Results 1 to 1 of 1
Thread: RVC high retrofit to Superb 3T5
    New User
    Sep 2015
    I have a Superb L&K with a TV tuner. I have fitted a RVC with controller to be used with an existing Columbus / RNS 510. As I wanted to keep the TV - although it is a bit useless in a car - I had to fit a VW oem cabel that runs both the RVC and TV.
    The part numbers I used are: 7N0 907 441 controller, 5N0827566AB - tailgate handle camera Passat, 7N1971327b cable Columus to TV Tuner + RFK High, Fakra cable Z-Z.
    It is all fitted and connected. Coding partially worked. RVC 6c is coded into STG 19. STG 10 knows about the camera, but I do not get a picture although I get the screen and controlls for the camera with OPs and PDC. I get an error that the RVC is not available. When I go into 6c and try to "calibrate" it will not accept the calibration. I have folled the instruction to set channel 4 and 5 and then confirm in channel. I can set ch1 to 1 but when I read it afterwards it only "0".
    I tried what I picked up from other forums, e.g. to set STG19 to PQ46 rather than PQ35 vehicles. I did a reset of the columbus, but I and up with a non working camera and the TV is malfunctioning too. An ideas please.
    Not sure how I can link upload my autoscan...
    Some of the errors disappeared after I first drove the car. They were just caused by a disconnected battery.
    Wednesday,31,May,2017,20:17:34:20809
    VCDS Version: 17.1.3.0 (x64)
    VIN: TMBMF...   License Plate:
    Mileage: 54470km-33846mi   Repair Order:
    Chassis Type: 3T (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 37 42 44 46 47 4F 52
              55 56 57 61 62 6C 72 77
    VIN: TMBMF73T3E9034631   Mileage: 54470km-33846miles
    57-TV Tuner -- Status: Malfunction 1010
    6C-Back-up Cam. -- Status: Malfunction 1010
    Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 RS    HW: 03L 906 018 MH
       Component: R4 2,0L EDC   H28 5357
       Revision: 41H28---    Serial number:
       Coding: 001D0032042701080000
       Shop #: WSC 33361 790 00999
       ASAM Dataset: EV_ECM20TDI01103L906018RS 003003
       ROD: EV_ECM20TDI01103L906018RQ.rod
       VCID: 0C17C779A71A1E2185-8058
       Part No SW: 02E 300 016 D    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4013
       Revision: 05652104    Serial number: 00001311100185
       VCID: 1521A21D3CD0DFE92A-8040
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 863D6016092500FE611106E7901A0092A1095023
       Shop #: WSC 33361 790 00085
       VCID: 7EF39DB1E9A63CB19B-802A
                        Reset counter: 230
                        Mileage: 54467 km
                        Date: 2017.05.30
                        Time: 14:53:21
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 16390
                        Count: 40704
       Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
       Component: Climatronic   H19 0709
       Revision: 00001009
       Coding: 0010100003
       Shop #: WSC 00123 123 12345
       VCID: 7CF797B9F7BA2EA1B5-8028
       Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
       Component: BCM PQ35  H+  112 0771
       Revision: AF112771
       Coding: 42010AFBE849F1C0404A00C0310089EC48790046617DC76099C5EF840041
       VCID: 7DF19ABDE4A027A982-8028
       Subsystem 1 - Part No: 3T2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 13101  26  0700
       Coding: 00DFB7
       Component: RLS 221113 05  54  0403
       Coding: 072BED
       Subsystem 3 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
                        Fault Status: 00101110
                        Reset counter: 16
                        Mileage: 54467 km
                        Date: 2017.05.31
                        Time: 00:48:50
                        Voltage: 14.25 V
                            Term 50 On
    Address 10: Park/Steer Assist (J791)       Labels: 3T0-919-475-V2.clb
       Part No SW: 3T0 919 475 D    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0005
       Revision: --------    Serial number: 56261330201000
       Coding: 341305
       ASAM Dataset: EV_EPHVA2CAS46X0000 001003
       ROD: EV_EPHVA2CAS46X0000.rod
       VCID: 3E735DB1A126FCB1DB-806A
       Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
       Component: J234__LDM VW10 HI   2518
       Revision: 25019000    Serial number: 003LEPPNRSD7
       Coding: 0017485
       VCID: 428B29411DDE9851BF-8016
       Subsystem 1 - Serial number: 6332MTS658493123
       Subsystem 2 - Serial number: 6342MTS658373123
       Subsystem 3 - Serial number: 6351HTS6C0AIFCKR
       Subsystem 4 - Serial number: 6361HTS63TDJFCKR
       Subsystem 5 - Serial number: 63727TS6IRG7CCKR
       Part No SW: 5K0 953 521 DD    HW: 5K0 953 569 AE
       Revision: FF010042    Serial number: 20131120201487
       Coding: 1882140000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 71E9B68DA0F853C916-8024
       Subsystem 1 - Part No SW: 5E0 919 719 F    HW: 5E0 919 719 F
       Component: E221__MFL-PR6  H04 0120
       Coding: 820000
       Part No SW: 3T2 920 941 M    HW: 3T2 920 941 M
       Component: KOMBI         H07 0811
       Coding: 111C01
       Shop #: WSC 12055 002 1048576
       VCID: 3F8D20B5A62CF5B9D0-806A
       Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1674
       Revision:   H55       Serial number: 250913F1003440
       Coding: 469303
       VCID: 75E1829DDC907FE9CA-8020
    00469 - Infotainment Databus in Single Wire Operation
                        Fault Status: 00101100
                        Reset counter: 14
                        Mileage: 54467 km
                        Date: 2017.05.30
                        Time: 21:18:14
    00467 - TV Tuner (R78)
                        Reset counter: 14
                        Mileage: 54467 km
                        Date: 2017.05.30
                        Time: 21:18:14
                        Fault Status: 00110100
                        Reset counter: 14
                        Mileage: 54467 km
                        Date: 2017.05.30
                        Time: 15:14:38
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 4581325D0CF0AF699A-8010
       Component: IMMO          H07 0811
       Coding: 000002
       VCID: 6ADBA1E18D2EA01157-803E
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
       Component: Sitzmemory    H05 3101
       Revision: 00H05000
       Coding: 00003B
       Shop #: WSC 12336 024 394758
       VCID: 377D4895861CCDF918-8062
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3T0 035 686 H    HW: 3T0 035 686 H
       Component: RNS-MID       H21 6276
       Revision: AB001001    Serial number: SKZ6Z7N9325044
       Coding: 04040002020100801000
       VCID: 3B7554A5BA34E999FC-806E
       Subsystem 1 - Part No: 3T0 051 859 AP
       Component: EU West V14  8477
    Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H10 0415
       Coding: 011D0220DE01001000
       VCID: 52AB19010DBE08D10F-8006
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 194    3501
       Revision: 00H22000
       VCID: 39794EAD7008DB89EE-806C
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H08 6815
       Revision: --------    Serial number: EAA098A0099997
       ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
       ROD: EV_AudioVerst10KanalBNO1.rod
       VCID: 264395D159B64471B3-8072
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1674
       Coding: 050B0100
       VCID: 6FEDB0F5BECC453900-803A
       Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
    Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H10 0415
       VCID: 51A9160D08B873C936-8004
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H04 0111
       Coding: 01CE00003F000000
       VCID: 377D48958E1CCDF918-8062
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0003
       Coding: 8E0000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0003
       Coding: 8E0000
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
    Address 57: TV Tuner        Labels: 7L6-919-148.clb
       Part No SW: 7L6 919 148 A    HW: 7L6 919 148
       Component: R0078 TVhybridDVB   0150
       Revision: R0H21000    Serial number: 93900501272701
       Coding: 0000003
       VCID: 3A7B51A1750ED091E7-806E
    00863 - Antenna 1 for TV (R55)
                        Fault Status: 00101010
                        Reset counter: 14
    00864 - Antenna 2 for TV (R56)
                        Reset counter: 14
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
       Component: Batt.regelung H55 1674
       Coding: 030F185A
       VCID: 71E9B68DA8F853C916-8024
       Component: J367-BDM  H07 0180
       Serial number: 40317811471491428949
       Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
       Component: TSG HL        H07 0415
       Coding: 010C00200001001000
       VCID: 50AF130903B27AC139-8004
       Part No SW: 7N0 907 441     HW: 7N0 907 441
       Component: J772__Rearview      0020
       Revision: 00H11000    Serial number: 525 PA8J264823
       Coding: 0020011
       Shop #: WSC 00020 790 00000
       VCID: 6ED3ADF179C64C310B-803A
    03006 - Back-up Camera System not calibrated
                        Reset counter: 230
    02283 - Video Connection to Output [End Unit]
                        Fault Status: 00101011
                        Reset counter: 16
                        Mileage: 54467 km
                        Date: 2017.05.31
                        Time: 00:46:59
                            Reverse ON
                        Count: 4
       Component: TSG HR        H07 0415
    Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
       Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Component: Telefon       022 0982
       Revision: --------    Serial number: 35502105078894
       Coding: 020000000100010000000101
       ASAM Dataset: EV_UHVPremi 002709
       ROD: EV_UHVPremi_002.rod
       VCID: 24478FD92F8AB661AD-8070
    End-------------------------(Elapsed Time: 04:57)--------------------------
    Address 03: DTCs cleared
    Address 09: DTCs cleared
    Address 19: DTCs cleared
    Address 57: DTCs cleared
    Address 6C,7N0 907 441 ,channel 1,adapted from,0,to,1,
    Address 6C,7N0 907 441 ,channel 4,adapted from,16310,to,16310,
    Address 6C,7N0 907 441 ,channel 5,adapted from,580,to,580,
    Adaptation Channel 001:
    Stored value
       Revision: 00H46001
       Revision: 00001009
       Coding: 0010100003
       Revision: AF112771
       Coding: 00DFB7
       Coding: 072BED
       Coding: 341305
       Coding: 0017485
       Coding: 1882140000
       Coding: 820000
       Coding: 111C01
       Coding: 469303
       Coding: 0000005
       Coding: 000002
       Revision: 00H05000
       Coding: 00003B
       Revision: 00H22000
       Coding: 050B0100
       Coding: 8E0000
       Coding: 8E0000
       Coding: 0000003
       Coding: 030F185A
       Coding: 0020011
                        Reset counter: 230
                        Reset counter: 231
                        Mileage: 54467 km
                        Date: 2017.05.31
                        Time: 00:46:59
                            Reverse ON
                        Count: 4
    End-------------------------(Elapsed Time: 04:19)--------------------------
    Wednesday,31,May,2017,20:40:04:20809
    VIN: TMBMF73T3E9034631   License Plate:
       Revision: 00H46001
       Revision: 00001009
       Coding: 0010100003
       Revision: AF112771
       Coding: 00DFB7
       Coding: 072BED
       Coding: 341305
       Coding: 0017485
       Coding: 1882140000
       Coding: 820000
       Coding: 111C01
       Coding: 469303
       Coding: 0000005
       Coding: 000002
       Revision: 00H05000
       Coding: 00003B
       Revision: 00H22000
       Coding: 050B0100
       Coding: 8E0000
       Coding: 8E0000
       Coding: 0000003
       Coding: 030F185A
       Coding: 0020011
                        Reset counter: 230
                        Reset counter: 231
                        Mileage: 54467 km
                        Date: 2017.05.31
                        Time: 00:46:59
                            Reverse ON
                        Count: 4
    End-------------------------(Elapsed Time: 04:20)--------------------------
