I recently purchased VCDS and joined the ranks. I'll be using it on my 2007 and 2009 Jettas, and potentially a third, which brings me to my question -
I have a scan (taken yesterday May 30, 118141mi) below of a 2010 Jetta I might buy. Only issue known is the right mirror turn signal out, but the scan found several failures.
Can you interpret or point me to where I can learn ? Anything I need to worry about?
Thanks for your time,
Steve
Steve
Tuesday,30,May,2017,18:37:51:29469
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: 3VWRZ7AJ1AM153396 License Plate:
Mileage: 190130km-118141mi Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWRZ7AJ1AM153396 Mileage: 190130km-118141miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AG HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H04--- Serial number:
Coding: 0000075
Shop #: WSC 02120 444 999999
VCID: 73B0D7D197B2194F20B-8026
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 7
Mileage: 190098 km
Date: 2011.10.17
Time: 23:22:09
RPM: 1283 /min
Load: 16.9 %
Speed: 60.0 km/h
Temperature: 86.0°C
Temperature: 43.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
006480 - Radiator Fan (V7)
P1950 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 190086 km
Date: 2011.10.07
Time: 23:27:10
RPM: 712 /min
Temperature: 87.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.700 V
Readiness: 0000 0100
Part No SW: 09G 927 750 HG HW: 09G 927 750 HG
Component: AQ 250 6F 1631
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 7DA4F1E9A1F65F3F46F-8028
Fault Status: 00101101
Fault Frequency: 11
Reset counter: 165
18253 - Please check DTC Memory of Steering Electronics (J527)
P1845 - 000 - - Intermittent
Fault Frequency: 11
Reset counter: 165
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C49270000880D02ED921F0041300000
VCID: 78AAE0FD82D47A17159-802C
Reset counter: 199
Mileage: 189877 km
Date: 2011.10.05
Time: 04:10:10
Count: 32768
Count: 4608
Count: 8193
Count: 51286
Count: 768
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00149
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B4E9C99546077F0EF-8020
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 18
Reset counter: 203
Mileage: 189862 km
Date: 2017.05.14
Time: 06:17:21
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0129
Revision: BI111001
Coding: 2D200B1E902F3EE480000085400000040100008641008D605C8020000000
VCID: 372823C1CF4AB56FDC3-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 25061 21 0512
Coding: 009795
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 178
Mileage: 188537 km
Date: 2011.09.11
Time: 11:41:41
Voltage: 14.45 V
Reset counter: 194
Mileage: 189952 km
Date: 2011.10.05
Time: 19:53:43
Term 15 Off
Voltage: 12.40 V
01598 - Drive Battery Voltage
Fault Status: 00101011
Reset counter: 177
Mileage: 188323 km
Date: 2011.09.11
Time: 09:16:44
Voltage: 13.60 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 194
Mileage: 177691 km
Date: 2011.05.25
Time: 16:53:14
Voltage: 14.30 V
Reset counter: 105
Mileage: 185718 km
Date: 2011.08.26
Time: 01:46:39
Voltage: 14.20 V
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM035K0C
Coding: 0012340
VCID: 6E86C6A5FC9034A7CF5-803A
Subsystem 2 - Serial number: 6332MSME53210A11.
Subsystem 3 - Serial number: 6342MSME533171541
Subsystem 4 - Serial number: 6351HSME214B526FD
Subsystem 5 - Serial number: 6361HSME214B6E31A
Subsystem 6 - Serial number: 63727SME21324579-
Subsystem 7 - Serial number: 63827SME21341432O
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001031
VCID: 025E8215D80820C73BD-8056
Part No SW: 5M0 920 960 E HW: 5M0 920 960 E
Component: KOMBI H14 0112
Revision: X0014004 Serial number:
Coding: 270700
ASAM Dataset: EV_KombiUDSMM9RM10 A04102
ROD: EV_KombiUDSMM9RM10_VW36.rod
VCID: 313C1DD921AE6B5F927-8064
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 150610F1000162
Coding: ED807F07000602001002
VCID: 698CB5B9C57ED39F9A7-803C
Part No SW: 5K0 953 234 HW: 5M0 920 960 E
Component: IMMO H14 0112
ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
ROD: EV_ImmoUDSMM9RM10_VW21.rod
VCID: 6A8ECAB5CCF8D88793D-803E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001053923
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2708F3811F6A25EF4C3-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005009231
Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 200
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 313C1DD92D2E6B5F927-8064
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001029516
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 280AF0BD12742A97459-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005019048
Coding: 000490
Reset counter: 203
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 151
Mileage: 189856 km
Date: 2017.05.13
Time: 04:08:28
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 020 0023
Revision: 00020000 Serial number: VWZ4Z7K6499948
Coding: 0042402
VCID: 201AE89D76C4D2D70D9-8074
00857 - CD Changer Unit (R41)
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07757161
Coding: 401100
VCID: 2A0E0AB50CF8188753D-807E
Reset counter: 177
Mileage: 189415 km
Date: 2011.09.12
Time: 16:30:41
End----------(Elapsed Time: 01:08, VBatt start/end: 13.9V/13.9V)-----------
