jetta ABS pump with control module (1K0 907 379 AC), mounting bracket, and plug end from eBay .... $85 including shipping.
    After looking at the ABS wiring diagrams for both the 2008 Jetta and my 2007 Passat ... it looks like it will work. There are many VCDS scans on the internet using both my ECU and this ABS unit ... so coding between the two shouldn't be a problem. The above ABS unit also has ESP, so I should be able to retain that. The only downside is ... it doesn't have provisions for the Electric Parking Brake ... so I'll loose the Auto-Hold feature.
    I'll have to rewire the Passat ABS plug since the Passat and Jetta ABS units use different plugs ... and of course, the wiring is slightly different. It won't be such a daunting task as the ECU was since there are only about 16 wires.
    We'll see if this works! If it does, then that's the final frontier for this project!
    I'll deal with the brake light switch fault after I get the ABS installed and working ... the fault may be at least partially because of the ABS problem ... we'll see.
  11. #50
    Jan 2015
    Bosnia and Herzegovina
    also expect error in cluster since in eeprom of cluster is data for epb but now there will be none
