Results 1 to 10 of 10
Thread: A4 B8 Cluster
    Dec 2016
    A4 B8 Cluster
    Hi
    Can VCDS adapt a virgin cluster to 2008 A4 2.0 TDI B8?
    I doubt it. Even if the car has Immo somewhere else (like Kessy), I would expect you'd run into Component Protection.
  3. Likes Ashraf6119 liked this post
    Dec 2016
    Ok thanks anyway
    Magdeburg, Germany
    You can install a new/used cluster in a B8 and adapt mileage etc. so that basic functions will work. However - as indicated by Uwe - to achieve full functionality, component protection will need to be removed via GeKo (by an Audi dealer or independent shop with adequate access). The cluster is not part of the immobilizer, in the B8 platform.
  6. Likes Ashraf6119 liked this post
    Dec 2016
    Ok, thanks. Any idea how to install even with basic functions?? Is it an adaption channel?
    Magdeburg, Germany
    Plug and play, that should do. Some function will be blocked due to component protection.
    Dec 2016
    Tired that. But says safe. And now no dials working. As far as I know this is cars original cluster but was virginized for some reason so needs married to car again....
  10. #8
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by NWT View Post
    Component protection removed ??
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 18.1.0
    (HEX-V2)
  11. #9
    Dec 2016
    Must not be. As it says component protection in faults along with incorrect adaption...
  12. #10
    Verified VCDS User Ashraf6119's Avatar
    Dec 2015
    Full Auto Scan would be more helpful to help you out mate........
