AUDI A6 2.0 TDI 2014, clutch switch fault
Hi, Below find autoscan of Audi A6 2.0 TDI with a clutch switch fault. The Audi got a new clutch switch and clutch slave cylinder but car is still hard to start
. If I press button to switch ignition on and cross starter relay the car will start every time. The Audi has never been damaged and only 39145 miles on dash. Its out of warranty. Its shows live reading of clutch position in ABS, 9 percent with pedal not pushed and 86 percent pushed fully in. I compared it to another Audi A6 and it shows the same readings. I am now thinking it might be the clutch that is faulty. Many thanks for any help.
Tuesday,30,May,2017,13:15:16:58444
VCDS Version: 17.1.3.0
VIN: WAUZZZ4G2EN107051
Mileage: 62998km-39145mi Repair Order: AUDI A6 2.0 TDI
Chassis Type: 4G (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G2EN107051 Mileage: 62998km-39145miles
Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9978
Revision: 45H25---
Coding: 0A194012242401080000
Shop #: WSC 22235 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LA 003012
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: 74E3B1C5DF5F63E1FD-8020
4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
U1010 00 [032] - -
Mileage: 62888 km
Date: 2017.05.29
Time: 09:44:02
Coolant temperature: 14 °C
Intake air temperature: 14 °C
Voltage terminal 30: 10.420 V
Accelerator pedal: sensor voltage 1: 757.4 mV
Accelerator pedal: sensor voltage 2: 381.0 mV
Accelerator pedal: switch positions-Bit 0: 00000000
Starter control: Interlock- or P/N-signal-Bit 0: 01000001
Limitation: torque: 0.0 Nm
Control Module temperature: 8.6 °C
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 06A09F016005F9808B00
Shop #: WSC 02391 785 00200
VCID: 3A7F5FFDBDBBD591E7-806E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 EG HW: 4H0 907 064 EG
Component: BCM2 2.0 H36 0521
Coding: 03B83046000000000000
VCID: 72EFB7DDAD4B6DD1EF-8026
Serial number: 0213000390057003
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AJ HW: 4G0 820 043 AJ
Component: KLIMA 2 ZONEN H14 0094
Serial number: 13011400110843
Coding: 34210008A1
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: 67D9D6899E89987948-8032
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CA HW: 4H0 907 063 A
Component: BCM1 2.0 H12 0130
Revision: 12012002 Serial number: 00000001502074
Coding: 690000108034A7600405008000005F5F0F9D82082708020100 0004406000
VCID: 69DDD0B1809DAE095E-803C
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 131227 H36 0080
Serial number: 140103184019
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22120887
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 10 12 2013 00000279
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 3E980A07000000000001
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Revision: 11001001 Serial number: 61031401300091
Coding: 08C205
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 71EDB8D1A04D56C916-8024
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00GB40Q
Coding: 3032343631324E303235554A305234473053
VCID: 36674BCD89A331F103-8062
Serial number: 3575HRB405D2AIFS8107
Serial number: 3585HRB40651ISF270I8
Serial number: 3515JRB400K50QLUOQ1D
Serial number: 3525JRB400250QLQM14B
Serial number: 3554VRB400S50QLSM1DJ
Serial number: 3564VRB400Q50QLSH0HG
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140113000128
Coding: 000014
VCID: 306B7DD563C71FC159-8064
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0010
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
Component: MDieGb H43 0411
Revision: 27450259 Serial number: 658060114592032
Coding: 33A4080003412600010000
ASAM Dataset: EV_RBC7KMID 004048
ROD: EV_RBC7KMID.rod
VCID: 3F892EE9A699F0B9D0-806A
Part No SW: 4G5 907 468 C HW: 4G5 907 468 B
Revision: -------- Serial number: 00000001227248
Coding: 00CD074400
ROD: EV_GatewPKOUDS_VW51.rod
VCID: 35654CC194A53AE90A-8060
Serial number: 7802501903
Voltage stabilizer:
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA7207Z4TZ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
VCID: 336172D99AD124D924-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C16004001620002080002
VCID: 47993609F649B87968-8012
Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0004183943
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326F77DD65CB2DD12F-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0320359356
Coding: 011B062280B900408320080400010E47000000000000000000 0000000000
03279 - Clutch Pedal Switch for Engine Start (F194)
Fault Frequency: 30
Reset counter: 204
Mileage: 62891 km
Date: 2017.05.29
Time: 11:18:53
Component: TSG BF H03 0507
VCID: 46873B0DF143A17193-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000002012627
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_AU57.rod
VCID: 316D78D160CD16C956-8064
Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
Component: RMC Nav Plus H55 0801
Coding: 0101000001415B47082B060301010000010000
VCID: 275996895609587988-8072
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464L10D2642952
Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Serial number: 90349NAD00043
02244 - Button in Control Head is Stuck
Reset counter: 203
Mileage: 62945 km
Date: 2017.05.29
Time: 15:12:13
Bin. Bits: 00000000 00001000
Bin. Bits: 00000000 00000000
Component: TSG HL H03 0507
Coding: 010814004001620002080002
VCID: 499D3031E05D4E097E-801C
Component: TSG HR H03 0507
End-------------------------(Elapsed Time: 03:45)--------------------------
Can you try disconnecting the multi plug connector from the clutch pedal switch and bridge those 2 pins on the wiring connector and see if the vehicle starts, if it starts than you know your wiring is OK and your fault is some where in the master cylinder.........(Just make sure your gear is in N
Hi, I think in the clutch pedal switch it has 6 pins so I am not sure if I can do that. Many thanks
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
