Results 1 to 3 of 3
Thread: AUDI A6 2.0 TDI 2014, clutch switch fault
    Jun 2016
    Hi, Below find autoscan of Audi A6 2.0 TDI with a clutch switch fault. The Audi got a new clutch switch and clutch slave cylinder but car is still hard to start . If I press button to switch ignition on and cross starter relay the car will start every time. The Audi has never been damaged and only 39145 miles on dash. Its out of warranty. Its shows live reading of clutch position in ABS, 9 percent with pedal not pushed and 86 percent pushed fully in. I compared it to another Audi A6 and it shows the same readings. I am now thinking it might be the clutch that is faulty. Many thanks for any help.
    Tuesday,30,May,2017,13:15:16:58444
    VCDS Version: 17.1.3.0
    VIN: WAUZZZ4G2EN107051
    Mileage: 62998km-39145mi Repair Order: AUDI A6 2.0 TDI
    Chassis Type: 4G (4G5)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72
    VIN: WAUZZZ4G2EN107051 Mileage: 62998km-39145miles
    Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
    Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
    Component: R4 2.0l TDI H25 9978
    Revision: 45H25---
    Coding: 0A194012242401080000
    Shop #: WSC 22235 002 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018LA 003012
    ROD: EV_ECM20TDI01103L906018GT.rod
    VCID: 74E3B1C5DF5F63E1FD-8020
    4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
    U1010 00 [032] - -
    Mileage: 62888 km
    Date: 2017.05.29
    Time: 09:44:02
    Coolant temperature: 14 C
    Intake air temperature: 14 C
    Voltage terminal 30: 10.420 V
    Accelerator pedal: sensor voltage 1: 757.4 mV
    Accelerator pedal: sensor voltage 2: 381.0 mV
    Accelerator pedal: switch positions-Bit 0: 00000000
    Starter control: Interlock- or P/N-signal-Bit 0: 01000001
    Limitation: torque: 0.0 Nm
    Control Module temperature: 8.6 C
    Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
    Component: ESP PREMIUM H09 0450
    Coding: 06A09F016005F9808B00
    VCID: 3A7F5FFDBDBBD591E7-806E
    Part No SW: 4H0 907 064 EG HW: 4H0 907 064 EG
    Component: BCM2 2.0 H36 0521
    Coding: 03B83046000000000000
    VCID: 72EFB7DDAD4B6DD1EF-8026
    Serial number: 0213000390057003
    Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
    Part No SW: 4G0 820 043 AJ HW: 4G0 820 043 AJ
    Component: KLIMA 2 ZONEN H14 0094
    Serial number: 13011400110843
    Coding: 34210008A1
    ASAM Dataset: EV_AirCondiBasisUDS 004002
    ROD: EV_AirCondiBasisUDS_004.rod
    VCID: 67D9D6899E89987948-8032
    Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 CA HW: 4H0 907 063 A
    Component: BCM1 2.0 H12 0130
    Revision: 12012002 Serial number: 00000001502074
    Coding: 690000108034A7600405008000005F5F0F9D82082708020100 0004406000
    VCID: 69DDD0B1809DAE095E-803C
    Component: WWS57X 131227 H36 0080
    Serial number: 140103184019
    Coding: 0045F7
    Component: G397_RLFS H06 0002
    Serial number: 22120887
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
    Component: E1 - LDS H07 0044
    Serial number: 10 12 2013 00000279
    Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
    Component: Humidity_Sens H03 0002
    Serial number: 3E980A07000000000001
    Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
    Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
    Revision: 11001001 Serial number: 61031401300091
    Coding: 08C205
    VCID: 71EDB8D1A04D56C916-8024
    Address 15: Airbags (J234) Labels: 4H0-959-655.clb
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H43 0040
    Revision: -------- Serial number: 003JG00GB40Q
    Coding: 3032343631324E303235554A305234473053
    VCID: 36674BCD89A331F103-8062
    Serial number: 3575HRB405D2AIFS8107
    Serial number: 3585HRB40651ISF270I8
    Serial number: 3515JRB400K50QLUOQ1D
    Serial number: 3525JRB400250QLQM14B
    Serial number: 3554VRB400S50QLSM1DJ
    Serial number: 3564VRB400Q50QLSH0HG
    Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
    Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
    Component: Lenks.Modul H05 0201
    Revision: 00000000 Serial number: 20140113000128
    Coding: 000014
    VCID: 306B7DD563C71FC159-8064
    Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
    Component: E221 - MFL H09 0010
    Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
    Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
    Component: MDieGb H43 0411
    Revision: 27450259 Serial number: 658060114592032
    Coding: 33A4080003412600010000
    ASAM Dataset: EV_RBC7KMID 004048
    ROD: EV_RBC7KMID.rod
    VCID: 3F892EE9A699F0B9D0-806A
    Part No SW: 4G5 907 468 C HW: 4G5 907 468 B
    Revision: -------- Serial number: 00000001227248
    Coding: 00CD074400
    ROD: EV_GatewPKOUDS_VW51.rod
    VCID: 35654CC194A53AE90A-8060
    Serial number: 7802501903
    Voltage stabilizer:
    Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
    Component: SARA 3D H03 0056
    Revision: -------- Serial number: EJ1BPA7207Z4TZ
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2_VW51.rod
    VCID: 336172D99AD124D924-8066
    Component: TSG FA H03 0507
    Coding: 011C16004001620002080002
    VCID: 47993609F649B87968-8012
    Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
    Component: RCEPS H40 0010
    Revision: 00001000 Serial number: 0004183943
    Coding: 101000010000
    ASAM Dataset: EV_RCEPS 009008
    ROD: EV_RCEPS_009.rod
    VCID: 326F77DD65CB2DD12F-8066
    Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0320359356
    Coding: 011B062280B900408320080400010E47000000000000000000 0000000000
    Component: DWA-Sensor H01 0010
    03279 - Clutch Pedal Switch for Engine Start (F194)
    Fault Frequency: 30
    Reset counter: 204
    Mileage: 62891 km
    Date: 2017.05.29
    Time: 11:18:53
    Component: TSG BF H03 0507
    VCID: 46873B0DF143A17193-8012
    Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
    Component: EPB-4 H05 0017
    Revision: -------- Serial number: 00000002012627
    ASAM Dataset: EV_ParkiBrake 001029
    ROD: EV_ParkiBrake_AU57.rod
    VCID: 316D78D160CD16C956-8064
    Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
    Component: RMC Nav Plus H55 0801
    Coding: 0101000001415B47082B060301010000010000
    VCID: 275996895609587988-8072
    Subsystem 1 - Part No: 8X0 919 884 D
    Component: P13-50-11.06 0002
    Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
    Component: DU6 Basic H43 0084
    Serial number: 9464L10D2642952
    Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
    Component: E380 BDT C7 H11 0204
    Serial number: 90349NAD00043
    Reset counter: 203
    Mileage: 62945 km
    Date: 2017.05.29
    Time: 15:12:13
    Bin. Bits: 00000000 00001000
    Bin. Bits: 00000000 00000000
    Component: TSG HL H03 0507
    VCID: 499D3031E05D4E097E-801C
    Component: TSG HR H03 0507
    End-------------------------(Elapsed Time: 03:45)--------------------------
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Can you try disconnecting the multi plug connector from the clutch pedal switch and bridge those 2 pins on the wiring connector and see if the vehicle starts, if it starts than you know your wiring is OK and your fault is some where in the master cylinder.........(Just make sure your gear is in N )
    Jun 2016
    Hi, I think in the clutch pedal switch it has 6 pins so I am not sure if I can do that. Many thanks
